Tiger Stability
#1
Posted 01 February 2012 - 03:08 AM
Just noted that our beloved FT has higher SI than a 40.7!!
Clew
#2
Posted 01 February 2012 - 08:30 PM
#3
Posted 02 February 2012 - 12:41 AM
Does a stability index of 126.7 mean that the Tiger can or should be retrofitted to do longer distance racing?
Yes!............................If weather be calm
#4
Posted 02 February 2012 - 02:29 AM
Interesting discussion on another thread about Chicago-Mac stability index requirements: http://forums.sailin...pic=130894&st=0
Clew
Yes, if you put a rig made of match sticks on the FT the stability index would increase but that does not mean the boat is safer...
#5
Posted 02 February 2012 - 04:44 AM
Maybe we need Bob to jump in with his wisdom here.
C
#6
Posted 03 February 2012 - 03:37 AM
I don't know.....if I read that list as it is published, it is saying that an FT in stock configuration is safer than a 40.7 in terms of stability.
C
As I understand it the stability rating is measured independent of the sailplan
the high aspect ratio of the sails on a tiger contribute to tippiness
as for safer hmmm... well not quite sure its a measure of safety, just as to how quick the boat will return from a knockdown - without sails being a factor
Or in other words the RM torque for a given angle of heel >45<90.
and having some experience with the handling of both the 40.7 and the ft10 the figures don't lie! The tiger will flick up faster if the sail factor is removed
Tigers are a actually a stiff boat in the true sense of the word but... (and admittedly its a biggie) they are very easily over powered. This is why people refer to them as tender
Anyone who's put a reef in on the tiger will know of the vast improvement in handling and overall stability when its blowing.
#7
Posted 03 February 2012 - 06:21 AM
what does that even mean? makes no sense
aaaaaand how much slower they become compared to other similar weight boats that hold their sail plan better. (stiffer in the true sense of the word)
#8
Posted 03 February 2012 - 08:35 AM
bye tiger
#9
Posted 03 February 2012 - 12:11 PM
what does that even mean? makes no senseAnyone who's put a reef in on the tiger will know of the vast improvement in handling and overall stability when its blowing.
1st question
stiffness//tenderness of a vessel (gumnuts to warships here) is about COG vs COB with beam as a factor
essentially its rm torque - this is where the terms comes from
so a log with a bump on it is tender and a blackfish fishing float is stiff
the proportional difference between a tigers COG and COB is greater than the 40.7 (my initial point) and many other boats
that is why it is stiff - this is the measure
the real world shows the tiger falls over more than other boats but this is not because of "tenderness" or "stiffness"
it's just cause the rig is high, the boom is long and there a big fucken roach up there. Its nothing to do with the hull/keel relatoinship (tenderness/stiffness)
2nd statement;
look up the SASC results mate
we do get beaten by lighter craft but we certainly don't get beaten by heavier - ever
#10
Posted 03 February 2012 - 12:26 PM
hi tiger
bye tiger
weren't we ahead of you when this was taken?
#11
Posted 03 February 2012 - 03:10 PM
hi tiger
bye tiger
What kind of boat were you on? Looks like he should have had a kite up and shaken the reef out. Hiking helps as well.
#12
Posted 03 February 2012 - 07:24 PM
hi tiger
bye tiger
love yer werk.....firstly that was taken after starting 3 mins late as there were issues with main track.....secondly you weren't even on the same leg at the finish. Too busy with stability checks. the phrase HJ came into play
#13
Posted 03 February 2012 - 07:28 PM
Y840....a shorter, stiffer, much older boat with all it's rag up.....tough leg to have a kite on (no one flew)....big variations in direction with wind speed going from 20 to 30kts and a lee shore.
#14
Posted 04 February 2012 - 01:52 AM
2nd statement;
can't get beaten when it's too windy for your own stability eh. lucky the scorer doesn't see it that way......this is only one result. how would it look if we'd actually started on time?? ...don't embarrass yourself by having me dredge up the light air ones. (who can forget you calling us above close hauled in the Audi) yer full of it kid...weren't in the mix at all that year. ever
#15
Posted 04 February 2012 - 04:30 AM
2nd statement;
i admire your attention to detail however, I sail on Tigger dummy
perhaps having a little peek at results from the last couple of years might be somewhat more enlightening
#16
Posted 04 February 2012 - 05:51 AM
2nd statement;
yes...you were obviously too skeered to come out that day. it was windy. you weren't the only one....dummy!
it wasn't me that thought they were in front when those pics were taken...you weren't even there....dummy!
I have watched...I have also sailed with you once (it will only be once as i don't like unpleasant surprises)....I do not appreciate some of the things you believed afterwards that you decided in your wisdom to espouse to other people. Want to check what happened after that?....dummy!!
You don't move automatically and need to be told by old fat arsed bastard average hacks when to.....dummy!
I don't think much of you as a sailor...more a giant haired blowhard who doesn't know what a tippy boat is while he stands rock solid in the middle of it. dummy!
a bloke who likes the sound of his own voice and making sure he is seen "because those guys hate me". (wtf???) more than learning how to sail...dummy!
are we clear? dummy!!
now get back to blowing hard about stability. something you clearly don't understand...dummy!!
#17
Posted 04 February 2012 - 06:22 AM
2nd statement;
methinks you need to get back on your meds mate or perhaps a sailing boat
I won't be further drawn into defending myself against your imagination
I'm happy to let my results speak for themselves
if you think you're so much better come out and race against me I'm sure there is no shortage of boats that would love to have such a sailing god on board
#18
Posted 04 February 2012 - 07:32 AM
it's not imagination Leon....you on the other hand are fully in love with yourself...delusional even
you have no results....see ya very soon kid
back to stability
#19
Posted 04 February 2012 - 01:33 PM
#20
Posted 04 February 2012 - 02:01 PM
back to stability
no outing and bring it down a notch.
