stainless steel pins
12 replies to this topic
#1 quasi-expert
quasi-expert
  • 404 posts
Posted 29 February 2012 - 04:17 PM
here is one for the carbon/composite gurus
our whole rigging is connected to the mast with eye terminals and stainless steel pins.
Would it be possible to replace them with carbon rods?
can carbon cope with the shear stresses?
#2 sailman
sailman
  • 7,377 posts
Posted 29 February 2012 - 05:20 PM
The short answer would be no, carbon's high properties are in tension and compression. The pin would be relatively large compared to it's stainless counterpart.
#3 bammiller
bammiller
  • 913 posts
Posted 29 February 2012 - 05:58 PM
We just made up 4 barrel pins out of 13-8 stainless steel; probably could knock 50% of the diameter out of them, compared to 316 stainless, especially after they are hardened. A bit pricey though.
Bam Miller
Attached File  IMG_2677.JPG   289.41K   23 downloads
#4 quasi-expert
quasi-expert
  • 404 posts
Posted 01 March 2012 - 11:06 AM
Thanks for the link. Pretty useful for quick estimations.
But IMO one important information is missing to evaluate this. All the data regarding the shear refer to the fabric plane (so IMO the given shear strength is a result of the resin used, not so much the fibre). For a UD carbon pin the strain would be vertical to the fibres. Anyone have data for this loadcase?
#5 quasi-expert
quasi-expert
  • 404 posts
Posted 01 March 2012 - 11:11 AM
Bam Miller
The diameter would have to remain constant to use the old rigging. I just thought this would be an easy way to save weight aloft as UD rods are pretty cheap (~20$/m for 8mm).
#6 sailman
sailman
  • 7,377 posts
Posted 01 March 2012 - 01:12 PM
Shear is still shear though.
#7 Overbored
Overbored
  • 143 posts
  • Interests:Sailing, Flying, Skiing
Posted 01 March 2012 - 04:26 PM
Look at it this way. I can shear of a piece of 8mm carbon rod with a wood chisel and a light blow with a hammer. try this with a 8mm stainless steel pin. carbon pins are just plastic with the carbon as reinforcement and the shear strength of either does not change when you cover the carbon with the plastic..if you want to save weight then go to titanium. in racing, he who spends the most money wins.
#8 vmg
vmg
  • 1,161 posts
Posted 01 March 2012 - 04:58 PM
Carbon is not good with abrasion, the pin will wear very quickly
#9 Remodel
Remodel
  • 4,859 posts
  • Interests:Sailboat racing and long distance cruising
Posted 19 March 2012 - 05:51 PM
No, this is a bad idea.
How is that for succinct? :rolleyes:
#10 BFD
BFD
  • 105 posts
Posted 19 March 2012 - 07:45 PM
Sure you can use the carbon pins. Just make sure the insurance is paid in advance and have lots of video cameras around the first time you go sailing. Make sure to post the video here. We will enjoy the show.
PS You might want to issue hard hats to the crew and be more than one mast length to weather of any other boats in the area.
#11 Oxygen Mask
Oxygen Mask
  • 6,590 posts
Posted 19 March 2012 - 09:27 PM
Does money spent on beer count?
#12 pickles
pickles
  • 296 posts
Posted 20 March 2012 - 10:24 AM
Didn't some boating magazine in theuk use fiberglass rod as rigging pins to try and break the rig and didn't they in the end have to use a lot smaller fiberglass pins in the end to make it fall over? There was a video of it.
I would not recommend it though!
#13 Presuming Ed
Presuming Ed
  • 6,643 posts
Posted 20 March 2012 - 11:07 AM
