Top-Down Furler - for asym's
#1
Posted 25 May 2010 - 12:16 PM
There is a small section on something, relatively new, called a "top-down" furler, which they say is being used by race boats for asymmetrical spinnakers, and which they say will be making it's way to cruising boats.
I guess I though that the existing furlers for free-flying sails were being used for asym's...,
or maybe they were actually top-down furlers, and i didn't realize it...
or maybe the sails were actually gennakers, not real asym's, and i didn't realize it...
when does a gennaker become an asym - is there some AWA, below which the sail is a gennaker?
#2
Posted 25 May 2010 - 03:08 PM
#3
Posted 25 May 2010 - 05:35 PM
Details here: http://news.futurefi...own_furling.pdf
[url="]
This differs from Balmar Rollgen, where the kite rolls from the top and bottom at the same time.
#4
Posted 25 May 2010 - 06:43 PM
so, why is it better to roll an asym from the top, but it's better to furl a gennaker from the bottom?
#5
Posted 25 May 2010 - 07:49 PM
#6
Posted 25 May 2010 - 08:28 PM
#7
Posted 25 May 2010 - 08:33 PM
#8
Posted 25 May 2010 - 09:45 PM
#9
Posted 25 May 2010 - 10:34 PM
#10
Posted 26 May 2010 - 02:26 AM
Since the head and tack are fixed with the furling line, how do you adjust shape?
If I heard correctly the tension line, while rigid enough to be furled, is still succeptable to halyard tension. This is why halyard tension is so important when you're flying Code Zero's because without it the shape of the sail is going to be all wrong.
#11
Posted 03 June 2010 - 12:10 PM
Guys
When you are talking top down furling, you need to forget what you know about traditional Code 0's and even A3 type sails with an integrated Luff cable.
Top down furling does exactly what it says. It's a torsioal cable, independent of the sail. When you start your furl, whether with a continuous furling line or a hydraulic furling unit, the cable transfers the torque all the way to the head swivel, where the sail is lashed and because the tack is not connected to this set up, it starts furling the sail from the top down. Some manufactures such as KZ marine and Karver actually build dedicated furling units for this. Its similar to their code sail furlers except that the tack can freely rotate.
This system is finding a foot hold in the superyacht market as it effectively makes the 'bucket's', which can get jammed and take a cast of thousands to opperate it, redundant.
There are a couple of Vids online:
http://riggingnews.b...4/its-wrap.html
http://riggingnews.b...ts-wrap-ii.html
#12
Posted 04 June 2010 - 06:44 AM
http://www.futurefib.../newsletter/13/
Think it is a few pages in..... Sorry should be more specific.
Wish I could add more but just don´t understand it!
#13
Posted 05 June 2012 - 01:49 PM
http://www.facebook....47892832&type=1
#15
Posted 05 June 2012 - 09:34 PM
"The KSF Furler includes all the advantages of the KF line, but incorporates an independent swivel on the top of the drum that enables the sail to furl from the top to the bottom. It is now possible to furl the Asym from the cockpit for more safety and convenience when cruising. This is also a weapon for racers that can hold their asym closer to the mark and in worst weather conditions.
The anti torsion line is independent from the luff. The tack of the asymmetrical is attached to an independent swivel on the top of the furling drum while the head of the spinnaker is lashed to a lashing thimble. When furling, the spinnaker starts to furl from the head and continues down to bottom, hence the term “Top Down Furler”. The system is already approved by Maxi Yachts and do not need to have the spinnaker retrofitted."
Check here for load capacity and sailboat size selection: Karver KSF Asymmetrical Spinnaker Furler
Note about Gennaker vs.Asymmetrical Spinnaker:
"when does a gennaker become an asym - is there some AWA, below which the sail is a gennaker? "
We consider a "gennaker" to be sort of a generic name for asymmetrical offwind sails. IN a general way, we refer to them by AWA:
50 - 80: Code Zero (laminate sail with integral luff rope)
80 - 110: Gennaker or Close Reaching Asymmetrical Spinnaker (nylon sail)
110 - 140: Asymmetrical Spinnaker (nylon sail)
Best,
#16
Posted 28 June 2012 - 06:28 AM
The video from the Swan 112 Top Down furling which was mentioned in a post above.
#17
Posted 28 June 2012 - 07:20 AM
#18
Posted 03 July 2012 - 12:12 AM
Abu Dab was/is using this system for their fractional runners.Anybody can douse in those conditions - can it handle heavy air?
My thought was to make the luff of the heavy air kites about 12" short so that you could unfurl with the 2:1 tackline tight, then ease the tack up for sailing, then tension again for furling.
A short luff can also make your heavier air kites reach a little better by allowing you to tension the luff which frees the leach a bit.
#19
Posted 03 July 2012 - 02:32 PM
Have used other systems but none are as good as Karver IMHO.
If I remember correctly the whole top down concept was originally developed by Karver and Allspars
#20
Posted 11 July 2012 - 02:22 PM
check my buddy John from colligo marine
tell him I send you ... lol
Thor
#21
Posted 11 July 2012 - 10:20 PM
Especially in a blow it tends to get very tight at the top and the material is taking a lot of the tension (in a direction not intended by the designer)?
#22
Posted 13 July 2012 - 06:59 PM
Here is what we have learned about top down style furling for asymmetrics:
1. A good torque line is essential. A twisty torque line will wind the sail up while twisted, then when the torque of the drive line is released the line will twist the sail up, often into a mess that demands lowering the hole system and untwisting the sail by hand.
2. Asymms seem to roll up easier in higher winds (might be a limit to this!) as we think this keeps the sail away from the torque line longer, which is key to rolling the sail up correctly.
3. Keep the clue from rolling in until the last 1/4 of the sail or so is rolled in. The clue rolling in too early can make for a mess when unfurling the sail.
4. Good tension on the system (halyard) helps but not essential if you have a good torque line.
5. Keep good tension on the clue when unfurling as the lower end of the sail can get sucked back into the lower end of the system when unfurling, especially in light winds. This can cause issues.
6. When furling in it helps to keep the sheets together as they are rolled around the sail. If you let these go in separately it sometimes causes issues when unfurling.
7. An existing sail that is cut for a full hoist sometimes causes issues as the hoist length is now shorter by the distance of the furler drive end and the swivel, making for a curvier luff. The straighter the luff it seems the better the sail furls in. Some existing sails might not work if the luff ends up being too curvy.
As with sleeves there is a learning curve with a top down style spinnaker furler. One thing I like about our systems is that they seem to work better as the winds go up. The high torque line that we have works great even in higher winds. These systems work good now but all of us manufacturers are still on a learning curve here so stay tuned for more as we attempt to perfect this great method of handling a light air headsail.
Best Regards,
John Franta, Colligo Marine
#23
Posted 30 August 2012 - 08:41 PM
We have just developed a new Top Down Furler at Profurl : The SPINEX.
We are posting lots of news and videos online : http://www.facebook....401156926587196
LIKE it if you want to keep in touch.
Press release : http://riggingnews.b...ight-round.html
Feel free to ask questions.
Regards,
Clément Leflot, Development Engineer, Wichard - Profurl
#24
Posted 30 August 2012 - 08:49 PM
#25
Posted 31 August 2012 - 12:16 PM
Is this system what they are running on the AC 45's? Seems like it- crazy cool function makes me think that there are some cool sail options possible for short handed mono's
Hello U20guy2,
I think I understand why you think they are the same system as the AC45s: because the hoist / unfurling is so easy and quick just like on our SPINEX videos that you apparently saw on facebook or youtube.
However, it is not exactly the same systems but could be... let me explain.
In the flying sail furlers world, there are 3 types of sails that can be furled :
1st - The "Code 0" : which has a straight luff and for which the torque rope (or furling textile cable) runs through the luff in the sail pocket: like on the AC45s.
2nd - The "Staysail" : also a straight luff and more and more popular for removable staysail systems.
3rd - The "Asymmetrical Spinnaker" : which has a loose luff, which means that the luff is separated from the torque rope.
https://plus.google.com/photos/105849540239944113160/albums/5782808962593925169?authkey=CIXxk4zSrsu4lAE
Our new SPINEX concerns the 3rd sail and is designed to suit your existing Asymmetrical Spinnaker.
However, the SPINEX is a complete package that includes the NEX: which is just the flying sail furling unit and can be used for the 1st (Code 0) and the 2nd sail (Staysail).
So you are right, the are some cool sail options : One SPINEX can be plugged to 3 sails with an easy quick sail attachment:
The SPINEX Kit is available if you already have an NEX.
Clément
#26
Posted 31 August 2012 - 12:40 PM
Generally speaking : but depends a lot on your sail shape
- Code 0 (or similar straight luff down wind sails) : AWA = 50 to 120°
- Asymmetrical Spinnaker (loose luff) : AWA = 70 to 160° : depends a lot on your sail shape
https://plus.google....CIXxk4zSrsu4lAE
Having the two sails gives you great performance gain.
Having a furled removable staysail would also bring a lot more comfort in strong breeze: stay in the cockpit all the time.
#27
Posted 31 August 2012 - 05:17 PM
Fast multihulls like AC45s don't have asymmetrical spinnaker because they go too fast and therefore their Apparent Wind Angles are low :
I know this - heck even on the U20 there were times a code zero would have been fantastic in SF winds given the boat speeds we could do. However if your short handed or single handed and on a mono that can plane - this furler system would in effect open up a wider range of solo or short handed sailor sail options that remain easy to handle enabling a solo sailor or double handed boat to carry more sail when they might have simply gone short on sail due to the lack of easily managed sail options etc.
#28
Posted 31 August 2012 - 05:21 PM
#29
Posted 31 August 2012 - 05:42 PM
The bugaboo right now is the torsion rope, especially for smaller boats. I'm told the smaller-sized torsion ropes are twisting too much. The roller-ball deal above looks interesting but seems like a lot more weight and windage. Racing solo, you may not be able to get the thing on deck until awhile after rounding the leeward mark.
I've used a Code Zero on a Facnor furler successfully for several years and just put a NDPO 3A/5A on that furler for around here. My goal is to be able to "peel" between the reacher and runner (with both on furlers).
I'd like to hear more about reliable torsion ropes (41 feet long for a 93 s/m 2A).
#30
Posted 06 September 2012 - 04:05 PM
Anyone using one of these successfully on a 30-35 footer? Whose torsion rope is working?
#31
Posted 07 September 2012 - 09:11 PM
Part of our development process was to test different Torsion Ropes.
We tested the Torsion Ropes over a 30ft length.
We selected the best supplier for our SPINEX package and we are very happy with its performance.
It is important to always furl in the same direction : the cable will develop a Torsional memory and become even more efficient over time.
The torsional performance also depends on how you use your sail:
- If you ease the sheet completely before furling, the sail would immediately start furling.
- If you keep some tension on the sheet, either to have a very tight furl or to pre-load some torque on the cable, you would have to turn a very maximum of 10 turns before you reach the effect point when the sail starts furling.
Please follow us on Facebook as we will post new videos very soon.
#32
Posted 25 September 2012 - 06:33 PM
