"Production Boats" That Bring It
195 replies to this topic
#101 smackdaddy
smackdaddy
  • 1,493 posts
Posted 22 February 2012 - 08:04 PM
An update from Michael from the Falklands. Apart from the sight-seeing, history, and seriously good food and booze, he assesses the damage...
We had arrived in the Falklands through a violent storm with sustained Force 10 and 11 winds and gusts into Force 12.
http://www.sailblogs...?xjMsgID=210679
Seems the tally was a broken bowl, a chipped candleholder, a foghorn speaker blown off the mast, a couple of small leaks from an overhead hatch during breaking waves, one torn grommet on their cockpit enclosure (which amazes me), and a bent pin on the windvane. Not bad.
#102 trenace
trenace
  • 2,282 posts
Posted 22 February 2012 - 08:06 PM
Chipped candleholder?
Well screw that! I demand more durability than this.
#103 smackdaddy
smackdaddy
  • 1,493 posts
Posted 22 February 2012 - 08:08 PM
The sad thing is that it was a Hinckley candleholder. Shameful.
#104 Ishmael
  • 6,787 posts
Posted 22 February 2012 - 08:15 PM
Probably one of the many Chinese knockoffs.
#105 Steam Flyer
  • 4,287 posts
Posted 22 February 2012 - 08:19 PM
I didn't know Hinckley made candles !!
#106 Joli
Joli
  • 2,447 posts
Posted 22 February 2012 - 11:47 PM
I was speaking to the yard this week about the rebuild they are doing on a.7, seems like its going well. Some surprises though. When the set the pan in the hull there were multiple locations where the pan and the hull were not close enough for both (hull and pan) to contact the glue, in essence the pan was floating. They found this with a boriscope. Another surprise was how easily they were able to pull out the glue "pucks, dollops?", they simply hooked them and gave a yank, they popped out buckets of them. Maybe the glue is stronger in tension but it seems to have little strength in shear.
Anyway, the took out gobs of furniture. For the gutter held pieces they jacked the deck up to remove them from the troughs. They have been re tabbing and have opened the pan in some areas to build a good bond to the hull.
#107 Jon Eisberg
Jon Eisberg
  • 5,384 posts
Posted 23 February 2012 - 03:33 AM
Looking over the many boat comparisons thus far, and having been in these discussions on various forums (usually as a thorn in the side) - the two most defining characteristics of a "good" boat versus a "bad" boat is "heavier" versus "lighter" construction. Obviously, it's hard to argue rationally against "heavier" if it means more safety in a storm - and more "comfort" in that storm. But let's take "comfort" out of it for a second - and just focus on the safety issue.
dude, seriously - you're trying way too hard, here... (grin)
Sorry, but if you think "comfort" and "safety" are somehow distinct and unrelated issues when taking a small boat out on a big ocean, well... you really need to a lot more sailing offshore, preferably in a wider assortment of boats...
"Seakindliness", for want of a better term, perhaps, is one of the most important characteristics in attempting to define a boat's suitability for bluewater sailing...Especially, with the sort of short-handed sailing the majority of cruisers do. Some boats simply "take care of their crews" better than others, and if you cannot accept that, or dismiss the value of that, well... then I don't know what else to say...
There are so many intangibles to such discussions, but I seriously doubt you have any real appreciation for the sort of Cascade Effect that even the most minor design or construction deficiencies common to so many of today's production boats can produce during the course of an arduous passage... Or how a prolonged and sustained exposure to such relative "discomfort" can so easily lead to fatigue, lassitude, poor morale, and ultimately the sort of frustration and/or exhaustion of the crew that can so easily result in poor decisions, or fatal mistakes being made...
The problem is that when some people see a cute comfortable cruiser, that you can race until "you retire," rated "safe" for offshore use they think they can go out into bad weather instead of avoiding it and being able to survive it once or twice.
Actually, the same logic could be applied to a Hinckswavaltesterly - perhaps even more so. All depends on the skipper...not the boat.
Again, that's a naive and overly simplistic point of view, IMHO...
Sometimes, it actually IS about the freakin' boat, dammit... (grin)
#108 jetboy
jetboy
  • 750 posts
Posted 23 February 2012 - 04:37 AM
Out of curiosity with this discussion; would any of you trust a one off, or ten off vehicle to drive across Africa over a factory built Land Cruiser? A one off airplane over a Boeing 737?
I think its not really arguable that higher volume production facilities can and in practically every field do build with greater precision than one-off vehicles. It is fair to say that there's a reason Land Cruiser is so popular in Africa while Land Rover or Jeep are not. Both come from high volume production lines. One better than the others. However, I don't think anyone would propose that a small volume vehicle mfg. could even attempt to build a vehicle or airplane to compete with even the least reliable of the factor models.
Would those of you that are "traditionalists" buy a production high volume blue water boat if there were enough sales volume to actually generate statistical relevant results that the high volume production boat was both half the cost and better built?
#109 smackdaddy
smackdaddy
  • 1,493 posts
Posted 23 February 2012 - 04:40 AM
"Seakindliness", for want of a better term, perhaps, is one of the most important characteristics in attempting to define a boat's suitability for bluewater sailing... Some boats simply "take care of their crews" better than others, and if you cannot accept that, or dismiss the value of that, well... then I don't know what else to say...
There are so many intangibles to such discussions, but I seriously doubt you have any real appreciation for the sort of Cascade Effect that even the most minor design or construction deficiencies common to so many of today's production boats can produce during the course of an arduous passage... Or how a prolonged and sustained exposure to such "discomfort" can so easily lead to fatigue, lassitude, poor morale, and ultimately the sort of frustration and/or exhaustion of the crew that can so easily result in poor decisions, or fatal mistakes being made...
Again, that's naive and overly simplistic point of view, IMHO...
Jeez - it took you long enough...you crusty bastard! Heh-heh.
Okay - so, first, granted - I'm a novice offshorerer. I've only got about 1000 miles via a couple of races in two very bluewater boats - in mellow conditions. And I know you've got about 26X that - in boats of ALL kinds - in conditions of ALL kinds - ALL over the world. You seriously have my respect for that. I mean it. I've got no "right" to question you.
But here's the deal...in spite of all that, and in spite of my comparative ignorance, I just don't yet fully believe you. Your perspective on things just doesn't quite add up. It seems limited - and a bit antiquated. Here's what I mean:
Comfort: I fully understand that comfort (sea-kindliness) is an invaluable component of safety. I fully understand the cascade effect. I've been involved in plenty of dangerous sports where this is a critical factor. But in this case I wanted to focus purely on the safety factor of the boat in terms of its construction because of the long-standing critique that Benehunterlinas are built too "lightly" to go blue. In other words, will these boats really fall apart in a storm (notice I'm not asking if they will last for 40 years and multiple F10s - different question altogether)? Or will they stay together and keep you, at least, "safe"? I think most would, perhaps grudgingly, admit that yes, they will likely hold together and keep you safe. At least the CE ratings assure us this is the case, though you might think they're naive too.
Even so, to your point of comfort, one of the reasons I'm having a hard time taking what you say at face value is the very clear evidence presented by Michael. Not only did this Hunter not disintegrate in F10/11/12 conditions in the Southern Freakin' Ocean, he and his lady sat below under their duvets and "enjoyed the storm" - watching the breaking waves wash over the deck! Yeah. And they had only a broken bowl and chipped candleholder to show for it. Isn't that seakindliness? Sure seems like it to me.
If I simply took your word as-is, that Hunter should have never been there in the first place. But it is. And it seems it is kind of a bad-ass. Personally, I think that's kind of cool. It definitely brings up some questions that might be worth asking...hence the thread.
Besides, "comfort" despite the algorithms, is definitely a relative term. Some people hate Bene Firsts or even Wallys because they "slam" and spill stuff (see PCP's epic "Interesting Boats" thread on SN) - others are more "comfortable" hauling ass and finishing off the keg at the bar while the non-slammers spend two more days out there in "comfort". Go figure.
The freakin' boat dammit: My point on that one is that if a naive, overly simplistic chump like me takes your advice at face value and buys that Hinckswavaltesterly, I figure, "Hey, I'm in a bullet proof boat. I can handle it." That's not the boat being stupid - that's the mook at the wheel. How many times have you seen this happen? I mean if it really is just about the boat - then no wonder the CG is busy. A great example is the guys that put their boat on the rocks while at anchor near the Horn - while Micheal was fluffing his duvet in the F11.
So, as I said - busted: I'm naive and simplistic. But I'm also inquisitive as hell. And I'm seeing evidence here and there that makes me question this whole blue-water mythology. I have a hunch that the used boat market is going to look very, very different in 10 years...when I finally graduate high school and save enough to get a boat. I just want to be informed and ready.
#110 savoir
savoir
  • 2,714 posts
Posted 23 February 2012 - 04:43 AM
" boriscope "?
Sounds like some kind of top secret cold war device.
Attached File  boris_gun.jpg   47.21K   1 downloads
#111 olaf hart
olaf hart
  • 2,239 posts
Posted 23 February 2012 - 04:52 AM
The same sort of thing as a Natashameter?
Not to be confused with a Horacescope.
#112 VALIS
VALIS
  • 1,447 posts
Posted 23 February 2012 - 07:21 AM
I think this is a misguided perspective. Boats can be be consistently produced in high volume, and if the process is well-controlled they will reliably perform according to their design. This has nothing to do with their suitability for a particular task. One high-volume production Toyota Camry will perform much like another, but this car would not be your first choice for off-roading in Africa.
#113 Tom Ray
  • 19,911 posts
Posted 23 February 2012 - 11:52 AM
...In most of these cases the design was adequate. It was not intended to be too light. But the build was simply crap. So, the first defining characteristic is process quality control.
Good help is hard to find. ;)
I have seen boat factories clear out at the end of the day. Wow. Was everything really ready to drop right at that moment?
Quality control can be very difficult for big pieces. The best mix depends on temperature and humidity and those things can change a lot during a layup. There are plastic magicians who can juggle all the variables and make things work, and there are less skilled people who screw up. Detecting some of those screw-ups would require destructive testing so it is not done, until it is done on the water by some owner.
#114 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 23 February 2012 - 12:59 PM
Airplanes and boats are very different than cars. I would and HAVE trusted "one-off" airplanes. It is quite possible to do a MUCH better job than the factory building an airplane. Also possible to do much worse of course :rolleyes:
Airplanes and boats are generally made in such small numbers that they never do employ the kind of automated robotic assembly lines that cars do. There are "one-off" boats around that are excellent and some that are not. If you pay a good designer (hmmm - where oh where could you find one around here) and get a good yard to build her as designed, you'll have a great boat that is likely way better than the average factory build - and way more expensive too. I actually have worked building boats and you have no idea what a difference it makes if the workers have sailed offshore and are thinking they might one day be out there on that very boat and someone who is just getting a paycheck and has no idea why they can't use welding cable or romex on a boat.
#115 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 23 February 2012 - 01:16 PM
You are getting this WAY backwards:
IMHO voyages end in disaster for these reasons, starting with the most common:
1 - The crew: It is NOT people thinking their boat is indestructible and ramming icebergs. (well OK that did happen once) It is people getting scared and NOT TRUSTING the boat anymore. This fear is VERY debilitating and leads to calling for the nearest ship to come save you. Back in the day, absent modern electronics, people eventually got over it or got into a liferaft never to be seen again. Now with a sat-phone and EPIRB on every boat, not so much. I once read about a disastrous voyage that went something like this:
"Things were bad enough and then solid green water came over the cockpit and we knew we had to abandon ship". WTF! :unsure: One memorable storm my boat spent so much time under solid green water you almost needed scuba gear to work on deck or steer. So what? Keep the hatches closed, pump the bilges, and don't forget to laugh at the helmsman getting half-drowned. We were having fun because we could go fast and we trusted the boat. You have no idea how corrosive it is to have the thought "this boat wasn't made for this, something is going to break any second" come to mind every time you come off a big wave. I would say stories of abandoned boats later found floating outnumber maniacs sailing the boats too hard 500:1.
2 - The death of 1,000 cuts: The head clogs up. The stove gimbal bracket comes loose. The running light switch is corroded. Water gets in the fuel tank. The port leaks water on your bunk. The latch for the locker lets loose and things fall out. The tack fitting backs out. On and on and on with enough of this and even if nothing is wrong but trivial annoyances, everyone wants off right now. Kind of leads back to #1.
3 - The boat actually suffers a major structural failure. Even for relatively shitty boats, this is rare.
NOTE: None of this applies to modern racing with paid crews pushing boats purpose-built to be as light as they can get away with very very hard. Totally different kettle of fish.
#116 sculpin
sculpin
  • 1,880 posts
Not all Pintos blew up when rear ended... doesn't make 'em safe!
#117 Innocent Bystander
Innocent Bystander
  • 5,109 posts
Posted 23 February 2012 - 01:44 PM
I agree with you completely with one exception. In a number of boats, from B-H-Cs to Swans, C&Cs, J's and IIRC Oysters, the spade rudder has failed, either through insufficient design allowables, undiscovered damage or poor repair after a grounding, or physical impact damage causing rudder loss. For many modern boats, loss of the rudder puts a big hole in the boat or leaves the boat difficult to control (or uncontrollable in the mind of the crew)and that leads to the "Mommy get me out of here call." While I love a spade rudder, I would consider replacing the rudder on any older boat I was planning to take offshore and probably consult with a noted designer and engineer to make sure the rudder and installation were as robust as possible.
For your number 2, I could not agree more. I witnessed 5 Bene Oceanus series boats from a flotilla abandoned in the Med during a Mistral after one skipper was injured and his crew declared a mayday. Conditions were such that our escort cruiser suffered a (IIRC) 48 degree roll and structural damage while conducting the search. The crew of each boat our helos found asked to be taken off even though there were no injuries or significant damage to the boats. The next day, we passed several of the boats lying ahull undamaged having seen themselves through the storm unhindered by their crews.
#118 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 23 February 2012 - 02:13 PM
+1 on the rudder. Mine was just about to go :o For my year C&C, they used a *steel* collar with a grub screw to hold the rudder in the boat. If it lets loose, the rudder just drops right out! I replaced it with a stainless steel split collar that clamps on tight AND added another split collar at the top bearing so now I have a much better and fail safe system. Both would have to let go now.
( C&C engineering is a mix of superb and "hey you hoser go to Ace Hardware and buy some shit will ya)
That reminds me: My emergency steering is quite good. Actually better than any boat I can think of offhand. I have used my emergency tiller to steer in the rain so I could stay under the dodger. If I wasn't dragging the wheel around it would be like the boat was designed to use a tiller. IMHO one thing that makes a good offshore boat is emergency steering that actually works.
#119 Estar
Estar
  • 3,804 posts
Posted 23 February 2012 - 02:39 PM
Smack, just by way of education, and not at all to take anything away from this voyage, but there are two VERY different types of Cape Horn storms - essentially storms to the west of the horn vs storms to the east. The storms to the west have massive and confused breaking waves, because they are open to the full fetch of the pacific and coming onto a shallow continental shelf and in a current forcing thru the Drake, while storms to the east even with very strong winds tend to be in relatively flat water because they are protected by the land mass of the Americas and don't have the same shelf and current situation. This Hunter storm was strongish winds but flattish waves - their tactic was lying ahull which you don't do if there are any significant waves. Essentially any vessel that kept the water out would have survived that particular storm.
The skipper was smart and experienced enough to know all this. And he treated it exactly right and did not panic and instead got some rest and some food. A less good or experienced skipper might well have panicked and called to get taken off or done something stupid and driven the boat underwater.
#120 smackdaddy
smackdaddy
  • 1,493 posts
Posted 23 February 2012 - 03:03 PM
1 - The crew:
Actually, kis, I agree with everything you said in your post...especially in light of this...
Smack, just by way of education, and not at all to take anything away from this voyage, but there are two VERY different types of Cape Horn storms...
I understand what you're saying Evans about the storm. And I TOTALLY agree with your last sentence. If a Benehunterlina is going to sail in the southern ocean - Michael is showing how it should be done. I have a ton of respect for the guy. The boat is secondary to that.
Thanks for the input fellas.
(PS - Now, c'mon you guys...aren't you even the slightest bit impressed by this damn Hunter?)
#121 Anomaly2
Anomaly2
  • 507 posts
Posted 23 February 2012 - 03:26 PM
Honestly Smack..... pay attention:
You f__k one goat..... Therefore, Hunter's suck.
Now get with the program and stop bothering us with "facts"....
(for the record, I'm impressed by the exploits of both "this" Hunter and "that" Albin Vega and their skippers)
#122 Hiracer
Hiracer
  • 1,467 posts
  • Interests:x
Posted 23 February 2012 - 05:14 PM
I think the issue here is one of priorities. Many have commented that the most important cog in the system is the captain and crew. Keeping them in good working order, if you will, is the highest priority. Focusing on the design and build quality of the boat fails to take this into account, unless one includes in design quality the idea of sea kindliness.
This is NOT to say the boat is not important too. It is only an observation that keeping the captain and crew fully functioning is THE highest priority for short-handed voyaging.
Once one views keeping the captain and crew in good working order as the highest order of business, then 'comfort' or sea kindliness becomes of paramount importance. To then turn around and attempt to review whether a boat's design and build is suitable for voyaging while pointedly ignoring sea kindliness is a backhanded way of negating the importance of captain and crew, a position at odds with the original premise.
Trying to figure out which boats don't fall apart in storms is valuable information, but it's only one data point in determining whether a boat makes for a suitable off-shore voyager, I think.
OTOH, I must admit I don't want to go to sea on a boat that has great sea kindliness but falls apart in its first, second, or tenth storm. Build quality is obviously high priority too, but not in a vacuum or to the exclusion of other priorities.
That a boat is nearly indestructible does not in itself make the boat suitable for voyaging any more than the isolated fact that a boat has fine sea kindliness make it a suitable boat for voyaging. There are many more pieces to the puzzle.
#123 Bob Perry
  • 13,167 posts
Posted 23 February 2012 - 05:16 PM
Tre:
Please check your private messages for a mesage from me.
#124 jetboy
jetboy
  • 750 posts
Posted 23 February 2012 - 05:24 PM
Would it be fair to say that a high volume production boat could be built better than the one-off boats for a substantially lower price if the product was correct for the task?
#125 pete_nj
pete_nj
  • 123 posts
Posted 23 February 2012 - 05:35 PM
In a well run operation there will always be an economy of scale, so it theoretically would be much cheaper. The issue here is that there is not enough demand to find these economies. The only real scale in the sailboat business is at the price/quality point of the hunter/bene/etc. group. There are not enough buyers who want to spend significantly more for a boat of the same size but higher quality.
Consider how expensive the typical luxury car would be if they were only building 10 or 20 per year.
#126 trenace
trenace
  • 2,282 posts
Posted 23 February 2012 - 05:40 PM
Tre:
Thank you, Bob! I hadn't seen it. Not so good with always spotting the PM notification. On it now.
#127 Hiracer
Hiracer
  • 1,467 posts
  • Interests:x
Posted 23 February 2012 - 05:47 PM
Isn't this why it's nearly the same price to design and build a one-off as it is to buy a high end boat? Neither offer much in the way of economies of scale.
#128 jetboy
jetboy
  • 750 posts
Posted 23 February 2012 - 07:14 PM
You make a good point about volume of demand.
I always look at the larger boats and think about how much faster and cheaper they could be if you had an order for 1,000 per year. You'd be able to cut a ton of inefficiencies like building from single small foam core sheets. You can already buy some of the cores in 50 foot by 6 foot sizes. If you had enough demand you could upsize the production and just build the hull from a single piece of foam pressed in a form then have a single step to infuse an entire boat hull all at once and build very reliable high quality hulls quickly and cheaply. Even fiberglass and carbon fabrics that could be custom woven to so that the correct fiber placement on the hull etc. I'm sure the savings would be 50% or more on the cost of the boat. Unfortunately a high volume blue water cruiser might be just a dream.
As far as the original topic, I'd say a MacGregor 65 kinda fits the bill of a production boat that has been impressive. Especially for the original price tag of ~ $100k.
#129 dogfish
dogfish
  • 109 posts
Posted 23 February 2012 - 11:42 PM
point....counterpoint(s):
rudder failure 1
#2
#3
all in fairly moderate conditions
#130 Jon Eisberg
Jon Eisberg
  • 5,384 posts
Posted 24 February 2012 - 05:36 AM
I wish you'd pay a bit closer attention to what I actually say, as opposed to what you might assume I'll say... Back in Post #15, I thought I made it fairly clear that I've been favorably impressed by what the late Mike Harker, and now Michael & Edi, have done with their respective Hunter 49s... On the other hand, what the photo I posted of Michael Calabrese's Hunter 420 Passage reveals about the engineering and construction of the stem on that piece of crap, well... perhaps not so much...
In my observation of the migration of East coast snowbirds, I'm not seeing much evidence that a significant percentage of Mom & Pop cruisers have too much stomach for days on end offshore, "slamming" and "hauling ass" in their production coastal cruisers... The overwhelming majority motor down a 1,000 mile ditch between the Chesapeake and Florida, rarely taking the opportunity to venture outside for so much as a daysail, much less an overnight from, say, Beaufort to Charleston... Then, many will wait for however long it takes, for a flat calm day to motor across the Stream to the Bahamas... So, I'm gonna hazard the guess that "comfort" is, indeed, a higher priority than "hauling ass" offshore, at least for the vast majority of East coast kroozers, in their primarily "Modern Production Boats"...
I've never considered it my place to tell anyone else what sort of boat to buy, much less specify any particular BRAND... I would have thought by now, you might have noticed I am somewhat of a broken record about people educating themselves, beginning with a careful reading of DESIRABLE AND UNDESIRABLE CHARACTERISTICS IN THE OFFSHORE YACHT... People need to understand for themselves why such "quaint" or "antiquated" notions of characteristics such as STABILITY still matter offshore...
As for you contention that people get in trouble due to the assumption they're on a bulletproof boat, I must say i don't see such examples all that often... Care to share some with us?
Rather, I see the opposite, a couple of abandonments between the East coast and Bermuda from last fall immediately come to mind... In particular, the abandonment of the Beneteau 393 SANCTUARY, and the crew's rescue by the cruise ship NORWEGIAN GEM...
In that instance, I see the classic example of a crew being battered by the shortcomings of a "typical" production coastal cruiser pressed into some serious conditions offshore... A fuel bladder added for the passage begins leaking, making life extremely difficult below... An apparent inability to make the boat heave-to when conditions warranted such a tactic... No staysail or storm jib, because of course very few "modern production boats" afford the appropriate structure/bulkhead for retro-fitting an inner forestay... The boat begins taking on water, but determining the source of the leak is greatly complicated by the boat's construction and the use of a hull liner... Finally, the skipper punches out, when he fears the hull has begun to suffer delamination... One of the crew came incredibly close to being crushed between the boat and the NORWEGIAN GEM's shore boat during the rescue, and indeed the ship's crew was lucky they were able to return to the ship as the conditions worsened dramatically...
Perhaps, then, you should contact some of the crew from SANCTUARY, or the other abandoned Beneteau ELLE, and see what they have to say about that whole "Blue Water Mythology" thing...
#131 Tom Ray
  • 19,911 posts
Posted 24 February 2012 - 10:42 AM
Perhaps it's a miracle that those stems do not break off all the time.
I'm still waiting for another example. One that got thrashed in a hurricane due to owner idiocy does not indicate a design deficiency at all to me. Now if there were more than one, that would be a different story.
Is there more than one, or has every single other example of that model been incredibly lucky? Or is there maybe a third possibility, that the design is adequate (unless you're an idiot who does not know to get out of the way of hurricanes.)
#132 pete_nj
pete_nj
  • 123 posts
Posted 24 February 2012 - 01:14 PM
I've been reading here with interest since the beginning. Lots of great discussion.
As someone with much less experience than many others that are posting, I come away with the following:
  • It's all about the crew - better to be with a world class crew in a mass-produced boat than in the world's best blue water boat with a questionable crew
  • From a pure safety perspective, modern, mass produced boats are pretty good; not as good as the higher end boats in the extreme, but capable of saving your butt in some pretty bad conditions
  • Mostly, you get what you pay for. After some years of hard sailing, the difference between the boats will be readily apparent. The better boat will be in significantly better condition, will look better, will have a better maintenance history, and will continue to be safe. The lesser boat may be ready for scrap
  • The better boat will likely have better sailing characteristics, be easier to sail, be generally dryer and more comfortable
Is this a fair assessment? Is it oversimplified?
It would seem that technology plays a large role in safety as well:
  • the simple availability of good weather information makes staying away from bad conditions much easier for a broader cross-section of the sailing community
  • The Yanmar diesels found in many of the mass-produced boats is likely as reliable as the auxiliary in any high-end boat
  • gps, sat phones, and epirb make rescue much more likely (although possibly as the expense of creating a false sense of security for some that are not really ready for rough conditions)
#133 Jon Eisberg
Jon Eisberg
  • 5,384 posts
Posted 24 February 2012 - 03:08 PM
Well, perhaps it is... (grin)
Or, perhaps it's due to the well-documented likelihood of the rudders on Hunter 420 Passages breaking off, before the stem fittings/anchor rollers have a chance to?
Sorry, we went thru this before on the other thread... No, I cannot offer proof of another example of a stem fitting being torn out...
All I know is what I see with own eyes, what is revealed by that photo... No, I'm not a structural engineer, nor a yacht design expert, either... But I still see an example of construction FAR less robust than on my own little POS built 40 years ago, little evidence of any additional laminate or layup at that point in the hull, the complete absence of any supporting bulkhead intended to distribute the loads imparted upon that tiny piece of deck forward of the large anchor locker hatch, nor any protection against the likelihood of the anchor chain jumping the roller, becoming wedged between the roller and that bulbous deck flange, and begin sawing it's way thru the hull... Not to mention, another photo indicates the anchor roller/stem fitting was not even so much as BENT before it was torn out of the boat... Again, I'm not a structural or mechanical engineer, but to me, that seems evidence of a substandard design and construction, I don't think that's the way those sort of failures are designed to occur, are they? Shouldn't the fitting itself be the weaker link, the point of initial failure, instead of the freakin' hull and deck it's attached to?
Nope, not the sort of thing I want to see on a boat marketed as an Offshore Passagemaker...
BTW, while this boat did eventually wind up having a hurricane pass over the top of it, and was undoubtedly under the "Command" of a complete moron, the NOAA data from the South Island Chesapeake Bridge/Tunnel that morning indicates she had never experienced winds in excess of 35-40 knots prior to the time she was already on the beach, and this damage had already been done...
#134 Estar
Estar
  • 3,804 posts
Posted 24 February 2012 - 03:27 PM
Yes definitely.
Sort of, except I would say there are good and bad boats at both the mass produced and 'higher end'. But almost all boats can save your butt in 'pretty bad conditions' if you let them. All you have to do is look at how long almost all the boats stay afloat after being abandoned (most with even the companionway open).
Yes, mostly, but there are some expensive boats that have a lot of style but poor engineering, and even some that have neither and just a good brand name.
Hmmm . . . I agree by definition "the better boat will sail better", but its not at all the case that the more expensive boat will sail better. Some of the expensive boats are dogs (intentionally motor sailors) and some cheaper ones (like say a Cal 39) sail really well.
Yes, but not a sure thing as Sean showed us this past fall. You do need to have some skill and knowledge to use weather info well. Hiring someone ashore to just tell you what to do is a recipe for disaster, because the weather guy ashore can only see what the weather looks like on the internet - he can't know how your boat feels and what the waves are shaped like and a hundred other important things that only the skipper on the spot can know.
I am not even sure where this comes from. Yanmars are terrific engines. Perhaps the best designed and built piece of marine equipment I know. They have always scored highest of any engine on cruiser satisfaction surveys.
Yes, the especially the combination of an epirb and sat phone makes a rescue at sea much much more effective and likely to be successful. But as you point out, also makes it much more likily that people will abandon when they do not really need to.
Jon, is there any possibility that particular hull was a 'Friday boat' and some worker forgot to put on an important stiffener or the correct backing plates?
You have any plans for this comming summer's cruising?
#135 pete_nj
pete_nj
  • 123 posts
Posted 24 February 2012 - 03:41 PM
I was unclear. I was trying to say that the Yanmars are fantastic, and therefore, the entry level boats have engines that are just as reliable as high-end boats.
#136 smackdaddy
smackdaddy
  • 1,493 posts
Posted 24 February 2012 - 03:46 PM
One word of advice - don't take anything I write in this thread as any kind of advice. I'm just posting examples of production boats that are doing some pretty incredible things. I'm always a fan of "underdoggy" stuff like that. And these examples are leading me to ask questions and/or present assumptions regarding things I've heard/read in these "blue water" debates over the last few years. So, though I do think these examples are raising some valid counterpoints to the "Benehunterlinas are crap" mantra, personally I think any actual conclusions are still a ways off. For example, I think what you've laid out above is pretty reasonable - but, in my still-forming opinion, I wouldn't at all say:
"It's all about the crew..." (maybe it's mostly about the skipper/crew - but the boat obviously has to do its job); etc. There's more nuance, I think, than what you've laid out. The real offshore dudes here can (and are, I see) help refine it further.
But, I think you touch on a couple of things that are critical to this discussion - and the reason I think it's a never ending debate...people are talking about slightly different things. Here's what I mean:
1. The "life expectancy" of boats - and how that notion might be changing. (Your third bullet point.)
2. The "technology equals safety" factor - and how that is changing the way people sail...for better and worse.
Is a 40-50 year old traditional "blue water" boat inherently "better/safer" than a 1-5 year old production boat for the 99% of off-shore sailing most people will do (crossings, Coconut Milk run, etc.)? And in the, say, 1% event these boats do get caught in that F10 (assuming the same experienced/trained skipper and crew) - is the newer boat going to break more readily than the older boat? Also, isn't this "life expectancy" calculus going to change pretty drastically over the next 10-15 years? Are these modern production boats built to last 40-50 years? Do they need to be?
There are a lot of modern production boats (that carry that CE-A off-shore rating) filling up the marinas I visit. So I assume there are a lot more of these being built and sold than the traditional blue-water boats. And if that's the case, as time goes on, the discussion might need to shift from debating old vs. new design/construction techniques - to figuring out the "useful life" of a modern production boat - and what goes in to that calculation. As well as, what to prepare for and watch for in and after a storm. I think we're seeing much of this "first-hand" through Micheal's circ.
#137 Soņadora
Soņadora
  • 5,640 posts
Posted 24 February 2012 - 04:15 PM
This stuff is a lot like raising kids. You can tell everyone how to do it, but your own individual experience will be completely unique to you.
I remember a story from Cruising World or Lats and Atts about a kid who was buying his first boat. It was small like an O'day 20 something. He asked a guy in the yard if he thought the boat could sail across an ocean. The guy responded, "pretty much any boat can cross an ocean. Usually it's the person and not the boat that fails." Or something along those lines. It was a pretty good article. In the same article, the kid was trying to haggle pretty hard on the price and was concerned about all the costs. The broker replied, "you know, no one actually NEEDS a sailboat."
Again, I might be getting some of the details wrong, but that was the gist of it.
#138 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 24 February 2012 - 04:48 PM
You wouldn't happen to be a pilot, would you?
I can show you EXACTLY what loads a given airplane is designed for. I can show you exactly how the calculations for Va were done and what gust loads would exceed them. I can show you how many times a given airplane has suffered a structural failure per 100,000 flight hours.
For boats - THERE IS NO SUCH THING. You cannot assume that an X type of storm will apply exactly Y pounds to Z fitting. What we do have is centuries of experience to tell us what works offshore and what doesn't. You can take advantage of that knowledge and buy something like a Pacific Seacraft or a Valiant or you can take your chances in something that really is designed for something else. My own boat was NOT designed to be primarily used as an ocean voyager or they would have done a lot better with tankage and stowage, but they did make her sail well and hold together in the bad stuff. So I guess I got the really important stuff and 99% of the time I'm not out in the ocean anyway.
#139 smackdaddy
smackdaddy
  • 1,493 posts
Posted 24 February 2012 - 05:29 PM
I guess this sentence is the crux of the discussion. Are you saying that those centuries of knowledge and experience somehow culminated in then stopped with the Pacific Seacraft and/or the Valiant? Granted, the Valiant IS pure genius (like everything else Bob designs, of course...pissing in The Boss' pocket now) - and I raced offshore on a PS 37 Crealock last summer and it is a great boat. I certainly don't mean to take anything away from these - as if anything I say possibly could. But, I just don't think any of these boats (or any boat at all) is the "period" at the end of that centuries-long story of nautical technology and design. Honestly, that seems to be the mindset most times.
Keep in mind, I'm not talking about taking a production boat that is NOT appropriately "rated" (e.g. - CE-A) off-shore. But for those boats that are rated thus, it seems technology and design have continued to evolve and improve to offer something different...something that has its tradeoffs, yes, but is still suited for the job. It's just the expectations of that job might have to evolve a bit as well. That's what I'm trying to explore here.
(PS - I've only flown hang gliders.)
#140 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 24 February 2012 - 05:41 PM
You are confusing material science and design. One could build a PS 37 or V 40 out of the latest carbon-epoxy with lithium batteries and fuel cells if desired. That isn't the point.
The "advances" you seem to like are almost all "advances" in making MORE ROOM and MORE COMFORT in benign conditions. I can't think of any "advance" that has ANYTHING to do with better seakeeping ability.
For just one example, how many Cat-Ben-Huns have a decent sized chart table near the companionway facing forward? Do you have any idea what a huge PITA it is to have a chart table that faces sideways or backwards not easily accessible from the cockpit? 99% of their buyers couldn't care less because they'll never do that kind of sailing.
#141 smackdaddy
smackdaddy
  • 1,493 posts
Posted 24 February 2012 - 05:55 PM
Yes, I could very well be guilty of that. But, again, those are pretty broad generalities. All I have to go on right now, for this thread, is the first-hand account from Michael regarding his experience in that Hunter 49 which showed pretty damn good seakeeping ability in a serious storm - even with a very shorthanded crew - while also being pretty damn comfortable:
At least it looks like they got the chart table issue fixed. But really, what kind of bluewater boat has a freakin' potted plant on board? Shameful. Well...unless it's bread fruit.
#142 Hiracer
Hiracer
  • 1,467 posts
  • Interests:x
Posted 24 February 2012 - 06:23 PM
All I have to go on right now, for this thread, is the first-hand account from Michael . . . .
Seems to me you are willfully ignoring three rudder failures and a questionably engineered and built bow stem which have been pointed out in this thread. It's easy to make a point by turning a blind eye to evidence to the contrary.
As a matter of logic, I see problems taking the experience of one boat and one crew and trying to extrapolate that to all similar boats.
#143 trenace
trenace
  • 2,282 posts
Posted 24 February 2012 - 06:40 PM
My eyes! My eyes!
Now what am I going to do for eyes? :(
#144 smackdaddy
smackdaddy
  • 1,493 posts
Posted 24 February 2012 - 06:46 PM
No, I'm not ignoring them, hi. Not at all. But in this same thread there have also been mentions of rudder issues with Swans, C&Cs, J's and Oysters - as well as general quality issues with Hinckleys in the past, etc. Just like I don't take those examples as a blanket statement on those boats, I don't take examples of Benehunterlina rudder failures as a blanket statement either. How do you look at those examples of problems with the traditional bluewater boats?
As for the bow stem issue, I can't speak at all to the design stuff. No clue. I did, however, follow that story and know that the skipper of that boat made some horrible decisions. That boat was anchored near enough to the beach to be stuck in large breakers as the weather moved in (e.g. - shallow and unprotected anchorage). And it was parked just in front of a stone jetty. It eventually broke free, was thrown onto and over the jetty - then onto the beach where the wave action continued to use the chain as a saw.
So, again, I don't know what percentage of that goes to poor design/construction or massive human error.
(PS - My apologies tren. Eye Bleach in aisle 3.)
#145 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 24 February 2012 - 07:19 PM
That boat is like "opposite day". They did about everything I do NOT want in an offshore boat. The "island berth" V-berth is freaking retarded for any boat that sails offshore. Whomever or whatever you put up there is going to fall off. The sideways bunk aft is likewise useless. As far as I can tell, that boat has exactly 2 sea berths not counting the dinette, which would give you 3. My boat would fit inside that boat and I have 3 (or 4 if you're willing to sleep forward). The high freeboard makes for bad motion in the cockpit. Speaking of motion, I really really don't like the "cranky tricycle" handling of these fat ass boats when pushed hard. To my eye the boom gallows/elevated sheeting scheme looks horrible as well.
Speaking of horrible, that galley design was done by someone who NEVER cooked a meal in a storm.
#146 Hiracer
Hiracer
  • 1,467 posts
  • Interests:x
Posted 24 February 2012 - 07:26 PM
You make a good point here that is perhaps related to why I have a custom one-off boat. So I will not argue the point. :) :) :)
Which comes full circle to what I said earlier in this thread. It's really a boat specific assessment. Assessing bluewater capability in terms of brand is wide of the mark, IMO. I think we agree here.
#147 smackdaddy
smackdaddy
  • 1,493 posts
Posted 24 February 2012 - 07:34 PM
Heh-heh. Agreed, hi.
I'll shut up now.
#148 Innocent Bystander
Innocent Bystander
  • 5,109 posts
Posted 24 February 2012 - 09:03 PM
Of course, 40 odd years ago, a young designer penned a radical boat that was declared too light and unsafe to go to sea.
I guess that conventional wisdom wasn't very wise.
B)
#149 Hiracer
Hiracer
  • 1,467 posts
  • Interests:x
Posted 24 February 2012 - 09:06 PM
Yeah, but he knew what he was doing and that vessel has stood the test of time. Not sure many other boats can or will be able make that claim, especially today. :)
#150 ccruiser
ccruiser
  • 1,241 posts
Posted 25 February 2012 - 12:59 AM
What I read into the abandonment is not necessarily a boat issue but a crew issue. You say that the crew suffered from the "shortcomings of a typical production coastal cruiser" then mention 1. a fuel bladder added by the owner started leaking - I fail to see how that is a production boat issue, not sure why the bladder was added, but clearly was not done properly. 2. the crew was not able to make the boat heave to. Again a crew failure - admittedly it is harder to heave to all modern hull shapes, but it can be done, and I am willing to bet that the crew had not practiced it before leaving. 3. No staysail or storm jib, the boat was not set up for a staysail - that is not a failing of the boat unless you believe all offshore boats must carry a staysail. Having sailed more than a few boats with stay sails I don't. As for a storm jib, again a crew decision to either not have one or not fly it if they did - goes on to the forestay, pretty sure it had one of those. 3. Takes on water - really? It stayed afloat after the boat was abandoned. 4. The skippper "fears" that the hull is delaminating. Really, again boat survived the storm.
Not defending Beneteau, Hunter or Catalina or any boat, but what I see from your description is not a boat that was overwhelmed, but a crew that was overwhelmed because they were inexperienced, they did not know how to handle the boat, or the weather conditions, and then were able to convince themselves the boat was breaking up and they had to abandon ship. That fits as well with what I have read about the situation. Frankly, if you do not know how to handle the conditions you could have a Morris and still convince yourself the boat was breaking up, sleep deprived sailors who are struggling with the conditions, make bad decisions. And that in conditions which as far as I can see were unpleasant, to say the least, but very survivable, even by a "production" boat.
Off shore sailing brings out all sorts of emotions. One of the most poignant is giving up, resignation, which leads to abandoning ship. I have delivered any number of boats under all sorts of conditions, windless to 50 plus knots, (more than a few times, and fortunately never over 60 or more sustained). It requires a cool head, and understanding of your boat, confidence that you know what to do, and doing it as the conditions deteriorate. Whatever kind of boat you have. While I agree a sea kindly boat is a great help, if you know what your doing you will take off with a boat set up to handle the conditions you may experience, and will do what needs to be done to handle the conditions if they arise, which allows the crew to get sufficient rest, and keep things in perspective. As a friend always used to say you have to be ahead of the boat. At least this bad decision did not cost anyone's life. The crew of the captain that convinced himself to go into Little Cut in the Abacos, at night, during rage conditions, was not so lucky.
I delivered a Hylas 46 with the owner and his friends a few years ago. Ft Lauderdale to Martha's in May. It was a great sail. We had about 24 hours of 30 plus with the attendant seas north of Hatteras. They had been talking about an new 46 foot Jenneau, one of your dreaded production boats no doubt. It had made the trip the month before experienced similar conditions with an inexperienced crew that tried to motor into the seas and wind, and who were able to convince themselves that the boat was breaking up and to abandon ship. I am sure we can agree that a 46 foot boat in 30 plus knots motoring into it is not an acceptable response, and the fact that the boat did not break up is a testament to the construction of the boat, not the crew work. Again, the fatigue and emotions caused by slamming into those conditions for hours caused the crew to compound the mistakes they were making. We reduced sail to meet the conditions carried on sailing close reaching, and when the wind abated, shook out the reef, and continued on our way. Everyone got to sleep, eat and conduct themselves in regular fashion, consistent with living on the heel of course. The conditions were no big deal, and were treated as such, and everyone and the boat were no worse for the wear.
The point is there is no substitute for good crew work, and boat handling, whatever you are sailing, and you cannot blame the boat for poor crew work. Sorry this is so long
#151 smackdaddy
smackdaddy
  • 1,493 posts
Posted 25 February 2012 - 02:26 AM
Okay - this is a damn good thread.
#152 Solen
Solen
  • 163 posts
  • Interests:Sailing, tweaking, fixing, sailing.
Posted 25 February 2012 - 09:50 PM
No more panning the Hunter - I fixed the design so its just like the "rule" boats.
#153 Jon Eisberg
Jon Eisberg
  • 5,384 posts
Posted 26 February 2012 - 02:14 PM
Presumably, because the skipper felt the standard fuel capacity was inadequate for the trip. Tankage is one of the most basic specifications that separates a boat like the Beneteau 393 from a production boat more suitable for passagemaking, such as a Caliber, to name one. So, to compensate for what is perceived to be marginal fuel capacity, many people undertaking such passages in today’s production boats are carrying additional fuel on deck, which I rate as one of the most dangerous and unseamanlike practices I routinely see out there, today…
Sure, successful passages have been made without a staysail, but I still consider the provision for flying an additional smaller/backup sail to be one of the hallmarks of a true bluewater boat… Especially, for a boat like the one in question, with only a roller furling genoa fitted… A staysail would certainly improve the prospects for getting such a design to more easily heave-to, or to simply endure the sort of conditions they faced on that trip… While it might not be absolutely essential equipment, for a passage from NY to Bermuda in November, it would certainly be right at the top of my own “Nice to Have” List…
Well, I’ll give the skipper the benefit of the doubt, and assume he might have had good reason to believe the hull had suffered structural damage. The tabbing on one of the aft bulkheads had apparently been compromised, to the extent that it had some sufficiently ajar that the door to one of the staterooms could no longer be opened. Looking at the guy’s resume below, sounds like he may actually know a thing or two about sailboat engineering, design, and construction… (Not to mention, afterwards he described the boat as a “floating condo”, relative to the Beneteau First Series, which he assesses to be a better choice for sailing offshore)
As to the taking on of water, do you have any doubt that might have been the case? Or, do you dispute the fact that a boat with a liner would make it far more difficult to assess potential sources of leaks below the waterline?
Also, it should be noted that one of the primary reasons the decision to abandon was taken, was the fact that their liferaft had been swept overboard during one of their knockdowns, or by a boarding sea… It had been stowed on top of the coachroof, which by now has become generally accepted to be a rather vulnerable and poor choice for liferaft stowage… A more offshore-capable boat would have had a dedicated locker or some safer provision for the location of the liferaft, perhaps in the cockpit or transom. One of the requirements for an Offshore CE rating is such a dedicated liferaft storage solution, if I’m not mistaken…
Well, I read it a bit differently, hardly seems such a simplistic example of Either/Or, to me… No doubt, some of the crew was likely to have lacked offshore experience – they were paying for the privilege of gaining some, after all, by signing onto this delivery of a charter boat to St. Marten…. But I still see this as a classic example of demands being made upon a crew by a boat possessing a number of characteristics that can produce major problems when serious weather is encountered offshore – problems that would have been less likely to arise had the boat been more properly well-found and equipped for such a passage… I see this as the perfect example of a COMBINATION of factors regarding both a boat AND a crew (for the life of me, I am continually perplexed in these discussions by the tendency of many to insist it has to be one OR the other), but starting with the boat, and the crew being asked to perform duties or take actions that they might not have otherwise had to do, had they been aboard a more suitable boat...
Delivery skippers don’t always get to choose the hand they’re dealt, and there’s generally a limit to how much modification or upgrading the client or owner will be willing to make for such a trip… So, the skipper often has some tough choices to make in that regard. Personally, I would have passed on such a delivery, or at the very least would have departed from the Chesapeake or Beaufort, instead… No way would I have taken that boat – much less with paying customers of unknown skills or personalities – from the NE to Bermuda, in November…
But, perhaps that's just me... (oh, and Don Street, as well (grin))
From what I've read of this incident, I, too, have some reservations about some of the tactics chosen, etc... But, the skipper made it absolutely clear that the safety of his crew was his top priority (as it should have been, of course), and with the weather quickly deteriorating, and his belief that the hull had been structurally compromised, the boat having become basically uninhabitable below largely due to the presence of diesel (I would have to assume at least a couple of his crew must have become significantly incapacitated by seasickness, at that point), well... I'm not gonna second-guess the decision to abandon ship when he had that opportunity was the wisest choice, at that point...
However, I’m certainly not gonna brand the skipper as “inexperienced”, if one accepts his resume at face value, he sure seems to have a fair amount of experience, to me…
Captain Thierry Simon
QUALIFICATIONS ET EXPÉRIENCE
• MCA Master Of Yachts Offshore 200 Tons (copy of the certificate here)
• STCW 95
• 31,500 miles at sea-1390 days at sea
• Studied Yacht Design at YDI, Blue Hill, Maine, USA
• Extensive knowledge of marine electronics onboard yachts
• Outstanding mechanical engineering skills
• Strong capabilities in watchkeeping, navigation, engineering, and electrical maintenance
• Extensive Experience in rebuild’s of smaller sail vessels
• Transformed a 100yr old 93’Gaff Rig from a Fishing Schooner back to its original state as a S/V
• Ability to maintain and repair electrical systems and electrical equipment
• Over 40 years of sailing in both racing and cruising
• Owned and operated 9 boats (Charter and Personal Usage)
• Adapted a wooden boat design by Francis Herreshoff into modern aluminum build
• Specialist in Vessel Deliveries
#154 Jon Eisberg
Jon Eisberg
  • 5,384 posts
Posted 26 February 2012 - 02:36 PM
Hi Evans...
Not sure at the moment, but I'm hoping to get back up into the Canadian Maritimes again, maybe Newfoundland or even possibly Labrador... (If I can come up with the money for the freakin' CHARTS, that is (grin))
However, such a plan is likely to be compromised by the fact I'll be staying down south this winter longer than I usually do, I probably won't be back home until late May this year, which is about 6 weeks later than I usually do... Given the amount of shit I'll have to catch up on when I get back, I'm afraid I'll get stuck there for awhile, and getting too far north this summer won't be very likely...
Didn't I see you mention Greenland for you and Beth this summer? Wow, that's fantastic, I'd love to do that trip someday...
But, damn, talk about another place where the price of charts is outta sight, eh? (grin) Good luck, hope you guys can manage it, I'll follow that one with great interest...
#155 Mung Breath
Mung Breath
  • 739 posts
  • Interests:Balance in Life
Posted 26 February 2012 - 03:03 PM
I generally think that these voyages say a hell of a lot more about the skipper than they do about the boat.
I am in the Evans camp on this one.
I wish I could design luck into my boats.
I think you do, Bob.
Luck = preparation + opportunity. A good naval architect contributes pretty substantially to the first part of the equasion.
#156 bjkrad
bjkrad
  • 25 posts
  • Interests:sailing
Posted 26 February 2012 - 04:40 PM
Smack: I agree, great thread!
Between a Hunter, Catalina, Beneteau, and Sabre, I'll take the Sabre.
Between a Hunter, Catalina, Beneteau, and Hinckley, I'll take the Hinckley.
Between a Hunter, Catalina, Beneteau, and Valiant, I'll take the Valiant.
Between a Hunter, Catalina, Beneteau, and Morris, I'll take the Morris.
Between a Hunter, Catalina, and Beneteau, I'll take the Beneteau.
Between a Hunter, and Catalina, I'll take the Catalina.
Between a Hunter and nothing, I'll take a Hunter.
I liked that progression, but come at it from a different pov:
1. When I was a teen, between nothing and sailing a Sunfish I sailed a Sunfish.
2. In my twenties,I decided to be a keelboat sailor. So between Sunfish and renting various small keel boats, I rented the keel boats.
3. After getting married, between renting small keel boats and the thought of ownership, we did two years of fractional membership. (On a brand new and beautiful Hunter 33, for very little financial commitment.)
4 When we had kids we decided to commit to more serious coastal cruising. Between fractional membership and purchasing a respectable production coastal cruiser, we chose a respectable production coastal cruiser. (A 5 year old Beneteau 361.)
5. Fast forward seven years later, we are gearing up for blue water. So between the Beneteau and going into contract again, we're going into contract again. (One of those b.w. boats mentioned in this thread.)
All of those boats were and still are, for me, perfect matches. But I wouldn't take any of them across an Ocean or around Cape Horn. Not even #5 (that is, not yet). But when I do, I'm gonna be comforted by the thought that for where I am, #5 is "the" perfect match. And that is definitely not a knock of choices #1-4! In fact, I could not have "survived" without them!
#157 ccruiser
ccruiser
  • 1,241 posts
Posted 26 February 2012 - 08:13 PM
[quote name='Jon Eisberg' timestamp='1330265695' post='3600960']
[quote name='ccruiser' timestamp='1330131587' post='3599499']
[quote name='Jon Eisberg' timestamp='1330061793' post='3598216']
Jon,
To start let me agree with you that the boat normally plays a not insignificant part in these incidents, and I agree that it is not all one or the other crew or boat. But the crew is the variable part, and the part that can adjust to the boat. A good crew can make up for the shortcomings of the boat, and all boats have shortcomings. I also believe that we will never know what goes into making the specific incident happen - at best we are speculating to some greater or lesser extent. You tend to second guess the boat at least in this thread, and I generally second guess the crew, unless there is a documented boat failure.
As for the skipper, interesting resume, seems like a qualified delivery guy, but who knows what his state of mind was, given the inexperienced crew he was sailing with, or how much rest he had had?? All I know for sure is the boat made it through, so while there may have been water coming into the boat, it clearly was not enough to swamp the boat or which the boat's bilge pumps could not handle; and the structural damage, whatever that may have been, did not result in a hull or deck failure. If you look at the VOR races you see what a crew can do with actual hull de-lamination, not just a bulkhead coming adrift - by the way was it a structural bulk head? Now to your specific comments:
1. Bladder - whatever the owner/skipper may have thought, two things are true. 1. The boat carried 39 gallons of fuel. We can certainly agree that this is more than enough fuel for the intended passage - it should give the boat a 3 day, 400 mile range. 2. You do not respond to the point that the bladder was not properly installed. So assume we agree on that point. So the bladder was unnecessary and improperly installed - not a boat problem - bad choices by the owner/crew.
2. Staysail. A lot of passages have been made without a staysail. They are unnecessary in my opinion, and I am not a fan. So we have a personal disagreement on this point, but what I am sure we do not disagree on is if you undertake this type of passage you need a full sail compliment - #1 (a 130 in all likelihood, do not need a 150 in the Caribbean or offshore), #3 (will use that in the Caribbean 90% or more of the time), #4 (storm jib for what happened here) and a chute of some kind. The main should have three reef points, and have been recently inspected or new. Again, the fact that they chose to have only a #1 is not the boat's fault, its theirs. Absolutely foolhardy to take off without a #4.
3. Liner - In my experience, every boat I have sailed on had accessible thru-hulls, some more accessible than others. :) So you could see it they were leaking. Indeed every hull penetration was observable. Particularly if there was a major breach, allowing in a substantial amount of water. I had thought you were referring to the headliner, not the structural grid. It is not unusual for a boat in those conditions to have some water down below, the primary question is are they minor or major. The former leads to more crew discomfort, and potential fatigue, the latter, to we better find this and fix it. I do not think either you or I know enough to comment more than we have here on this point.
4. Liferaft. Sure its nice to have a separate compartment for the raft. If that is a requirement for offshore sailing in your mind, and you have one, you not going to meet many people offshore. Particularly in 39' boats. :) Again this is a poor owner/crew choice. More likely the owner. Mounting liferafts on cradles is just poor judgment IMHO. If it is there "permanently" its hard on the raft, particularly in the Tropics, and it is subject to this very issue. There is, I am sure a spot, in a locker or down below where this raft could have been stored - the owner in all liklihood made a bad decision. Again not a boat problem.
I have raced 30' ULDB's offshore. We always carried a raft, a full compliment of sails, etc. (We even carried a outboard and a few gallons of fuel - it was a sail boat race after all). The raft was never stored on deck - can you image the negative effect on righting moment. :) They were stored below - always. Where they were not subject to the weather, and in the center of the boat, helped to keep the boat flat - a little bit at least. If I could do that in a 30' ULDB, hard to believe that these folks could not have found a better place to store it, had they thought about it correctly, which they did not. My current boat, a 46' has the raft stored in a valise in the aft lazzie.
I am not second guessing the decision to abandon ship - was not there, just discussing the factors that may have lead up to it, and this thread - whether the boat was suitable for the delivery. We agree on it having been a combination of factors, but the skipper knew what he was getting in the boat and crew. Boats of this type are delivered all the time in these conditions, and worse, and make out fine.
Don would have moved the boat in October if I recall his position correctly, and then done the second leg to the Caribbean in November from Bermuda. Always sounded like a good plan to me.
#158 Cavelamb
Cavelamb
  • 1,077 posts
Posted 26 February 2012 - 08:27 PM
I apologize for this in advance. And I don't mean to hijack the thread.
But I do wonder about this question.
Prices of ALL petro related products are starting to liftoff like rockets.
If that continues for very long, will there even BE any production boats?
Will the world return to the economic models of the early 1800s?
If you want a boat, you'll have to have it built?
#159 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 26 February 2012 - 11:53 PM
Psychology:
If you THINK your boat is a POS, and many a delivery skipper thinks what they call a BendyTwo is a POS, irregardless of the ACTUAL abilities of the boat you will act as though your boat won't make it through. To a large extent, your boat is as good as you think she is ;)
Jon,
#160 smackdaddy
smackdaddy
  • 1,493 posts
Posted 27 February 2012 - 02:05 AM
Psychology:
I think that's exactly right. And I also think that's why this topic is so interesting. Has the "prevailing wisdom" regarding modern production boats' inadequacies been a bit over the top?
I guess time and examples will tell.
#161 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 27 February 2012 - 03:50 AM
It depends. If I take my family offshore, it isn't going to be in a boat that will probably be fine. It will be in boat that will still be floating barring extraordinarily bad luck.
Don't forget, I have taken hole saws to all these boats and I know what went into them! Also don't forget I *HAVE* pushed a Hunter hard and I know what that was like.
Psychology:
#162 Soņadora
Soņadora
  • 5,640 posts
Posted 27 February 2012 - 04:25 AM
Cave,
I think this is exactly what's going to happen. Or at least, a large majority of new boats will be one-offs. Which means the number of new boats each year is going to be really low. A shop who can do other stuff besides build boats will be able to survive. There are a number of yards like that now and some of the bigger names seem to have a majority of their bottom line covered by service rather than new boat construction.
It is a great time to pursue being a boat designer...HA! The very good ones will have a lot of work. And maybe we'll see some interesting trends in boat construction. Wood is looking pretty damn attractive, ain't it ;)
hmmm....a renewable, domestic resource.
#163 smackdaddy
smackdaddy
  • 1,493 posts
Posted 27 February 2012 - 03:57 PM
It depends. If I take my family offshore, it isn't going to be in a boat that will probably be fine. It will be in boat that will still be floating barring extraordinarily bad luck...
Don't forget, I have taken hole saws to all these boats...
...or a hole saw.
#164 kent_island_sailor
kent_island_sailor
  • 7,251 posts
Posted 27 February 2012 - 04:19 PM
There is that :lol:
#165 Hiracer
Hiracer
  • 1,467 posts
  • Interests:x
Posted 27 February 2012 - 05:57 PM
If that continues for very long, will there even BE any production boats?.
I have my boat so that's not the issue for me. I worry about the cost of replacement sails, paint, lines, etc.
World production of oil peaked in May of 2005 and has been statistically flat ever since, a first in over one hundred years of world oil production.
I think it was November of 2010 when DOE stop publishing its estimate of world oil production, which is a scary parallel to March 2006 when the Fed stopped publishing its money supply metric (and of course we now know that the money supply started imploding shortly thereafter).
Just saying . . . .
I always get nervous when the government starts hiding hard-to-get information.
#166 Cavelamb
Cavelamb
  • 1,077 posts
Posted 28 February 2012 - 01:03 AM
Cave,
You could be right, Sons.
The guy who owns the boatyard here is making custom bodies for golf carts.
Like that red race car in the movie "Cars"...
Too cute, and a lot more forgiving than boat work...
More demand to, I'm afraid.
#167 jacrider
jacrider
  • 105 posts
Posted 10 March 2012 - 01:36 PM
..........snip...............
... However, the right 80's vintage Frers-designed Beneteau First series could well be in the running, those were very good boats, IMHO, and many of them have a ton of fairly serious offshore miles to their credit...
For what Michael must have spent on a brand new Hunter 49 with all the trimmings, I'm pretty certain I could find something on Yachtworld that I would consider equally - if not considerably more suitable - for the trip he's undertaken, at a fraction of the price...
I agree with that Jon. Those were solid performers. After doing the Sydney Hobart and return delivery in 35knots to almost 70 knots on a Beneteau First 47.7, and then on the same boat, being the only survivor to round the first mark in 65knots in the 2010 Southern Straits Race in Vancouver, I am pretty comfortable with the seaworthiness of that production boat. However, the same couldn't be said for their Oceanis production line.
A steady 35 before the shit hit the fan
The following morning after crossing the Bass Strait, I took this pic of the max boat speed during the night of thundering down some pretty big seas with 3 reefs in the main.
http://gallery.me.com/adamfys#100013 a little snip from the Southern Straits B) from one of the crew.It blew a steady 40 knots off the start, then built during the late afternoon to solid mid 60's
Great to hear this endorsement of the 47.7, we just bought one. We were looking for a big, tough fast boat. We aren't going to race this boat, just cruise it. Funny thing though, when looking for a boat, no "cruising" boats had any appeal to us. We really place importance on performance when evaluating boats and the only place we found that was with racing boats. Needless to say, we are looking forward to sailing this boat.
#168 reis123
reis123
  • 337 posts
Posted 10 March 2012 - 02:42 PM
I was speaking with a pretty well known naval architect about a boat recently, a terrific and respected na, and basically, he advised that unless one knows in pretty good detail one's own requirements, it is all duck soup.
#169 smackdaddy
smackdaddy
  • 1,493 posts
Posted 10 March 2012 - 04:44 PM
Pics!
#170 smackdaddy
smackdaddy
  • 1,493 posts
Posted 07 June 2012 - 08:14 PM
I can't help it...I like this guy and his damn Hunter:
At 1014 we secured alongside the south float at Saint Augustine Marine. We had come 9375 miles from Puerto Montt, Chile in a little under six months with 47 ports and 111 days at sea. Sequitur, our Hunter 49 had safely and comfortably brought us through one Force 12 storm, three Force 11s and several Force 10s and 9s. We had bucked adverse winds, currents and bureaucracies. We were tired.
http://www.sailblogs...?xjMsgID=226545
#171 curm
curm
  • 457 posts
Posted 07 June 2012 - 09:48 PM
If I were going to do serious offshore sailing in a Hunter, Catalina or Beneteau, that boat would be like the Chevy Impalas that race in NASCAR as opposed to the ones you drive off the showroom floor. I would beef up everything: chainplates, shrouds and backstays, turnbuckles, hull to deck joint, backing plates, high capacity bilge pump, bronze or marelon through hulls, stronger rudder post, removable inner forestay, better tankage, more handholds, padeyes for harnesses.... the list goes on. It's because I'm a coward.
I'm in the process of upgrading my Bristol to cruise the Med for a year and I'm doing some of the same things. But at least my starting point is a 19,000 lb boat with a solid fiberglass hull.
#172 smackdaddy
smackdaddy
  • 1,493 posts
Posted 08 June 2012 - 12:33 AM
Here's a list of everything Michael did to that 49 (nothing drastic I don't think):
http://www.yacht-sequitur.ca/gestation1.htm
Once the decision had been made to order the Hunter 49, the next step was to wade through the long list of standard equipment and options and decide on exactly what I wanted. For ease of handling and for sailing performance, among the things I ordered were:
  • the deep keel;
  • the tall rig;
  • the vertical battened in-mast furling;
  • the self-tacking furling staysail;
  • the asymmetrical cruising spinnaker;
  • one electrical self-tailing winch;
  • and for safety, the spare rudder system;
For interior creature comfort and convenience, among the options I ordered were:
  • the three cabin layout with the workshop/office option in the starboard aft;
  • the Splendide washer/dryer;
  • the Quiet Flush heads;
  • the second top-loading freezer and second fridge; and
  • the leather interior upholstery.
When the boat arrived in Vancouver the first week of February 2007, I began adding or upgrading a number of other things, including:
  • a Raymarine E-Series chart plotter with an E120 in the cockpit and an E80 at the nav station;
  • a Raymarine 2kW radar dome on a Waltz swivel mast mount;
  • a SeaCAS AIS SafePassage 100 receiver;
  • a Rozendal Luneberg Tri-Lens radar reflector;
  • a Raymarine 7002 autopilot with remote controller;
  • a 40kg Rocna with 100m of 9.5mm hi-test chain as primary anchor;
  • demoting the 20kg Delta with 15m of 9.5mm hi-test chain and 80m of nylon to secondary anchor;
  • a Walker Bay FTD-310 Hypalon dinghy;
  • a Torqeedo Travel 801 rechargeable lithium-ion electric outboard;
  • a set of customized Ocean Marine davits;
  • a custom dodger and bimini with matching pedestal and dinghy/davit covers;
  • a 1225 aH house bank of 6v flooded cell batteries with Water Miser caps;
  • a Fischer-Panda 4kW DC generator with a starting battery and switching to charge all three battery banks;
  • a pair of Racor primary fuel filters with isolation switching to replace the single Racor;
  • an Espar hydronic interior heating system; and
  • forty-two folding nylon/glass-fibre MastSteps to the top of the mast.
I decided to have the canvas work, the generator, davits and the electronics installed in Vancouver, rather than at the factory in Florida, to give me more control over their design and placement. The fit-out took just over five months, and I took possession of Sequitur on 4 July 2007.
Then with more than a year-and-a-half cruising the local waters, we had plenty of time to determine what needed to be added or modified. During this time I also kept track of the ongoing technological advancements in such things as watermakers, communications equipment and alternate power, and by early 2009, we were ready to begin Sequitur's final fit-out. On 2 March, among equipment additions, installations and modifications we initiated were:
  • a telescoping whisker pole, track-mounted on the mast.
  • a Spectra Newport II watermaker;
  • a stainless steel arch above the after end of the cockpit to help carry the solar and wind systems;
  • a 522 Watt array of Kyocera solar panels and a Blue Sky charge controller;
  • an Eclectic Energy D400 wind generator with any excess power diverted to the hot water heater;
  • a Magnum 2800 Watt pure sine wave inverter, keeping the Xantrex 2500 modified wave as a spare;
  • an HF antenna from the new arch to the masthead;
  • an Icom 802 SSB radio with an AT140 tuner;
  • a Pactor II/III usb modem;
  • an Icom 604 to upgrade the existing VHF;
  • an Iridium satellite telephone;
  • an Ocens Weather Pack with WeatherNet, MetMapper and Grib Explorer;
  • an EchoPilot Platinum forward-looking sonar feeding to the chart plotters;
  • a Raymarine AIS5000 Class B Transceiver;
  • a Hydrovane wind steering unit;
  • a Fortress FX-37 as a third anchor;
  • a 180 metre spool of 19mm nylon line;
  • two rail-mounted 90 metre spools of 13mm polypropylene for stern ties;
  • a Jordan series drogue;
  • a SeaKits Damage Control kit;
  • an OceanMedix Marine 3000 medical kit; and
  • a Revere Offshore Elite 6-person liferaft in a hard container, mounted aft of the mast.
Our next task is to assemble tools and complete the outfitting of the workshop and we need to lay in spare equipment, spare parts and a ditch bag to hedge our bets on all the worst-case scenarios.
#173 curm
curm
  • 457 posts
Posted 08 June 2012 - 01:11 AM
All of that stuff is great-- especially the safety and communications equipment-- but not very much of it makes the boat itself stronger.
#174 Tom Ray
  • 19,911 posts
Posted 08 June 2012 - 11:46 AM
Spare rudder system?
#175 puddin
puddin
  • 903 posts
Posted 08 June 2012 - 03:31 PM
See WHL's post about the First 47.7. I whole heartedly agree with his thoughts on the matter. All Beneteau's are NOT created equally.
#176 Elegua
Elegua
  • 391 posts
Posted 08 June 2012 - 04:19 PM
<br />If I were going to do serious offshore sailing in a Hunter, Catalina or Beneteau, that boat would be like the Chevy Impalas that race in NASCAR as opposed to the ones you drive off the showroom floor.  I would beef up everything: chainplates, shrouds and backstays, turnbuckles, hull to deck joint, backing plates, high capacity bilge pump, bronze or marelon through hulls, stronger rudder post, removable inner forestay, better tankage, more handholds, padeyes for harnesses.... the list goes on.   It's because I'm a coward.<br /><br />I'm in the process of upgrading my Bristol to cruise the Med for a year and I'm doing some of the same things.  But at least my starting point is a 19,000 lb boat with a solid fiberglass hull.<br />
<br /><br /><br />
We've almost the same boat - just mine is the uglier sister that is a bit fatter at 22k lbs. Luckily, most of that is in the keel. I've re-built the chainplates, rudder and keel, engine, engine box and next year goes the deck and electricals. The year after is electronics and sailing hardware. My ambition is to do a full circle and at least one cape.
Ooops, there. I said it.
#177 curm
curm
  • 457 posts
Posted 09 June 2012 - 01:20 AM
If your boat is a 41.1, I don't think they're ugly at all.
I've never sailed a Beneteau First. If I could be convinced that it is a strong boat, sure I'd go offshore in it. But I would have to be convinced. If someone offered me a Morris or Hallberg Rassy, there would be considerably less convincing to do.
Generally speaking, my experience has been that you get what you pay for, and a boat built to a price point would not be my first choice for ocean voyaging.
#178 Road Runner
Road Runner
  • 49 posts
  • Interests:escaping all traps.
Posted 09 June 2012 - 01:31 AM
Any of these designs can handle offshore, some are slow and some are fast. Some have two head and some have none. But with this Mike sailing the Hunter around the horn you have to ask what did he have to do to the boat to make it seaworthy enough for the trip? Even the standard halyards would chafe through in no time on a hunter. So halyard upgrades, chafe protection, he might have even had to add in more structure. This question need to be asked. If you took the same size models and then asked what we need to change to make seaworthy for going around the world then we compair.
Jeez, I'd love to have one-tenth of your sailing experience.
Beneteau have, according to rumour, produced some exceptionally good boats, and while I have nowhere near Tim's experience, seeing the Copeland's voyaging on Bagheera said that these were not just coastal cruisers/junk.
I also have to say that every hole I have drilled into my own aging beauty has been met with totally dry core, and I have drilled lots.
I met one man who said that our boat was his dream to sail to Mexico, and he had tried once with one and ended up on the rocks. This was several years ago, and SA had pix. Ick.
His second choice was a C&C 37, which he was sailing down by himself with pickup crew the year we met them. She was (wisely) doing shore support. I hope she had him well insured.
If some outcast can sail a Vega 27 around the Americas, I can surely sail my boat to the ends of the earth.
#179 smackdaddy
smackdaddy
  • 1,493 posts
Posted 09 June 2012 - 02:26 AM
That's exactly what intrigues me about Sequitur. See the quote above about the storms again. Then look at the modifications.
What does it take to convince you?
#180 Elegua
Elegua
  • 391 posts
Posted 09 June 2012 - 05:16 AM
I have the Wauquiez version of your boat; essentially the same hull with some minro differences in dimensions and 2 tons more ballast. My step father until very recently had a Bristol 38.8 which what was got me onto the design. For such heavy boats they do move along nicely and handle well.
#181 curm
curm
  • 457 posts
Posted 09 June 2012 - 01:32 PM
Yes, I'm familiar with both versions of the Wauquiez Hood. Nice boats, and some folks prefer the Wauquiez cabintop for working on deck. You also have the double quarter cabin.
#182 kdh
kdh
  • 2,229 posts
Posted 09 June 2012 - 01:56 PM
curm, what do you have for a rig/suit of sails?
#183 sailglobal
sailglobal
  • 246 posts
Posted 09 June 2012 - 03:34 PM
[/quote]
[/quote]
Call him an outcast if you choose, but if your definition is the same as most people I think you owe him an apology. To me he was a man with a mission and he well and truly achieved it, and the beneficiary is a very good cause. Yes there may be a book or even a movie, and I will bet proceeds go to a deserving cause be it himself or his non profit.
#184 Ishmael
  • 6,787 posts
Posted 09 June 2012 - 03:59 PM
I wasn't using the term pejoratively, probably should have used quote marks. "outcast" was the image that most people had of him. I thought he did a bang-up job all round.
#185 SemiSalt
SemiSalt
  • 3,750 posts
Posted 09 June 2012 - 08:03 PM
To me he was a man with a mission and he well and truly achieved it,...
There been some comments to the effect that the Vega wasn't the fit for the job, too. Well, it's pretty old, and it's pretty light for the southern ocean, but it's hardly the first time anyone has taken one to sea, and they have a good reputation.
#186 curm
curm
  • 457 posts
Posted 09 June 2012 - 10:59 PM
Masthead sloop, main with 3 reefs, 120% genoa (new), removable inner forestay for a staysail or storm jib. Runners. Next year I'm looking to add a light air sail--an asymetric or something like a Doyle UPS--maybe on a furler, maybe with a sock.
Today, close reaching in 13-15 knots apparent with the board down, we were doing an easy 5.5 to 6 kmots and never had to touch the wheel. Boat sailed itself so long as the sails were trimmed. We relaxed off the beavertail light while we watched the Rolex boats coming back in.
#187 SemiSalt
SemiSalt
  • 3,750 posts
Posted 19 June 2012 - 08:54 PM
I didn't want to start a whole thread for this.
I was taking my boat to the yard for bottom paint, and I was overtaken by another boat. (We were both under power.) I glanced over at the other boat and said, "That looks like a Bob Perry boat." And one of my friends said, "That's not a Perry boat. Look at that bow. Perry never designed a bow like that." My other friend said "That's a boat you could sail to Bermuda and be comfortable."
Here she is:
Attached File  SANY0711.JPG   646.14K   125 downloads
#188 wick
wick
  • 144 posts
Posted 19 June 2012 - 11:10 PM
Saga 43 - yup
#189 Ishmael
  • 6,787 posts
Posted 19 June 2012 - 11:54 PM
Here she is:
That can't be a Perry boat. There's not enough CODB.
#190 robertfraser
robertfraser
  • 112 posts
Posted 20 June 2012 - 01:23 AM
Is this thread open to other production boats, or is it primarily about Hunters that "bring it"? Are we talking modern production boats, or any production boat in the last 30-40 years?
I nominate the Albin Vega. 3450 built, and many have cruised long distances including the most recent example sailing around the Americas. Not very comfy though.
I also nominate my own Pearson 30, mostly because I love it to death, and I'm totally biased. She'll be 40 this year, and sailing in 25+ knots in a nasty chop on the Chesapeake gave me more confidence than I ever had in my Coronado. I'm not sure if the build quality was good throughout all of Pearson's models and timespan of production but if it was... Wow.
I'm with Ajax..... Pearson 30, hull 101, brought me home from every misadventure so far...... ('course it IS my first REAL boat...)
#191 justcruzan
justcruzan
  • 3 posts
  • Interests:sailing...and rum.
Posted 22 June 2012 - 05:43 PM
Looks like boat that started this thread is for sale:
http://www.yachtworl...L/United-States
#192 Bob Perry
  • 13,167 posts
Posted 22 June 2012 - 06:00 PM
Semi:
Thanks for the pic. In fact I have designed several boats with bows like that.
Here is the 60' version of the Saga 43. This is a very nice boat.
#193 Soņadora
Soņadora
  • 5,640 posts
Posted 22 June 2012 - 06:05 PM
"Perry never designed a bow like that." My other friend said "That's a boat you could sail to Bermuda and be comfortable."
WTF does that mean? :huh:
Time for new friends.
#194 MidPack
MidPack
  • 1,631 posts
Posted 22 June 2012 - 06:11 PM
Whatever else, that sure is a killer set of pictures to help the listing sell...
#195 smackdaddy
smackdaddy
  • 1,493 posts
Posted 22 June 2012 - 06:23 PM
Wow. I hope it's just case of them tiring out and wanting to do something else - and not sickness, etc.
I haven't seen anything on their blog about the change in plans. Well - they definitely "brought it" with that damn Hunter. Great sailing and seamanship - and even better food!
#196 SemiSalt
SemiSalt
  • 3,750 posts
Posted 27 June 2012 - 04:06 PM
I've seen articles and pictures about boats with wishbones aloft, but I can't remember seeing one in person until today.
Attached File  SANY0725c.jpg   88.24K   21 downloads
Attached File  SANY0722.JPG   565.71K   20 downloads
The boat's name is Vivimus (if I got it right).
