B&G compass sensor - fastnet cable ??
11 replies to this topic
#1 micha571
micha571
  • 286 posts
Posted 27 September 2010 - 12:25 PM
Hello,
Iíve managed to get a B&G halcyon compass-sensor to fit into my B&G Hydra System.
It is supposed to plug right into the fastnet cable.
Unfortunately, I donít have the cable for it, only a fitting plug.
Can anyone tell me to which pins of the plug the wires of the fastnet-cables (red, black, green, white, screen) go?
The attachment shows the six pins on the compass-sensor.
Thanks guys.
Michael
#2 fbrice
fbrice
  • 1 posts
Posted 05 January 2011 - 09:38 AM
Hi Michael,
did you get any news from somewhere else, i've exactly the same problem!
rgds
#3 micha571
micha571
  • 286 posts
Posted 06 January 2011 - 07:34 AM
Sorry, no.
It turned out I had a wrong compass sensor.
So I am desparately searching for a used Halcyon 2000 compass sensor.
You don't have one for sale? :)
regards, Michael
#4 SteveH
SteveH
  • 113 posts
Posted 06 January 2011 - 01:42 PM
http://www.myleselectronics.com
For used B&G.
#5 micha571
micha571
  • 286 posts
Posted 06 January 2011 - 01:48 PM
Thanks.
I've asked Myles, he doesn't have a compass.
Michael
#6 NoStrings
NoStrings
  • 10,672 posts
Posted 06 January 2011 - 10:40 PM
If you're willing to pay to have it fixed, I know someone that has one sitting in his garage. PM me and I'll put you guys in contact.
#7 micha571
micha571
  • 286 posts
Posted 07 January 2011 - 05:18 PM
PM sent.
Michael
#8 x-79
x-79
  • 16 posts
Posted 11 May 2013 - 12:45 PM
Does anybody know if its possible to modify the black Compass(similar to halcyon 2000) to fit the standard fastnet cable?
http://ckdboats.blog...ass-wiring.html
#9 Erik O
Erik O
  • 45 posts
Posted 11 May 2013 - 06:24 PM
This compass seems to be for the ACP1, the old h2000 pilot, check the manual
http://www.myleselec...pdfs/hpilot.pdf
page 4-11 lists the connections
It could also be the NETWORK type compass, Myles has the manual:
http://www.myleselec...susermanual.pdf
Edited by Erik O, 11 May 2013 - 06:40 PM.
#10 x-79
x-79
  • 16 posts
Posted 12 May 2013 - 05:27 PM
Many thanks for info. I guess it is the pilot compass as the pilot compass cable got 6 pins(refer to manual) I attached a photo of the compass as well.
This article says that the center pin (red cable) have no function. http://ckdboats.blog...ass-wiring.html
This means that I can connect a 5 pin fastnet cable to the compass and it will work as long as the other wires are the same as halcyon 2000?
#11 Erik O
Erik O
  • 45 posts
Posted 14 May 2013 - 07:30 AM
The Fastnet cable is completely different (and only uses 4 wires: 2 are power, 2 are data) and is a digital signal
The NETWORK compass uses 2 for power and 3 for signal (North/South, East/West and a common/neutral) and I think they use a SIN(sinus) function. Not 100% sure about that.
#12 x-79
x-79
  • 16 posts
Posted 14 May 2013 - 10:53 PM
This means that the halcyon 2000 Compass got 4 pins Connector for the fastnet cable?
