Splicing
#1
Posted 31 August 2011 - 02:09 AM
I can barely dig the core out of this shit, and then when I make the crossover, at the second step where you push the core back into the cover, I lose it right where it should come out of the cover, so you can pull out the excess because it simply won't slide against itself. Does brand new line really open up and slide against itself so much more easily? If you say so, then I'll go buy some but I want to know if I'm doing something wrong first.
#2
Posted 31 August 2011 - 02:12 AM
#3
Posted 31 August 2011 - 02:15 AM
#4
Posted 31 August 2011 - 02:17 AM
As soon as I tried it on some new nylon 1/2" line, it went as smooth as silk.
Buy some cheap Samson and practice on that. It will go easy.
This video and technique rocks.
#5
Posted 31 August 2011 - 02:25 AM
#6
Posted 31 August 2011 - 02:29 AM
#7
Posted 31 August 2011 - 02:30 AM
This isn't an affectation, I really feel that this is an important skill to have, that could save my ass out on the water some day so I at least want to master a basic double braid eye splice, and a 3 strand eye splice.
#8
Posted 31 August 2011 - 02:33 AM
#9
Posted 31 August 2011 - 02:40 AM
its easier for a heap of reasons..mostly its the sun and the salt that detract from the new rope features... NEW lines are more lubricated.. more flexible
And stretched...like a Chinese finger trap.
#10
Posted 31 August 2011 - 03:06 AM
To be honest, a splice probably isn't going to save your ass on the water. Being able to tie a bowline or other knot while it's blowing snot at 0300 and raining sideways is a better skill to have. Practice with you eyes closed standing in a cold shower.
#11
Posted 31 August 2011 - 03:09 AM
Class I being that the core and the cover both bear the load.
Class II being that the core bears the load and the cover is there for abrasion protection.
#12
Posted 31 August 2011 - 03:10 AM
If you can do a splice on an old line, then the new stuff is easy. A lot also depends on the cover, the more strands in the cover, the tighter it is and usually harder it is to splice. If you bring some new stuff with you tomorrow night, I can go over some tips with you on the deck over a beer. I don't think anyone would mind. Also, larger line is easier to splice. I wouldn't attempt to splice anything under 1/4".
To be honest, a splice probably isn't going to save your ass on the water. Being able to tie a bowline or other knot while it's blowing snot at 0300 and raining sideways is a better skill to have. Practice with you eyes closed standing in a cold shower during an earthquake.
#13
Posted 31 August 2011 - 03:22 AM
#14
Posted 31 August 2011 - 07:47 AM
#15
Posted 31 August 2011 - 04:02 PM
It is a piece of cake to splice the 12-strand Dyneema stuff. Have a look at L-36.com With old line, if you really must splice it, try soaking it in fresh water with dish washing soap, then push on the ends to open it up while it's wet. Don't rinse the soap out as that will lube the rope. But make sure you've got the dirt and salt out. May require multiple soakings in soapy water.
BV
#16
Posted 31 August 2011 - 06:35 PM
#17
Posted 31 August 2011 - 08:21 PM
I did't know you were in to S&M.
Gee you learn something new every day.
-M
and H,B!: my copy has about 5 pages that get 99.99% of the use, and the rest is the "why". interesting, but as a "tool" could be condensed to a pamphlet.
#18
Posted 31 August 2011 - 09:15 PM
#19
Posted 31 August 2011 - 09:54 PM
Ajax,
BV
Old line is definitely harder to splice. The idea of soaking or washing the lines first sounds like a good idea and may save you the cost of buying new line to practice on Ajax.
Good idea Beau.
#21
Posted 01 September 2011 - 01:03 AM
#22
Posted 01 September 2011 - 02:28 AM
... thats what I did anyway. If you plan ahead and trim your off-cuts to suit, you can end up with new dock lines!
#23
Posted 01 September 2011 - 02:36 AM
Ajax,
BV
Good idea Beau.
Something I've used for old rope is wiring pulling lubricant. Like this stuff:
You can get it at Home Depot.
Smear it on the fid and cover before you do the pull.
-tk
#24
Posted 01 September 2011 - 03:45 AM
#25
Posted 01 September 2011 - 07:34 AM
If I remember correctly , it was a kind of threading backwards and forwards thru the line....
Kris
#26
Posted 01 September 2011 - 07:48 AM
#27
Posted 01 September 2011 - 08:51 AM
You never know what will happen, but emergency splicing? I can only splice when calm and relaxed. If I need a loop in an emergency I tie a bowline.
Don't get me wrong, it's both a satisfying and useful skill, and will at least save your rigging $$$ on land, if not your ass on the water.
Splicing old line is a good punishment for disobedient crew.
#28
Posted 01 September 2011 - 12:57 PM
Has anyone spliced a constant diameter end for end??! That took for ever as at one point you have three diameters of rope trying to share the same space.. Ajax i agree its not about affectation, i learned via making up some lazyjacks and splicing the hardware into the lines. I was really surprised at how straightforward this can be when you simply follow the instructions. Its funny because at first it seems really complicated but after you do it the first time its just burying rope tails.
I've done constant diameter end for end for a continuous furler- used class 1 and found it ok using this video from NE Ropes. Not sure it is appropriate for a high load application but works fine in my furler.
#29
Posted 01 September 2011 - 01:28 PM
About 15 years ago I came across a braided line splice called Humbold - I didn't keep the article , and cant seem to find anything on the NET. anybody out there know what I am talking about ?
Kris
Are you thinking of the Brummel splice by any chance?
#30
Posted 01 September 2011 - 02:58 PM
I did soak the stuff, but I didn't try the soap. It wasn't any easier when it was wet, and it seemed to get worse when it was dry. I'll pony up and pay for new line to practice on.
Yeah. Check out the remnant rack at your local marine $upply $tore and see if you can get some ends.
#31
Posted 01 September 2011 - 08:38 PM
#32
Posted 02 September 2011 - 10:54 AM
Other thing to use help things along on a splice are, uhm... err....
water-based personal lubricants
Kind of like the fact that oysters are edible. One wonders how someone first came to learn that...
#33
Posted 02 September 2011 - 11:15 AM
#34
Posted 02 September 2011 - 11:44 AM
I'm with you Beau, love the 12 strand! Don't miss rope to wire splices one fucking bit.
My current halyards are like that. Obviously outdated in this new era extremely high strength textiles, but I'm amazed at how two very disimilar materials are woven together that way.
#35
Posted 02 September 2011 - 11:51 AM
+10000
Hated making them. Hated using them.
Also hated wire spin guys and 22' metal spin poles flailing around in a broach
#36
Posted 02 September 2011 - 01:17 PM
The best thing I've found for splicing are the Brion Toss wands. Yeah, they're bloody-assed expensive, but the ease of use makes 'em worth every cent. That you'll be happy to do your own splicing will save you the cost many times over.
I've also learned a lot from the Toss DVD "Making Your Own Eye Splices." Visual directions are just easier to follow.
#37
Posted 02 September 2011 - 03:40 PM
#38
Posted 02 September 2011 - 03:47 PM
Remember wire 180% genoa sheets on coffee-grinders aboard maxi boats!! Scary shit!
#39
Posted 02 September 2011 - 03:56 PM
And if you get all the meat hooks out, they are great for hanging sails & canvas in the back yard when you clean/waterproof it.
#40
Posted 02 September 2011 - 08:54 PM
Posted 02 September 2011 - 09:14 PM
A ha! Used a free end-cut, courtesy of my local WM. Quick and easy.
It looks crooked.
<running>
Have a nice holiday weekend!
#42
Posted 02 September 2011 - 09:37 PM
May your tails be long and tapered!
#43
Posted 03 September 2011 - 03:33 AM
#44
Posted 03 September 2011 - 04:44 AM
#45
Posted 03 September 2011 - 04:58 AM
seriously, it looks great. keep at it. there is little more satisfying than doing this yourself instead of paying someone at the marine supply store to do it for you.
Thus begins the anti-prostitution movement. Be careful, my friend.
#46
Posted 03 September 2011 - 12:25 PM
#47
Posted 04 September 2011 - 10:46 AM
#48
Posted 09 September 2011 - 01:18 PM
Never mind the 3 hour drive to the marine store...like most things here, we do it ourselves or it doesn't get done.
#49
Posted 09 September 2011 - 10:51 PM
Next up: 3-strand splices. Gotta scrounge some first.
Three strand is easy - once you get the hang of it.
I use masking tape for the ends - short wrap worked to a dull point.
But use string to tie off the working end (not tape - too wide)
Getting the splice started is the big mystery.
Working end center strand ON TOP to start (B in the diagram).
Then rotate into the lay and tuck A under the next loop; flip back over to dig out the loop for C.
(don't worry about all the letters, just get the orientation right and it works)
You should have three strands coming out in three places.
Never have two strands coming under the same place.
If you find that, back up to see where it went wrong.
After that, it's "over one - under one" - over standing part strands, of course - NEVER under a tucked strand!
The pic below is the best I've ever found.
Once you get eye splices starting easily, try a back splice.
Then maybe try end-to-end. (they are a bear to get started, but simple after that)
Posted 21 November 2012 - 01:54 AM
Lock-whips:
Posted 21 November 2012 - 02:41 AM
I'm just not getting enough helm time.
Lock-whips:
So I'm guessing that saying it was 74, sunny, wind sse 8-12 today wouldn't help???
#52
Posted 21 November 2012 - 02:28 PM
Lock-whips:
Ajax is too busy figuring out how he is going to raise the quadruplets (and rebuilding his boat so they all have bunks) he has spawned on the live-aboard/world cruiser thread to have any time for sailing right now.
3 strand splicing is dead easy. The New England Ropes strands tend to unravel, so if you are using that, tightly tape up the ends of each of the three strands for about 2 inches to hold them together.
#53
Posted 21 November 2012 - 02:46 PM
You are one sick bastard. I'm 40 years old, and will NEVER make more babies. I'd go to the doc to get snipped, but it hardly seems necessary, now that I'm essentially a marine version of a Gregorian monk.
#54
Posted 21 November 2012 - 02:51 PM
In the big scheme of sailing, maintinence and now learning splicing and rigging....You've come a long way in a short time Ajax....bravo!
#55
Posted 21 November 2012 - 02:53 PM
#56
Posted 21 November 2012 - 03:04 PM
#57
Posted 21 November 2012 - 05:07 PM
Looking good! Keep at it, it will get easier.I'm just not getting enough helm time.
Lock-whips:
I learned to splice double braid over 40 years ago. Since then I have done all my own splicing on all my boats and have recently starting making a little money making tapered halyards, installing chafe covers on halyards and splicing simple double braid eye splices on other boats. I have a couple of end-to-end splices to make up this week if the weather clears up some. It is a good skill to know and marketable too! A lot of people don't even want to try to splice.
The modern line is so much nicer for running rigging than some of what we worked with in the past. I strip and taper my halyards and sheets and guys. In the past, I spliced rope/wire halyards. I really don't want to do that again, but would probably try it again if someone wanted a halyard made up that way.
#58
Posted 21 November 2012 - 06:31 PM
ice,
ouch . . .
but never say never . . . . just look at Petraeus!
What's next on your 'skills to learn' list after splicing? There's weather, and emergency responder first aid, sewing, and welding to consider.
#59
Posted 21 November 2012 - 07:16 PM
General Petraeus is the father of Courtney's children??? !!!!! Now I'm really concerned about who hit her boat. At the time it seemed like an accident, not so much now.
Welding up a tin hat might just be a useful skill for a monk to have, just sayin'
And just who is this ice9a person who tries to pass for Estar anyways- have they ever been seen in the same room together?
#60
Posted 21 November 2012 - 11:59 PM
Lock-whips:
End-to-end wold be a very valuable skill to pick up.
The furling line on my friend's boat broke (after 28 years).
The marina's rigger came to fix it, but didn't know how.
He did the "loop?" type splice first time. (the type with the female part in it?)
That didn't work (obviously), but that was all he knew how to do then.
Next week he came back and did a proper in-line splice.
We all watched him for half an hour or so - the prep work.
Then, when nobody was looking it was suddenly done.
Still have no clue haw it happened!
#61
Posted 22 November 2012 - 12:57 AM
I just got back from the marina after splicing an end for end. It fought me for every part of it. The line is used but newer and the ends I did the splice on are unloaded. Oh well, looks really awesome when it is done. Red and green line spliced together! I hope the owner likes it.
Lock-whips:
#62
Posted 22 November 2012 - 12:59 AM
ice,
ouch . . .
Definitely weather. Meteorology is very interesting to me.
#63
Posted 22 November 2012 - 01:09 AM
A ton of free professional quality on-line seminars here:
https://www.meted.uc...ning_detail.php
edit no midget porn though
#64
Posted 22 November 2012 - 03:25 AM
Damnit
#65
Posted 22 November 2012 - 04:26 AM
#66
Posted 22 November 2012 - 01:41 PM
Ha, thanks man. I'm sure it's still a great resource and I'll check it out. I think I'll look into end-to-end splicing as well. I've got plenty of winter to practice.
