A-Cat in PHRF (or SMS?)
#1
Posted 16 February 2012 - 05:38 PM
Our club is doing our yearly check of our PHRF fleet breakdown, which is currently done not just by rating, but also taking into account displacement and other factors.
Here are our class splits from last year:
http://lcyc.info/racing/class
Our Spin A fleet is "furniture" cruiser racers, including big Beneteaus, J/122, some J/109s, up to the C&C 99.
Our Spin B fleet are lighter weight race boats, including Viper 640, Melges 20, J/80, J/92s, and several J/29s.
Our Spin C fleet are mostly cruiser or cruiser racer boats that are 120 and above in PHRF.
We also have two non-spin (Jib and Main) classes that split at about PHRF 171.
We have had two (now one) A-Cat racing, and last year it was in the JAM A fleet. It will be an odd fit in any fleet, but we want it racing!
Now I have been hoping to get enough sportboats for a sportboat fleet, but I'm not sure if we have enough, and I was thinking we could take the A-Cat with us. How does that sound?
In the meantime, I think the best fit would be with our Spin B fleet. Any thoughts?
Also, if we ever do get enough boats for a sportboat or "performance" fleet including the A-Cat, I would be tempted to try the SMS rating system instead of PHRF. I know SMS is about sportboats, but could we figure out an SMS rating for an A-Cat?
Thanks for you feedback! Maybe someday we will have a cat fleet, but not yet.
jason
#2
Posted 16 February 2012 - 06:30 PM
HI there,
jason
From USSailing
Portsmouth A Cat 64.5
http://offshore.ussailing.org/Portsmouth_Yardstick/Current_Tables/Multihull_Classes.htm
Portsmouth to PHRF
64.5=57
http://offshore.ussailing.org/Portsmouth_Yardstick/formulas/Table_v.htm
#3
Posted 16 February 2012 - 06:33 PM
From USSailing
Portsmouth to PHRF
64.5=57
Yup, we've got him at 57 for PHRF. Just trying to figure out the best fleet.
jason
#4
Posted 16 February 2012 - 09:53 PM
57 is waaaaaay too high. F'rinstance, PHRF for F-boats: F28R is 21; F25C is -15 (yes, NEGATIVE); F31-1D is -55
The Ports/PHRF conversion sort of works for monohulls but it's way out of line for multihulls. You'll have to see if you can find established PHRF numbers for multis and just make a good guess for the Acat. I'd suggest in the 20s, maybe even the teens.
btw, at this point, yes, Spin B looks the best fleet (sportboats)
#5
Posted 17 February 2012 - 02:03 AM
#6
Posted 17 February 2012 - 02:59 AM
Joe
#7
Posted 17 February 2012 - 04:28 AM
How odd, a spin boat with no headsail.
#8
Posted 18 February 2012 - 12:18 AM
#9
Posted 18 February 2012 - 08:50 PM
#10
Posted 19 February 2012 - 06:52 PM
The other issue in this is safety on the starting line with other boats. Do you see risks with an A-Cat on the line with aggressive sailors, when the A-Cat could lose momentum or go into irons and not be able to maneuver between bigger keelboats? This was one reason for being with the more mild JAM fleet last year.
Thanks,
jason
#11
Posted 21 February 2012 - 01:29 AM
#12
Posted 23 February 2012 - 02:14 PM
We had an A with curved boards race in this years hospice regatta at a -10 and even then he was rated to high. I think he should have been at a -30 or -40.
Joe
#13
Posted 23 February 2012 - 09:04 PM
I've raced a few mixed fleet events (one with a negative number handicap against a lot of PHRF and Portsmouth boats). My A has curved boards and a new flexy rig.
The reason the A cat beat the fleet by several minutes was a couple mile long beam reaches in 12 kts of wind. Until then, a rating near zero would have been reasonable. On a beam reach in 8 to 12 kts, an A with a skipper who can stay on the wire will be doing 1.5 x wind speed while the displacement boats sit.
The point that wind speed is a major factor ( up to 20 kts) is so spot on. Above the 20, the A cat will begin to back off again due to serious over power issues. And in winds under 8, the angles will be ugly even though the speeds will be high.
My advice is to pick your handicap based on skill and be willing to adjust it frequently until you get the buzz you like. Certainly don't take teh results seriously. You won't be proving anything!
Have fun,
Craig
#14
Posted 23 February 2012 - 09:09 PM
The A will die. And yes, they are quick and can get stuck in irons too easily.
The practical onus should be on the A skipper to keep his boat whole, but it depends on the other guys helping
#15
Posted 23 February 2012 - 09:39 PM
thor
#16
Posted 23 February 2012 - 09:55 PM
Thanks for all the great feedback! You can be assured that the A-Cat owner is part of the regatta committee and will be part of this discussion and choice.
Thanks,
jason
Most of the good A cat sailors (acutually modern beach cats in general) will just park on the line and then sheet in and go right before the gun. In a situation with lots of dissimilar boats though, might be wise to park somewhere else and then come in and start with clear air (away from all the slugs, even at the expense of not hitting the line at the right place and time). When you are around bigger slower boats, it's most important to keep your speed up and avoid sailing their race.
A bigger issue might be sailing downwind through the fleet that started in front of you, especially with big fleets on a confined race course. If I was the A cat, I'd want to be in the first fleet to start.
#17
Posted 24 February 2012 - 04:32 AM
"The A will die. And yes, they are quick and can get stuck in irons too easily".
Irons? What? Even if you blow a tack by sheeting out too much in a tack (don't do this), back it down in 3 seconds and ZIPPP you are out of there.
"The practical onus should be on the A skipper to keep his boat whole".
Truer words were never spoken.
#18
Posted 24 February 2012 - 06:37 PM
I hear you have to watch out for bridges, too."The practical onus should be on the A skipper to keep his boat whole".
#19
Posted 24 February 2012 - 11:12 PM
And Starboard tack boats!
