Raymarine X-5 Autopilot vs X-5 GP
#1
Posted 27 August 2010 - 01:50 AM
I can replace the tiller arm for $700, or upgrade via the GP "Corepack" for $1800. I'm being told the GP arm needs the upgraded computer and fluxgate compass.
So, the question is, will the GP last longer? work better? Or should I just get 2 regular X-5 tiller arms.
#2
Posted 27 August 2010 - 02:56 AM
I installed the X-5 Tiller pilot on my J/30 this past spring. It replaced an ST1000+ that was severely under powered and required sails to be well balanced or it couldn't handle the pressure. The J/30 is 6500 lbs and well within the 13,000 lb rating without upgrading to the GP version. A friend installed the X-5 wheel version on a Hunter 33 and has no problem either. The Raymarine compass with the course computer do a good job at compensating for roll and pitch to keep the heading on track. One of the things the X-5 setup / cal does is send the boat through a series of maneuvers to measure the response. This is stored in memory and allows the system to really track well and maneuver the boat without under or over helming. I've also integrated the system with my GPS and wind sensor via the TackTick T122 NMEA interface. It will maintain a constant wind angle if set, or the GPS can drive the boat via waypoints.My tiller arm gave up the ghost after 18 months on a 7,000 lb boat. Yes, I know. I should have bought an NKE system, but we're talking about a T-Ten here.
I'd say no need to go with the GP version for a 7,000 lb boat. Use the extra $ to buy the S100 remote as it also works great. Why are you asking about 2 regular X-5 tiller arms? It only needs a single tiller arm drive motor.
#3
Posted 27 August 2010 - 04:55 AM
Currently we have ours with a plastic bag around the cable/motor and a off road shock absorber boot at the ram end.
#4
Posted 27 August 2010 - 03:35 PM
___________________________
There was another set of road tests in the Singlehanded TransPac this Summer. The guys are just posting their "what worked, what didn't" comments on the SSS SH TransPac board at sfbaysss.net. It sounds like the X-5 below-deck parts were fine but as posted above, the drive units were the weak spot, as with previous RM models. I've blown up a few drive units myself. A cover helps as long as it's a bit loose and doesn't overheat the unit. Spares are essential if you're going any distance.
A couple of us are working on a better mousetrap for tiller-steered boats with sealed rudder tubes - nothing conclusive yet.
#5
Posted 27 August 2010 - 04:00 PM
#6
Posted 27 August 2010 - 04:16 PM
#7
Posted 27 August 2010 - 04:28 PM
My standard unit lasted about 2,000 miles on my T-Ten. So, the answer is to carry multiple spares, or maybe cut open your rudder stock tube (above the waterline!) & mount one belowdecks?
Anyone taken the tiller arm apart after it failed? Is it water intrusion? gears grinding & failing? Motor brushes failing?
The service guy down here said the GP arm would not work with my standard X-5 Controller and fluxgate. I have trouble believing him.
#8
Posted 27 August 2010 - 05:16 PM
An Olson 30 couldn't make it to Hawaii with a GP? Give me a break.
We run them about 2,000 miles in two weeks, racing downwind in the trades with the kite up - difference?
It's been all of the above - water intrusion is most common (which gets to the motor, sending a voltage spike to the controller), warn/busted gears, I had one simply break in half at the seal and drop on the cockpit floor - you name it.
Do us all a favor and press the service guy on using the GP drive unit on a standard X-5 computer and 6002 head. This would be useful information to several of us.
#9
Posted 29 August 2010 - 11:31 PM
Let me know when you come up with something!
#10
Posted 30 August 2010 - 08:29 PM
"Yes, the GP drives will work with the standard X5 Tiller course computers, there is no change with the course computer using GP drives."
As we suspected, I'll bet it will work fine. I will place an order for a GP drive unit and report back. Whether it lasts significantly longer is the question. I'm going to tear apart my old standard unit and see what happened to it. This is really frustrating as you'd think they would conduct a MTBF analysis on the components they use. I'll bet they could quadruple the life with little cost difference.
#11
Posted 31 August 2010 - 06:40 AM
I believe Raymarine's warranties are two years. Before you tear apart the old drive unit you should ask about returning it for a new one (to use as backup for the GP drive you plan to buy?), or maybe they'll give you credit towards the upgrade.
I just bought a new X-5 (non-GP) to replace my S1G/6001. The S1G has two SH TransPacs on it and is working fine, but I'll be able to get rid of the rudder reference unit, currently mounted atop the tiller. The X-5 doesn't need one.
#12
Posted 31 August 2010 - 08:20 PM
Is the X-5 compatible with the S100 remote ? I seem to recall to have read somewhere that it is not.
#13
Posted 03 September 2010 - 09:59 PM
The S100 remote will definitely work with the X-5 Smartpilot. I run this setup on my J90 and it works great.
Hot Toddy
#14
Posted 07 September 2010 - 04:35 AM
Looks like I'll be getting a sleeve of some kind to keep water off the unit.
I'll report back on the GP once it arrives.
Cheers.
#15
Posted 11 October 2010 - 04:05 AM
See photo.
Red Sky
Autopilot0102bb.jpg 476.04K
192 downloads
#16
Posted 11 October 2010 - 08:29 PM
Raymarine TillerPilot users take note: Unit arrived from the factory with gaskets NOT tightened down. I could turn the motor to gearing connection 1/2 a turn by hand, and the connection at the motor end by 3/4 of a turn by hand. I believe water could easily have entered the unit. TIGHTEN YOUR TILLER DRIVE UNITS!!! And keep them covered. Water ingress will kill these units quickly!
I cleaned up the old one as best I could. It could not be resurrected. It will go into the garage to sit for years thinking I might want the parts someday. Then 5 years from now I'll finally throw it away.
#17
Posted 08 March 2011 - 05:55 PM
Note* I am thinking of this unit as I already have a drive unit that came with my original ST4000 and the redundancy seems like a good idea.
#18
Posted 08 March 2011 - 06:37 PM
works well
have the S100 - works well - sometimes too well if I bump a button.
interfaced to both GPS and Wind
#19
Posted 14 March 2011 - 11:16 AM
#20
Posted 14 October 2012 - 07:02 PM
See http://www.portescap...4-35NT2R82.html
and http://avnetexpress....&page=2&rank=19
Normal unit has a Mabuchi RS555 which you can find for ....$4.00 (four dollars) on the Internet.
See http://www.allelectr...-MABUCHI/1.html
Replacement of the gear wheel is easy. Both the gear on Mabuchi and the Portescap are the same: 14T diam 8.2mm, axle 3.175mm.
The gear wheels of the planetary transmission are the same: some delrin type material, 18T diam 10.4mm.
Diam of motor sleeve is different: see picture: nr8 diam GP is 48mm; nr8 normal is44mm.
Material of end cap assembly nr9 is different: Aluminum for GP; some delrin like for normal
Posted 26 October 2012 - 01:23 AM
#22
Posted 26 October 2012 - 01:39 AM
The non-GP drive units should be fine for your boat, as they have been for my 5,500# 30-footer. Use the dollars you save to buy a spare (I have three).
#23
Posted 27 October 2012 - 11:14 AM
I have checked this: yes, actually I think that is possible, diameter and length of the is the same.So can you replace the Mabuchi with the Portescap in the field?
The "gear annulus" (see nr4 in drawing) is also interchangeable which proves the entrance diameter of "motor sleeve" nr8 is the same.
I have to correct my comment that axle diameter of the two mothers is the same: the Portescap axle diameter is larger and has two sides flattened.
Strange then why RM uses the larger diameter mother sleeve for the GP model: perhaps in the early day's a different motor was used which only fitted trough a different "end cap" nr9.
For now it seems that the larger motor sleeve only serves "looks": hey! Mine is bigger than yours! Which is fine for me
#24
Posted 27 October 2012 - 04:31 PM
Wouldn't there be more quality motors around with the same specs, but with a smaller pricetag than the Portescap?I have checked this: yes, actually I think that is possible, diameter and length of the is the same.
#25
Posted 28 October 2012 - 09:06 PM
Brilliant. Your comments are confirmed. I have a GP and standard unit torn apart on my desk.
My standard unit has a Mabuchi RS-555SH. http://www.compucanj.../rs-555sh20.pdf I'm not sure if the RS-555PH is the same, but I've ordered 4. My existing motor's brushes are ground down to nothing.
The GP unit has a Portescap 35NT 2R32 228P-20. http://www.portescap...5-35NT2R32.html
Both motors are encased in identical metal sleeves. I believe the Portescap has higher torque and would have much longer life than the Mabuchi, but at $4 each, I'm planning on keeping a few on hand and just replacing when the brushes wear down every 2,000 nm or so.
One thing I noticed was my GP unit seemed slower than the standard unit. Given the RPM specs, the standard unit may actually be faster, at least for my 7,000 lb boat.
Yeah, it looks like the larger GP unit's casing gives me bragging rights that I don't get to have in other parts of life...
Slack On
#26
Posted 28 October 2012 - 09:22 PM
Strange that this knowledge was not shared before.
Please note that Mabuchi does manufacture some different RS555's: http://www.mabuchi-m...rch/e_model.cgi
But I gues that when you order the 12volt type you'll be Ok.
I also found the rpm of the Portescap to be slightly lower than Mabuchi. I wonder what persons whit real knowledge of DC motors can tell us about the real difference between these two motors. Besides obvious things like numbers manufactured there should be some significant diffence!
