Tacking lines
21 replies to this topic
#1 jarcher
jarcher
  • 974 posts
Posted 31 January 2011 - 07:55 AM
To work correctly, do tacking lines have to be put in the center of the boat? Or is that too minor an issue to make any difference?
#2 learningj24
learningj24
  • 2,367 posts
Posted 31 January 2011 - 11:21 AM
I made a template for my tacking lines and put them on the deck with a Sharpie (the sunlight erases them after awhile and allows me to refine them). Then I draw a set on either side, on the deck, just forward of shrouds near the towrail for the use of the bowman. There's a second set forward and outboard of the primaries for the use of the trimmer and the driver. My template has a cross or not line, a layline and a tack and clear line. The design came from Conner's Sail like a Champion.
#3 mrgnstrn
mrgnstrn
  • 1,371 posts
Posted 31 January 2011 - 02:23 PM
Picture/diagram please?
-m
#4 Presuming Ed
Presuming Ed
  • 10,402 posts
Posted 31 January 2011 - 02:38 PM
Graham Sunderland produces "Winning laylines".
(No connection, just a satisfied customer of Winning Tides)
#5 Squalamax
Squalamax
  • 2,308 posts
Posted 31 January 2011 - 04:31 PM
We use a much simpler one than above which takes some use to get used to but works well after you know your angles.
We use a 45 degree (ahead or behind line) Works extremely well for most crossing situations.
70, 80, and 90 degree lines. My boats tacks thru 74 degrees in anything above 6 knots TWS. If we tack at 80 degrees in that windspeed we usually nail the layline(the extra 6 degrees accounts for leeway).
In less wind, tacking angles can be 90 degrees or more. In more wind, tacking angles can be less than 74 degrees.
We have these lines drawn on the deck just forward(and outboard) of the primary winches for my trimmer to use.
#6 Left Hook
Left Hook
  • 7,779 posts
Posted 31 January 2011 - 05:55 PM
Your laylines were beautiful at the BBR this year, absolutely stunning :wub:
#7 ducky
ducky
  • 1,951 posts
Posted 01 February 2011 - 06:19 PM
anybody have anything like this in USA?
#8 jarcher
jarcher
  • 974 posts
Posted 16 March 2011 - 04:10 PM
http://www.performancesailtools.com/
Not quite the same but close. I have seen this on the APS web site also.
#9 in_TO
in_TO
  • 1,038 posts
Posted 16 March 2011 - 04:18 PM
That Suderland one is waaaay too complicated. It looks like it is intended to take tidal effects into account
I sharpied lines at 90 45 and 135, and thinner lines at +/- 5 degrees on the 45 and 135. On the cockpit seats just forward of where the helm sits
#10 Anonymous Anarchist
Anonymous Anarchist
  • 421 posts
Posted 16 March 2011 - 06:59 PM
We sail with a GPS and I like to write down the heading over the ground on each tack, this is useful in spotting headers, but if you have the weather mark in as a way point you can also watch the bearing to the next waypoint display and use this to help decide.
aa
#11 jarcher
jarcher
  • 974 posts
Posted 16 March 2011 - 10:29 PM
Thanks everyone... So, if you imigian an extension of the lines, they don't need to pass through the middle of the boat (fore and aft)?
#12 in_TO
in_TO
  • 1,038 posts
Posted 16 March 2011 - 10:31 PM
No, not really, if I understand your question correctly.
#13 The Advocate
The Advocate
  • 7,422 posts
Posted 16 March 2011 - 10:44 PM
Jarcher, as long as the baseline of the semi circle is parallel with the centreline of the boat, you're sweet.
I stopped using these years ago though, and now just use my hockey puck compass, is more accurate. But that would be a whole other discussion.
#14 WHL
WHL
  • 6,016 posts
Posted 17 March 2011 - 02:17 AM
Nope because your down wind gybe angles will be different angles than your upwind lay lines/tacking angle..
#15 notallhere
notallhere
  • 343 posts
Posted 17 March 2011 - 02:32 AM
What he said...
Not sure I agree about the hockey puck though.... The problem I find with "the puck" is your baseline heading that you reference off. Having to take a heading bearing & then a mark bearing, & then figuring the difference, especially if working through the north quadrant of the compass, see it's taxing just trying to write/read about it.
The biggest advantage of having tacking lines on the side deck, & aft? It doesn't matter if your lifted knocking, pinching, 80 deg is always 80 degrees 150 is always 150, relative to the boat. Frees up the mind to think more about speed & tactics. My 2c
#16 The Advocate
The Advocate
  • 7,422 posts
Posted 17 March 2011 - 02:45 AM
What he said...
I have a bit of a head for crunching those kinda numbers quickly I guess.
#17 notallhere
notallhere
  • 343 posts
Posted 17 March 2011 - 02:57 AM
What he said...
I have a bit of a head for crunching those kinda numbers quickly I guess. :D
Or maybe the boats slow enough that you have time to work it out :lol:
#18 The Advocate
The Advocate
  • 7,422 posts
Posted 17 March 2011 - 03:02 AM
What he said...
Nice comeback, give you that one!
ROFLMAO.
#19 in_TO
in_TO
  • 1,038 posts
Posted 17 March 2011 - 02:53 PM
I use a hockey puck if I'm hiking on the rail of a >30 footer, but if you are driving on a one-design keelboat, you can't exactly drop the tiller or mainsheet to put a handbearing compass to your eye.
#20 some dude
some dude
  • 3,644 posts
Posted 17 March 2011 - 03:18 PM
not anyone who looks outside the boat from time to time
#21 scarlet
scarlet
  • 118 posts
Posted 17 March 2011 - 09:10 PM
All too much for me. use time on the water and your judgement to build up a mental model of when to tack. surface currents fouls up anything that might be precise.
IMHO
#22 The Advocate
The Advocate
  • 7,422 posts
Posted 17 March 2011 - 09:38 PM
nor can you come into the boat to look over sightlines. a quick glance over the shoulder is all you get.
