Leech 6.5
871 replies to this topic
#801 Raw Prawn
Raw Prawn
  • 21 posts
Posted 10 March 2014 - 10:21 AM
Good vid Stealth  :D
Ready for the rig now, getting fitted next week. Newly mounted outboard rack thanks to Michael James who makes these for the VX ONES. Works perfectly on the Tohatsu 3.5 If any one wants info on these send me a PM and i will pass on his number.
Cheers
#802 steveromagnino
steveromagnino
  • 2,489 posts
Posted 10 March 2014 - 12:09 PM
I thought the older timber shaws had some flex in them (forestay would sag a bit downwind, glass ones don't do it as they are stiffer), the Slingshot is really getting some serious bending going on to get the forestay that loose on a 6.5m boat with basically the same rig as a 650!
Looks really nice and fun blasting downwind for sure!
#803 Scottyk
Scottyk
  • 120 posts
Posted 11 March 2014 - 11:07 AM
Not sure about the woodie Shaw's not being stiff as the glass ones? Vinyl ester Vs Epoxy..Hmmmm?
Leech looks great, forestay tension would be a worry for me, much more rig tension needed, or a new boat if it flexes that much.
#804 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 11 March 2014 - 11:39 AM
Or pull the main sheet on and vang it harder.
#805 itkiwi
itkiwi
  • 70 posts
Posted 12 March 2014 - 12:36 AM
It would be a pity to damn the class because one boat is not set up properly.
http://forums.sailin...28719&p=4381419
Can you see any sag in this?
#806 Raw Prawn
Raw Prawn
  • 21 posts
Posted 12 March 2014 - 02:26 AM
Thanks! Not sure need to build up the funds again for the rigging. I already have the mast, boom etc off Dans plans (C-Tec) but need to fit the boat out and rig etc. If the rigger and the lead bulb dude get some free time early enough in the new year I might just make it but well see,CheersDamo
Damo,
How big is the bulb and when are you getting it made and what sort of dollars to get it made ?
Pulpit
Just received the Bulb back from Qualcast here in Burleigh Heads $770.00 inc GST Total I just supplied the plug. and aprox 1.0mt long
#807 Scottyk
Scottyk
  • 120 posts
Posted 12 March 2014 - 05:53 AM
yeah I doubt the boat is at fault in that video, more likely the rig set up.  A modern boat, built with modern materials just won't flex that much
#808 steveromagnino
steveromagnino
  • 2,489 posts
Posted 12 March 2014 - 12:33 PM
didn't comment on the woodies in general, rather the two older timber Shaw boats we knew of both of which originally had less structure in them (Pornstar and No Limits) which was also a little prone to damage in front of the main bulkhead (3mm ply), resulting in a slightly bendier boat as the ply would bow out to one side.
Back in the day, we could set the Pstar rig to run 300kg rig tension and still the forestay was looking like that downwind. I know the P8s also had a saggy forestay downhill.
In both cases, at a later stage the PStar and No Limits were refurbished and for Pstar it meant replacing the bulkhead running fwd (as all the structure inside was no longer doing its job) and had more structure put into them as per the original design, and that stiffened it up a lot; the glass boats have a pretty beefy X frame running aft and also forward of the main bulkhead with a very solid base under the mastbase, plus being a thicker foam section than 3mm ply in the stringers; that's where the stiffness around the maststep to chainplates comes from - it's not vinylester vs. epoxy or foam vs. cedar but rather amount of structure in there. Should be no reason why a timber boat is not as stiff (or stiffer) than a glass one for this type of boat.
Maybe my original post was a bit misleading; would assume that a bit more rig tension would hopefully make this issue disappear on the Leech also.
#809 Scottyk
Scottyk
  • 120 posts
Posted 12 March 2014 - 11:58 PM
Thanks for the explaination
I didn't quite follow Rob's plans in the front.  I put a much stronger stringer running along the centreline from the mast bulkhead forward to the first bulkhead.  I think 4mm ply that was specified was just a bit too prone to finding a way to flex in compression which is what forestay tension in doing.
#810 Raw Prawn
Raw Prawn
  • 21 posts
Posted 20 March 2014 - 04:26 AM
Just about there :D , rig to to be fitted within 10 days bulb and keel fitted next week and hopefully a launch on the weekend of the 5/6 April??????????
#811 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 21 March 2014 - 06:52 AM
Spot filling at the moment, one more high build coat and we should be read for the shiny paint.
#812 Raw Prawn
Raw Prawn
  • 21 posts
Posted 21 March 2014 - 08:02 AM
Keep it going guys but need to see more beers!!!!!!
#813 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 29 March 2014 - 02:48 AM
Hull is now ready for gloss. Glued the rig together the other day. Building the trailer frames this afternoon. Lots of little projects to do again. Trailer, rig and deck gear still to be done.
#814 rantifarian
rantifarian
  • 2,827 posts
Posted 29 March 2014 - 06:22 AM
She's getting close ttb, looking good
#815 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 05 April 2014 - 11:28 PM
Getting there now, flipped her back over and now time to do the deck and think about deck gear
#816 i550sailor
i550sailor
  • 281 posts
Posted 06 April 2014 - 03:11 AM
Looks great Andrew.
#817 kmcfast
kmcfast
  • 492 posts
Posted 09 April 2014 - 05:20 AM
Yo, Andrew, that bitch look fast. Good on ya.
#818 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 18 April 2014 - 08:35 AM
4 days off for Easter so trying to have the deck done by the end of it. High build on today, rubbing tomorrow.
#819 Raw Prawn
Raw Prawn
  • 21 posts
Posted 14 May 2014 - 02:23 AM
Finally "Raw Prawn" was launched last Saturday with only about 6 knots of breeze but that wasn't going to stop me after 2 years of building!!. I would like to thank the following people for their support and help through the build process.
  1. Dan Leech for the easy CNC kit plan set, phone and e-mail support. For the home builder this was fantastic and went together like a jigsaw puzzle. With my next build this will defiantly be the only way I would go after working on this build "Thank you Dan".
  2. Graham Sheering at Evolution Sails for the advise during and still on going with the rig and sail tune not to mention great sails.
  3. ATL Composites for the CNC kit and help with the build advise.
  4. And Last but not least is Peter Green Boat Builders for the help with the structural parts and the fairing/Painting of the hull.
Just a few pics of the launch, hope to have some racing in a blow next time
Cheers
Damo   :D
#820 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 14 May 2014 - 09:34 AM
Nice one Damo! Good to see it on the water... We will be out there soon enough!
#821 Raw Prawn
Raw Prawn
  • 21 posts
Posted 14 May 2014 - 10:21 AM
Thanks, looking forward to having you guys on the water to, do you have an E.T.A for yours?
#822 jim lee
jim lee
  • 951 posts
Posted 15 May 2014 - 12:19 AM
Congrats! Nothing like launching a boat you build yourself!
-jim lee
#823 83TER
83TER
  • 265 posts
Posted 15 May 2014 - 04:11 AM
Congrats Damo boat looks great. I hope you didn't get advice from Graham about how to sling up the boat for launching!!!
#824 itkiwi
itkiwi
  • 70 posts
Posted 15 May 2014 - 07:20 AM
Awesome - congratulations - I should have been this bold with the paint job. You will have so much fun. They are tough wee boats too. There is a keelboat here with a hole in the side slightly larger than the sprit. On his starboard side I might add.
Some traps are the way to make it go too - even if you are not allowed to use them in ASBA events.
Rob
#825 fullsail
fullsail
  • 437 posts
Posted 15 May 2014 - 11:24 AM
Congrats.
Nice job. Nice boat. Have wonderful time with her.
#826 Raw Prawn
Raw Prawn
  • 21 posts
Posted 16 May 2014 - 05:15 AM
Thanks for the kind words everyone.
Rob "I love the traps"!! wish we could use them here   :(
#827 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 16 May 2014 - 08:28 AM
We will be there soon enough damo ;-)
#828 i550sailor
i550sailor
  • 281 posts
Posted 04 July 2014 - 03:32 AM
How is the boat going?
#829 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 04 July 2014 - 03:50 AM
Getting there now. Rig is built, all deck gear has been drilled and cored and re drilled. Hopefully we might have a trailer this weekend and go into gloss the following week.
#830 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 04 July 2014 - 03:54 AM
Rig test fit
#831 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 06 July 2014 - 06:40 AM
Back to finishing off the rig and finishing off the rudder with a few other bits as well. Getting there now though!
#832 i550sailor
i550sailor
  • 281 posts
Posted 06 July 2014 - 05:49 PM
Thats awesome, it is really looking good,,, I may flip mine over today and start on the bottom.
#833 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 14 July 2014 - 09:34 AM
Trailer done done.
#834 Varan
Varan
  • 2,733 posts
Posted 17 July 2014 - 03:53 AM
Very nice!
#835 splat
splat
  • 241 posts
Posted 17 July 2014 - 07:37 AM
What's the max width on that trailer?
#836 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 17 July 2014 - 09:57 AM
2.4m trailer boat is 2.3m wide. Makes it easy to jump up onto the boat compared to the last boat and trailer combo which was a bit of the opposite
#837 Raw Prawn
Raw Prawn
  • 21 posts
Posted 31 July 2014 - 09:40 PM
A few shots of Rawprawn at her first regatta, sails great, easy to build Reconmend a Leech650 any day. Just need the boys from "Hellyeah" to come out and play!!  :D
#838 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 02 August 2014 - 08:05 AM
Hull is painted and buffed, flipped over yesterday to do thie deck tomorrow. Getting pretty fucking excited now I can tell you! Just in time for sailing season!
#839 fullsail
fullsail
  • 437 posts
Posted 02 August 2014 - 11:50 PM
Nice.
Congrats
#840 SCANAS
SCANAS
  • 3,817 posts
Posted 03 August 2014 - 12:08 PM
X 2
#841 Melbourne A31
Melbourne A31
  • 174 posts
Posted 04 August 2014 - 07:56 AM
Looks nice and fair. That's the reward for hours on the long boards.
#842 huey 2
huey 2
  • 980 posts
Posted 04 August 2014 - 04:28 PM
torture boards
#843 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 10 August 2014 - 08:04 AM
Nearly there now
#844 TBone
TBone
  • 714 posts
Posted 10 August 2014 - 08:30 AM
Awesome progress, TTB!
Looking good!
How's that OB arrangement work?
#845 SCANAS
SCANAS
  • 3,817 posts
Posted 11 August 2014 - 11:03 AM
Very nice!
#846 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 15 August 2014 - 10:38 PM
Looking good!
Just a folding set up. Get rid of the clamp off the outboard, bolt the arm(not pictured) to it, then bolt the other arm to the middle lugs . Just allows the outboard to be folded up into the boat to get it tucked away and weight closer to the centreline.
#847 noosa special
noosa special
  • 58 posts
Posted 05 September 2014 - 12:55 AM
It is a year now since last Airlie race week where we learned so much about the boat.. We felt the cabin was causing a rig dynamic problem not apparent on the flat decks as we could not match the J7 upwind over 10K. We moved the mast step aft which allowed us to get rid of some rake, back to where Dan advised,  reduced working sail area to just under 25M as we have a light crew of 270Kg.
  With help from Vaughan at Norths we tuned the mast which was a mess, difficult to stop the excessive pre bend we were using. Got rid of the adjustable caps, went for simple and put back to Dans original cap design.
  This was all good but were still not right upwind it had to be a crew problem. It is funny how unexpected help can occur and came in the form of Raw Prawn at Mooloolaba. The penny dropped when we saw the photos of our 2 boats together and Damian with a crew weight of over 400kg against our 270kg.
  It is hard to find photos of boats sailing upwind, There had to be some reason why the Audi Shaw is almost unbeatable, in 6M class, it is no different than the other Shaws, We found a few pics, it was obvious how superior they sailed their boat upwind in any pressure.
  We went to Airlie with a new outlook on how to sail the boat, we are quick in our Blazer23 but that style was wrong for Slingshot.
  We had no experience of skiff sailing, was all strange, we thought we would be low but didnt seem to be, we had no experience of this style of steering but adapted, we could now hike hard and make a difference, was brilliant, we now understood how Slingshot worked.
Dan designed Slingshot to be a complying CBH boat and did a fantastic job, It took me a year to understand just how good.
  Airlie was one of  the best regattas I have ever sailed, we sailed in Trailable fleet which had 10  8M class boats, We matched the boats up wind and had a whisker more height but all very even, the only place we could claw back some time for our higher handicap was with our very superior off wind pace.
The 6 days were SE20/33K  mostly 25/33K, We did not have a reef which would have helped. The boat reveled in the strong winds, the main only inverted in the strongest gusts, generally we used our fractional assey, and every day we had incredible rides. On the thursday off pioneer rocks in recorded 30/33K against the tide our 6th jibe didnt work spun down and took 5min before we were off again. with only a 90kg bulb the boat was safe, and puck had us doing 4K against the tide, this boat is fast it does 6K laying down going sideways.
 There was lots of pics posted from other boats of us sending it big time, was hard to get the grins off our faces.
  We were pushed into SMS earlier which was unfortunate, there is no allowance in SMS for the wind drag of the higher hull, cabin and space of cabin where the jib should be. Was great to race CBH we belong there and will never race SMS again except maybe Bay 2 Bay.
If you are not keen on the ASBA  W/Return form of racing, and want to race CBH with a spirited fun machine Dans the Man.
Hope to see the new boats at St Helena Cup be nice if it is SE 25/30K.
#848 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 08 September 2014 - 10:05 AM
Deck gear is on now, mast track is down so we can roll the boat on its side with the mast up so Ullman sails Brisbane can accurately measure prebend for the mainsail. A heap of small jobs to do to get her on the water, which is slightly painful but rushing isn't the way forward. Prodder bearings to still make and end plugs, rope systems to run, bulb onto the fin and get the flashy mag wheels onto the trailer! Amongst a heap more.
#849 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 13 September 2014 - 11:36 AM
Checked how the keel fits and the rudder. Got an accurate prebend measurement for our sail maker at Ullman sails brisbane and any other measurements he needed. Bulb has been fitted to the keel as well. Still a lot of little jobs to do, but hoping to make it to st Helena cup to race the other leech 650's :-)
#850 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 05 October 2014 - 10:33 AM
What a little weapon! First sail was our first race. Mild conditions 10-12knots all weekend. Saturday we finished in behind the two thompsons(7m&650) with a vxone in front and behind us. Sunday saw us being the first non-winged sportsboat to finish. Awesome kite ride from the top mark really showed us just how much potential this boat has. Dan has really designed a great little sporty for amateur construction and we are absolutely thrilled with how she performed straight off the trailer with no sailing time under our belts. Can't wait to rack up against the other l650's and see how we really perform. What a boat! Really stoked!
#851 fullsail
fullsail
  • 437 posts
Posted 05 October 2014 - 12:32 PM
Congratulations Tokyo.
#852 TOTALXS
TOTALXS
  • 488 posts
Posted 05 October 2014 - 12:50 PM
Looks great,  look forward to more reports.
#853 timber
timber
  • 1,150 posts
Posted 07 October 2014 - 05:22 AM
beautiful boat Tokyo. Have been following it all along.
#854 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 07 October 2014 - 09:37 AM
Thanks guys. So far so good, performed well above expectations for our first sail.
#855 jim lee
jim lee
  • 951 posts
Posted 09 October 2014 - 05:16 AM
Congrats!
-jim lee
#856 couchsurfer
couchsurfer
  • 18,365 posts
Posted 09 October 2014 - 04:12 PM
....I bet you'll miss dragging the stern corner around ,,and the self-steering 'V' bow,,,
.                  .....and being WL'd by -everything- upwind  :blink:  ;)
#857 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 09 October 2014 - 10:12 PM
Ah we still miss TTB! This boat has a much finer groove upwind, easy to fall out of it compared to the little box boat.
#858 couchsurfer
couchsurfer
  • 18,365 posts
Posted 09 October 2014 - 10:28 PM
....yah....I'll miss mine too!..........   http://forums.sailin...27#entry4696729
#859 noosa special
noosa special
  • 58 posts
Posted 10 October 2014 - 11:45 PM
Congrats to the DC Ethel crew, the boat was great last weekend straight out of the box. We were impressed with the good upwind pace and Robs ability to sail the boat flat, Skiff experience I expect. They will be on the pace when they meet the Gold Coast boats.
For Slingshot crew was a gift. Our lifting center board is nothing like the standard boats, being 50% longer front to rear edge and more than 50% wider and same fore aft width to within 600mm of bulb. I have never seen the standard board before till DCE as only seen Grahames boat in the water.  Our problem has been solved. We could not compare with the flat decks.as too different.
   Will hurt to have to cut our foil shaped cassette out and put in a box, the boat will never sail again in Noosa Creek, but will be getting a conventional SB foil. Was a mistake to make an all round boat.
  Moving the mast countered  the lack of lift from the CB and enabled us to sail in stronger pressure and get some helm, will be interesting  to find if this is a plus or has to be move to original position.
#860 noosa special
noosa special
  • 58 posts
Posted 13 October 2014 - 05:03 AM
I would like to clarify one point re the CB.  The boat was designed at my request to have a lifting board with a 150Kg Bulb to race CBH and have a large stability factor. The CB needed to be strong.  We have now fitted a 90KG bulb  so possible to use a much lighter one. The stability is still OK.
#861 SCANAS
SCANAS
  • 3,817 posts
Posted 14 October 2014 - 10:05 AM
Keep us posted about the mast position.
#862 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 27 December 2014 - 12:47 AM
Went out for a little play on Christmas Eve
#863 SCANAS
SCANAS
  • 3,817 posts
Posted 27 December 2014 - 12:56 AM
Bow looks nice & high.
How many crew will you race with?
#864 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 27 December 2014 - 11:13 AM
4 crew
#865 Alcatraz5768
Alcatraz5768
  • 1,958 posts
Posted 20 January 2015 - 07:36 AM
Are you running a square top jib?
#866 Tokyo Trash Baby
Tokyo Trash Baby
  • 1,896 posts
Posted 20 January 2015 - 07:53 AM
Only on our #2 jib. #1 has pin head
#867 rodlaser
rodlaser
  • 147 posts
Posted 28 January 2015 - 07:07 AM
Won't this change your current rating?
#868 MSA
MSA
  • 1,022 posts
Posted 26 February 2015 - 04:36 AM
http://www.asba.org....t-bob-mccamley/
RIP
#869 SCANAS
SCANAS
  • 3,817 posts
Posted 26 February 2015 - 05:25 AM
RIP
He spent a huge amount of time & energy on SLINGSHOT, I was looking forward to checking it out at the Pearl Challenge.
Fair Winds.
#870 GybeSetŪ
GybeSetŪ
  • 22,166 posts
Posted 26 February 2015 - 11:39 AM
RIP, a true enthusiast
#871 huey 2
huey 2
  • 980 posts
Posted 01 March 2015 - 02:15 AM
wow ,that comes as a shock     met him when he was looking over a racing ski boat but he spent more time
going into the sportsboat we had on the trailer   .. fair winds too yah Bob
#872 Bryce
Bryce
  • 500 posts
Posted 05 March 2015 - 01:10 AM
Believe Slingshot will still be at the Pearl Challenge. Bob, in spirit... Vale.
