Nacra F20 Carbon takes line honours ....Nacra take 3 out of the first 4 places on handicap....
http://www.roundtexe....asp?navid=live (check under corrected results....)
Nacra F20 Carbon
#901
Posted 11 June 2012 - 08:56 AM
#902
Posted 11 June 2012 - 04:15 PM
They should have doublechecked before telling Pols though.
The N20c is impressive out of the box, no need to have raking boards etc.
Good decision from the organizers to let the race be held on sunday, which turned out to be in perfect conditions as well. (10-14kts and sun!).
#903
Posted 12 June 2012 - 03:47 PM
What is the latest advice on mast rake, diamond tension, rig tension, mast rotation and board height in different levels of breeze etc.
#904
Posted 12 June 2012 - 03:58 PM
#905
Posted 13 June 2012 - 08:55 AM
Thanks Krash, are you finding this is working out well for you? I think the board situation is never ending and everyone will have their preferences I guess depending on where you sail etc.Tuning guide is on www.nacrasailing.com
Here's a link - http://www.nacrasail...nuals&Itemid=91
-M
#906
Posted 13 June 2012 - 01:05 PM
-Mike
#907
Posted 15 June 2012 - 08:48 PM
-M
Rumour has it your new F20 is almost here Readie, make sure you get some pictures up once you've got it together.
#908
Posted 15 June 2012 - 09:55 PM
nacra20.jpg 545.01K
74 downloadsF20 is a real FORD "First On Race Day"
http://lss.a.se/body..._tot_2012v2.pdf
Ahead of M32 most of the race
#909
Posted 16 June 2012 - 09:28 AM
We now have a fleet of 4 F20Cs, plus a Ventilo 20 Carbon, based in Sdot Yam, that will be vying for line honors in our upcoming distance race to Achziv next month.
F20Cs have basically replaced the N20 (which replaced the N6.0) for the larger active crews here.
Oracle Carbon IL.jpg 809.97K
132 downloads
#910
Posted 16 June 2012 - 09:47 AM
4's a nice number for racing
is that J in the surf city T?
#911
Posted 16 June 2012 - 09:56 AM
#912
Posted 16 June 2012 - 03:36 PM
Geff, you are more than welcome to come sail with us year round, as are any cat sailors visiting Israel
Posted 17 June 2012 - 12:26 AM
That's Ronny, one of the proud new owners. I believe J is busy in Texas...
he didn't look big or hairy enough
#914
Posted 18 June 2012 - 01:19 AM
I sailed out today in light air. The lake was flat. We were doing less than 6 knots for about half an hour when the wind picked up all of a sudden.
I assumed hiking position about 1 foot aft of the shroud. The crew went on the trapeze wire behind me (that's what we always do now). Both foils were all the way down.
We crossed the lake twice sailing to windward at 14-16.4 knots.
We had a great Father's Day!
PS: I did a 45 degrees wheely in a bad gust and the wind picked up the underside of the trampoline. Felt like we were airborne for a while until the boat came down and crashed dead in the water.
#915
Posted 18 June 2012 - 10:22 AM
-M
Yeah should be here in the next week or two...!! Can't wait to get her out on the water!!
#916
Posted 15 July 2012 - 11:29 PM
When sailing her according to the NACRA tuning guide i have experienced several times spin-outs which resultated in a sudden drift towards leeward.
With the following setup i have made good experience to sail her fast which i would like to share here.
Reaching: When sailing in windforce >5 i found it's more efficient to have leeward board app. 1ft up and windward board fully up. Mastrotation nearly fully open so mast shows good flex/bend characteristics and is self-responding on gusts. Keep jib cleated to the middle position and traveller full released. Mainsail at all times full sheeted but traveller 0.5ft out. Work with traveller instead of mainsheet to depower. Position of crew around shroud/trunk to weight-balance her especially when she becomes airborne. In general she sails (with this setup) leeward higher out of the water which reduces spray and drag.
let me know your thoughts
#917
Posted 29 August 2012 - 01:24 PM
Hi All,
Just wondering what plans people have in Europe for some F20C class racing in 2013? It would be good to get as many boats together as possible at something like Texel Week. 3 days of windward/leewards followed by the long distance race on the Saturday!
Would be good to get the ball rolling now to try and get as many boats there as possible and enjoy some good class racing.
James
#918
Posted 11 September 2012 - 05:40 PM
have fun sailing her fast
Ludger
#919
Posted 14 September 2012 - 03:04 PM
LudgerJames, i like the idea and would like to add that we already had the three german boats all together at lake como in northern italy together with a bunch of tornados for early season training. We will have this in 2013 as well. I would greatly appreciate if someone would like to join us. To get more boats together we are flexible on schedule and location. Any proposal is appreciated.
Ludger
Sounds amazing, these boats so deserve some good class racing now there is enough of us. There is no reason why we cannot get 15/20 boats at Texel. I hope Nacra will put some marketing into this and help us out with organisation, it is the 'flagship' model after all. We could do three events to constitute a mini circuit e.g. Eurocat - Carnac, France / Texel Week - Texel, Netherlands / one other location in Northern Europe like Erquy or St Lunaire.
What are your thoughts on this? Anyone else?
James
#920
Posted 18 September 2012 - 06:46 PM
Once can be bad luck. Is twice a trend? Anybody else has had this problem?
#921
Posted 18 September 2012 - 06:47 PM
#922
Posted 18 September 2012 - 08:48 PM
I had a front beam bolt strip shortly after. I drilled and tapped it out to 7/16", and used a stud and nut insted of a bolt.
I think it is fair to say that it is a design weakness...
#923
Posted 19 September 2012 - 02:23 PM
http://www.jergensin...ts/group_no=304
It's smarter than a helicoil insert because the part can be replaced if it strips again.
#924
Posted 19 September 2012 - 08:28 PM
We also had problems with severe cracks on the front beam, near the hull. One boat almost sheared through the beam before discovering it while inserting the beach wheels. We subsequently checked ours and found smaller cracks. Nacra sent us new beams with reinforced inserts near the dolphin striker connections.
Add to that having rudder grudge owns shear off while sailing, and rudder screws bending (so steering becomes harder as the rudder locks higher)...
Bottom line - huge stresses on these boats, and where they used existing 18/20 hardware as is, expect problems... I strongly recommend checking the beams, rudder gudgeons, rudder screws, main block connections etc. periodically
Absolutely fantastic boat to sail, which we do twice a week almost every week, but still quite a few teething problems that are causing us quite a bit of down time
#925
Posted 19 September 2012 - 11:35 PM
We do indeed have 2 boats with this problem on the front beam. We solved ours (hopefully) by inserting hellicoils. Another boat was not as lucky, and after consulting Nacra received larger inserts from Nacra, and are currently fitting them out. We took advantage of the situation to seat our beams with epoxy, and are quite happy with the results. Now we only have to hope that the hellicoils hold...
Rudder bolts and springs were always an issue on the N-20s also. May be a spot that's worth a Titanium bolt. The bolts used to bend almost immediately upon replacement.
#926
Posted 27 September 2012 - 01:00 PM
As today Nacra F20 Carbon is fairly priced compare to F18 and A Cat, I guess it should be an alternative to be considered for anybody who wish to sail a modern boat, but one question remains:
How much is this boat physically demanding, compared to an F18 and a Tornado ?
I know already that a Tornado is very demanding, at least too much for me.
I have little illusion, the F20C is as wide as a T and has similar sail area, so should be little difference with a T, but I d like to have the feedback of experts.
Thanks in advance
Cheers All
W
#927
Posted 27 September 2012 - 01:31 PM
I'm curious where this "fairly priced" F20C is located, or what dealer can offer such pricing? I don't really think the boat is excessively priced for what it is, but I don't think it is competitive with F18 pricing, everything I've seen says F20C is 50% more than an F18.
-Sam
#928
Posted 27 September 2012 - 03:07 PM
at least afew months ago, I did not check recently
#929
Posted 27 September 2012 - 04:39 PM
#930
Posted 27 September 2012 - 07:07 PM
But OH, what a great ride !! The thing that hurts most after a long day out are the facial muscles from the huge grin as you race down the back of big waves with the windward hull 3 stories high and drive the leeward bow straight through the next wave without faltering... Not to mention the looks from the F18 driver as you pass him and outpoint him... Our 4 boat F20C fleet usually starts our informal distance sails after all the other boats are long gone, just for the pleasure of blasting through the entire fleet...
And on a more serious note, in addition to the greater physical demands, the F20C speeds require higher concentration, relaxing in medium to high winds can be hazardous to your health.
#931
Posted 27 September 2012 - 07:23 PM
#932
Posted 27 September 2012 - 08:15 PM
So it is probably as physical as for a T.
For the price it was at Saint Malo but a Belgium dealer I think, probably the basic one without racing package, or maybe a special discount?
Anyway it is clear that is a bit too much for me; Too bad
Cheers
W
#933
Posted 28 September 2012 - 01:10 AM
The jenniker has 3 extra square meters. It makes a big difference.The folks who crew with me all wear gloves and complain after long downwind legs that their arms are dead.
#934
Posted 28 September 2012 - 02:17 AM
#935
Posted 28 September 2012 - 09:57 AM
The addition of a ratchet block with a becket and single block at the spin clew would half the load on high wind days. I have done this on my F18 to help out my sister, we only rig it this way if its blowing.
#936
Posted 28 September 2012 - 11:34 AM
Just Sail, as far as I understand, you set up a 2:1 puley system ?
If yes: the spinnaker line has to be much longer ? is it easy to manage, does it not create "spagettis" on the tramp, always in your feet when you tack or gybe ?
I know that if you put 2 ratchet blocks in "serie", you divide the holding force required to maintain the spinnaker leech, but to sheet in you need the same force.
So combining both could be a solution for long distance race to save crew arms ?
Regards
W
#937
Posted 28 September 2012 - 01:08 PM
#938
Posted 28 September 2012 - 07:19 PM
#939
Posted 01 October 2012 - 02:35 AM
#940
Posted 01 October 2012 - 10:31 AM
Thjat is it, the link you post show exactly, what I had in mind, a 2:1 ratio + 2 autoratchets in serie.
Sam99us: Of course, if you have to release in hurry, it might be tricky, but may be you could try a 49er spinnaker holding approach:
According to some 49er crew, if you are in difficulties with the kite, the best solution to avoid capsize is not to release the spinnaker, instead the crew should pull the spinnaker line strongly to trigger stall.
After a thorough brain storming in my little brain, I realized that this solution could make sense:
Usually the troubles with the kite up, start with a viscious wave which slows down the boat, the apparent wind turns backward, so if the crew releases the kite line accordingly, it will maintain the air flow "laminar" around the sail, and the sail power will remain constant, instead, if you pull the line when the apparent wind is turning backward, you will trigger the kite to stall and decrease significantly the pressure on the leeward bow.
I should say I never try it myself, as I am more A-Cat oriented. But I know F18 crew who manage the kite like that, and they do not capsize very often in the breeze.
Cheers
W
#941
Posted 01 October 2012 - 11:20 AM
#942
Posted 01 October 2012 - 09:00 PM
Thanks, Just Sail,
Cheers
W
With an F20C you should be going hot and very fast, even in a strong breeze. At that point, your spi will be in very tight and you have no chance of yanking it in tighter quickly (remember, we started this discussion with how hard it was to sheet). If you drive her correctly in this state, you will be pretty high and drive straight through even big waves on one hull barely slowing. Pretty scary, but works.
If you run too deep, with the spi loose accordingly and both hulls in the water, you WILL slam into the big waves , stop and bury the bows, in which case maybe you can tighten the sheet, but I doubt it will work in time. The couple of times we were too scared to run hot in big seas we preferred to take down the spi, sit way way back, run deep and pray...
#943
Posted 02 October 2012 - 07:09 PM
http://www.youtube.c...eature=youtu.be
#944
Posted 03 October 2012 - 12:24 PM
Can anyone help me to get the required paperwork to register my boat from Nacra. Mike Krantz sold me his N 20 but he will not get me the final paperwork so that I can register it in my state. Does anyone know who I can contact to complain. Its been 4 months and he just has excuse after excuse will never do business with him again.
mydaddycat
#945
Posted 03 October 2012 - 03:01 PM
You called me on 9/6, and I told you that I was out of the office and travelling until 9/23. You emailed me on 9/25 and I responded to you on 9/26 that the MSO had been requested from the factory.
I received and mailed your MSO on 10/1.
You want to complain, man up and call me, instead of making an ass of yourself on the internet.
-Mike
#946
Posted 03 October 2012 - 04:42 PM
First it was 3 months, now it's 4 months??? You bought the boat on 8/1 - that's only 2 months in my calendar.
-Mike
Mydaddycat seems to have an alternative take on reality many times from what little I have read or his exploits and opinions.
I was wondering, has he been given the traditional SA welcome?
B
#947
Posted 04 October 2012 - 12:54 AM
-Mike
B
Not yet, but I'm thinking leave out the tits part and leave in the "FUCK OFF" with a permanently added.
Mike Krantz does more for cat sailing promotion in the U.S. than anyone.
#948
Posted 10 October 2012 - 02:07 AM
#949
Posted 10 October 2012 - 10:14 AM
mydaddycat's rather unique way of communicating....
#950
Posted 19 December 2012 - 04:16 PM
Are there any plans for some Nacra F20 Carbon class racing in Europe next season?
Would be good to organise at least one 'one design' regatta, maybe Texel sailing week, 3 days of windward leeward and then the long distance on the Saturday? Amazing fun if we could get 10 - 15 boats.
Thoughts?
James
