Vendee Globe 2012
#101
Posted 02 May 2012 - 04:37 PM
On 2 May, at 1540, whilst training off Thorness Bay, Isle of Wight, in 12 knots of wind, Mike Golding’s IMOCA 60, Gamesa, was dismasted following a suspected failure in the furling gear. Mike Golding, and his crew of Graham Tourell (Boat Captain) and Mike Ferguson (Preparateur) were all unhurt in the incident.
The mast has been recovered to the deck, in one piece, and the team are currently returning Gamesa to her berth at Ocean Village, Southampton.
More information will be released as it becomes available.
Released: 2 May 2012, 1700 BST
another dismasted imoca
#102
Posted 02 May 2012 - 05:08 PM
https://www.facebook.com/mikegoldingyachtracing
#103
Posted 02 May 2012 - 09:23 PM
#104
Posted 02 May 2012 - 09:54 PM
Future fibres rig?
yup, they haven't had the best of starts to building rigs...
#105
Posted 02 May 2012 - 10:07 PM
#106
Posted 02 May 2012 - 11:40 PM
I think future fibres are going to have an extremely hard time in recovering from this...
What's their count now?
HW
#107
Posted 03 May 2012 - 12:04 AM
#108
Posted 03 May 2012 - 06:55 AM
#109
Posted 03 May 2012 - 06:59 AM
#110
Posted 03 May 2012 - 08:01 AM
This looks and reads like the result of not having a fixed forestay - no fixed forestay, a halyard lock or some other part of the furler system fails, and down comes the mast. I don't think FF makes halyard locks do they? They very likely have nothing to do with the rest of the headsail handling system, so laying this at their doorstep right off the bat seems pretty presumptuous.
Just looking at the picture shows the rig to be in one piece, so hard work to lay it on FF as you say.
As for fixed forestays, every IMOCA 60 has one, it is part of the rules. However, the definition of 'fixed' does not mean that the furling gear cannot be part of it (apologies for double negative).
#111
Posted 03 May 2012 - 11:15 AM
#113
Posted 04 May 2012 - 08:07 AM
I am not sure what Mike has on the FF rig, on the previous 2 Southern rigs for that boat it was just a standard pin fitting through an eye (same as Aviva). I would be surprised if it was on a lock, as that would seem to be unneccesary weight high up. The designer was actually the same between the two companies so he had a lot of history with the 60s.I am familiar with the fixed forestay as part of the IMOCA rules, but I've also read (I think from Rail Meat in a Class 40 thread) that Ecover did not have one and relied entirely on the halyard lock, and furling gear, of whichever headsail was deployed. I forgot Gamesa had got a new rig with the name change and has most likely done away with that system to comply with the rules. Indeed, pretty much all the IMOCAs, Multi50s, and G class multis I've wasted countless hours studying photos of seem to make the solent furling gear part of the permanent forestay.
From Gringo: “It is a sorry picture behind me as you can see. The Solent drum basically exploded while we were sailing in the Solent [off the Isle of Wight], causing the rig to come down, in one piece, thankfully. You can see the aftermath of it and we are getting ready to crane it off and see what damage lies beneath.
“If there was any luck involved in the dismasting, we have probably had it today because it was perfectly flat water, luckily the rig came down straight on the back of the boat and didn’t go in the water otherwise we would have had hull damage as well, so we will wait and see what lurks beneath.
“It all seemed to run in slow motion. Obviously a big bang, then as the rig started falling backwards, it was a case of getting everyone clear. Mike and Mikey were both in the cockpit and I was just up looking up the rig and as it went bang, I had to dive out the way of it. It was very calm and controlled on board, rather than all going round and cutting lines. We all have enough experience where you don’t go into a flat spin and panic, it is just a case of letting the dust settle and see what we are dealing with.
“What happens now? The mast will be craned off the boat, then the main [sail] off, which is trapped underneath the rig, daggerboards have to come out, then the surveyors come and test the integrity of the rig to make sure it is fine, even though it is in one piece, we need to make sure there is no damage, same with the sails, everything will need to get looked at as there will have been big spike loads as the rig went. Once we have everything off the boat, that is when the work begins really.
“We’ll take it all in our stride and get Mike out sailing again as quickly as we can. Any sort of saving grace is that we have time to put the boat back together again and get Mike in tip-top shape for the Vendée Globe. If it were two months before the Vendée, we’d be in panic mode, but as it is at the moment we are fine.
“There has been a lot of talk recently about rigging partly because of what has been happening in the Volvo and we have been monitoring it closely, but what has happened today is absolutely nothing to do with the rigging, it is blatantly obvious that it was 100% one of the furling drums that exploded, which there is absolutely nothing you can do about it, to prevent it or foresee it. It is one of those bits of kit that shouldn’t be failing. As far as the whole rigging discussion goes, there is no question about what has happened here, it is not related to rigging whatsoever.”
#114
Posted 04 May 2012 - 08:50 AM
#115
Posted 04 May 2012 - 11:22 AM
Or more likely that he worked with Mike for years before Artemis. You should get a chip on the other shoulder to even yourself out.And why is it that twat Tourell from Johnny fame happens to be there? Coincidence no doubt.
#116
Posted 04 May 2012 - 05:33 PM
#117
Posted 05 May 2012 - 01:31 AM
Truthy assaulted him during an argument about how either of them were ever going to get a job involving boats.
#118
Posted 16 May 2012 - 02:09 PM
Hugo Boss new look revealed: paint
The boat will not be the Juan K: "Confirming that the Farr designed yacht, purchased in 2011, will be used for the 24,000 mile race, following successful performances during the Transat Jacques Vabre and B2B race in 2011, Thomson showed the impressive new chrome-effect which has been applied during its recent refit."
C.
#119
Posted 17 May 2012 - 12:09 AM
#120
Posted 17 May 2012 - 05:26 PM
Very cool the chrome paintjob, looks more modern
Every girl crazy 'bout a sharp dressed man.
#121
Posted 30 May 2012 - 03:08 PM
Groupe Bel dismasted close to the Azores
third dismasting or i have lost counting already
#122
Posted 30 May 2012 - 09:09 PM
#123
Posted 31 May 2012 - 02:16 PM
Really? The first was at the start of the Vendee 4 years ago, when was the second?and another imoca dismasted before vendee globe.
#124
Posted 31 May 2012 - 02:50 PM
#125
Posted 31 May 2012 - 03:54 PM
#126
Posted 31 May 2012 - 04:32 PM
i mean imocas this year.
maitre coq, gamesa, groupe bel
#127
Posted 31 May 2012 - 05:37 PM
Ah. I guesss the thing with IMOA Class is that you cannot point a finger at any single thing, as the rigs are all so different. The fact of the matter is that they can fail for 1000 different reasons, and the mast is essentially the single most obvius weak point.
Hope those 3 are fighting fit for November.
#128
Posted 01 June 2012 - 02:58 PM
#129
Posted 11 June 2012 - 10:57 PM
Classement de la deuxième étape de l’Europa Warm’Up (à 18h dimanche)
1- PRB (Vincent Riou, FRA) arrivé dimanche 3 juin 2012 à 11h22’50’’ en 7j18h22’50’’
2- MACIF (François Gabart, FRA) 7j19h33’58’’
3- Banque Populaire (Armel Le Cleac’h, FRA) 7j22h11’15’’
4- Cheminées Poujoulat (Bernard Stamm, SUI) 8j00h16’17’’
5- ACCIONA 100% EcoPowered (Javier Sanso, ESP) 8j21h12'22"
Abandons : Virbac-Paprec 3 (Jean-Pierre Dick), vérin de quille
Groupe Bel (Kito de Pavant), démâtage
#130
Posted 12 June 2012 - 06:51 AM
Wonder is Stamm beginning to wonder if he's sailing a lemon?
#131
Posted 12 June 2012 - 08:21 AM
Gamesa's failure was on the (IMOCA required) fixed forestay which all IMOCA's must have to prevent such an occurance, in this case, rather unexpectedly - the actual furler broke! The failure was on the metal part exending from the sealed bearing at the base of a single line furling drum, which basically sheared inside. Just to be clear our FF rig and rigging was absolutly not a factor and fortunatly (if you can say that about a dismasting) the mast was relatively undamaged only needing one of the spreader roots replacing. This work is underway now by FF and with any luck we will be out sailing again in a few weeks time. Just one of those things - but as has been said already - better now than this coming winter...
if you hadnt dropped the rig were you planning on doing the Europa Warmup?
#132
Posted 13 June 2012 - 10:30 PM
Maître CoQ, the monohull on which Jérémie Beyou will start the 2012-2013 Vendée Globe this coming November, was christened on Sunday in Les Sables d’Olonne. Its prestigious godfather, French swimmer Alain Bernard, traditionally broke the champagne bottle on the boat’s hull during a ceremony also attended by Michel Desjoyeaux, Vendée General Council President Bruno Retailleau and Maître CoQ General manager Stéphane Sallé.
story here
#133
Posted 14 June 2012 - 12:06 PM
#134
Posted 14 June 2012 - 02:34 PM
#135
Posted 14 June 2012 - 03:52 PM
Not sure why Stamm went for a JK design, the last effort wasn't very successful.Fair play to Riou, could be a good punt for the Vendee.
#136
Posted 14 June 2012 - 10:53 PM
Same, but things are far from settled... Think Acciona might have some legs when Bubi is up to speed? He won't be in for the win I'm sure but I think he'll do well if he finishes
#137
Posted 16 June 2012 - 10:11 AM
http://www.zoltek.co...-racing-vessel/
#138
Posted 16 June 2012 - 10:53 AM
Just to inspire for the 2016 Vendee, Nandor Fa will be back. Zoltek as sponsor. Hope he will make it.
http://www.zoltek.com/zoltek-to-supply-carbon-fiber-for-around-the-world-ocean-racing-vessel/
Thanks for the info and link, Leo, pretty interesting to see Nandor's business ventures and him building-up single-handed racing on the Balaton, pretty good sailors down there ! Hungarians in the mini someday ?
Posted 17 June 2012 - 07:57 AM
Un-fcuking-believable!!!! A great news, he made it 5th last time he went around, hope he will be at least as much competitive. Hard to decide for whom to root. Being Hungarian, of course, Nandor is the winner, living in France....well that is another story with so many racers....
#140
Posted 17 June 2012 - 12:11 PM
MSafari, glad it made your day. Fa is in my book a Corinthian style sailor. So will be cheering for him...
He knows the money pitfalls etc, so I reckon he will make it.
#141
Posted 17 June 2012 - 01:33 PM
Hi Moody, is that an own Fa design that 77 ? It aint a mini..
LeoV, it was a great dig, you made. Hoped for years that he will have another go, after the failures he had last time. I think one of his boat is still sailed by Dinelli, which proves - at least to me - that he knows how to design one and how to build one.
Though seeing the state Hungary is in now, I doubt a bit that he will be able to get sponsorship there. Hope he will make it, with a great boat. Will go this year to see the start, but will go there in 2016 FOR SURE!
MSafiri
#142
Posted 17 June 2012 - 04:04 PM
No Leo it's not a mini, just a boat for local single-handed racing, from what I read Fa input is launching and supporting a singlehanded racing association with several races a year.
Went through the links in your post
see: association
#144
Posted 28 July 2012 - 02:07 PM
Not very interesting though, kind of a clip rather than a summary of the Atlantic record.
Almost three months to the Vendee Globe now!
C.
#145
Posted 08 August 2012 - 11:47 AM
AT's video here: http://www.youtube.c...d&v=IXf60PQq-Nk
C.
#146
Posted 15 August 2012 - 08:38 AM
On top of Mike's dismasting in the 2008 Vendee Globe and the recent forestay failure dismasting = 3 dismastings , this bloke is having a run of bad luck with masts! I hope he finally completes the race this year...
#147
Posted 15 August 2012 - 05:26 PM
I was reading Robin Knox Johnson's book on the Velux 2006 and there was a good account by Mike Golding about his rescue of Alex Thomson (scary stuff) then his dismasting.
IMO Mike is an excellent sailor who unlike Thompson, has real results behind his bad luck.
If he gets a good Craic at it with Gamesa, which until the mast breaking had proved herself to be a quick and solid boat, I think he could do very well this time round...
#148
Posted 15 August 2012 - 08:13 PM
#149
Posted 09 September 2012 - 11:03 PM
#150
Posted 10 September 2012 - 12:42 PM
Any recent news on the Vendee preparations?
there's a weekly update on the teams preparation status on the French version of the VG website. You can broadly get what it says by googletranslating it into English.
Other than that, I understand there was a training session in Brittany with around ten Imocas last week. Anyone has inside information on the performances of the boats and skippers?
#151
Posted 11 September 2012 - 08:37 AM
Unfortunately, like a lot of events, their budget has been cut so they will not have Andy Robertson for the actual race this time. I think there will only be Fr journos in house this time. There will be written update son the English site, but not of the same standard; also Andy was very good on the audio. Pity.
#152
Posted 11 September 2012 - 02:18 PM
How are your translation skills?Go to the English Language part of the VG site, and you can sign up for English email updates. Also their Facebook page does updates in English, French or Spanish.
#153
Posted 11 September 2012 - 02:41 PM
Terrible still. They have a English language writer doing some stuff, but I will reserve judgement at the moment.How are your translation skills?
#154
Posted 11 September 2012 - 04:40 PM
Is Sam going round this time? She would be a great option for the job.Terrible still. They have a English language writer doing some stuff, but I will reserve judgement at the moment.
#155
Posted 11 September 2012 - 05:30 PM
She is definitely going, for the sake of breton tomatoes !
http://www.samdavies.com/?langue=en
#156
Posted 12 September 2012 - 05:46 AM
Thanks for the link.
#157
Posted 17 September 2012 - 05:35 PM
Can a Brit Win the Vendee Globe 2012-13?
The author does not seem to have a sailing background, or does not describe it, but has a lot of enthusiasm for the event.
Here is some background on her: A Modern Military Mother Does the Vendee Globe
#158
Posted 19 September 2012 - 09:22 AM
Anyone knows how Stamm's Imoca is going vs. other boats (especially Verdier designs)? Someone heard any gossip regarding boat performances after the training sessions in Port-la-forest?
#159
Posted 20 September 2012 - 09:48 AM
http://www.youtube.c...Qk&feature=plcp
#160
Posted 20 September 2012 - 08:43 PM
But I support Tanguy, great guy, and sponsor is great, as is the colorscheme of the boat, I have sailed on a 21 ft version of it
#161
Posted 21 September 2012 - 09:52 PM
Sounds like you may know something?A new IMOCA by Juan K should enter the BWR with Martinez and Fernandez http://pontoon.es/20...andez/#more-734
Apart from Stamm's JK 60, have any more JK boats raced yet? Any news on what happened on that Transat race?
#162
Posted 26 September 2012 - 06:14 PM
http://www.thedailys...ppers-announced
This was news to me: "Bertrand de Broc (famous for the surgery he performed on his own tongue in the 1996 race)"
Wow.
#163
Posted 26 September 2012 - 08:10 PM
Wow.
Yes, as far as i remember he was hit by the boom, chopped his tongue off with the teeth, but managed to call the race's surgeon and stitch it back, guided by phone. maybe it was a bit less dramatic, but I was a teen back then and found it super cool
One of the reasons that got little me interested into sailing (for the adventure side of it, as a pure spectator, before i started sailing then racing myself)...
#164
Posted 28 September 2012 - 09:20 AM
Remember that story as well, pretty tough guy.
Wow.
#165
Posted 02 October 2012 - 08:08 PM
#166
Posted 03 October 2012 - 02:34 AM
#167
Posted 04 October 2012 - 01:04 PM
http://www.yachtingm...-french-skipper
#168
Posted 04 October 2012 - 10:50 PM
Bit naughty of Mark Guillemot to miss his court hearing about breaking TSS rules (allegedly). Arrest warrant issued! How long before the "Perfidious Albion trying to nobble Sam's rival" stories start?
Theyhave already started
#169
Posted 05 October 2012 - 10:56 PM
#171
Posted 08 October 2012 - 09:42 PM
#172
Posted 09 October 2012 - 01:56 PM
I'll see what I can do, but do not count on me for translating all the vid's every day, like for BPV!!! I have a new job, crazy schedule, still married, and I want it to stay that way...
Laurent
#173
Posted 09 October 2012 - 07:36 PM
Does it have hugo boss branding or energa?
#174
Posted 09 October 2012 - 08:15 PM
#176
Posted 09 October 2012 - 11:40 PM
#177
Posted 10 October 2012 - 06:28 PM
Great lineup for start. Seems a hell of lot more interesting than 5.5 boats in the Volvo.
#178
Posted 11 October 2012 - 06:43 AM
I hope Bernard Stamm will be right there as I meet him onc and he is a good guy wich had bad luck last time....so as many....
#179
Posted 11 October 2012 - 01:10 PM
Laurent
Uhhhh, Laurent, some of us absolutely count on you
#180
Posted 11 October 2012 - 08:03 PM
We've got our tickets and hotel booked. Looking forward to the weekend, then a few days in Paris afterward. Never been to either place before.
I'm Jealous..., I'd love to get there to see the spectacle.
I also agree with you about the comparison with the Volvo - that race hasn't held my attention for a longtime now.
The last Vendee was pretty interesting,, and I'm hoping this one will be even better.
As far as I'm concerned, the Vendee is the pinnacle of ocean racing.
#181
Posted 12 October 2012 - 06:26 AM
Laurent
Uhhhh, Laurent, some of us absolutely count on youYour translations have brought me and many others much pleasure- I hope you feel appreciated.
+100
#182
Posted 13 October 2012 - 01:52 PM
Be much appreciated if you could translate the technical boat/rig issues and some of more detailed interviews. There's a lot left down to translation and interpretation.
Laurent
#183
Posted 13 October 2012 - 01:59 PM
Any news on the new JK design? Radical, light, fast, slow, issues etcDont forget Vincent Riou !!!!!!! and armel lecleach.
Seems to have been very quiet on the news about the project.
#184
Posted 13 October 2012 - 03:51 PM
They do say no news is good news, but in this case I'm not so sure.
But who knows, maybe the big boat will scream in the southern ocean?
#185
Posted 14 October 2012 - 01:43 PM
Laurent
+100
+1000000
#186
Posted 14 October 2012 - 03:59 PM
In the last webcast of the "Café de la Marine" that you can see at:
http://www.letelegra...-du-telegramme/
Bernard Stamm seemed happy but not overly confident. He explained that he chose JK not only because he liked him... but also because he was available and could work on the project. He even says (very quickly): "Guillaume did not have the time" (9:20 on the video) so maybe he would have preferred a Guillaume Verdier design...
He also says that they did make some mistakes; some of them have been corrected.
For instance, according to the IMOCA rules, you have to have a permanent stay that must be at least at 2/3 of the mast. They decided to use the staysail as the permanent stay, which means that he had to not only furl but also to take down the TWO front sails, solent and genoa. And the solent goes down at around 22 knots true wind... Getting that baby down, once furled, by yourself is apparently not a walk in the park, in 22 knots true wind... Bernard says: "it was war; you had to take your last neuron, put it in your biceps and stop thinking"!! So they came back to a more conventional set up earlier this year.
When asked it the boat is now ready and the way he wants it, he replies with some hesitation "yeah, it is like I want it, but right now, it's still a teenager!!!"
"It's not easy every day a teenager!" replies the journalist.
"Yeah, it still gives me a "foul play" once in a while" ("coup fourré" in slang French, I am not sure of the translation).
He also explains, with some humor, that you have to create a boat that is going to be better than the other ones... 3 years down the road. Including against the ones that do not exist yet...
Another booboo, apparently, is the shape of the roof. It's too low... Bernard says: "Juan is super happy, because for aerodynamics, it's super good. But when I stand, it's up to here (and he points to his arm, at the height of the biceps... 13:25 on the video). It's terrible, when we are going fast, you have 25 knots of water current on deck..."
And they did that eventhough they build a full scale mock up of the cockpit...
So maybe fast, but not perfect...
Laurent
#187
Posted 14 October 2012 - 09:59 PM
I hope you can give us some transaltion. You have (as others have said) opened the mysteries of these races or record attempts to those of us who are too lazy (or in my case stupid) to learn your language.
Thank you x 1,000,000
#189
Posted 15 October 2012 - 07:37 AM
Last time there were 7 Brits, and American and a Canadian. This time there are just 3 Brits and that includes Sam who will happily do French interviews (and rightly so as she has French sponsors). So there will not be as much direct content as last time.
Looking forward to seeing the start without the stress of knowing that I have to spend the next 3 months waiting for the phone to ring
#190
Posted 15 October 2012 - 11:19 PM
#191
Posted 16 October 2012 - 10:09 AM
doesn't look too slow here http://www.dailymoti...om/video/xu6ahe where stamm is smoking maitre coq (ex-foncia, former VG winner)
#192
Posted 16 October 2012 - 10:52 AM
#193
Posted 16 October 2012 - 12:36 PM
Hi,
Some close-up pictures here...
http://hot-yoting.bl...ndee-globe.html
Awesome!! we need more...
Thanks for those.
#194
Posted 16 October 2012 - 12:40 PM
#196
Posted 17 October 2012 - 12:35 PM
#197
Posted 17 October 2012 - 04:10 PM
Laurent
Thanks again Laurent...
I am hoping Bernard wins it all. Hopefully he keeps this new boat together and just stays competitive, might be all we can ask for with his responses...all I know is he likes to go fast and is always pushing, fun to watch.
#198
Posted 17 October 2012 - 09:15 PM
Thanks Laurent, some of Bernards comments sound a bit ominous. Sounds like JK designed a boat and forgot that a human being has to sail it.
Laurent
#199
Posted 18 October 2012 - 04:27 AM
http://www.ocean-racing.net
#200
Posted 18 October 2012 - 06:06 AM
I notice that on ocean-racing.net you can view the English translation of the French Ocean Racing magazine the last free edition on the web has an extensive artivle on the Vendee Globe and an interview with Mich Desj about the race.
Thanks, that's a great find.....
