Cruising Spares
#1
Posted 28 November 2011 - 07:04 PM
What I'm looking for is both feedback and suggestions, whether it's stuff that I've overlooked or stuff I shouldn't bother with.
Basic criteria, assuming that failure occurs in a remote anchorage a few days from port, or halfway through a major passage:
Priority 1:
Part failure leaves us immobilized or unable to maneuver in close quarters with no wind (e.g. engine failure)
Priority 2:
Consumables, spares & refills. I know we will used up/break this stuff so at least one, preferable two or more changes/replacements. Oil filters, etc.
Priority 3:
Merely inconvenient and/or if it breaks, but will not be life or boat endangering if things go awry. Somewhere around Priority 2.5 I suppose there are things like refrigeration, where losing a freezer load of food would suck if I can't fix it quickly, but won't kill us.
So on this list the entire generator really because a "nice to have" item, because I can do everything except run the A/C (which is a zero priority) with the engine, it just takes longer and uses more diesel. So genset parts - I'll keep consumables supplies on hand but not go nuts with backups except for a couple of items.
I know that in some cases I can slim down/get cheaper things such as getting only the starter solenoid (most likely thing to fail) or a raw water pump rebuild kit. But I know for example that in these cases that makes no sense - for example the solenoid costs about 80% of what a new starter does, and that the raw water pump rebuild kit requires a machine press; something I won't have access to unless I'm in a port. So for those things it makes more sense to just get the whole part so I can change it out quickly and not mess around trying to rebuild something while under way. Think "Fix it Right Now!" (engine failure halfway to Tortola) vs. "Tinker With it Later" (rebuild a shower sump pump or a head).
List:
Engine Spares:
- Starter
- Raw Water pump
- Fuel lift pump
- Oil pressure & engine temp senders
- Injector (1)
- Valves (one intake, one exhaust)
- Oil pump
- Thermostat
- the usual filters, gaskets, hoses, and belts
- 24V Alternator (I already own a spare)
- 12V Alternator
- A length of fuel line / suitable temporary line
- Spare voltage regulator (preferably one that can do 12V or 24V)
Generator Spares (depend on prices...)
- Raw water pump
- Fuel lift pump
- filters, gaskets, hoses & belts
The rest...well I suspect they'd knock the genset out but we can wait it out for parts on anything with that.
Other (non engine) things that might be a nuisance to come by or be needed under way:
- Wind generator blades
- LPG Regulator
- Spare pump for refrigeration
- Gaskets & seals, refrigerant for fridge compressors
- Sail Repair / patch / sewing kit
- Spare batten or two
- Bilge pump rebuild kits
- Other pump (water, shower sump, etc.) rebuild kits
- Head rebuild kits
- Things like the water maker have a pretty well defined parts & spares the manufacturer recommends.
- Spare rigging components, pins, shackles, etc.
So...what can we add or subtract here? I'm new to this, and as some of you have observed I have a tendency to buy more crap than I really need.
#2
Posted 28 November 2011 - 07:14 PM
Spare AP or vane spares. Particularly on a shorthanded passage, you don't want to find yourself hand steering 24X7. It builds character but you are already a character.
I would add a priority 1.5. Something whose loss would significantly degrade your passage or cause you to consider a divert to a closer destination. I would put self steering in some form on that list.
#3
Posted 28 November 2011 - 07:24 PM
#4
Posted 28 November 2011 - 08:08 PM
List:
Engine Spares: (the fact is for common engines, there are engine parts and good diesel guys almost everywhere today, and you can sail/cruise without an engine with some enjoyment)
- Starter (don't have - pretty reliable, unless yours in really old, in case just replace now)
- Raw Water pump (don't have but do carry impellers and o-rings)
- Fuel lift pump (yes have a spare)
- Oil pressure & engine temp senders (have because don't take any space but don;t really need. you can function perfectly fine without)
- Injector (1) (I carry 4, as I find it easier to change all rather than try to find which one is bad, and just take all 4 in to shop to have serviced occasionally)
- Valves (one intake, one exhaust) (don't have, pretty reliable)
- Oil pump (don't have pretty reliable)
- Thermostat (don;t have)
- the usual filters, gaskets, hoses, and belts (yes lots)
- 24V Alternator (I already own a spare) (don;'t have 24vt)
- 12V Alternator (I have two installed and running, so redundancy already there, plus the honda, so don't carry a 'spare')
- A length of fuel line / suitable temporary line (yes)
- Spare voltage regulator (preferably one that can do 12V or 24V) (You can actually rig a perfectly function one from a couple light bulbs!)
Zincs
Oil for 3 oil changes (plus transmission oil if different)
Generator Spares (depend on prices...) (don;t have)
- Raw water pump
- Fuel lift pump
- Wind generator blades yes
- LPG Regulator yes
- Spare pump for refrigeration don;t have
- Gaskets & seals, refrigerant for fridge compressors don't have
- Sail Repair / patch / sewing kit yes
- Spare batten or two yes - equal to size of longest
- Bilge pump rebuild kits yes
- Other pump (water, shower sump, etc.) rebuild kits yes
- Head rebuild kits yes
- Spare rigging components, pins, shackles, etc. yes
autopilot spares (ram at least, and oil if its hydraulic)
Spare gps antenna (can die in near lightening strike) plus handhelds
Outboard spares - at least spark plugs
spare batt car
spare halyard
spare deck switch and solenoid for windless
I have a bag of all sorts of plumbing bits - never know when you will need to cobble something together
spare vhf antenna and coax (really more 'emergency' equipment than spare)
big collection of screws and bolts
spool of 5mm spectra for lashing stuff
Probably a few things I have forgotten
#5
Posted 28 November 2011 - 09:25 PM
LPG stuff- add a solenoid, and a complete length of hose from tank to stove.
Running light fixtures, or at minimum spare lens for the bow (needed that at least once so far)
#6
Posted 28 November 2011 - 09:38 PM
A friend had to eventually abandon his Oyster 50 during horrible weather while on a short handed passage due to a chain of events that started with a broken mounting bracket on the 12v alternator.
#7
Posted 29 November 2011 - 01:58 AM
I think you'll get plenty of specific advice here on items so I won't focus on details.
First, I'd suggest you think about a somewhat different strategy. If you're "handy" with tools and have a work bench or at least a vice that you can use well, then you may want to take along various bits of raw material and the tools to make it into what you need. For example, a couple of sheets of gasket material can be cut to fit a wide variety of situations that would require that you haul around dozens of different gaskets for pumps, flanges, etc.... Similarly, a couple of 6' lengths of all-thread in different thicknesses can replace almost any broken or stripped bolt; the same it true of long lengths of hose and pipe. Further, the tools to build the part you need are often what you really need in far away places. Most of the 3rd world has raw metal, rubber, wood, etc... it just isn't in the shape of a particular part. Learn to make the parts, they you bring tools rather than spares for all but the most complex stuff.
Second, when I go "out there" for a long trip, I load up a small storage locker at home with all the spare parts that I will probably have to "wait on". Clearly, I take the safety stuff that one would need to keep afloat. But, rather than taking three or four rams for the autopilot I take one spare and when it is deployed due to a failure I sail-mail to a friend back home who launches the next spare to meet me at the next port of call. That way the boat isn't full of specialty stuff that could support multiple years of cruising. In addition, a lot of the various bits and pieces of boats (especially older boats) are hard to get so I find those and put them in the locker as I'm getting ready to cruise. Everything is labeled and stored on shelves. Then, the "friend" simply pulls the part and heads down to DHL or UPS or whomever is headed my way. Having depleted the locker the friend orders the replacement for the locker, information written on the shelf under the part that has been used, and it arrives at some point that is entirely independent of me sailing.
Mail service, even to Tonga, is faster than any "order" for a part I've ever seen. One is, obviously, putting a lot of money into spares that one might not ever need, but if you do need a head gasket kit for the Gen Set (for example) it can be shipped from SF to Tonga in about 4 days. That means that you might have that Gen Set up and running a couple of weeks earlier than if you have to hunt around via the interweb from Tonga for a part to be shipped from NZ or wherever. Most importantly, you know it's the right part because you checked it before you left to go cruising.
Just a thought.
BV
#8
Posted 29 November 2011 - 02:21 AM
The same trip we sucked up a bunch of crap into the raw water intake line. It may have been original and had to come off in pieces. Even if not all that crap would have been very difficult to remove. So some hose suitable to be used on the raw water system.
#9
Posted 29 November 2011 - 04:03 AM
Tools;
This book.
1 top quality hand palm, don't go cheap on this, get one like this.
1 tube mixed needles, like these.
A 8" pair of good scissors, keep them in wax paper.
2 sailmakers spikes/awls.
A block of PTFE.
Mallet with PTFE one side and rubber the other.
Selection of hollow and solid fids.
Gas fuelled mini hot knife
Tape measure
Consumables;
Spool of good waxed sailmakers hand thread.
10 of what ever slides you may have on your sails.
2 headboard slides.
1Mtr Headsail luff tape if you have that.
12 hanks of whatever type you have.
10Mtrs 1/2" tube webbing
10Mtrs 1" tube webbing
10Mtrs 2" seat belt webbing
1Mtr Kevlar PSA.
2Mtrs Dacron PSA.
20Mtrs 3" 8oz Dacron tape.
20Mtrs 3" Dacron PSA tape.
1/2Mtr Boiler Patch.
1/2Mtr of Sunbrella in your colour, but just one, not all colours you have!
Selection of SS rings of various sizes.
20 plastic rings around 3/4" in dia.
2 lengths of batten as long as the longest batten you have, would suggest OR2 profile or similar.
Spool of 2.5mm Dyneema.
That is off the top of my head from what I used to put together for clients. There may be other things of course depending on what sails and type you have.
Just remember that a great sail repair kit is warranted for you most used engine, don't scrimp.
#10
You're a pretty smart guy.BJ,
Just a thought.
BV
#11
Posted 29 November 2011 - 04:25 AM
BJ,
Just a thought.
BV
I think he's done this before.
#12
Posted 29 November 2011 - 05:00 AM
Mail service, even to Tonga, is faster than any "order" for a part I've ever seen. One is, obviously, putting a lot of money into spares that one might not ever need, but if you do need a head gasket kit for the Gen Set (for example) it can be shipped from SF to Tonga in about 4 days. ...
The mails have gotten pretty good but YMMV. They don't really go everywhere. Good luck getting anything from anywhere for any amount of money in 4 days to Niuatoputapu. And in some places that they do go they don't always have the kind of service we take for granted in the developed world. I'm skeptical that you can reliably get parts even to Neiafu from SF in four days. I once spent a month in Apia waiting on a part sent via DHL from New Zealand. According to DHL is was on the plane for the entire time... I spent a week in Rarotonga waiting on a part also sent by express courier service from New Zealand.
#13
Posted 29 November 2011 - 05:18 AM
OK, you have both 12v and 24v systems, plus a generator. What system does your AP run off? 12v I assume. How many ways do you have to charge the 12v system to keep the AP running if short handed during bad weather? Will the failure of just one component in these systems prevent you from charging the 12v batteries or is there some redundancy built in? Or does a very reliable wind vane make this irrelevant?
A/P is 24 Volt - all house and electronics are except the really finicky things unavailable in 12V like SSB / VHF. 24 House bank is 600 Ah.
I can charge 24V with the following methods:
- Engine alternator (75A...really yields around 45A at cruising RPMs)
- Genset alternator (less...25A?)
- Genset Generator via charger (two - one Victron Phoenix 3000 Watts and a backup Newmar ~45 Amp)
- Wind (Airmarine...200 Watts if it's blowing 20+)
- Solar (260 Watts of panels)
- Shore power via the above chargers in the highly unlikely event I am at a dock.
There are two Autopilots, when I am done with the installation they will be completely separate and unconnected. One is a new Furuno system that will be fully connected to the boat's electronics. The other is one of the older Raymarine systems on the boat now which will not talk to anything but itself except via NMEA 0183 over a Seatalk bridge.
With a second autopilot I'm less concerned about carrying say, a spare hydraulic ram (@ $2,300 ea) since I can cut over to the backup if I need to. We'd love to do a wind vane but it's not...practical...with our setup.
#14
Posted 29 November 2011 - 05:20 AM
List:
Zincs
- Raw water pump
- Fuel lift pump
- LPG Regulator yes
spare batt car
spare halyard
I'm working from the lists in your wife's Handbook for some of this as a starting point.
#15
Posted 29 November 2011 - 05:24 AM
BJ,
Just a thought.
BV
It's a good thought. It's a big boat, but space is finite. Enough oil for 3 oil changes of the engine = 9 gallons, just for example. Which takes a different sort of oil than the generator, BTW.
#16
Posted 29 November 2011 - 07:25 AM
First, if you're going to spend your first season in the East Caribbean, you have less to worry about. Between a few suppliers and FedEx you can get most anything fairly quickly.
Here are the big priorities:
1) Autopilot
Lose this and you've lost one of your best crew. You've got two so you should be good. Does that mean total redundancy with two heading sensors, two computers etc? Know what it takes to switch from one to another, and then do it just for practice. I've had to switch from one unit to another twice (change rams and rewire computer), once in fair conditions, once in shitty conditions. Fortunately the shitty conditions was the second time and I was better prepared. Better to practice when you pick the time, than when the time picks you.
2) GPS
Have a couple, and include a couple of hand helds; they're cheap.
3) Windlass
Not so much a "carry a spare item" as know how to maintain it and do it regularly. I always have my engine revved up to at least 1,500 - 2,000 when using the windlass. More volts means less current means a cooler and happier windlass. Then have a backup plan. If it dies, how will you hoist the hook? Should be a PITA with a cockpit winch and some configuration of lines but will get it back on board.
4) Water maker
If you (and your wife) have gotten used to using 20-30 gallons of water a day, losing your watermaker will put a real damper on your cruising. I found we used more filters in the Caribbean than in the Pacific. Even with a good water collection system (do you have one - I don't) cruising season is usually not rainy season in the tropics. Carry plenty of spare filters and know how to bypass all the various sensors in your water maker so it will keep running even when the electronics say "stop".
Other random thoughts:
** Unless you're really a diesel mechanic, you'll be able to find someone more capable than yourself almost anywhere in the world and having the parts just means less down time. Carrying everything is useful, but so is FedEx (never use UPS or DHL). In practice, diesel engines are pretty reliable. Change the oil as specified and keep salt water out of the places it's not supposed to be. I think the source of Estar's "3 oil changes" suggestion is that sometimes diesels get a salt water enema. I think his was off the coast of Brazil, but I saw it happen to a Farr 56 sitting at anchor in the Galapagos. I've also had oil containers chafe themselves enough to leak which is not pretty. Ideally you'd transfer the oil from the purchased container to a better container. In any case, be sure to carry a container or containers to hold the old oil.
** Carry 200' (or maybe 2x 100' depending on your max halyard) of 10mm spectra line (e.g., Warpspeed), 100' of 3/16 Amsteel and 100' of 5/16" yacht braid will probably allow you to solve 99% of your running rigging issues (assuming you have spare shackles, pins, etc.). I also use threads extracted from 1.75mm Samson Zing It for whipping. It's spectra and yellow; great for finding the ends of a line.
** I use kevlar sleeves for anti-chafe as needed. I got them from http://hsarmor.com/htm/chafeprice.htm but I'm sure there are other sources.
** The wind generator is not critical enough to carry any spares. I would upgrade your primary engine alternator (75a @ 24v) to 100-150a, or upgrade size AND add a second (more challenging mechanically). I have seen many boats paralyzed by the death of the genset. Don't be hostage to your genset, they are much less reliable than the main engine.
** Totally agree with Estar re: spare deck switches for any electric items with deck mounted switches (windlass, winches, thruster, etc.). If your windlass has a coiled cord remote switch, carry a spare.
** A really good set of tools, with a bunch of specialty tools like picks, punches, clamps, a really big crescent, a medium crescent, a small crescent, all those weird security bits (torx et al), a socket you know will fit your outboard plugs, split ring tool, etc. Nothing is more frustrating than not being able to get the damn thing apart to fix it.
** A bunch of cable ties. I like to Cobra ties which don't leave as big a sharp edge. Get medium and long. I use the instead of seizing wire, they last longer.
** Some rolls of Rescue tape, or some other brand of self amalgamating tape. Really useful for fixing all kinds of plumbing issues, air hoses, etc. Not good for anything involving chafe.
** Spare dinghy pump.
** A bundle of those oil absorber sheets and some very heavy plastic bags. I think WM sells a bundle of 100 sheets for about $10. I've stashed them all over the boat and I'm using them up. When you change the oil or fuel filters, where will you put them? Wrap them in the absorber sheets, then place in a heavy plastic bag (that won't melt when diesel hits it) and put it away until you reach a place where you can dispose of it properly.
** At least 6x 50' x 3/4" dock lines, 1x 100' and 1x 150'. I prefer Yale Brait to 3 strand. They're not always used for docking.
** Boye rigging knives never rust
** Consider an anchor light mounted lower on the boat. Dinghies zipping through anchorages don't look up 75', also makes it easier to find your own boat when you're coming back after tipping a few. I use one from Bebi Electronics which I just hang and connect to a deck 12v outlet. They consume essentially no power, are very bright, turn on/off automatically and are much more effective in an anchorage with more than 3-4 boats.
Then buy half of all the stuff you need because it will never fit on the boat!
Enjoy!
#18
Posted 29 November 2011 - 12:55 PM
An engine exhaust mixing elbow...
These can be quite expensive, I wouldn't want to have to locate one in a remote place, and you certainly don't want to pay Volvo's retail price for one... You might shop around this winter, try to locate one at a decent price...
On the other hand, a clogged/failed elbow usually can be repaired to a certain extent, if you can find a decent welder... Pack some JB Weld in any event, in case yours develops a pinhole leak, or similar...
I also carry a set of high pressure fuel lines from the injector pump to the injectors, and a spare set of glow plugs, and probably a few other items I'm forgetting at the moment...
Also, do you currently have an inline electric fuel pump installed in your fuel system? If not, definitely pick up a 12V pump that can be jury-rigged into the system in a pinch, one of those can sometimes be the cure for a LOT of diesel woes... (grin) When I first got started in the delivery business, back before Racors were common on recreational boats, I always packed a 12V pump in my kit bag...
Finally, in an engine room on a long cruise, you can never, EVER, have too large a supply of disposable diapers on board... (grin)
One more thing, you really want to research all the possible crossovers for spares and parts for your engine (Volvo, I presume) There may be suitable replacements that don't have to come out of one of those pricey Volvo boxes, my Perkins (Shibuhara block, the same as used on some Volvo series engines) is actually one of the world's most popular tractor/light duty engines, and uses a number of commonly-found components... A bit of research might save you some real money, in the long run...
#19
Posted 29 November 2011 - 01:17 PM
Seriously.......
#20
Posted 29 November 2011 - 01:23 PM
#21
Posted 29 November 2011 - 01:58 PM
Bulbs for running lights.
Spare simple windex.
Damage control items (ie. tarp for outside hull that you can slow ingress of H2O)Lord forbid .
Wooden bungs for every through hole (inc. rudder post,mabe a nerf football?)
Personal EPIRB's ?
Overboard locator?
#22
Posted 29 November 2011 - 02:24 PM
You've gotten a lot of advice here already, so I'll try to add a bit and confirm a bit.
1) Autopilot
2) GPS
3) Windlass
4) Water maker
Enjoy!
Good stuff. The Autopilots are completely discrete systems, separate drives, CPUs, compasses, etc. Cutting between them is as simple as throwing a switch.
#23
Posted 29 November 2011 - 03:00 PM
ah well, sometimes Beth and I have different opinions. I just asked her and the list in the book primarily came from a pro captain we know, where everything has to be perfect and run exactly to schedule but there is also an engineer on board - a somewhat different perspective/approach than I have on Hawk.. She did that because we simply don't have a lot of stuff on Hawk (like genset and fridge) and so don't know what sort of spares they need. On Hawk we are actually more along BV's lines and carry less spares and more tools and raw materials.
I have now carried Yanmar's 'blue water cruising spares kit' twice round the world and never used a single part from it - love my Yanmar's. My current approach has evolved. We carried more yanmar spares originally. Currently my approach is to carry relatively few spares but at the 10 year point (two years ago) to have all the main 'wear pieces' (starter, turbo, pumps, etc) preemptively taken apart and either replaced or rebuilt. As an aside, don't go overboard on rubber parts (like impellers). The rubber can get brittle over time. I had to throw out a bunch of unused impellers after carrying them for 10 years, I then used one and all the vanes broke off almost immediately.
Russ, is right about the 3 oil changes. It's in case you get water in the block. That seems to happen to offshore boats more often than anyone wants to publicly admit. Our experience was sort of funny and I guess telling on spares. We were crossing the doldrums and I had only one oil change on board - one change probably saves the engine but still is milky and I really didn't want to run the engine. While finishing up fussy with the engine I said to Beth "what we need right now is a ship to come over the horizon and drop us 20lts of new oil'. She looked out the hatch as said - 'Evans there is a ship right here'. We called them on the radio and they did drop us 20lts of oil. I did also learn that the best way to fix this problem is to pull the injectors and spin the engine, rather than what is recommended in Nigel's book (turning the crankshaft by hand and forcing the water out of the cylinders). You will use the oil sometime anyway, so unlike some 'spares' its not a waste of money, just stowage space. I agree again with Russ - get a nice strong container - we also had an oil jug break open and had a nicely lubbed bilge for a while
On autopilots - the only bit that has broken so far was the fluxgate compass - twice. But it sounds like you have two completely independent systems, with separate compasses, which is great. I thought about that approach but decided to keep my autopilot 'spares' in sealed boxes rather that installed and exposed to the elements. There are pros and cons and I am not sure which is the better way to go.
Forgive me if this is completely obvious, but on the big picture, you want to focus on reliability so you only have to carry consumables and not 'spares'. My 'repair' rule is to fix gear once (a decade) and make sure the installation is perfectly correct while doing it, and then if it breaks again I trash it (don't replace with same) and either reengineer/replace with a much more reliable system or just live without.
#24
Posted 29 November 2011 - 08:49 PM
#25
Posted 29 November 2011 - 08:53 PM
#26
Posted 29 November 2011 - 08:57 PM
Yeah, and it usually goes just after the autopilot has clapped out.
The autopilot kept working and could almost steer the boat in the conditions we encountered. Losing the compass light was still memorable. Would have been even more so without a helmbot.
#27
Posted 29 November 2011 - 09:08 PM
..and taping a flashlight to the compass lights it up but makes it point in funny directions.
#28
Posted 29 November 2011 - 10:48 PM
Speaking of compass failure, the light on your compass won't fail often, but when it does, it's memorable.
For this and many other reasons the head lamp has become one of my favorite bits of kit.
#29
Posted 30 November 2011 - 03:01 AM
#30
Posted 30 November 2011 - 04:29 AM
Once, when sailing home to San Francisco at night, we turned off the masthead tricolor and turned on the deck-level lights only to discover that the starboard (green) bow light was dead. There was heavy fog just off the water, and we were approaching the Gate, so I really didn't want to rely on the tricolor. A crew member had a green flashlight, which we taped to the bow. Problem solved.
I suppose that's why the old square-riggers used kerosene lights -- the LEDs kept burning out.
OK, fuel filters: Carry *lots*, not just a couple. If your tank has a slime population explosion you can go through a whole bunch of filters before you have a chance to clean it out.
#31
Posted 30 November 2011 - 05:17 AM
Got plenty of fishing spares ? Lures, trace, swivels, pliers, filleting knives, filleting glove ( just like Michael Jackson's )
Got plenty of rat and roach proof food containers ? You want ones with a gasket and lockable lid. Tropical roaches can eat through cardboard and cellophane no problem. They aren't as genteel as your New England types. Sooner or later you will learn how well rats can swim.
Got an nice long anchor chain snubber made up ?
Got plenty of dinghy repair stuff ?
Got a pair of handheld VHFs ? They make a pretty good walkie talkie system.
Got a grocery carrying system worked out ? I use a large backpack which can also hold a gerry can.
I'll probably think of more later.
#32
Posted 30 November 2011 - 07:21 AM
#33
Posted 01 December 2011 - 11:35 AM
#34
Posted 01 December 2011 - 05:57 PM
BV
#35
Posted 01 December 2011 - 06:27 PM
#36
Posted 01 December 2011 - 07:23 PM
I don't think I'll show my wife this thread after all...I don't think BJ was planning on spending that kind of money. Besides, if the first one breaks down, don't replace, rent...
#37
Posted 01 December 2011 - 09:54 PM
Starting a voyage with "You can be replaced by a bimbo" is probably not an auspicious beginning.
#38
Posted 01 December 2011 - 11:48 PM
#39
Posted 02 December 2011 - 12:30 AM
Boat Essential Tools & Repair Items
General Tools:
Wrenches – Assorted and sized for your vessels nuts and bolts
Flare Wrench’s – Very important for any fuel line work
Drills – 1 Corded and 1 Cordless
Wooden Plugs - One for each thru-hull & tethered to it
LED Head lamp & Flashlights
Hole Saw Kit
Screw Drivers – Assorted
Pick Set – Very Handy
Tap/Die Set – Sized accordingly
Heli-Coil repair kit
Hack Saw – With spare blades
Bolt/Wire Cutters – Big enough to cut rigging
Wire Cutters – Big enough to cut battery cable
Blow Torch – Mini butane type and one standard torch head
Socket Set - SAE and Metric
Pipe Wrenches
Pliers - Various sizes
Water Pump Pliers
Needle Nose Vise Grips - For clamping hoses off etc.
Files – Various
Drill Bits – Full Kit
Countersink - At least two sizes
Sandpaper
Dremel
Rigging Knife's
Calipers
Rigging:
Sewing Kit
Monel & SS Seizing Wire
Sail Repair Tape
1” Nylon Webbing
1" Spectra webbing
Sail Slugs – To fit mast track
Outhaul car
Pre-feder
Sailors Palm, Needles & whipping twine
Clevis Pins – Spares sized for our boat
Cotter Pins – Stainless various sizes
Grommets, Snaps & Twist Locks
Grommet punch and set
Loos Tension Gauge
Dodger fittings
Mechanical rigging fittings
Engine/Plumbing:
Water pump – Complete spare and rebuild kit
Plumbing Fittings – Assorted to match parts on vessel
Zincs – For heat exchanger
Solenoid – Spare
Fuel Pump -Spare
Fuel Line Hose – Min 6 feet all sizes on vessel
Hose barbs – male/male for splicing all hose sizes on vessel
Impellers – With spare gaskets.
Oil Filters
Oil – for engine 2 gal min
Air filter
Antifreeze - 2 gal
Fuel Filters – Primary and secondary
Fuel Filtering Funnel (Racor)
Hoses – Min 6 feet each size
Oil absorbing bilge pads (min 10)
Alternator Belts - 4
Thermostat & gaskets
Engine service & parts manuals
Mechanics Service Manual – For our engine
Hose Clamps – Stainless AWAB type various sizes
Electrical:Inverter – Spare at least 500 watts to power small tools
Electrical Connectors – Assorted marine grade various sizes
Multimeter – Clamp on AC/DC to measure amps, volts and resistance
Heat Shrink – Adhesive lined
Crimper – Ratcheting style for marine grade terminals
Zip Ties
Pyrometer
Hydrometer
Wire – Assorted gauges 12 feet min per size
Jumper Wires 10 ga- With alligator clips on each end
Wire Strippers
Light Bulbs – Spares for each socket on the boat
Wire Snake
Terminal strips
Misc electrical clamps
Fuses - spares for each on-board
Breakers - 1 each size
Misc:
Turkey baster
Stainless Steel Bar Stock
Aluminum Bar Stock
Stainless Steel Dodger Tubing – short length
Velcro – Regular and industrial grade
Grease – Water proof winch grease
PB Blaster (NOT WD-40;))
BoeShield
Lanocote
TFF Tef Gel
Silicone Caulk
Butyl Tape
Sika 295UV – Or equivalent
Wet Suit, Mask & Fins, hood
Hook Knife
UV Resistant Duct Tape
Stainless Steel - Screws, nuts, bolts, fender washers, nyloc nuts, etc.
Tape – Electrical plus green painters tapes
JB Weld – Or equivalent
Hose – 6 feet minimum for each size on vessel
C-Clamps
Label maker
Bosuns chair = 2
Spare boat hook = 2
R-134 and charger adapter for refrigeration system
Spare prop, nuts & key
Prop Puller
Emergency tiller
Spare anchors and rodes
Outboard motor fuel line with priming bulb
2 stroke oil
I know I missed a lot.....
A couple of the spare parts bins I carry. They make organizing easy..
#40
Posted 02 December 2011 - 03:47 AM
#41
Posted 02 December 2011 - 04:04 AM
Maine sail Dude, I AM IMPRESSED!! BV
And my friends wonder why I don't race my own boat........
#42
Posted 02 December 2011 - 07:10 AM
#43
Posted 02 December 2011 - 10:55 AM
Sheet of rubber or something to repair large, jagged holes in hull.
Oh yeah. A couple of ways to call for help.
#44
Posted 02 December 2011 - 11:38 AM
Bolt cutters or something to use to cut the rig the rest of the way off the boat, should that become necessary.
How to cut my rig away is another entire thread...seriously.
On the plus side it's decked stepped so it should just go over.
On the downside...
- Everything is fracking huge. The standing rigging is bigger around than my thumb. Bolt cutters...not an option except for maybe Superman.
- It's deck stepped so I won't have a stump left to jury rig
My rigger and I have discussed two options.
1) An insanely expensive hydraulic press cutter like the one she uses in her shop
2) A much less expensive cordless rotary cutter (e.g. Dewalt) with some cutting blades on it. All batteries to be fully recharged before we pull up the anchor...
#45
Posted 02 December 2011 - 12:19 PM
I keep a small sledgehammer and a punch to knock out clevis pins.
On the downside...
- It's deck stepped so I won't have a stump left to jury rig![]()
#46
Posted 02 December 2011 - 12:39 PM
I like kdh's approach. Attack parts that are supposed to come apart.
Trying to envision using a hydraulic cutter or an electric one in conditions that would topple a rig. I envision the hydraulic one bouncing off some part of me on the way overboard and the electric one seizing up after a dramatic display of sparks.
If we're going into extremely unlikely but really bad failures.... sometimes rudders don't stay attached to the post, or even the boat. Got some kind of drouge steering in mind?
#47
Posted 02 December 2011 - 01:57 PM
Turned it off and hand drove the rest of the trip. I spoke with Will at WH and will try a gyro next season. Odd.....maybe a near by lightning strike?
Do you know what caused your failures?
#48
Posted 02 December 2011 - 02:04 PM
#49
Posted 02 December 2011 - 02:54 PM
No, don't know. Pretty sure, not lightening, just some sort of internal breakdown/wear out.
The first time happened coastal, like yours and it was easy to swap in the spare at anchor. But the second happened at sea in the middle of the Tasman. I hooked up the spare and then the display told me I had to calibrate it before it would work - which required 'two 360 degree circles at slow speed in flat water'. There is not so much flat water in the middle of the Tasman and it would just not start working with a 'bumpy circle'. I called the techs on the iridium, and after some long pauses they figured out a work around, paid for the iridium right there as otherwise we would have had to hand steer.
#50
Posted 02 December 2011 - 09:40 PM
On the downside...
Except when you drive out the pin, the punch *becomes* the pin. (if it's under much tension)
DAMHIK ;-)
Mike
#51
Posted 03 December 2011 - 11:12 AM
On the downside...
#52
Posted 05 December 2011 - 08:03 PM
One thing those new to stowing parts on cruising vessel is numbering your lockers on the inside and then making a drawing of your boat with the numbered lockers on it. Then have a notebook that says what number locker parts are in. If you don't then in 5 months time you will start ripping through lockers looking for something you need and can't remember what locker you put it in. Seems like the more stuff you have you start putting it in every small nook and obscure locker and finding it means ripping apart your boat or even worse not remembering if you brought that one part you are looking for. The Mason had a total of 94 lockers on board some of them were 3 deep inside another locker, without the numbering system we would have never found half the stuff. The new boat has less stowage and that can be a blessing or a disaster depending on how overboard and paranoid I get for extra parts.
#53
Posted 13 June 2012 - 02:46 AM
Decided to give the cordless DeWalt cutting tool a try. Went with the 18V because I figured I'd have a need for other tools, and the 36v family was too limited selection and high in price. Results were impressive, I am pretty comfortable this will work.
Tests performed on a new battery, freshly 100% charged.
Cutting 5/8" Wire rigging took about 7 seconds to cut clean through. Minimal effort and force applied in this case. The battery could do about 7-8 cuts before it stopped. Not many, but you are doing a lot of damage fast. In theory I'd need to make 8 cuts to remove my rig - six lower shrouds and the stays. I will buy two more batteries and a second charger in the fall before we leave the US, figuring that we want to stagger their ages a bit. I think my standing rigging is a little larger than 5/8"; probably 12mm or the like.
Rod rigging - similar cutting speeds for what I think was 1/4" rod. I didn't pay it much attention since I don't have any rod, but it was not bothered or slowed bit.
I could also cut through 12mm high strength anchor chain in about 10-15 seconds. I didn't time it since I was working in an awkward position and wanted to get it done, but with a fresh blade it zipped through it.
Also with a 120 grit sand paper flap disc and some polishing pads I cleaned my prop up better in an hour than I did in a day with a wire wheels and a drill. I think I am becoming unnaturally attached to this tool.
#54
Posted 13 June 2012 - 03:51 AM
Spare engine control cables.
Dental tool selection.
Flex shaft 4 prong bolt retrievers in 2 locations.
Lotsa Kanberra gel and H2out. H2out/equiv dessicant in small salt shakers or mesh bags works well.
#55
Posted 14 June 2012 - 11:18 PM
The usual advice is carry a batten as long as your longest. However, on modern full battened sails that is going to have limited utility. The battens I have are different diameter to go with the different length. about 3/4" diameter solid pulltruded on the main lower, down to about 3/8 on the mizzen top batten. If I did carry a lower main batten it would be 3/4" by 24 feet - not real handy to have in the cabin (or even on deck). And it surely will not fit in more than half of the batt car receptacles.
I'm wondering if some short lengths of aluminum tube of the appropriate ID would be sufficient to repair them. What happens when a pulltruded batten breaks? Nice clean thing or 3 feet of shredded fiberglass?
#56
Posted 02 July 2012 - 01:57 AM
#57
Posted 02 July 2012 - 10:27 PM
Question for those (like Estar) that might have full battened mains: do you carry a spare batten or some sort of repair kit?
Could you carry 3 lengths of 3/8" and bind them together for the other battens? Still really long, but easier to handle.
#58
Posted 02 July 2012 - 10:48 PM
That's not a bad suggestion. I could pick a diameter and length that made sense, along with some tubes to connect them together to deal with the lower mainsail ones. I suppose the most likely to break are the mid to upper ones anyway....
#59
Posted 03 July 2012 - 12:13 AM
#60
Posted 03 July 2012 - 01:23 AM
Now I just purchased (at exhorbitant cost) a rebuild kit for my electric head. Now that's a survival item. If I had the money, I'd replace the damn thing with a Wilcox Crittenden Skipper or British Lavac. But I don't at the moment, and the admiral likes the electric head.
IMHO you have to distinguish between tools and spares. Tools aren't spares. One tool I wouldn't be without is my dremel. Another is the vacuum cleaner.
#61
Posted 03 July 2012 - 01:29 AM
Store the spare battens in the boom...should be plenty of room and long enough.
Excellent but careful on this one. I recently lost a brand new 8' pigstay stored in the boom. We were caught in a nasty 30-minute squall that shook the boom pretty violently until we got the reefs in. Damn thing vibrated out into the Sound. Dumb me. Trick is to secure it but not so that it interferes with internal outhaul and reefing lines. Sure isn't anywhere else to store it though.
#62
Posted 03 July 2012 - 01:53 PM
Make your sail maker reimburse you for the extra spare battens you'll have to carry; surely it was their idea in the first place, no? The performance benefits of different size battens don't really pay off for a cruising boat - and the drama of having to deal with the spares problems are a really serious consideration, especially with a rig like yours. I'd bet you can't source that materially anywhere but Antigua in the whole Caribean and anywhere but Papeete in all of the South Pacific.
#63
Posted 03 July 2012 - 03:10 PM
I couldn't find good batten stock in Papeete last time I was there.DDW,
#64
Posted 03 July 2012 - 03:12 PM
I couldn't find good batten stock inpapeete last time I was there .DDW,
#65
Posted 03 July 2012 - 11:26 PM
Yup... A little stick n rip goes a long way...
#66
Posted 04 July 2012 - 08:56 PM
Boom is full of reefing gear (shuttle cars and blocks, etc.) - that's where I put 'em when I unbend the sail though. I'd worry about something getting tangled...if there were access to fasten it down maybe...
Not a survival item, but on a square head sail (depending on the batten) it will make the sail unusable. No mainsail on my boat means not much sail at all.Why spare battens? That's not a survival item. If a batten breaks, so what?
Well that's water under the bridge, however I am not sure you could rely on a 3/8"dia batten 24' long, and you surely wouldn't want a 3/4" dia batten at the top of the mizzen, hence the different sizes.DDW,
#67
Posted 05 July 2012 - 12:12 AM
I thought about a Wilcox Crittenden Skipper instead of my Vacuflush when I built. Then I realized all that salt water I would be pumping through with my industrial strength toilet would be going into a holding tank rather than outside the boat. The salt water is worse than than the piss and crap.Now I just purchased (at exhorbitant cost) a rebuild kit for my electric head. Now that's a survival item. If I had the money, I'd replace the damn thing with a Wilcox Crittenden Skipper or British Lavac. But I don't at the moment, and the admiral likes the electric head.
Plus Hinckley said the castings on the WC had been not well done recently.
#68
Posted 05 July 2012 - 01:34 AM
My head (a Sealand Vacuflush) was just rebuilt but I don't trust it. I want something foolproof. Plus, the pump and vacuum tank for the Vacuflush take up too much space.
#69
Posted 05 July 2012 - 01:50 AM
Youi can set up the Wilcox Crittenden or Lavac to use fresh water if you want.
How about a nice seat hanging off the stern?
When you're anchored for a month, what else do you do? I guess a composting toilet would be the only environmentally friendly alternative.
#70
Posted 05 July 2012 - 03:15 AM
#71
Posted 05 July 2012 - 12:12 PM
My general feeling is that a dinghy can be good at one of these three things: sailing, powering, paddle/rowing. Making a boat good at two of them is going to be a challenge and three is even harder.
But I do WANT something that is good at all three and always love to see a new take on it. While not great, that little thing appears to me to be a passable powerboat, a fun little sailboat, and an OK tandem kayak. Tandem kayaks have a tendency to be at least 16 feet long, making any but a foldable a real hassle on a cruising boat.
Pretty clever!
#72
Posted 05 July 2012 - 12:56 PM
Spare dinghy?
Pretty clever!
You forgot requirement #4 - Schlepping.
That looks cool, and fun. I can't imagine any of those modes where I'd want to carry ten bags of groceries and a case of beer on it.
We're thrilled with our Portland Pudgy still.
#73
Posted 05 July 2012 - 03:01 PM
Spare dinghy?
http://youtu.be/ihM6XQemtBY
Pretty clever!
Reports from the NW School of Wooden Boatbuilding are that the nester by Russell Brown rows and sails very well. I don't know about motoring . I haven't heard of anyone putting a Honda 2HP on one yet.
http://www.ptwatercr...craft/PT11.html
Posted 05 July 2012 - 04:27 PM
I've never had a motor, the noise isolates people as they buzz around the harbor talking over the motor. Everyone can hear them, but they can't hear anyone. Takes away all the "beautiful day, [insert question about boat here]" as you are out and about rowing or sailing.
#75
Posted 05 July 2012 - 04:44 PM
Here's my dink, in sailing mode. Sailing or rowing is a delight and she'll schlep me, the dog, groceries and the beer.
Posted 05 July 2012 - 05:06 PM
Some nice videos of it available too. Does look good. Pretty easy to join up/take down
#77
Posted 05 July 2012 - 05:11 PM
I'm using the sailing rig for my Dyer a lot more than I thought I would. It makes for a fun way to explore an anchorage and it beats rowing to get ashore.
And if I had unlimited storage room and not far to go, I'd have one of those too. Running a 10-mile round trip for groceries and milk in Desolation Sound would take about 6 weeks in one, so I'll stick with the kayak for short haul and the Zodiac with motor for longer trips.
#78
Posted 05 July 2012 - 05:30 PM
i) 6 weeks? are you rowing one-handed?
ii) sheesh, this generation has gone all soft-- why back when I was a boy, I used to row 10 miles one-way just to go to school. Carried a baked potato in the winter to warm up my hands....
iii) anchor closer to the store?
#79
Posted 05 July 2012 - 06:47 PM
Presumably that 10-mile row was uphill both ways? You're lucky, you got to go to school.
We used to live in a Cardboard Box in the middle of the street.....oooooh we could only dream of a cardboard box............I used to have to get up in the morning half an hour before I went to bed, work 29 hours down at Mill and pay Mill owner for the privilege.........but if you tell that to the young people of today they won't believe a word of it.......
You're right, I am soft, but there's no way I'm rowing a Zodiac any further than I have to (15 feet), and I don't have room for a pulling boat. I always wanted to build a Bolger "Victoria" but haven't found the time yet.
Usually we take the mothership to the dock at either Squirrel Cove or Refuge Cove, the two stores in Desolation, but sometimes it's nice to stay on the hook and take the dinghy.
#80
Posted 05 July 2012 - 09:10 PM
Spare dinghy?
Pretty clever!
I did not entirely forget. It's only a passable powerboat because it looks to lack the capacity and speed that a powerboat should have. Meaning, it should plane with 4 adults and gear aboard. Oh, and still row and sail well. This might explain why I think it can't be designed.
#81
Posted 07 July 2012 - 09:27 PM
Well, after much deliberation and gnashing of teeth I just ordered a WC skipper (with rebuild kit). The British Lavac (salt water) on my previous boat didn't smell that much worse than the Vacuflush, and I have a pumpout service when I'm on my mooring.
If anyone wants to buy a recently rebuilt Sealand Vacuflush (new duckbuill valves, bellows, gaskets etc.) , complete with pump, vacuum tank and electrical stuff, PM me.
In any case, a rebuild kit for whatever head you have is an essential cruising spare. The "direct deposit" method (or even a chlorinating macerator) is illegal in too many cruising grounds.
#82
Posted 08 July 2012 - 01:23 PM
#83
Posted 08 July 2012 - 04:42 PM
How did you get hold of a Skipper ? I couldn't find one anywhere and wound up buying a Groco K.
A friend of a friend had one in stock in RI. It came with the rebuild kit too.
