Vendee Globe 2012
#1601
Posted 05 December 2012 - 05:25 PM
#1602
Posted 05 December 2012 - 06:38 PM
#1603
Posted 05 December 2012 - 07:00 PM
not my workAlex Thomson going fast
(subtitled)
Back before the 02/03 Around Alone, I was staying at Billy Black's place in Portsmouth and Claudio Stampi came to stay one night (doing some seminar I think). I was upstairs and Claudio was camped out downstairs in the living room...I came down the stairs in the morning and he was snoring impressively. So I got my smartphone and recorded the "sleep doctor": snoring...thought it was pretty funny.
im just impressed that you had a smart phone before 2002/ 03, Bruce
hooooo burned !
edit : Alex is the fastest actually for sure, but is VMG is around 2 knots less than the front pack. And he is going to bleed quite a lot of miles to clear the Crozet gate isn't he ?
and he is also going to be flirting with the limit of the icebergs.
For sure he probably had no other choice because of a little bit slower boat, but it seems that next day is going to be painful for him
#1604
Posted 05 December 2012 - 08:02 PM
BP is obviously going for the western end of the crozet gate. He is steering 82 degrees at 17.3 kts and is currently out-sailing the routing (Which calculates 13.3kts), which indicates there is more breeze up near the west crozet east waypoint than shown in the gfs grib. It will be fascinating to see if he makes it around without getting stopped. The current weather file/routing says he will be stopped sometime about noon tomorrow, and fall just behind HB & CP.
Here is a look at the different routes (to the west gate) resulting if you vary his % of polar, the strength of grib winds, and the timing of the grib winds:
bp.jpg 144.51K
84 downloadsHB is obviously going for the other (eastern end of the gate) and is doing just about the polar speed. The routing says he should go further south, but there is ice down there (the reason for the gate) so I will guess he will not go much further. By his course I would guess he has set a southern limit of 44S.
If we guess (based on his course) he does not want to go below 44S, here are the range of routes to the (east gate) based on varying his % of polars, and grib wind speed and timing
HB.jpg 174.2K
97 downloadsCP is steering 84 degrees at 19kts. It's not clear from that what his plan is, but I would guess the eastern end of the gate. HE also appears to have a bit more wind than shown on the gfs gribs.
If we guess (based on his course) he does not want to go below 42S, here are the range of routes to the (east gate) based on varying his % of polars, and grib wind speed and timing.
CP.jpg 234.81K
62 downloadsGamesa steering 98 degrees at 5kts . . . . he is in light air, and the routing agrees (5.7kts BS calculated), but the routing says he should be steering 161 to get out of it ASAP. Not sure why he has been staying up so high . . . ice danger?
#1605
Posted 05 December 2012 - 08:40 PM
He had a chinese gybe because his autopilot ram has dissociated itself from the rudder.
He has been able to pass on the spare autopilot.
But 4 batten are dissociated from the cars
#1606
I'm assuming the charts are Mercator and I'm just trying to get a feel for how much of the curve in their projected courses is account for by great circle sailing.
#1607
Posted 05 December 2012 - 09:07 PM
Estar, I'm wondering if that black line is the great circle route between the two points on your charts?
Had to double check.You can toggle it between rumb line and GC, but yes its set for the GC route between the points.
#1608
Posted 05 December 2012 - 09:13 PM
you gotta check each solution for the gate manualy ?
the software don't know how to deal with this kind of "marks" ?
The packages all have windward/leeward gates, but this ice gate is different because you don't have to round either end (as with a W/L gate) . . . you can just cross in the middle if you want. So, if this sort of gate is in the software I have not found it yet, and I am doing it manually . . . .but it's the first time I have worked with these sorts of gates and they may be buried somewhere or there may be a work around I am not aware of.
The fact that they can be below the ice gates, makes the location of the actual ice a factor, and the risk one is willing to take with it, a factor in the routing. It seems that AT has a higher risk acceptance in this regard than MG or BS.
#1609
Posted 05 December 2012 - 09:46 PM
It's seems more than tricky on the video !
#1610
Posted 05 December 2012 - 10:09 PM
Is that possible that Alex has been "trapped" by the wind, boat speed and sea, and wasn't in any way able to gybe back to the gate earlier because of boat handling ?
I think he hopes the high behind the leading 4 catch them so he can sail back to them with pressure. Looking at their current speeds and distance to the gate I think the 4 will get to the gate and start back south before the high catches them. The worst scenario for HB is to have to sail up to the gate through the high. My thoughts for any of the first 4 is to get up to the gate asap, which would make the western end the favoured end to get to.
#1611
Posted 05 December 2012 - 10:26 PM
Regarding BP, it looks like a very close thing . . . but #1 there seems to be a bit more wind near the gate than shown in the girbs, and #2 BP has already proven relatively fast in light airs, and #3 BP/ALC has shown he is good at this 'aim at the gate in light air' tactic (in th edoldrums and in the St Helena high). So, I give it 70/30 he will get round the gate without being trapped.
#1612
Posted 05 December 2012 - 10:38 PM
MG's Dover straits TSS violation court case tomorrow.
http://www.yachtingm...aces-100-k-fine
Ouch, that's a big (potential) fine, seen a lot more serious acts by commercial/Fishing traffic.
#1613
Posted 05 December 2012 - 10:44 PM
#1614
Posted 05 December 2012 - 11:45 PM
Agreed about AT's strategy. I think he saw he was clearly not going to make the western end of the gate before the low. So the best choice was to split with the french and hope the high traps them. There is no real downside in that choice for him, and big potential upside. But that video is pretty dramatic . . . one mistake in those conditions and there would be serious consequences.
Yes I like running the slider on the tracker slowly through the race to see what each boat in turn has done. BP has not tried to dodge the light air as much and has sailed a straighter course.
#1615
Posted 06 December 2012 - 05:40 AM
#1616
Posted 06 December 2012 - 06:03 AM
I think there was a discussion during the last Volvo about how often the boat sailing the shorter course was the winner.
It definitely seems to be a part of Armel's strategy.
#1617
Posted 06 December 2012 - 06:38 AM
Macif's tracker is gone again !!
Yeah, the Golden Boy is too fast for the sat to catch him !
#1618
Posted 06 December 2012 - 11:12 AM
http://blogs.lexpres...rancois-gabart/
#1619
Posted 06 December 2012 - 11:34 AM
Are these tracking errors strategic?
#1620
Posted 06 December 2012 - 11:46 AM
I had to scratch my head a little bit to get the video, cause it's not on youtube or dailymotion, but it's ok, I got it and I'll start subtitling soon !Hi everyone, I've been following this forum for a very long time but this is my first post (I know all about the newbie initiation
). this may have been posted before but I haven't seen it anywhere, is there any chance either Popo or Laurent can translate this video about the tour of Macif 60 by Francois Gabart? Thanks
Tanguy de Lamotte is having troubles.
the same in video !
AIS at work !
#1621
Posted 06 December 2012 - 12:01 PM
Now BP is AWOL.
He's on there doing 0, don't like to wake up here on the east coast and check in to see zero's. No notes on the main VG site.
#1622
Posted 06 December 2012 - 12:30 PM
#1624
Posted 06 December 2012 - 01:55 PM
At the 0800 position report he was just past the gate doing 11.7kts. It looks like a brilliant move.
Using the 0800 positions it puts him in the lead, CP second +5hr, HB and MA tied for third +7hrs, and VBP at +8hrs, and G at +16hrs
FG/MA must be kicking himself for bailing out to the south and not following BP.
I will do a closer look when we get the 2000 positions, but its all going to be down to how much the high slows everyone behind BP.
#1625
Posted 06 December 2012 - 02:18 PM
It seems to me that Armel will be sailing away...he is free to go having passed the gate. For all the boats in the South it will be painful to climb up to this gate. AT is really far out...
#1626
Posted 06 December 2012 - 03:08 PM
The 15.00 U.T poll rankings do not take the gate into account ! It shows ALC behind FG when he is actually miles ahead !
(and The Daily Sail predicts he is going to extend very much in the next days)
#1627
Posted 06 December 2012 - 04:05 PM
12/06: BP working has way out of the high, while the others start to come up to the gate (BP=dark blue, Ma=pink, CP=light blue)
612.jpg 134.98K
107 downloads12/07: BP down in the wind, while the others arrive at the gate
712.jpg 134.19K
121 downloads12/08: Everyone back down in the wind
812.jpg 127.43K
101 downloads12/11: a southern ocean low drives a trough which pushes off the high pressure as they arrive at the A-gate
1112.jpg 131.53K
75 downloadsTwo cautions:
#1 there does seem to be more wind in the high pressure up at the gate than is shown in the grib files. What is there will be critical. The following boats could get seriously stuck if there is less wind, but lose less time if there is more wind.
#2 I am not sure how deep BP will be willing to go. I have put a 44S limit on the routing. I suspect he will not even go that far.
#1628
Posted 06 December 2012 - 04:06 PM
And, looking at the tracker, even the gate wasn't enough to keep everyone out of the ice area.
It's going to be very interesting to watch this race develop over the next few days! I'm guessing that we may see ALC pull out a substantial lead. I'm wondering if this may allow some of the following trio to close the gap on Macif, Hugo Boss & CP as well.
#1629
Posted 06 December 2012 - 05:31 PM
Bonehead move of the day (IMHO) was Gabart and JPD going off south. They were within spitting distance of LeCleac'h yesterday and then decided to bail out. I guess according to the tracker Gabart's leading but AlC gets to boogie south and do whatever he wants and they have to fight back up to the gate in slackening breeze and bad angles while AT's bringing up the breeze and sailing hotter angles and Armel is going going to sail a hundred miles or so south and take off in the stronger westerlies.
As Asterix once told Obelix, "he's got a free hand now!"
#1630
Posted 06 December 2012 - 07:18 PM
the oldest man of the fleet in tough conditions !
Bertrand isn't losing his time
#1631
Posted 06 December 2012 - 08:13 PM
In past races I think either of those two moves would have given the boat a commanding lead, but in this race the top pack is so alert even these brilliant moves only seem to gain 5-10 hrs.
2000 routing looks the same as 1600. I would guess that ALC/BP will gain more than is shown here because the boat seems so good in the lighter stuff. This race, with the added ice gates, has been shifted in a way that suits him.
(dark blue = BP, Pink = Ma, Light blue = G)
vendee.jpg 114.42K
75 downloads
#1632
Posted 06 December 2012 - 08:44 PM
Looks like AT's south move is going to work out OK. I'm sure he didn't expect to pass the guys ahead but he needed to make up ground. Yeah he'll be sailing toward the east end of the gate in lightening wind but he doesn't have to gybe again and he's made up a decent amount of ground.
Totally agree with the bonehead award.
I'm amazed at how far AT is going to bang the corner, especially if any of the current Estar found there is running. I know it is what the routing shows but he is quickly providing himself only downside if the breeze doesn't do as predicted.
#1633
Posted 06 December 2012 - 08:45 PM
#1634
Posted 06 December 2012 - 09:02 PM
why AT gybed again? seemed to me he hed ideal course to the east end of the gate
the tracker shows him at 126 degrees at 1800 ut. He is on port gybe in his video interview before 1800 and says he may gybe back ... so I think he must have.
#1635
Posted 06 December 2012 - 10:34 PM
Thanks
#1636
Posted 06 December 2012 - 11:04 PM
Looking at his website, looks like he has been dodging icebergs....
#1637
Posted 06 December 2012 - 11:28 PM
#1638
Does anyone know how to get rid of the video camera logo off the tracker? Sometimes there are so many you can't see the boats.
Thanks
click on the camera symbol, right side of the screen, just left of the name of first skipper
#1639
Posted 07 December 2012 - 12:58 AM
Thanks
#1640
Posted 07 December 2012 - 01:00 AM
I'm sure it has already been asked, but what is everyone (except BP) doing a long way south of the gate? Are they all going to have to come up to go thru the gate?
Indeed they are all going to have to get up to the gate. AlC has made the move of the race.
#1641
Posted 07 December 2012 - 02:41 AM
Maybe, ............. looks like a mine field for everyone over the next 36+ hrs.
#1642
Posted 07 December 2012 - 03:56 AM
"Each hour that goes by they will feel the wind getting lighter in strength and moving more to the west. Banque Populaire has already passed the Westerly mark this morning and at some point this morning the rest of them will have to gybe for their final approach to the ice gate. HUGO BOSS being the furthest south of the leading pack will have the stronger winds of the group and will most likely be the last to gybe and should make some good gains on the other four front boats and extend on the boats behind . But there is no avoiding it, all five leading boats will get caught in the high pressure before they reach the gate and the pace will slow."
#1643
Posted 07 December 2012 - 04:21 AM
I'll just twiddle my thumbs until Estar come along.
These gates are having a massive effect on the race strategy.
#1644
Posted 07 December 2012 - 04:51 AM
Anyone care to guess how many hours before BS and FG actually make the gate? Then how long they stay hung up in the high?
#1645
Posted 07 December 2012 - 08:32 AM
Posted 07 December 2012 - 08:38 AM
on another note the latest english update is the fourth? one that is still in french!? wtf they should hire popo already!
#1647
Posted 07 December 2012 - 08:42 AM
The other 3 are down to ~12kts and look to be heading for the dead centre of the system directly above gate.
Yuck.
#1648
Posted 07 December 2012 - 09:36 AM
Fined £9,381 and costs against him of £4,125.
#1649
Posted 07 December 2012 - 12:10 PM
BP in the lead, with CP second (+4hr), MA third (+5hrs), VBP (+7hrs), HB (+9hrs), and G (+1d 10hrs). This assumes BP will go down to 44 20S. I suspect he will not want to go that far south. If he only goes to 43 S it costs him an hour. BP is now sailing at exactly the routing course, so the grib winds are probably now more accurate.
Routings (BP blue, CP pink, Ma green, vbp light blue, HB (flesh color), G brown)
vendee1.jpg 151.32K
79 downloads7/12 BP (blue) still working his way slowly out of the high, while CP (pink), MA, VBP, & HB (flesh color) enter it.
712.jpg 146.02K
65 downloads8/12 BP out of the high and gybed toward the next gate. CP rounded gate and starting to come (slowly) south. HB at the gate in very light winds
812.jpg 110.1K
34 downloads9/12 Main group starting to get breeze. You can see a trough coming in from behind. This is what save the followers from getting killed by BP. With this trough they don't have to sail as far south in light winds as BP has to.
912.jpg 108.86K
38 downloads10/12 All firmly in good breeze from the trough.
1012.jpg 153.21K
29 downloads
#1650
Posted 07 December 2012 - 12:26 PM
#1651
Posted 07 December 2012 - 01:51 PM
from Wavre
and from Le Cam !
and the Golden Boy
#1652
Posted 07 December 2012 - 02:10 PM
Suck it Alex !
#1653
Posted 07 December 2012 - 02:26 PM
Shure ?
#1654
Posted 07 December 2012 - 02:27 PM
Suck it Alex !
Thanks again for the translations, PoPo. Very much appreciated.
#1655
Posted 07 December 2012 - 03:00 PM
hard times for Stamm !
PS : I'd never seen inside his boat, my god how raw it is !
#1656
Posted 07 December 2012 - 03:26 PM
Pick up a can of paint.... its kilos of weight. When you spend an astronomical amount of money to reduce weight in the boat, you don't willingly slap more weight onto the boat unless it really needs to be done. I painted only those surfaces that there was a reasonable chance that I would come into contact with, simply to avoid picking up glass splinters. otherwise, the lightest solution is to leave it unpainted.
#1657
Posted 07 December 2012 - 03:35 PM
#1658
Posted 07 December 2012 - 03:43 PM
BP is pretty much doing exactly the routing - suggests his wind is as shown on the gribs.
CP and VBP are sailing more northerly with more speed, suggesting they have more wind as they approach the high and they have already gybed (which MA seems not to have done yet)
HB is about the same speed as the routing but on a more northerly course - he may be sailing more northerly to keep the angle hot and it does not hurt him as he can cross the gate anywhere.
actual routing, actual routing
BP: 162 vs 157 , 11.1kts vs 11.8kts
CP: 359 vs 020 , 10.3kts vs 7.1kts
VBP: 014 vs 041 , 9.4kts vs 7.9kts
HB: 036 vs 055 , 11.0kts vs 11.4kts
#1659
Posted 07 December 2012 - 04:11 PM
From the 1600 positions . . . Looking at actual course and speed vs the routing program recommendations . . . .
Estar, can you throw in a factor for current into the routing?
#1660
Posted 07 December 2012 - 04:59 PM
Yes, the easiest way is to have a current grib file. They are easy to get for the Atlantic - from the RTOFS model.
It is a little harder and probably less accurate in the Indian ocean but there is data, like this . . . .
current.jpg 153.51K
22 downloadsGenerally its about .5kts ENE but as the above pic shows the details are locally wind driven.
#1661
Posted 07 December 2012 - 05:41 PM
now I've had a good look around another useful tool.
it appears a little weird to see them sailing up to a virtual mark then gybe around it and head south. I hope no one hits it.
I think Armel/BP is doing to the following 3 what JPD did at the previous gate. It is amazing to see him hunt the breeze so aggressively 11.1 knots of boat speed but only 4.7 of VMG. I'm sure he is sailing to his routing polars, though.
#1662
Posted 07 December 2012 - 06:11 PM
AlC's gotten rolled a bit harder than I'd guessed but I think it's still the better choice. The others particularly Gabart and Stamm have to sail almost north to make the gate plus maintain a decent wind angle once they get to the gate they'll have to tack or gybe (either way it'll be light air) and come back almost south to have a decent angle i.e. terrible VMG. Another thing to consider is they will need to take some time to ensure that race control verifies they've crossed the gate (I assume the penalties for not obeying the gate are severe). Once he gybes Armel is going to boogie of downwind "at a high rate of speed". The only problem is ice...
Seems like Bernard is quite stressed. He says he's breaking things but other than hydro-gen problems and a stanchion he mentioned we don't know what else. The inside of his boat is a wide open space i.e. it doesn't have the line guides and struts that a lot of the other boats have because of the small coachroof and flat deck. It's allowed him to have a slick stack machine but at the same time in a lurch he could end up taking a huge header into the other side of the boat. I'm surprised more of the skippers don't sleep in hammocks or hanging cots - a little bungie and you'd be pretty secure and at the same time isolated from some of the boat movements
#1663
Posted 07 December 2012 - 07:34 PM
gennak issues
worried about what's to come Golden Boy ?
#1664
Posted 07 December 2012 - 07:52 PM
Never thought I'd see where you could almost call overlap in an ocean race...
I always try to see who is stacking and who has stuff to leeward. Francois, the `Golden Boy' seems to do it, always. The last 12 hours has seen a lot of gybing in the following 4 (I still regard them as following) so executing the gybe then stacking would be tiring. I saw Francois had a headsail bagged and strapped down aft on the side deck against the stanchions. I hope he doesn't `stick it' and do damage in the fresh winds.
#1665
Posted 07 December 2012 - 09:06 PM
But they are only doing 2.6kts and 2.9kts.
But the wind is 'supposed' to build a tiny bit very shortly and come a little forward, and the router has them doing most of the rounding at about 6-8kts of boat speed.
Very hard to predict. They may come to a dead stop (the real solid breeze is forecast to fill-in in 24hrs), or CP may be around by mid-night if they can hold 6-8kts of breeze forward of the beam (what the router says).
BP has gybed, so it looks like he does not want to go much below 42S. He looks like he is now dead on the great circle route.
At this report golding was 339nm behind BP, but when BP gets to the A gate he is predicted to be 643nm behind. (has to go to the C gate, and then has to stay high to get over a light air bubble . . . but that's speculative as it's too far out for forecast accuracy).
#1666
Posted 07 December 2012 - 11:11 PM
CP now 23nm to the gate, and Ma 40nm.
I think 2.6 and 2.9 knots is a dead stop! Those big roached mains would flap hard enough in a swell to move them at that pace!
At least Alex T will get to catch the other 3 and join them in the parking lot.
If Armel/BP can average 15 knots for the next 24 hours he'll end up with a 100nm lead (min) and continue to extend it in the fresher winds to the south.
#1667
Posted 07 December 2012 - 11:37 PM
Full shuffle re-deal. The high is parked over the eastern end of the gate with the four of them inching towards LESS wind.
Armel may very well be gone. I'm not sure I like the ice gate for this reason but the rules are the rules. Biting the bullet early is looking good right now.
#1668
Posted 08 December 2012 - 03:47 AM
#1669
Posted 08 December 2012 - 04:24 AM
#1670
Posted 08 December 2012 - 04:57 AM
2.6 knots at 40 degrees S in the Indian ocean in an IMOCA 60. AKA - parked!
I don't know, for me the ice gates make it much more interesting tactically. Sure it's great to watch boats surfing down the waves at 20+ kts, but this is an amazing chess match and I wouldn't be surprised if at the end the leading group end up a few miles from each other.
Although this should go under a Vendee Globe 2016 thread, but here is a vid about Nandor Fa's boat being built in Hungary at Pauger:
The part about the new boat starts around 2:00. The boat, Spirit of Hungary, was designed by Nandor Fa and Attila Dery. Hull should be ready by February and will be splashed in Slovenia in June as reported by sailing.hu. Plan is to do multiple IMOCA races then the Vendee!
#1671
Posted 08 December 2012 - 05:09 AM
#1672
Posted 08 December 2012 - 06:55 AM
we did a boat tour of Cheminees Poujoulat at the pontoon in Les Sables before the race. Fairly interesting. Extremely interseting interior layout and very spartan. Coolest stacking system in the fleet. Do a serch for it.
#1673
Posted 08 December 2012 - 08:14 AM
nice video, it's a lot of black !
#1674
Posted 08 December 2012 - 09:35 AM
Yes, in a way, there is definitely more ice than a decade ago. As the amount of ice had increased, so ice gates were introduced. The ice gates are keeping the competitors at lower latitudes, therefore in lighter winds.Is global warming contributing to light airs in Indian ocean?
In the latitudes that they sailed in a few years ago the wind strengths are the same as they have been for millenia.
#1675
Posted 08 December 2012 - 11:59 AM
It appears the reality is matching the predictions and Armel will regain the lead, but it hasn't been a knockout blow this time.
#1676
Posted 08 December 2012 - 12:17 PM
the two grandpas are still together !
mostly for ladies !
#1677
Posted 08 December 2012 - 12:51 PM
Armel is only 20nm behind Francois and doing 13.5kts to Francois's 3.5kts.
Exactly. Everyone got around the gate last night. They still have to dig out of the high but wind is filling in from behind and ALC/BP came out with a 2-3hr lead. BP has stayed at 42S and as predicted has paid about an hour for not going further south. MA (AKA the golden boy) somehow managed to get around CP and into second place in the rounding - I suspect his work rate was higher but this design is also obviously terrific in light airs.
Routings ; BP (blue) in lead, M (green) second +2:23hrs, CP (Pink) third +2:53hrs, VBP fourth (light blue) +3:08hrs, HB fifth (salmon) +6:14hrs, and G (darkest blue) +1d 1h. Pretty much a straight line boat speed contest from here to the A gate.
vendee.jpg 166.27K
52 downloads12/08, everyone (in the front 5) around the C gate. BP in wind, the others still digging out of the high. But you can see the center of the high is past them and moving away and wind is filling in behind.
1208.jpg 104.38K
44 downloads12/09 Everyone in wind. You can see the trough coming from behind pushing the high out and bringing nice winds.
1209.jpg 160.62K
24 downloads12/10 Trough develops a circulating low, which does not bother the front pack but makes golding's group go extra distance to get above it
1210.jpg 126.96K
17 downloads
#1678
Posted 08 December 2012 - 12:56 PM
So much for the global warming scaremongers !
#1679
Posted 08 December 2012 - 01:43 PM
Um........... It's the warming that is dropping the ice off at a rapid pace.
#1680
Posted 08 December 2012 - 01:53 PM
Interesting…So if that plays out they leave the Crozet gate pretty much as they were when approaching it despite the different routes taken.
#1681
Posted 08 December 2012 - 02:47 PM
#1682
Posted 08 December 2012 - 03:12 PM
12/12 just as he leaves the Amsterdam gate he runs into headwinds (green line BP, blue line G/MG). You can see to the right that BP has managed to ride the trough all the way basically from tommorow thru the amsterdam gate to the Australia gate
1212.jpg 90.33K
34 downloads12/13 these headwinds are driven by a tropical storm dropping south right at him . . . this is cyclone season and the ice gates do keep the boats closer to their paths
1213.jpg 182.83K
32 downloads12/14 It's a very close encounter and he needs to go over the top of the storm
1214.jpg 169.25K
21 downloads12/15 then approaching the Australia gate he is in the light left over slop after the storm passes
1215.jpg 96.72K
19 downloadsG loses more than a day in all this.
#1683
Posted 08 December 2012 - 03:18 PM
Great job !
#1684
Posted 08 December 2012 - 03:37 PM
bp.jpg 92.09K
58 downloads
#1685
Posted 08 December 2012 - 04:29 PM
5 hrs later and Armel has put 31 miles more under his belt and is now 11 miles ahead of Macif. He is doing 16 knots and is extending his lead.
#1686
Posted 08 December 2012 - 04:44 PM
Interesting the different courses that MA & HB (more easterly - going for the shortest distance) are taking from CP & VBP (more southerly - going for the quickest breeze). It will be interesting to see if one pays off more. The router thinks they should be going east (95 degrees)
This is an important fight because if the tropical storm develops as predicted the leader will have more wind and every mile back will have less wind, so the rich will get richer.
By the way, thank you Estar for all this, it makes the whole thing much more interesting to follow.
Great job !
My pleasure. popo is the one doing the harder work and deserving of the praise .
I am going to be ruined after this exercise for routing my own 7kt boat!
#1687
Posted 08 December 2012 - 05:10 PM
Great job !
+1 from here. Particularly appreciated as I have the impression the cartography and commentary provided by the VG official site is weaker than last time in terms of content (or maybe I haven't looked at it as much as I've found this place).
#1688
Posted 08 December 2012 - 09:19 PM
Cali knows how to live !
Le Cam geographic !
#1689
Posted 08 December 2012 - 10:27 PM
OR you could just go for a quicker boat...^^
Great job !
#1690
Posted 08 December 2012 - 10:55 PM
storm2.jpg 230.47K
49 downloads
#1691
Posted 09 December 2012 - 02:38 AM
Thank dog for Estar and Popo!
#1692
Posted 09 December 2012 - 05:04 AM
Bollocks,what is Potter was saying is that there IS MORE ICE this year than a decade ago !
#1693
Posted 09 December 2012 - 06:21 AM
#1694
Posted 09 December 2012 - 06:31 AM
Oh dear......there is more ice further north because it is breaking off from the bigger bergs that have historically been further south and well out of the yachtie's way. The bergs are warming up and breaking up.......not good my friend, not good.
#1695
Posted 09 December 2012 - 08:39 AM
ALC was 12 miles in the lead before the move (5-12), later today they will sail on the same latitude you can see what the gain is. Around 50 miles, so he won. Not much, but being in the lead and gaining is good for moral.
#1696
Posted 09 December 2012 - 09:19 AM
Macif also got a shorter route to the next gate it seems,
#1697
Posted 09 December 2012 - 09:50 AM
#1698
Posted 09 December 2012 - 10:13 AM
The race hasn't started yet. The biggest let down for me is Mike Golding Gamesa. He is no where near the leading pack. Macif to win if it doesn't fall apart.
I presume you were joking about Mike Golding, he is a good sailor, but not a racer in this company.
#1699
Posted 09 December 2012 - 10:59 AM
For sure, but he won't put 100 miles to everybody, will he ?
You are right on lead, this being said, I'm wondering if the step-up in racing level and boat speeds (average whatever the conditions) we see this year, is not driving the race towards Figaro and/or cycling Tour de France style.
I.e: no more clever flyers but shaking up the fleet at key points to distance one competitor at a time (Dick does not seem to get too well out of Crozet) , next key point, next shake-up.
Would not that fit with a "jackal" technique ?
Of course, the overall weather and course picture is different this year, and ..... we are not yet half-way.
We'll see
#1700
Posted 09 December 2012 - 12:31 PM
I thinks, without breakage, if the close race stays like this for a long time, it's clearly advantage Le Cleac'h !
