Leech 6.5
650 replies to this topic
#501 Nrg85
Nrg85
  • 46 posts
Posted 01 October 2012 - 11:58 AM
Laminated the keel today. Took 5hrs to laminate then vac bagged it. Will find out tomorrow how well we did with it. Should have te foils done in the next fortnight. Then onto pouring a bulb.
Can I ask how many layers of biax and unidirectional glass did you use? On a keel and a rudder?
Keep up the good work! How long do you estimate the building will take?
#502 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
  • Interests:rum, boats, girls and rum
Posted 01 October 2012 - 12:14 PM
About 10layers of carbon uni a side. Then 3 layers of biax on the keel.
#503 Nrg85
Nrg85
  • 46 posts
Posted 01 October 2012 - 12:32 PM
Interesting.
I have heared that before from people for rudder and keel.
Is it so common for 6-8m sportboats to have roughly the same layer?
10 layers of lets say 200 g/m2 unidirectional carbon and that 3 layers of biax seem a lot to me.
Or is it unidirectional only 10 cm (about 4 inches) wide and one layer over another so only 3 layers of biax are over the whole thing?
This boat seems to weight similar like i550 but more powerful, it should give more speed in every direction, especialy upwind.
#504 noosa special
noosa special
  • 45 posts
  • Interests:Sailing, motorcycles, all things marine.
Posted 04 October 2012 - 07:00 AM
My 2 away boats went well on weekend. Charles Baker, a mate and my 2 adult crew took, line, handicap and class in my Spider 22 Bobsled finishing 40 Min in front of next boat in Pearl challenge in 25K northerly. I sailed Slingshot in Heaven can wait with Sydney crew in a wild 20 to 40K westerly. The boat was not good , it was brilliant. Because crew had no Slingshot experience, we decided not to run a kite even though our fractional is easy to use. With full rig the sails set well. rarely inverted, little back winding being footed off a bit, we were very quick compared to other boats. Had we used our kite the race was ours for the taking. We only did the 1 lap pulling out of 12 and 24 hour races. was happy with 2nd out of 28 boats that finished. Finally got a score up.
Even with lots of advice and help there has been no quick fix, of poor upwind speed, and not enough time on open water. Last SBS at RQ found direction, the mast has same rake and bend as before, when sails would not work, but do now, all about fore stay sag.
Grahame has some mods for my sail but going to wait till after next 2day Manly regatta to get best out of where I am Now.
Good to see the builds progressing, exciting times for you Guys.
#505 noosa special
noosa special
  • 45 posts
Posted 04 October 2012 - 10:25 AM
Tokyo, I do not have contact details so this may do. If you are going for the 2+2 option on bunks as I did, there is really not enough room for 4 people unless very small as Dan pointed out.. The coffin bunks are great to store the crane etc.. There is plenty of room for 2 good bunks especially if you make a removable infill foreward of compression post as I have. and a boom tent will look after other crew if required. To have the coffin bunks the deck floor is carried right to the front bulkhead. I now realise a mistake but a huge job to rectify as you dont have enough head room to sit on bunk , It may compromise rigidity but if bunk was 150mm lower would be great.. This is no criticism of the design the bunks work fine as is but there is a big difference between functional and great. To make a 150mm step at cockpit bulkhead would be up to Dan , If I had my chance over I would make the change.
#506 itkiwi
itkiwi
  • 57 posts
Posted 07 October 2012 - 05:40 AM
Almost finished sanding hopefully - the painter guy is coming around tonight. I have some beers for him - surely he will let me stop.
Keel vacuum bagged last week, looks great, not to much fairing I think. Found someone to pour the bulb as well. $600 plus I supply the lead - seems good to me.
Maybe launch in January is going to happen.
#507 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 07 October 2012 - 05:41 AM
Thanks Bob. we will be using the quarter berths as storage mainly and plan to sleep two in the cockpit and two in the boat so quarter berths wont be too much of an issue to us. Glad your starting to get your boat sorted and going
#508 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 07 October 2012 - 05:47 AM
Keel is now ready for fairing, after bagging. thought there would be a lot of bits to fix up after we tried so hard to fuck it up but the bagging process does wonders to making the glass and carbon conform to the shape you need! The amount of resin that came out was incredible, you don't realise how much resin a big laminate takes up until you watch it all come out in the bleeder.
#509 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 07 October 2012 - 05:52 AM
Looking good! Bet your glad you are coming to the end of fairing the hull?!
#510 itkiwi
itkiwi
  • 57 posts
Posted 12 October 2012 - 09:22 PM
Halyard setup - can someone tell me if a Harken 150 cam cleat is the go for mounting on the floor for spinnaker halyards - are they big enough not to slip?
Second thing - if I cleat the main and jib on the mast with the same cleat will that work? Possibly with a cheek block first to turn the halyard run back 90 degrees and then the cleat so I can pull aft on the halyards. A picture of someone's setup would be great.
The painter guy said I can stop sanding and put some duropox undercoat on. Temp is 5, raining and possible snow - maybe not this weekend.
#511 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 13 October 2012 - 05:45 AM
Depends what size rope you are using and what the jaws of the cleat are like. I remember I had a harken cam cleat holding my tack line and the jaws tapered back out at the bottom so it never held in breeze, ended up double cleating it then reverted back to a ronstan swivel cleat and all was sorted, the rope was only 6mm so problems probably started with the rope size!
#512 crossa
crossa
  • 92 posts
Posted 13 October 2012 - 06:41 AM
do u reckon u will have it at the donald hay in feb?
#513 Young Rocketeers
Young Rocketeers
  • 32 posts
  • Interests:Sailing, Scuba diving
Posted 13 October 2012 - 11:27 PM
i had cam cleats holding the spinnaker halyard & tack line on my boat. They held fine, i did put some stitches through the lines for a meter either side of where the line sat in the cleat so the inner core didn't slip in the cover.
this issue i have with cam cleats on halyards or tack lines is they're very hard to release under load. i would consider a small spinlock clutch like an XAS that's what i changed to simply so anyone can dump the halyard if they have to no strength required.
#514 Slim Jim
Slim Jim
  • 10 posts
Posted 15 October 2012 - 09:22 AM
Horn cleats......
#515 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 16 October 2012 - 01:40 PM
8mm halyard and harken cams!
Sorted!
#516 Sandgroper Yachting
Sandgroper Yachting
  • 534 posts
Posted 16 October 2012 - 01:47 PM
Sorted!
8mm? Are your crew worried about breaking a nail or something.
#517 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 16 October 2012 - 11:10 PM
Sorted!
Dosnt break, easy to use, dosnt fuck cleats!
#518 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 17 October 2012 - 12:10 AM
And all cruising boats use 8mm
#519 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 17 October 2012 - 03:43 AM
Well IOR ones anyway!
#520 Hobbs
Hobbs
  • 155 posts
Posted 17 October 2012 - 10:45 AM
Sorted!
Got to agree there! Easiest set up and easier on the crew. For all the weight and windage you might save with 5 or 6 mm halyards you will loose it all with one slipping cleat or a jam in the smaller line. Too many people over-think boat set up!
#521 noosa special
noosa special
  • 45 posts
Posted 19 October 2012 - 02:04 AM
Sorted!
We have 2 to 1 on Main and jig halyards, single on rest, all either 6mm Spectra or D.Braid. No problems using extreme angle 150 cleats so far.
It is difficult to pull lazy sheet through aft block when jibing and has to be fed and eased through even with ratchet off, 8mm could be difficult.
#522 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 29 October 2012 - 11:53 AM
flying!!
#523 Broomstick
Broomstick
  • 38 posts
Posted 30 October 2012 - 05:12 AM
flying!!
Nice footage!!!!!!! we had a similar ride on Shaw Thing a couple of weeks ago but the GoPro card filled up just before the ride
#524 NZL3481
NZL3481
  • 187 posts
Posted 02 November 2012 - 11:14 AM
very nice!
#525 206
206
  • 572 posts
Posted 14 November 2012 - 03:21 AM
Did the Leech 8m in Otago ever get finished?
http://www.otagoyach...Story&story=151
#526 itkiwi
itkiwi
  • 57 posts
Posted 14 November 2012 - 03:28 AM
Almost, he is still fitting deck hardware and wait for sails. I have had a look a few weeks ago. Will get you a pic next time I go past.
#527 facthunt
facthunt
  • 760 posts
Posted 14 November 2012 - 08:53 AM
Sorted!
i thought asba were looking at banning 8mm halyards
#528 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 14 November 2012 - 11:24 PM
Sorted!
After they ban dinghys i heard!
:rolleyes: :rolleyes:
#529 83TER
83TER
  • 218 posts
Posted 15 November 2012 - 04:06 AM
Sorted!
Sorted!
I herd the other day that they are talking about banning flares aswell because of a recent high win ratio for boats with them. :P :P
#530 MSA
MSA
  • 693 posts
Posted 15 November 2012 - 04:33 AM
Which ones??? :P
  • Attached File  hot.jpg   6.96K   6 downloads
  • Attached File  Cool.jpg   3.39K   18 downloads
  • Attached File  Fun.jpg   6.41K   29 downloads
#531 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 15 November 2012 - 04:44 AM
Naa, scientific studies have found if a wind limit between 10 and 25 knots is enforced it solves the problem!
#532 facthunt
facthunt
  • 760 posts
Posted 15 November 2012 - 11:10 AM
theyre going to ban scientific studies as well.
#533 noosa special
noosa special
  • 45 posts
Posted 15 November 2012 - 10:07 PM
One thing ASBA has gone hard on is Squaretops, our rating went up 21 now same as Magoo. Never liked it and believe responsible for our problems up wind. Not a problem now as cut it off and will request re rating.
#534 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 15 November 2012 - 10:49 PM
You will find it wasnt the ASBA that went hard on the square tops, the SMS mob at YV do it fella!
Yor boat wasnt that far behind us last time we raced, wont be long!
#535 Berndty
Berndty
  • 29 posts
  • Interests:sailing
Posted 16 November 2012 - 01:11 AM
Ahh is that why the leech and shaws rating went up??
#536 noosa special
noosa special
  • 45 posts
Posted 16 November 2012 - 03:13 AM
Cross out ASBA and put SMS my mistake
#537 GybeSet®
GybeSet®
  • 19,978 posts
Posted 16 November 2012 - 10:44 AM
One thing YV has gone hard on is Squaretops, our rating went up 21 now same as Magoo. Never liked it and believe responsible for our problems up wind. Not a problem now as cut it off and will request re rating.
lets get rid of the mis info
Are you saying that YV has changed the rating of mainsails
or you changed mainsails from a conventional to a Sqr Top
yes YV is hard ( too hard) on all kinds of 'big roach' but that is nothing new and precedes the Leech being launched
They take a 'headboard width' measurement which is stupid IMO
you are suggesting it has changed recently to 'more penalty'.
any other reports or sqr top boats that went thru the roof ?
#538 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 16 November 2012 - 12:38 PM
Sounds to me like he cut off his squaretop. Not the other way around.
#539 GybeSet®
GybeSet®
  • 19,978 posts
Posted 16 November 2012 - 06:55 PM
no that doesn't make your rating go up
it reads that that is 'the cure'
his rating is high now on the YV list
what has changed ? SMS calcs ?
#540 oregami
oregami
  • 90 posts
  • Interests:sailing
Posted 17 November 2012 - 12:33 AM
Info we received.
"Yachting Victoria (with input from ASBA) have amended the SMS handicap system for 2012/13.  The outcome appears to be an increased penalty for lighter displacement boats and upwind horsepower.  Some of the changes are:
·         Vipers (OD) up 13 points to 0.778
·         Octopussy - Shaw 650 up 17 points to 0.823
·         Shaw Thing- Shaw 650 up 8 points to 0.800
·         Melges 24 (OD) up 1 point to 0.810
·         Ducks Nuts (T750) up 8 points to 0.866"
We Vipers don't even have a square top we can get rid of!!!
#541 oregami
oregami
  • 90 posts
  • Interests:sailing
Posted 17 November 2012 - 12:40 AM
(try again.....sorry about formatting - didn't like the cut and paste dot points.....)
Info we received
We vipers don't even have a square top we can get rid of!!!
#542 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 17 November 2012 - 12:54 AM
Arnt the vipers the fastest things on the planet?
Thats what we keep reading!
Some of the brisbane races lately have real close results, as the Fastest Shaw and Leech in the universe race here, and its been seconds between leech, shaw and T7, where finally it has been up to who makes mistakes loses, how it should be! Peow is still dificult to beat once the breese in, but its way closer now, and just mabe if they hit a couple of the fringe boats we4 might see some of the older fleet come back and the numbers grow again!
#543 oregami
oregami
  • 90 posts
  • Interests:sailing
Posted 17 November 2012 - 01:08 AM
I hadn't heard that....
Thanks for putting the word out Slapper.....
Sounds like good racing in Brisvegas
Unfortunately they hit the T7's (eg The Fifth 7 went from .810 to .815) and 750's in the Perth fleet so it will still be hard for them.....we need to encourage these current owners, to build the SMS fleet
#544 GybeSet®
GybeSet®
  • 19,978 posts
Posted 17 November 2012 - 01:19 AM
Info we received
is Shaw Thing* representative of the production Shaw, and Octopussy a bit maxxed out then ?
(rates less than the much heavier cruising vers.of the Leech )
Looking at their philosophy did the 1st gen. SBs ( Es & Ys) hold, like the M did
#545 noosa special
noosa special
  • 45 posts
Posted 17 November 2012 - 03:40 AM
To clarify have cut 1/2 of square top off Slingshot main with other mods. Will try tomorrow unfortunately at Noosa. More work may be done before next RQ SB SAT and re rating. Some interesting comments since my last post.
#546 oregami
oregami
  • 90 posts
  • Interests:sailing
Posted 17 November 2012 - 02:48 PM
Shaw 650, Octopussy probably went up the most (0.017), because of a change of owners and philosophy...change from smaller sail area to larger sail area so a large change in rating.
Octopussy has probably just moved more towards a standard Shaw setup and rating (.823 - .827), although at the lower range.
Shaw 650, Shaw Thing (who co owned Octopussy) stuck with smaller sail area, so kept the lower rating. (now .800)
The E 7"s seemed to go down roughly .007-8
The Young 7.8 stays about the same
Vivace goes up .006
Shaw 650’s go up about .008
Raptor goes up .009
Kiss goes up .012
Shit…the Viper 640 goes up .013 … as far as I can see, the largest change in rating...?????
Gotta love one design…
#547 noosa special
noosa special
  • 45 posts
Posted 17 November 2012 - 09:08 PM
Vivace goes up .006
Raptor goes up .009
Kiss goes up .012
Leech 650TS up .021 with no changes.
Leech 650 up .020. "
Square Tops Gotta go !!!
#548 oomummado
oomummado
  • 107 posts
Posted 17 November 2012 - 11:06 PM
Cutting half your mainsail roach off seems a knee jerk reaction. How much slower are you going to be with that? Rate low go slow. You can't just cut roach off. Rookie error. You will need a whole new mainsail to be effective otherwise you will keep on going around in circles blaming your equipment for lack of performance..... An old guy once said.... A poor workman .......
#549 oregami
oregami
  • 90 posts
  • Interests:sailing
Posted 18 November 2012 - 12:34 AM
Ouch, that increase hurts and then hurts some more.....
It must be a couple of things they've hit (weight and square tops) seeing we don't have a square top main.
#550 GybeSet®
GybeSet®
  • 19,978 posts
Posted 18 November 2012 - 02:25 AM
Noosa, do a trial cert fer goodness sake!
there are more factors than just roach going on here
e.g. The Vipes did not have a SqrTop
#551 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 18 November 2012 - 03:42 AM
The shaws and leeches and the rest of the light boats had an advantage and hence have been pulled back a little in sms numbers, still only seconds per race! Chopping sails down on the small rigged leeches and shaws will kill them even more in the light conditions where they have there work cut out anyway, and in breese can still win easily with the big sails as the pair in Brisbane show! It worked on the T7 cause our sails are so big anyway. As for.the viper, results we have seen say they win as they are now, or do they not race true sms regulations yet?
#552 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 18 November 2012 - 03:48 AM
Yeah, sounds like you are getting way too dramatic. Get your boat up to pace and finishing with boats it should be consistently before you go chopping and changing!
#553 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 18 November 2012 - 03:54 AM
exactly, noosa boat isn't far off, but being heavier and less mainsail would kill it in under 12 knots! Heavier older designs still need a bit more grace before I think they will come back, but its getting closer, some of the extreem end boats, at both ends are the ones needed to be looked at im thinking! The middle of the fleet is good close racing at times, with only a couple of adnormallitys!
#554 Hobbs
Hobbs
  • 155 posts
Posted 18 November 2012 - 04:38 AM
I keep looking at all the SMS rubbish and just keep wondering what is going on! From the racing I have done there is some very good close racing and some results that are out of place. There are some very good boats and sailors going around so it is unrealistic to think you can just show up and get a win. You have get the boat working well, sail well and not make any mistakes around the course to win and even then it will be close.
Some people seem to focus only on the rating and forget that the most important things is to get the boat going fast as often as possible and then you can beat your rating with good sailing.
Sling Shot is a great example. It is not far off the pace as it is. Given the modifications from the 'standard' Leech I think they are doing a great job and catching up to the fleet quickly. This is only a new boat for a 'one off' set up that is different to what the owner has had previously so it will take some getting used to! Any modification will lead to a new rating but that will not change the game. Sailing the boat more and getting used to what makes it work in different conditions will get you sailing closer to the rating, regardless of what the rating is!
#555 GybeSet®
GybeSet®
  • 19,978 posts
Posted 18 November 2012 - 04:42 AM
Old shipwrights rule
measure thrice, cut once
in this case 'consider' thrice ?
#556 Hobbs
Hobbs
  • 155 posts
Posted 18 November 2012 - 04:50 AM
In regards to the 'extreme' boats, I think that the rules as they are need to be more strictly enforced along with clarifying the self righting rule and have random testing of the rules as events. I have seen extreme boats in all sort of trouble in racing conditions that we regularly experience and that should never be the case!
The extreme boats will put people off racing sports boats.
The first race of the RQYS Sports Boat Saturday Series is a great example. Raptor beat Peow by almost 2 mins on corrected time. Raptor was late to start and went the wrong way up the first work. Peow had a blinder of a race and beat Stay Tuned by about 2 mins as well. The rest of the fleet (including Sling Shot) were all within 1 minute on corrected time! There were some good sailor on Raptor that day but to say they were 4 mins better than the fleet after missing the start is ridiculous!
In the next race the rest of the fleet (which include some very experienced and successful sailors too!) got around the course in a building breeze while Raptor hooked the inner top mark on the way upwind and could not get unstuck. It looked downright dangerous while they were trying to get unstuck and in the end they had to pull out of the race after send a crew member over board to get loose.
The boat is so 'extreme' it could be considered dangerous in anything other then benign conditions! There is no way the ASBA should have rules that allow for such a boat being so far removed from the rest of the fleet!
#557 Frank
Frank
  • 130 posts
Posted 18 November 2012 - 07:03 AM
What makes the boat so extreme as compared to sports 8??? cause you can't beat it
#558 noosa special
noosa special
  • 45 posts
Posted 18 November 2012 - 08:38 AM
Wow we have some interesting comment going on here which I seem to have started. About time this forum had some spunk. Seems most people know more about the Noosa Boat than me which could be true, anyway all comment can only add to my ability.
So lets go back to the start post Bay 2 Bay which was a down hill run.
This is extremely difficult as I have the greatest respect for Grahame( Evolution Sails) and consider him a great guy and friend, I hope you guys are adult enough to understand my problems. If I lived in Bris or Gold Coast would be great to work with Grahame. He has taken the leech in a very short time to the front. I have no doubt it will not be long before he is the boat to beat ,he has the ability and resources to do so. he is the man to see for you guys down that way when you get boats finished. I am just too far away. We made our sail as developmental ones, not conventional, and knew would not be a instant suit.
We both had identical sails, my 1st trip to Gold Coast for tests had my boat slightly faster upwind, ( the sails were purposely designed flat) Next trip to GC we put in a lot of work, changed to full lower battens, Later a re cut luff, the boats were not competitive. Grahame did 2 regattas and turned up at Race week with new radial cut Jib and main. He had made a big improvement which he has worked on to be up the front now. My big problem is it is a 500k trip to GC and can not expect Grahame to come up here , which he offered, also we can not sail in Noosa River with board fully down and wind disturbed by buildings and trees. So development has been difficult.
So re rating may be good, but the re cut main was about performance not numbers. I was surprised when we hoisted altered main to find it is a pinhead. No more full lower battens which Had the draft too far aft. The Square top which was a flag with draft against mast is thankfully gone but sail has lots more power which is easily flattened as wind increases.,
It is hard to tell with the board up in our creek but for the 1st time we had a main that looked it would work and powerfull, we have some very good Blazer sailors here and for 1st time we were much faster up wind close hauled than them, we need to make a few adjustments as mast too straight trying to get some shape in old main but i believe we have turned the corner. the extra 100kg in our boat is no excuse for not being competitive on a beat.
#559 MSA
MSA
  • 693 posts
Posted 18 November 2012 - 09:01 AM
Full battens in the lower 1/3 mask luff curve issues.
So you cut the sail down and now it sheets on and you can sail up wind... Seen that happen many a time.
Sounds too me the large main was to much load for the rig... Maybe increasing tube stiffness as well.
One of the Shaw 650's had the same issue here with an Evo main.. Same thing, was converted to full battens and had a luff recut.. Next mainsail had a smaller head width.
#560 Hobbs
Hobbs
  • 155 posts
Posted 18 November 2012 - 10:34 AM
Note: I abbreviated my comments above so not everyone has to keep reading them.
Frank, I used the term 'Extreme' as I believe Raptor has been designed specially to one edge of the available rules and taken this aspect to the limit. This being the weight. Extreme is not an insult. It is a description. In this case, Raptor has be purposefully designed to get a rating advantage. There is nothing wrong with this and a good rule needs to evolve in these situations to ensure the fleet remains relevant. If you go to far with this you end up with a boat that may not handle all of the conditions that we race in. Sailing is littered with stories of these types of boats.
There is nothing new in this and in many rules over time they have developed to such an extreme that the rule becomes useless and the owners and sailors move on to the next big thing. IOR and IMS are examples of this.
I would hope that the sports boats can steadily modify the rules that are in use to keep the fleet result close as they recently have so that all the boats remain relevant to the result. That is the way to keep people in the class and bring people in. At the moment, if a boat at one extreme of the rule dominates in certain conditions then that should be a concern to association and the rest of the fleet.
With regards to a result, it is not so much about winning/losing. It is more about the margin. No boat should be able to win in this type of rule unless they sail an extremely good race. Given how close the rest of the fleet results have been a poor set, a bad gybe, poor tactics or a missed start would cost you places. The rules should be able to evolve to take new boats into account and keep the current fleet from becoming obsolete due to just one boat.
BTW, Mark has contacted me and made some good points as well. He knows who I am and I am sure will have the chance to tell me what he thinks again.
#561 83TER
83TER
  • 218 posts
Posted 18 November 2012 - 10:36 AM
What a fucking pole smoker, riding a bull in the pro riding circuit is extreme and dangerous not a souped up skiff i bet you all the boys on raptor didnt think they were in danger (except for Mark maybe :D ) pull your head out of your ass Hobbs
#562 Hobbs
Hobbs
  • 155 posts
Posted 18 November 2012 - 11:17 AM
Noosa Special, I hope you don't take offence at my comment. I like what you are doing and I have been impressed with how much your boat has improved. I have been looking at different sports boats and I have discussed the Leech with Dan and several others. I had a good look at your boat under constructions and went to see Graham a couple of times during his build as well.
It is up to you how you develop your boat and I am sure you will have plenty of fun along the way.
#563 GybeSet®
GybeSet®
  • 19,978 posts
Posted 18 November 2012 - 12:52 PM
:lol:
looks like you guessed right !!
a bit 'o 'extreme' cock shaking goin' on now, if that what you predicted by 'spunk'
#564 TD Floater
TD Floater
  • 3,836 posts
Posted 19 November 2012 - 07:05 PM
Well left Hobbs, points to you.
#565 Broomstick
Broomstick
  • 38 posts
Posted 20 November 2012 - 02:52 AM
HAHAHA good call TD B)
#566 noosa special
noosa special
  • 45 posts
Posted 20 November 2012 - 10:43 PM
I think I am missing something here. Who was the SB upside down near the finish 1st day of St Helena Cup
#567 Turkey Slapper
Turkey Slapper
  • 5,743 posts
Posted 20 November 2012 - 10:54 PM
There were 2 that fell over that day, shorty the Eagan 6, which later lost its rig as well while getting towed and Raptor! The shorty looks all fixed and ready to sail again now!
#568 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 21 November 2012 - 12:18 AM
Shorty pulled the complete forestay chainplate out of the bow. Looks fixed now though.
#569 noosa special
noosa special
  • 45 posts
Posted 21 November 2012 - 03:37 AM
Thanks, now I understand the spirited comment.
#570 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 22 November 2012 - 11:54 AM
Got boat into the building after being away from the project for a while. Bagged down the chainplates as per Dan's instructions. the lines on the table were to get the uni running in the correct angle for each layer. whole process from start to finish when the bagged had pulled down was about an hour and three quarters. Foils will be undercoated this weekend and looking to have them glossed by next week, along with our mould to pour our bulb.
#571 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 22 November 2012 - 12:04 PM
#572 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 25 November 2012 - 07:33 AM
Got into the cabin a bit this weekend
#573 itkiwi
itkiwi
  • 57 posts
Posted 26 November 2012 - 12:02 AM
Does anyone have a link for some non-skid sheeting for a cockpit sole. Treadmaster I have found on the web but it is 2kg per square meter. There must be a lighter product out there. I would rather not use one of the paint systems.
Thanks
#574 Sandgroper Yachting
Sandgroper Yachting
  • 534 posts
Posted 26 November 2012 - 01:14 AM
Thanks
We have this: http://www.noskiddin...m/ns_ns5200.htm
Its the same stuff that you see on most of the big racing boats.
#575 WCB
WCB
  • 1,542 posts
Posted 26 November 2012 - 03:22 AM
Check out the Raptor deck...looks like cool stuff. http://www.raptorsails.com/
#576 noosa special
noosa special
  • 45 posts
Posted 26 November 2012 - 09:25 PM
Thanks
We used glass beads and 2pack on Slingshot, Looked great but proved slippery when wet. Have installed J P Bowers of Gold Coast EVA dogbone deck tread same as Stay Tuned. Dos not seem heavy. Still to use it in high winds.
#577 itkiwi
itkiwi
  • 57 posts
Posted 10 December 2012 - 08:06 AM
Some progress - off to the paint shop today I have spent the last 6 weeks sanding back the duropox undercoat. Horrible stuff - easy to sand but the fine dust goes everywhere.
Rig and sails are supposed to be here this week - I might beat Geary into the water yet.
Rob
#578 noosa special
noosa special
  • 45 posts
Posted 10 December 2012 - 08:47 AM
Brilliant stuff. To bring your boat to construction finish in the deep freeze of winter and spring there, with high tech materials is pretty special , I employed a very skilled boat builder here at noosa , rarely below 25deg as summer build, but was not easy. If you sail as well as your build skills a lot of fun is to be had. Well done.
#579 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 10 December 2012 - 09:20 AM
Where did you guys get your receiving tubes and prods from?
#580 itkiwi
itkiwi
  • 57 posts
Posted 10 December 2012 - 07:38 PM
The rig including prod came from Southern Spars. Currently all of this is on a truck somewhere between here and Auckland.
All the other tubes of various smaller sizes came from c-Tech. The bigger of the two receiving tubes is carbon but might well be made out of e-glass - to me it appears only there to keep the water out.
Thank you Noosa.
#581 noosa special
noosa special
  • 45 posts
Posted 14 December 2012 - 08:00 AM
Getting rid of the mains square top which did not work and making it a roachy pin head with half width and lower left the same and no other mods made to boat, has changed our SMS from 815 to 800. New rating issued today. I Gotta be smiling.
Looking forward to Sports boats SAT tomorrow at RQ
#582 Nrg85
Nrg85
  • 46 posts
Posted 20 December 2012 - 12:03 AM
Is there an option to build this boat without carbon fibre?
Only e-glass?
How much heavier would it have to be?
#583 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 20 December 2012 - 09:22 AM
anarchist "sporty" is building one from glass i believe. maybe he can shed some light on that for you?
#584 Sporty
Sporty
  • 21 posts
  • Interests:Racing
Posted 20 December 2012 - 09:26 AM
Only e-glass?
Mine is carbon hull e glass everywhere else, aproxamate weight to price is around 15kg extra in the hull for around $4000.00 saving, no brainier to me, just ask Dan Leech to draw up what you want, this was my brief for the build. Hope this helps
Cheers B)
#585 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 20 December 2012 - 10:16 AM
Got our bulb poured last weekend. not much has happened this week due to big hours at work but the christmas break should see a cabin top and a few other bits done.
#586 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 20 December 2012 - 10:21 AM
Poured it as one unit, with the mdf covered in glass acting as a plug for where the keel will insert. the two glass halves were bolted every 30-40 mm around the whole perimeter of the mould then put into a sand box to support it when the lead was poured into it.
#587 Berndty
Berndty
  • 29 posts
  • Interests:sailing
Posted 20 December 2012 - 10:57 AM
What is the weight of the bulb? If I can ask?
#588 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 20 December 2012 - 11:23 AM
110 according to the design. we didnt weigh ours as we didnt have anything to weigh it at the time
#589 Jethrow
Jethrow
  • 356 posts
Posted 20 December 2012 - 10:28 PM
Sorry for my ignorance but did you make a fibreglass mold then fill it with the molten lead? I'm not sure if I'm seeing it correctly. Do you use special resin that's heat resistant? I would have thought the resin would burn off but I've never done anything like this.
#590 fullsail
fullsail
  • 422 posts
Posted 20 December 2012 - 11:57 PM
Epoxy resins does not burn when melting lead.
#591 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 21 December 2012 - 12:07 AM
We used vinylester resin for the mould
#592 Jethrow
Jethrow
  • 356 posts
Posted 21 December 2012 - 12:16 AM
Cool, thanks guys, I'll file that away in my memory banks for later...
#593 itkiwi
itkiwi
  • 57 posts
Posted 21 December 2012 - 02:04 AM
My one came back from foundry at 134kg. A bit more than planned but was made wtb cnc cut plug
#594 Nrg85
Nrg85
  • 46 posts
Posted 21 December 2012 - 11:13 AM
Cheers B)
Thanx, I will contact him.
15 kg really isn't much extra weight, at least not for me and for that cost savings.
I assume that you put carbon just on the hull inside and outside and everywhere else e-glass.
#595 Nrg85
Nrg85
  • 46 posts
Posted 21 December 2012 - 11:28 AM
TTB so you did use fiberglass and resin for mould? Rowing fiberglass or chopped strand mat?
Similiar to Jethrow I also tought that the resin or fiberglass would burn off if pouring hot lead into it.
Any more info about that, would that work for bigger moulds for pouring lead as well? Maybe someone knows some useful page with some info about that.
#596 Sporty
Sporty
  • 21 posts
  • Interests:Racing
Posted 21 December 2012 - 11:50 AM
Cheers B)
Spot on! carbon in and out on the hull e-glass every ware else.
Cheers ;)
#597 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,747 posts
Posted 21 December 2012 - 12:50 PM
Chop strand mat shot from a gun with vinylester resin I believe!
#598 jonsailor
jonsailor
  • 1,175 posts
  • Interests:Sailing, design, hot babes
Posted 22 December 2012 - 01:02 AM
Vinylester resin is the only one that will cope with the heat. Epoxy will re-soften around 54 degress for the average one where viny is much higher. We just did a 2000kg bulb with hand laid choppy and vinny of about 10mm thick and into a concrete support box. Sand may have been alright, but we added a bit of HTFU stuff to be more resiliant. The stuff stinks with the first pour as it post cures but we did another one which was clean as!!
#599 crossa
crossa
  • 92 posts
Posted 22 December 2012 - 06:24 AM
we used casting plaster for the mould and layered fbreglass tape around the mould to retain shape when we split the mould to get it off the buck, them recoated in more casting plaster after we sat the stainless frame to attach to the foil, then we sat the whole thing in a box filled in sand, which we compacted well and then melted lead in a huge catapiller bulldozer sump above it and then poured it, had no distortion at all , easy as !!
#600 fullsail
fullsail
  • 422 posts
Posted 22 December 2012 - 01:33 PM
The set I had when I poured 800 pounds of lead. The mold was 3 layers of six ounces fiberglass in epoxy resin. Maybe the resin got soft, I do not know. But even the lead shrunk or the mold expanded, there was void between the mold and the lead. I cut the mold off, faired with car putty and recovered with glass.
