Chain plate a go-go
#1
Posted 05 November 2010 - 04:05 AM
Anyways Kidz, I need some ideas of which course of action to steer the new owner to---without scaring the financial dogshit out of him, killing his dream of sailing forever or pushing him off the cliff of suicide 'cuz he bit off more boat than he could chew and is pretty much both depressed and flat broke this evening. It's really pretty f'ng sad to see this happen to him right now, so I'm gonna try my damnest to help him out.
Gracias,
E.M.
#2
Posted 05 November 2010 - 05:08 AM
Inspection and/or replacement is the safe answer.
#3
Posted 05 November 2010 - 07:26 AM
Go to Puerta Vallarta and have the rig pulled. Then, remove all the chain plates and get detailed measurements of the materials required to make new chain plates. It's quite likely that they are all made from the same basic material - probably 2" x 1/2" stainless stock.
I'd get that material in the USA - not Mexico. The problem here is that if you get lousy stainless, you'll just be screwed again in no time.
Once you have the material, chop it into appropriate lengths and stick it in a suitcase and fly back to Mexico. Find a good metal shop and have them fabricate the chainplates.
It's not an inexpensive job. I'd guess you're going to pay about a grand to have the mast pulled and re-stepped plus another $500 or so per chain plate by the time you're done. But then, I haven't been in Mexico for 4 years now ...
What ever you do - don't go to La Paz - that upwind trip easily has the potential to cost you the rig. Even Mazatlan, a long reach on port, isn't a good idea with a missing port-side aft lower.
Good luck!
#4
Posted 05 November 2010 - 11:54 AM
#5
Posted 05 November 2010 - 12:40 PM
#6
Posted 05 November 2010 - 01:29 PM
I am curious about how a chain plate will only pull partially out of the deck.
Bam Miller
#7
Posted 05 November 2010 - 01:45 PM
IMHO Get halyards into position and start making plans on making new chainplates from US stock - Good luck
Sail safe!
#8
Posted 05 November 2010 - 01:58 PM
I have to agree with the others. Break one. Change all. You can do it with the rig up if you do them one or two at a time.
#9
Posted 05 November 2010 - 02:41 PM
1) PV Sailing - the local North Sails loft and rigging 329-295-4065 mex, Attn Mike
2) SYS Rigging and Yacht services -322-145-8194, Attn Jorge
Best Wishes.
#10
Posted 05 November 2010 - 04:12 PM
I replaced all chainplates on a Shannon 50 ketch a couple of years ago, after finding a failing chainplate. All had cracks, all had corroded bolts, some had the holes thru the knees elongating. This was causes by use of fully threaded bolts, the thread actually cut thru the knees. Should have smooth bolt shank entirely thru knees. New chainplates were made from solid stock, all new (correct length) bolts, bolt hole pattern offset as needed to skip old worn holes.
The hardest part of the job was getting access to all the chainplates & pulling them up out of the deck.
In your situation: aft lowers undergo more shock loading than all the other chainplates as mast pumps. I would remove & inspect the other aft lower chainplate. Inspect the others as much as possible in situ. Bright lighting will show any cracking as it will have rust inside. If entire surface is dirty, clean it off with a scotch brite pad. The rust down in the crack will remain & be visible. I would leave the stick up, do chainplates in pairs. The added cost & damage possible to rig lying on ground far outweigh the additional time required by doing two at a time. You also need the halyards/winches to get the plates out of the deck.
#11
Posted 05 November 2010 - 04:30 PM
#12
Posted 05 November 2010 - 07:57 PM
#13
Posted 05 November 2010 - 07:59 PM
#14
Posted 05 November 2010 - 08:11 PM
#15
Posted 05 November 2010 - 08:21 PM
#16
Posted 05 November 2010 - 08:25 PM
#17
Posted 05 November 2010 - 08:41 PM
#18
Posted 05 November 2010 - 09:12 PM
#19
Posted 05 November 2010 - 09:18 PM
Isn't there somethin' bout buried stainless always rusts with moisture present and no air??? (This is a real question)
Yep - IIRC, stainless requires the presence of oxygen to create an oxide layer on it's surface, which prevents further oxidation. Let it sit in stagnant water, it'll corrode.
#20
Posted 05 November 2010 - 10:21 PM
#21
Posted 05 November 2010 - 11:07 PM
That black bit of teak doesn't look promising...I'd be nervous.
Not my $, but I'd do them all as soon as possible.
#22
Posted 06 November 2010 - 12:16 AM
Yup, agreed. And it only took me 14 fricken hours to finally convince him of that.
Now then, that said, here's his latest plan-----Gene Gammon sent him some pics of another I52 that had the same problems. His idea/solution? let off the turnbuckles, Sawzall off the tops of all 8 chain plates, make eight new ones that will go on the outside of the hull (after chopping the dogshit out of both the rub rails and cap rails), mark the holes of the new ones and drill straight thru the hull and the existing ones, put on 8 appropriate sized backing plates on the inside of the hull at all 8 areas, and then bolt the hell out the whole shebang. I'm still not too sure about this entire procedure myself, but I'd love to hear your thoughts. Oh yeah, fwiw, the work will be done by the boat yard next door. At least they have a sister yard in San Diego, so they can't be all that bad. I hope. And they bill at just $70.00 US per hour----plus materials. Regardless, this sailing adventure is now officially over. Back to Hell-A tomorrow afternoon.........
#23
Posted 06 November 2010 - 12:41 AM
http://www.irwinyach...Chainplates.pdf
#24
Posted 06 November 2010 - 02:57 PM
Just curious. Is there a problem burying the old chainplates or will the moisture be cooked out and sealed? Will rust continue and swell/fracture the mount area? Is that a 1 year, 10 year or 50 year problem? Guessing the old chainplates aren't being removed(those that don't break).
#25
Posted 08 November 2010 - 11:44 AM
#26
Posted 08 November 2010 - 12:39 PM
So anyway, what you used in your industrial testing was almost certainly x-ray machinery, not gamma.
#27
Posted 08 November 2010 - 06:48 PM
Umm, 'gamma radiation' and 'x-rays' are both high energy photons... historically there has been some differentiation between the two based on the energy levels and means of production but that is no longer true.Gamma radiation has higher energy than that of x-rays. Medical devices (CT, x-ray, mammo, etc) produce x-rays using x-ray tubes. Zap some electricity into the tube and blast some electrons out the other end sort of thing. Gamma radiation is usually the result of radiactive decay and is also used medically (nuclear medicine for example). Because of its higher energy special detectors are used (gamma cameras). Both gamma and x-ray are ionizion radiation meaning they interact with tissues of the body, so you shield yourself from both.
#28
Posted 09 November 2010 - 02:57 AM
Its all relative eh? Typical gamma energies as i was taught are above 100kev, x-ray generally below 90kev. So by "high" energy i meant higher. I suppose its all semantics, but in the medical field there are gamma cameras, and they are completely different beasts than x-ray equipment.
#29
Posted 10 November 2010 - 10:18 AM
