You can buy oxalic acid at most hardware stores under the name "Wood Bleach". It's way cheaper than FRS but doesn't have the gel carrier that lets it stay on vertical surfaces. I find that alone is enough to recommend FRS.
Ajax's Pearson 30 Rehab Thread
#801
Posted 23 July 2012 - 09:44 PM
#802
Posted 23 July 2012 - 10:16 PM
I'll hit Ace Hardware tomorrow for the pressure washer concentrate. I already have one of the pump-up pesticide sprayers.
Wow...at this rate, I might actually get to the brightwork before winter sets in.
#803
Posted 23 July 2012 - 10:43 PM
Well, Sea Wooluf is no more, all the lettering is gone.
Finally!
#804
Posted 24 July 2012 - 12:18 AM
#805
Posted 24 July 2012 - 04:07 AM
So....Who's invited?Well, Sea Wooluf is no more, all the lettering is gone. I need to wet sand a bit, and have a de-naming ceremony.
-M
#806
Posted 25 July 2012 - 02:10 AM
#807
Posted 29 July 2012 - 12:10 AM
From this (disgraceful):
To this (acceptable):
I also replaced the navigation lights with high power, warm white LED's. They'll go a long way towards extending battery life.
#808
Posted 29 July 2012 - 12:39 AM
#809
Posted 29 July 2012 - 12:44 AM
#810
Posted 29 July 2012 - 12:59 AM
Did you get some wax on the hull to keep it looking nice a bit longer?
No, it's been raining all friggin' day. I was lucky to get that done.
#811
Posted 29 July 2012 - 04:48 AM
You HAVE to colour match the LED nav lights, the light output drop of a white LED and a red lense is lots, I haven t tried a green one but guess its the same. Honestly how much are you paying for LED nav lights. I can get a red green pair for less thart $50. job done and sealed fitting.I also replaced the navigation lights with high power, warm white LED's. They'll go a long way towards extending battery life.
Boat looks good by the way.
#812
Posted 30 July 2012 - 02:09 AM
Also, dropping an LED replacement bulb into a nav light fitting is technically no longer certified by the Coast Guard. You have to have a certified configuration to be legal.You HAVE to colour match the LED nav lights, the light output drop of a white LED and a red lense is lots, I haven t tried a green one but guess its the same. Honestly how much are you paying for LED nav lights. I can get a red green pair for less thart $50. job done and sealed fitting.
#813
Posted 30 July 2012 - 11:30 AM
I didn't just buy the cheapest LED's on the market and slap 'em in. I chose a color designed to work with colored lenses, that put out the required number of lumens to account for the loss through the lens to acheive the equivalent brightness of the same incandescent bulb. Yes, I've read that in some applications, you need to use a red LED with a red lense, but if you use a powerful enough bank of warm white LEDs, you can achieve the required intensity. I also ensured that they would provide the necessary 112 degree arc of visibility.
You may be right, but I have a question about that: You can go into West Marine right now, and buy replacement "navigation LEDs" for use in Aqua Signal navigation fixtures that use a 33mm or 41mm festoon bulb. These LED's are NOT made or sold by Aqua Signal. Are you telling me that West Marine is knowingly marketing a product that invalidates a boat owner's navigation lights CG certification to be legal?
In fact, here is the product: Dr. LED on WM Oops, this one is specifically for a clear lens for masthead and anchor lights. Still, it would violate a CG certification, no?
This one is for colored lenses: More Dr. LED on WM
At least on the Defender website, many LED ads state whether or not the LED should be used in a navigation fixture for some of them.
Here's a warm white LED that claims to be suitable for reading lamps and most navigational lighting fixtures: Dr. LED on Defender
I can site other web examples from other vendors but you get the point. None of the WM items say anything about maintaining a CG certification. What about boaters who accidentally replace a burned out incandescent bulb with one of the proper fit, but incorrect wattage? I guess they'll be found guilty in an admiralty court as well.
In the end, I've kept the incandescent bulbs and I can put them back in, if I feel that the LED's aren't up to the task.
#814
Posted 01 August 2012 - 02:28 AM
I am retrofitting the stern light with non-USCG compliant fittings..the jury is still out since I haven't completed it yet...but it's gotta be better than the GE-90 5 watt bulb that was in there..
#815
Posted 07 August 2012 - 11:25 AM
Any user experience with these? Durable? Easy to find re-build kits and repair parts? Decent flushing capability?
#816
Posted 07 August 2012 - 12:05 PM
Upgraded the boat from the 39 year-old, leaky Wilcox-Crittendon "Headmate" toilet to a Jabsco yesterday. It works a treat.
Jabsco is perfectly fine.
Why are you spending money on a toilet?
You need a genoa
#817
Posted 07 August 2012 - 12:41 PM
You need a genoa
It was free!
#818
Posted 07 August 2012 - 03:23 PM
nice job on the cleanup
I love cleanup. It makes you feel like you have a new boat.
#819
Posted 09 August 2012 - 02:53 AM
#820
Posted 09 August 2012 - 12:39 PM
Ajax, The Jabsco works fine. Add to your annual maintenance list, the $10.99 Joker Valve from Defender. Do not pass go and do not spend $26 at West Marine. In your neck of the woods, even at the god damned Beneteau dealer at Jabin's a joker valve costs less than $10!!
Good to know, HB. I know you don't have access to SA at work anymore, but you've been awfully quiet. I hope all is well in the Land of Bystanders and Bitches.
Yesterday, I installed and wired in the starboard AC receptacle that is meant for a mini-fridge. Neat and tidy. I'm using permanent cable supports that are padded with rubber. Marine grade wire, and of course, another GFCI outlet because the damn thing is on it's own breaker, and not downstream of another GFCI outlet.
All that's left to do, is wire up the photon torpedo launchers and the retracting stripper pole!
#821
Posted 10 August 2012 - 03:12 AM
I wholeheartedly understand your attempts to civilize your boat, but do not complain to me when you have to move the boot stripe up an inch in a few years from all the added weight..and remember, you do not get a rating credit for all that 'stuff'.
#822
Posted 10 August 2012 - 03:21 AM
I'm pretty sure I'm the dork on the other end of that photo... and I'm also pretty sure that if Ajax posts the photo he took, there will be a camera over my face too.what is with us dorks taking pictures of a boat that's taking pictures of us at the same time?
#823
Yesterday, I installed and wired in the starboard AC receptacle that is meant for a mini-fridge. Neat and tidy. I'm using permanent cable supports that are padded with rubber. Marine grade wire, and of course, another GFCI outlet because the damn thing is on it's own breaker, and not downstream of another GFCI outlet.And NO, the fridge will NOT EVER be permanently mounted, nor will I ever sail with it. Just toss it up on the dock, and go. There's no reason to be uncivilized when you're tied up at the dock.
Those darned Klingons aren't back again are they ? As if the roaches weren't bad enough.
#824
Posted 10 August 2012 - 01:26 PM
Not at all. The photon torpedoes are for killing the roaches.
#825
Posted 12 August 2012 - 02:49 AM
1974 P30, Hull 644, Passeggiata. Been reading Ajax's adventure with interest. Bought boat last summer, new thru hulls done, deck hardware removed/rebedded, bottom blasted to gelcoat-barrier coat-paint, 20Amp Charles battery charger, stuffing box redone, new manifold and exhaust system, new (used) vhf and new antenna, 7/16 jib Halyard (VPC), 1/2 staset sheets, found a 100% jib on ebay, about 4 years old (used maybe a year).........spent WAY more than expected, but got it for a good price (isn't that what everyone says!)
Don't have a boom vang, and would appreciate some recommendations. Outhaul goes to forward cleat on boom, starboard side. Topping lift, when reattached when taking main down, got snagged on batten (about mid sail level).
Recommendations on sailing without a boom vang. Here's why:
Just had her launched in Rock Hall about a month ago......Sailed her up to Aberdeen Proving Ground last Saturday. A bit hot but some wind.....Definitely have to learn how to sail her....enjoyed every minute! But, sailing her downwind was disappointing since the boom would raise due to no vang........Acknowledge I have a lot to learn about maneuvering with her. ....No bail or place on mast currently to mount a soft vang.
Will provide photos as soon as able.
Bottom Line.....A whole lot to learn - and can't wait to....
BTW: Thanks for the tip on 50/50 bottle of barkeepers and bug sprayer. Will that work on topside and cockpit too, or too harsh?
Cheers
#826
Posted 12 August 2012 - 12:07 PM
Congratulations! I'm jealous of your VPC halyards. I haven't got that far yet. It's good to hear from another local P30 owner. From what I can tell, the cockpit gelcoat is the same as everywhere else, so you can use the barkeepers there. Test in a small, inconspicuous spot around a drain first.
If you've been lurking for a while, then you know the traditional greeting. Get 'em out!
#827
Posted 12 August 2012 - 03:55 PM
#828
Posted 19 August 2012 - 12:27 AM
saw this thread a long time ago and thought I'd chime in.
If you need to know something about the P30 just ask ..I'll do my best.
#829
Posted 19 August 2012 - 10:40 AM
just joined in...will be glad to talk anything Pearson 30 with folks.
You just joined in and want to go straight to talking P30 trash?
Ahem, that's not the way it works.....
I'm tired, I had to spend the day with Olaf and Sweet Hart dragging me all over to show me the hillbilly highlights of Tassie. I'm sure somebody else will chime in to tell you the protocol around here.
#830
Posted 19 August 2012 - 12:51 PM
P30- Fuck off and show us your girlfriend's/sister's tits.
Now that protocol has been observed, I'd be very interested in seeing any photos you may have, and improvements that you've done.
#831
Posted 20 August 2012 - 04:38 AM
Sure hope the old fart took you to the Longly International for lunch. Did you meet Wizza?
#832
Posted 20 August 2012 - 06:33 AM
?? That must be on the A-tour. I'm pretty sure Olaf and his lovely bride took me on the B-tour. These sadists FORCED me to go sailing with them. Which meant DRAGGING me over to some hell-hole known as Barnes Bay (on Bruny Island). Where I had to look at what passes for boat porn around here. Oh yeah, and this is during the middle of "winter" here. All of about 55 degrees on Sunday. It was awful. Judge for yourself in the attached pics beginning with one of the boring view from Chez Olaf.
In seriousness-- the "Harts" are lovely and I was reminded of the old comment by the former Governor of Oregon (Tom McCall) who once said on national TV "visit often but please don't come to live here". Paradise found I'd say and anyone who gets a chance to visit should.
Thread relevance: I didn't see any P-30s......
Posted 20 August 2012 - 07:12 AM
I don't know about you, But personaly I'm more fond of natural tits.Eh, it's my rehab thread so I'll do it.
#834
Posted 21 August 2012 - 10:56 AM
Racing seems to have shaken and loosened some things up, so I had a leaky topside grab rail. On the P30, the topside grab rail mates to a belowdecks grab rail inside, so the bolts penetrate the cabin. Looks like it was only bedded in ordinary silicone.
A few hours after bedding the rail in butyl tape, a storm rolled through, and not a drop of moisture to be seen.
#835
Posted 21 August 2012 - 01:22 PM
Magellan is a sweet looking boat- some might say a big butt, but nicely done.
#836
Posted 21 August 2012 - 06:33 PM
Wow, that's a frustrating job getting those back on.Well done! I made new ones for Rita P, getting the holes right and bending them was a PITA.Two words people: Butyl-friggin'-tape.
Got a Jenny yet ?
#837
Posted 21 August 2012 - 06:49 PM
#838
Posted 21 August 2012 - 06:56 PM
+1 on butyl tape. Very easy to work with in the 'forward' direction. Getting it off's a bitch though. Typical sequence onboard Soñadora is to <perform operation> then realize it's fucked up then <un perform operation> fix fuck up <re-perform operation>. And in some cases repeat. If the <un perform operation> sequence involved any bolts (like those that hold down a cleat) getting the tape off is a major undertaking. A wire brush on a bench grinder is your best bet.
Interlux Special Thinner 216 dissolves butyl quite nicely.
#839
Posted 21 August 2012 - 09:25 PM
Many thanks.
#840
Posted 21 August 2012 - 09:51 PM
Many thanks.
+1 yeah, that's good to know
#841
Posted 21 August 2012 - 10:23 PM
you told me a short while ago...but where did you get this stuff again?
-M
#842
Posted 21 August 2012 - 11:38 PM
+10
#843
Posted 22 August 2012 - 12:44 AM
#844
Posted 05 October 2012 - 01:04 PM
Blue Sea 8-breaker + main panel.
Galley outlet.
Fridge/Microwave outlet.
Fwd cabin outlet.
Onboard battery charger.
I have done my very best to install things in a professional manner and use the proper materials. Yet...somehow I'm not quite satisfied. As I added more cable runs, things seemed to get a little cluttered. I mean, everything is restrained and suspended in a safe way, with strain-reliefs and all that. It's just not quite as neat as I'd like it. I think I'd like to get some cable labels to help identify everything.
The final run was a bitch. Finding a good, safe place to install the fwd cabin outlet was difficult, and then it was a long run through the bowels of the boat, back to the breaker panel. I've restrained the cable, and it's probably fine but it's just not the way I want it. I need a skinnier body with longer arms who can anchor the cable to the points I want it anchored to.
Am I just being persnickity or what?
#845
Posted 05 October 2012 - 03:43 PM
When do you install FWC for the engine so you can hook up a hot water through a heat exchanger?
#846
Posted 05 October 2012 - 03:50 PM
It is OK to be persnickety. One thing you might consider as you update an older basic 3 lights and a manual cold water system boat to something more modern is to install 12V wiring conduit (CPVC pipe) fore and aft on both sides. A good place is often the underside of bunks/berths along the hull. Thay will allow you to collect wires in an organized fashion and run them through lockers, bulkheads, etc. Naturally, never bundle 12V and AC in the same run.
Erm...that final 110v run has been run and restrained adjoining a 12vdc run. Is that bad? Even if the wires are plainly labled?
I'm kind of drawing the line here. No pressurized water, no hot water. I'm watching 2 people in my marina struggle with failed FWC heat exchangers and one of the engines only has a few hundred hours on it. I'm not certain it's worth the trouble to upgrade my old A-4 to FWC. If I do a re-power in the future, then I might.
#847
Posted 06 October 2012 - 03:09 AM
#848
Posted 09 October 2012 - 01:50 PM
ok, but I have both and have had no problem thus far, and neither have been replaced since the boat was new in 1987.
look closely at those two guys having problems....where they treating their boats right?
and...you can have a 120V hot water heater that isn't hooked up to the engine....most are dual duty, so just don't hook up the engine.
but what are you using hot pressurized water for anyway, showers? I doubt it.
probably just dishes and washing hands and the like.
you just need one of those under-counter hot water heaters (the kinds that simmer all day and make 210F hot water.) pretty compact and not a *huge* power draw.
food for thought.
what are you useign to stay warm in the cabin this winter? I have a friend who left a diesel cabin heater behind when they went to New Orleans...could get you a deal on it.
-m
#849
Posted 09 October 2012 - 02:00 PM
I appreciate the offer of the diesel heater, but I'm not cutting holes in my cabin top for an exhaust stack/Charlie Noble/whateveryoucallit. I'll be insulating hatches and areas of the hull. I'm using an oil-filled electric radiator heater, and I have a catalytic propane heater for a booster. This morning, the temperature was 48F. I had the radiator set for 900w and the cabin was 69F. The heater max output is 1500w. I can add another one if I need to. My final fallback in case of inability to compensate, is to stay at my buddy's house up in Gaithersburg. I won't freeze.
#850
Posted 02 November 2012 - 01:17 PM
My masthead has provisions for two more halyards. I'm thinking that it would be prudent to have spare halyards if I'm going to sail to Maine, or around Delmarva.
I want them to be internal, like my primary main & jib halyards. This obviously requires (shudder) cutting holes in my mast.
Can you guys offer any guidance on the placement/orientation of these holes? Side-by-side? Vertical? Should they be staggered? Approximately how high up should the holes be?
Thanks.
#851
Posted 02 November 2012 - 01:31 PM
I'd go with a 3 halyard setup. One primary for your jib, and two wing halyards. Pretty standard. Use sta-set spliced to dyneema and save some money and weight. Or, if you want to end-for-end, VPC should be a happy median.
#852
Posted 02 November 2012 - 01:38 PM
If you do end up coming to Maine, let me know if you plan to stop in Boston and I'll buy you a beer.
#853
Posted 02 November 2012 - 01:43 PM
Basic masthead sheaves don't really do it, even if they have "wings".
#854
Posted 02 November 2012 - 01:52 PM
These additional halyards will be redundant jib and main. I should have been more specific, sorry for that.
Ryley- Good idea. I think I'll take a range of photos and measurements and take them to Bacon Sails' rigger for a consult.
#855
Posted 02 November 2012 - 07:37 PM
#856
Posted 02 November 2012 - 07:39 PM
That's one less hole to cut.
#857
Posted 03 November 2012 - 12:49 PM
#858
Posted 03 November 2012 - 01:09 PM
The spin halyards cutouts are a couple feet down from the crane as IB stated.
Buy your exit plates before you do the cutout, so you know what size to cut them.
#859
Posted 04 November 2012 - 12:07 AM
#860
Posted 04 November 2012 - 03:31 AM
Also, I chose to drill& tap screws instead of rivets for the exit plates.
#861
Posted 04 November 2012 - 01:05 PM
Ajax, I ran my halyards internal...I put the exits about 24" above the winches on the mast...they (exits & winches) are not at exactly the same height. You are cutting a 3/4" x 1 1/2" hole...
Yes, rivets are 100% fucking verboten on any vessel in my fleet, no matter the application or what the load may be.
#862
Posted 04 November 2012 - 01:25 PM
#863
Posted 04 November 2012 - 01:41 PM
Where do you find gimballed drink holders without rivets?
You drill 'em out and replace 'em with ss machine screws!
#864
Posted 04 November 2012 - 02:07 PM
#865
Posted 04 November 2012 - 09:05 PM
At the top I used a slot for the spinny halyard well below the swivel block (on a bail) so it led fair no matter the angle of the chute. The jib halyard went through a hole in the bottom of the masthead crane and around one of the forward sheaves while the main halyard went around one of the aft sheaves.
+1 on spacing the exits well apart. Also make sure you radius any corners of whatever holes you put in the mast to avoid a stress riser and subsequent cracking. I even broke the edges of any hole I put in aluminum.
Good luck. Not only will you eliminate some drag you will eliminate annoying halyard slap.
#866
Posted 05 November 2012 - 01:20 AM
Ajax, I wil also comment that Jose is absolutely correct..there really is no necessity to have an exit plate. They are just pretty...if you are satisified with the hole(s) you cut..just smooth them out and off you go.
#867
Posted 05 November 2012 - 01:31 AM
handsDrink holders! WTF are drink holders?
#868
Posted 06 November 2012 - 01:30 AM
hands
With Stainless Steel screws through them?
(I started to say "Jesus!", but I'd probably get crucified for that.)
#869
Posted 06 November 2012 - 01:35 AM
#870
Posted 06 November 2012 - 01:47 AM
#871
Posted 06 November 2012 - 01:51 AM
#872
Posted 12 November 2012 - 01:58 PM
I believe I've read in the past, where people have built tanks or structures out of foam, and then layed them up with epoxy or cloth and epoxy.
I'm considering building a holding tank this way. The tank will definitely have to be custom due to the funky shape. Assuming I'm not crazy, what kind of foam can I use to build the basic shape, that will react well to being coated with epoxy? Also, will I need to use it with cloth, or can I just coat with epoxy?
Thanks.
#873
Posted 12 November 2012 - 02:17 PM
I've used corecell and divinycell foam in the past with great results.
It might cost a fair bit by the time you use a proper foam core with epoxy and glass. It may be cheaper to get a pre-made tank or flexible bladder.
I'd think that with the forces a vacuum pump can create when emptying your tank, you would want a pretty strong structure.
Edit:
http://www.jamestown...ble Water Tanks
http://www.oceanlink...ks-water-tanks/
http://www.jamestown...ed Holding Tank
#874
Posted 12 November 2012 - 02:21 PM
#875
Posted 12 November 2012 - 02:25 PM
What's the shape?
+1. a picture or better description of what you're trying to accomplish will probably yield substantially more helpful info.
Are you looking for something to build a mould with, so you can fit it and build outside?
#876
Posted 12 November 2012 - 02:34 PM
#877
Posted 12 November 2012 - 02:54 PM
What's the shape?
Edit:
Serene- Great links but none of them will fit the bill. If the tank is vented, then what forces will the tank see?
I guess a bladder would work, but does anyone here really trust them? Should I build a little enclsoure to protect the bladder, and also contain any leakage in case of failure?
What's the shape?
It looks like this, with an added complication-
The hull curvature side of the tank, will also have "twist" in it as the hull moves forward towards the bow, so not a pure "wedge" or curved wedge.
This is going occupy about 1/4 of my hang-up locker, directly behind the toilet. I do not want to install a tank under the port setee.
Posted 12 November 2012 - 03:26 PM
#879
Posted 12 November 2012 - 03:31 PM
Bladder tanks make very poor sanitation holding tanks.
No ventilation=anaerobic bacteria=stink you wouldn't believe that pervades & clings to the whole inside of the boat.
http://cruisingresources.com/Marine_Toilets
Or google "Peggy Hall, Head Mistress" and check out some of the resources. She's the real deal on this topic.
Posted 12 November 2012 - 03:35 PM
What's the shape?
Edit:
What's the shape?
If you're going to coat the thing with epoxy and cloth, it doesn't really matter what the core is. Almost any foam will do, epoxy doesn't eat foam the way polyester resin does. Foam is light, but bulky and not strong for it's thickness. I'd go with stitch and glue 1/4" or 3/8" plywood.
#881
Posted 12 November 2012 - 03:47 PM
So what you are saying is that you don't like the arrangement that the boat came with?
You're crazy Slick. The "arrangement" that the boat came with, is a 5 gallon jerry can plumbed to a Y-valve because the boat is so old, that it wasn't built with a holding tank at all. The OEM configuration is direct overboard discharge. The jerry can sits in the hang-up locker, where I want the custom tank to be.
#882
Posted 12 November 2012 - 04:04 PM
Yup, that's what I remember it being. Sorta functional, but not pretty. Kinda a Red Green holding tank.
#883
Posted 12 November 2012 - 04:11 PM
A couple times, after a spirited sail, shit has worked it's way up the vent lines and dried out. Not only is it smelly, but it reduces the diameter of the vent line until we flush it out. I believe it's Peggy who suggests flushing the vent line at each pumpout. But, that's one way your tank could see some vacuum. I've also had bugs build nests in the vent through-hull.
#884
Posted 12 November 2012 - 04:50 PM
Oh wow, thanks for pointing this out.
Slick- "Red Green" holding tank! LOL! At least there's no duct tape involved!
#885
Not yet.
#886
Posted 12 November 2012 - 06:18 PM
#887
Posted 12 November 2012 - 06:25 PM
#888
Posted 12 November 2012 - 06:47 PM
One problem with building a custom tank to fit an odd space under the settee or v-berth: How do you get it in there? You'd have to cut away a big section of the platform/deck, then repair it. Which adds a whole extra project. The PO of my boat chopped big ugly holes to try to get new tanks in place and they still didn't fit. I still have to fix those holes
#889
Posted 12 November 2012 - 07:12 PM
#890
Posted 13 November 2012 - 12:19 AM
#891
Posted 13 November 2012 - 01:53 AM
#892
Posted 13 November 2012 - 03:46 AM
I contacted them directly and got a great deal off retail pricing. they literally have hundreds of tank dimensions. I mocked up one for my holding tank with 1x2 lumber (overkill..furring strips would be fine) and duct tape to make sure it would fit where I wanted it to.
#893
Posted 13 November 2012 - 03:49 AM
as a side bar what ever became of Tern I moved up north to cape cod and always wondered what happened to the old girl?
#894
Posted 13 November 2012 - 12:34 PM
Ajax, Do not reinvent the wheel...stickboy knows the deal here..that looks a lot like a diagram for a tank from Ronco.
Oh I agree. If Stickboy's tank will fit in front of my water tank, I'll probably go with it. There was some variation during the builds though, and I'm concerned that my water tank is a longer dimension than his, and that there is no room in front of it.
Ajax, in regards to the holding tank and vent line, I would put an inline charcoal filter like this one from dometichttp://www.northeastsanitation.com/sanigard_filter_5_8inch.php. this will keep the smells at bay, well keep things from going up the vent line and clogging it as well.
Trend-
I agree and thanks for the tip of the charcoal filter. Regarding Tern, the last I ever saw of her, was what appeared to be a test sail or delivery early this year. I was on Mrgnstrn's boat for a race, and I observed them motoring around outside of the race area, prior to our starting sequence. Haven't seen her since. I can't recall the sail/hull number, so I don't really know how to track her down.
#895
Posted 13 November 2012 - 12:36 PM
I'm sure we've chatted about this before but this is what Rita P came with forward of the water tank:
Stickboy,
Regarding your pump-out hose to the deck fitting, where is that located? If this tank is forward of your water tank, the only place I can envision, is up by the anchor locker. Is your pump-out deck fitting way up on the bow?
#896
Posted 13 November 2012 - 01:41 PM
Oh I agree. If Stickboy's tank will fit in front of my water tank, I'll probably go with it. There was some variation during the builds though, and I'm concerned that my water tank is a longer dimension than his, and that there is no room in front of it.Ajax, in regards to the holding tank and vent line, I would put an inline charcoal filter like this one from dometichttp://www.northeastsanitation.com/sanigard_filter_5_8inch.php. this will keep the smells at bay, well keep things from going up the vent line and clogging it as well.
Trend-
One thing to consider on the filters. Overfilling the tank will clog the filter, block the vent and require the filter to be replaced. They do work but you need to be vigilant.
#897
Posted 13 November 2012 - 02:28 PM
What he said... http://www.plastic-m...ter-waste-tanks
They'll do a custom tank from a drawing for a very reasonable price and you won't get yourself covered in epoxy and glass fiber.
#898
Posted 13 November 2012 - 03:52 PM
My own boat and the P-30 really have no room for a decent holding tank unless you want less water and I always need MORE water. I think I only have 70 gallons and my wife can go right through that...........
#899
Posted 13 November 2012 - 04:59 PM
#900
Posted 13 November 2012 - 05:16 PM
Now a Lavac...that's a different story. Gatekeeper says he gets twice the holding time on his tank since he upgraded.
