rudder humm
#1
Posted 22 June 2011 - 01:30 PM
I normally sail on tigger and we haven't had this issue with the new rudder, but this was bad
real bad, were talking as loud as a lawn mower and very persistant
hard to see why, pintles seem tight, just noisy and slowing
anyone else with this issue? or is it just a bad day at the mould?
it wasnt just a small humm that happens ocasionally we're talking about three distinct tones that were increasingly severe
the top one would rattle screws out of a rolex
and IMHO was costing the boat 10- 15% boatspeed at worst ,let alone stopping it from accelerating
#2
Posted 22 June 2011 - 02:20 PM
I'd check that rudder for trailing edge treatment first, that's easy, then symetry. That will require templating it. A slight change to the trailing edge could fix it. I have no idea how the trailing edge was designed but I favor a chamferred trailing edge. The three different tones is worrysome. Make sure the traliong edge is a crisp cut. You can't really do that in a mold but you can fair it by hand. Maybe Jim Betts has some ideas.
If it really as violent as you say then symetry could very well be the cause. You neeed to ask Betts for some rudder templates.
#3
Posted 22 June 2011 - 02:21 PM
the leading or trailing edge needs adjustment ( shaping )
one the OEM rudders was humming and it was eliminated by sanding ( reshaping slightly with sander ) one of the edges. The price point is relatively high for the aftermarket rudder, I would contact the mfg and ask for guidence. I wouldn't think there is much room for error. Sending it back would be expensive and time consuming to let them do the adjusting, but probably the better option. The rudder mfg is probably not interested in an exchange.
#4
Posted 22 June 2011 - 03:29 PM
Are you sure it was not there with the old OEM rudder? On most boats, the 8 kt humm is from the keel. Humms at 8 / 16 / 24 kts....went sailing today on share kahn in 20+kts and the brand new betts rudder resonated for half of the time
Clew
#5
Posted 23 June 2011 - 03:08 AM
Take the rudder off and square off the trailing edge with a file (just take off what you need to get 90 degree edges), then put a tiny 45 degree bevel on one side only.
This prevent the oscillations from starting.
#6
Posted 23 June 2011 - 08:01 AM
#7
Posted 23 June 2011 - 10:07 AM
I templated & faired the rudder of my boat (not an FT10) a few months ago, and repainted it with a twin-pack polyurethane which has a high gloss finish. When I sailed the boat again the rudder was humming at 14-16kts boatspeed. I took the gloss off the paint and the hum was gone. Maybe there really is such a thing as TOO perfect?
There is such a thing as too perfect.
IIRC and the numbers are rough (pun) for planing dinghies/fast sprotsboats etc. the hull shouldn't be any glossier than approx 600-800 grit wet and dry. Slower lead mines need 400 grit. High speed powerboats need glossier - ie 1200-2000grit.
#8
Posted 23 June 2011 - 02:22 PM
"Too symetrical" that's a new one on me but you sound like you know what your're talking about so I will consider it. I do know that with other ruder and keel vibe problems fairing them to symetry has most often helped the problem. I agree with you trailing edge treatment.
Boy, 65 years old (almost) and still learning.
Bill Garden once told me. "If the rudder flutters check the trailing edge. If it's round square it. If it's square round it."
#9
Posted 23 June 2011 - 05:47 PM
Mark:
"Too symmetrical" is a very inexact term for it. But if the trailing edge is loaded even a bit in one direction it tends not to start oscillating, and it's all very much about the trailing edge on hum.
The science of it is over my head, but here's a paper on vibration problems in hydrofoils by a real Mr. Science. Hydrofoil "singing" is dealt with in chapter 4.
http://docs.hydrofoils.org/hiper.pdf
I learned how to fix it from the early days of thin daggers in cats. Everybody had the problem at one time of another.
#10
Posted 23 June 2011 - 07:54 PM
#11
Posted 23 June 2011 - 08:37 PM
#13
Posted 23 June 2011 - 10:06 PM
http://www.youtube.c...feature=related
Not sure if this would work to dampen the vortices, but might be worth a try. There was a guy in the California surfing scene who came up with the idea of putting flexible chines of a sort on the bottom on his surfboards. His thinking was that in a hard bottom turn, if you could bet the sheet of water flowing diagonally across the bottom of the board, it would reduce wetted surface and reduce drag and add speed. He would mask off a tapered width of 1/2" or so across the board and then apply silicone caulk between the masking tape and then tool the silicone into a V shaped chine for the lack of a better word. Peel the tape and this little flap would offer little resistance to straight line speed as it was mostly parallel to the CL, but when the board was turned it would trip the flow! He would tryit for a day or so and then razor knife off the silicone and try a different configuration. I never got the knack of troweling the sticky crap into anything that could possibly help, but perhaps a nice clean trailing edge V added to the 1/8" flat on a well tuned foil would clean up the flow but due to the resilient nature of the silicone would damp out the vortice formation??? Worth a try?
#14
Posted 23 June 2011 - 11:18 PM
Those are interesting buit is there on showing the flow around a chamferred trailing edge?
Thanks for that link.
#15
Posted 24 June 2011 - 03:05 AM
This one is even better, flow starts off laminar but then after a while breaks down into the alternating Von Karmann vortices. CFD will play a huge part in the upcoming wing design for the AC 72's...
awesome links mate thanks heaps
this is how I had pictured it (from people describing it to me)
the answer that so many seem to disagree on though is a symmetrical or asymmetrical solution,
Betts prescribed an asymmetrical trailing edge as a solution, but it irks me somewhat to do anything asymmetrical to the underwater shape of a boat.
Fortunately it isn't the tiger i sail on normally so the PBO will have to make his own mind up on this one.
I'm still curious though if this is the only one of these rudders that has this issue
tiggers rudder has only a slight hum that certainly seems too small an issue for us to worry about, and the other tiger I've been on was much the same
could there be another factor contributing?
for example a loose pintle?
Would that allow the resonance to grow and become more established?
#17
Posted 24 June 2011 - 04:40 AM
thought this one shows quite well the reynolds number relationship to votrex shedding that extrad mentioned above
#18
Posted 24 June 2011 - 11:28 AM
Strange how conversations in the CY on a Sunday afternoon and posts here merge into one.
Good job we weren't discussing Colebrook White backwater step factors - that would surely bring out guns at 12 paces amongst hydrodynamicists
PS I think that the 1st step in resolving Shere Kahns ghetto blaster loud rudder hum issue would be to clean the bottom of the boat. Followed by confirming that it isn't the keel. (AKA put an unsymettrical chamfer on the back edge of the keel.)
#19
Posted 26 June 2011 - 01:35 PM
#20
Posted 05 July 2011 - 02:33 PM
Anything to report on your rudder hum problem yet?
#21
Posted 06 July 2011 - 03:13 AM
#22
Posted 07 July 2011 - 12:29 AM
#23
Posted 07 July 2011 - 04:01 AM
While my boat is not a FT but to some degree similar in setup (transom hung rudder) and high aspect foils i can tell you that I do have a very little amount of humm - it starts at about 19 knots and stops at about 19.5 knots and doesn't re-appear (at least not under 26 knots). The humm used to be a little worse but got better after we rafaired both the hull and foils a couple of years ago - I did use the recommendations from Steve thompson I posted above regarding trailing edge treatment.
Christian takie your Viper 870 and your 19.5 knots to a thread that gives a fuck! you fucktard want a be FT10 owner and don't even go into how you didn't follow threw with your order cause ??????? what ever the fuckin reason you come up with cause your boat is more of an orphan than a Tiger will ever be. Lots of luv to Perry, Scoot, and Hip for a really good boat.
#24
Posted 07 July 2011 - 06:56 AM
Sideshow:
this is a rudder on a tiger that I don't normally sail on,
so I'm not sure
but I'll find out from it's owner on sunday, unless he wants to chime i here and give us an update
#25
Posted 07 July 2011 - 11:52 AM
#26
Posted 07 July 2011 - 07:31 PM
Thanks. I'd like to know how he has dealt with it.
Can you Fed Ex me some fish and chips?
I prefer the ones from the fish shop across the street from the Ashfield train station.
It's probably a Boutique now.
#27
Posted 07 July 2011 - 11:14 PM
That's just wonderful Christian. But this is the FD thread and my question was addresed to Matt with an FD 10m.
Bob, I understand - my point was that foil humm is not unique to FT's and is something that happens on a lot of boats with high aspect foils and I posted some recommendations how to help minimize/eliminate the problem.
#28
Posted 07 July 2011 - 11:19 PM
Christian - thanks for the contributions even if slightly off topic. I think a lot of people get a bit protective or defensive given the mud that has been thrown at the FT10 over the past few years. Thanks for trying to stay above it.
#29
Posted 07 July 2011 - 11:44 PM
EMF!
#30
Posted 08 July 2011 - 12:40 AM
#31
Posted 08 July 2011 - 12:50 AM
#32
Posted 08 July 2011 - 01:09 AM
Christian: please translate "EMF". I'm sure it's another one of your positive contributions to this forum. Care to enlighten us? Or at least me?
Coined by the Editor - Eat My Fuck
Only used when people call me fucktard or some other pretty lame namecalling
#33
Posted 08 July 2011 - 01:14 AM
I was more hoping for:
Everglades Marine Foundation
or
Egyptian Mummified Frogs
#34
Posted 08 July 2011 - 06:23 PM
When someone's intellectual retort is "EMF" it kinds of brings an end to any adult discussion.
I really don't carte if Scot said it first.
As my Dad would have said, "If Scot jumped of a bridge so you have to do it?"
#35
Posted 08 July 2011 - 07:29 PM
#36
Posted 09 July 2011 - 02:11 AM
#37
#38
Posted 09 July 2011 - 03:05 AM
"Elect More Frontiersmen"
Or from a Native American perspective:
"Eviscerate More Frontiersmen"
At least something that made grammatical sense. Christian is speaking ESL.
"Well Scot said it."
As all of our Dads used to say, "If Scot told you to jump off a bridge would you do it?"
Jeesus, if I had a dime for everytime I heard that.
#39
Posted 09 July 2011 - 05:14 AM
#40
Posted 09 July 2011 - 11:38 PM
I thought it stood for German Shorthaired Pointer.
#41
Posted 10 July 2011 - 12:06 AM
that was very funny and I could use some funny today.
How is my calf doing? Are you putting a blanket over it at night? Are you taking it for walks?
Can I have a new pic?
Was it scared on the 4th of July?
I hope you brought it into the house for that night.
I'm thinking that we skip the cutting off the balls thing and let it grow into a huge Bull.
I'd like that.
By then it would be house broken and think of the surprise on your friend's face when they see a 3,257 lb. bull sitting watching TV in your living room.
Bulls like to watch golf.
#42
Posted 10 July 2011 - 12:40 AM
Sideshow:
chish&fips Ashfield link
good news it's stil there , if anything all vacancies there become chinese takeaways, asian groceries or yum-cha joints ! it's full on one of sydneys 2nd tier chinatowns
ur making me hungry
#43
Posted 10 July 2011 - 02:52 AM
The only reason bulls like golf is it's grass pasture porn. Can you imagine a swimming pool of scotch?
Watch Temple Grandin. Good flick.
My neighbor's mom from the conservative rural south calls tattoos 'skin illustrations'. As in, "Why on Gawd's great earth would you wanna be gettin' yerself painted with no skin illustration?"
#44
Posted 12 July 2011 - 02:29 AM
I just saw your calf today but no pics. They've been on the DL until today. I'll get a pic.
just to bring it back slightly on topic, I talked to the owner on sunday and he was waiting to finish the series, (last sunday), before taking it to a man called Bruce (who most sydney types will know) to get his midas fingers involved.
It may seem like overkill to some getting a boatbuilder involved, but i think its a good call.
this way it will be put right, not made worse, no problems created, no butchering. Or at least if there is, it will be made right again by someone who knows how.
Will let you know of the "fix" and its effectiveness in due course
#45
Posted 12 July 2011 - 02:45 AM
Lucky you weren't as off-topic as the dude who posted a link to docs about hydrofoiling Russian ferries.
And here was me stumbling across this thread when searching for posts about singing rudders. I fixed it by sanding the trailing edges finer, but since I don't have an FT10 that information will be useless to anyone here.
#46
Posted 12 July 2011 - 04:49 AM
Yeah those FT-s are soooooo special that the tricks that fix problems on other boats simply are not good enough for the FT folks since they are very special too
#47
Posted 12 July 2011 - 06:51 AM
#48
Posted 12 July 2011 - 07:02 AM
#49
Posted 12 July 2011 - 06:42 PM
I don't own an FT10.
#50
Posted 18 July 2012 - 03:23 AM
#51
Posted 18 July 2012 - 05:41 AM
Christian takie your Viper 870 and your 19.5 knots to a thread that gives a fuck! you fucktard want a be FT10 owner and don't even go into how you didn't follow threw with your order cause ??????? what ever the fuckin reason you come up with cause your boat is more of an orphan than a Tiger will ever be. Lots of luv to Perry, Scoot, and Hip for a really good boat.While my boat is not a FT but to some degree similar in setup (transom hung rudder) and high aspect foils i can tell you that I do have a very little amount of humm - it starts at about 19 knots and stops at about 19.5 knots and doesn't re-appear (at least not under 26 knots). The humm used to be a little worse but got better after we rafaired both the hull and foils a couple of years ago - I did use the recommendations from Steve thompson I posted above regarding trailing edge treatment.
So what in the f is a Viper 870? Raced a bunch on the 830 and the 640 but would love to see a 870
#52
Posted 18 July 2012 - 02:52 PM
I don't think you want a razor sharp trailing edge on any appendage. Snaps is right, chamfer it. But it appears it has self chamfered.
#53
Posted 18 July 2012 - 09:17 PM
I know this is an old topic, but I too have a hum, a violent floor shaking hum that you swear will shake every screw on the boat loose! The boat is a perfectly smooth Star that I re-faired the keel on over the winter. I thought it to be the rudder until reading this forum. During a particularly violent hummer of a sail in moderate breeze, the "humm" mysteriously and suddenly abated to a quite flutter. Upon haul-out, the trailing edge of my razor sharp bulb, solid glass by the way, was shredded to bits. Maybe there is something to too symmetrical, to sharp on some boats!
Class rules prohibit fairing so the correct terminology is that you fixed defects.
#54
Posted 19 July 2012 - 03:05 AM
Donno what a Viper 870 is. I have an 830. There is a T870 (same designer) but is is a slightly more crusier design. Obviously the poster (before you ) is a little off................................and an idiot too.
#55
Posted 19 July 2012 - 10:40 AM
When I received our boat, not an FT10 (but alot like it), our keel had no foil at all, professionally faired from the factory my ass. We still get a little buzz at 9.5 knots, but nothing else.
#56
Posted 20 July 2012 - 12:07 PM
Check that the engine box door is flush with the hull... we had a similar prob and this was the fix.
Doug
