A-Cat info
#1
Posted 08 March 2012 - 07:41 AM
#2
Posted 08 March 2012 - 06:24 PM
http://usaca.info/
You might try both of these sites when looking at the A-Class for information. You are able to send this message out through the usaca.info site. I do not know if you can do this through the Australian site. I do know that there are currently both a Tool and a coupl of Objects for sale through the Australian site.
#3
Posted 08 March 2012 - 07:30 PM
Thinking about switching from a nacra infusion to an a class for a number of reasons. I have been finding it hard to find useful info on the wide variety of designs.... Other than the DNA is the go if you have the coin. Looking at the tool or an object but can't find much info on either so if anyone can fill me in on either that would be great. Cheers in advance.
Go and do it - its a wonderfull class. I dont know the Object, but the Tool is a good boat. Not the same finish as some of the others (it doesnt make the boat faster, anyway;-). It has more volume and less rocker than the flyers, Bimares etc. and compared to the newer designs it has straight foils and narrover transom. Steve Ashby sailed a tool for a while and beat the nikitas that was around at that time (like Glenn Brewin did in his Flyer)
The Nikitas, Scheurer, Visions, DMAs are all good boats as well, but you can get at lot of the joy of an a-cat out of older designs as well (and the difference isnt big, a midfleeter in a new flashy design is still a midfleeter...).
Have fun
Lars
#4
Posted 08 March 2012 - 07:42 PM
#5
Posted 08 March 2012 - 08:01 PM
but the A Group in Aust are a great group of guys
#6
Posted 08 March 2012 - 09:20 PM
#7
Posted 08 March 2012 - 10:00 PM
#8
Posted 08 March 2012 - 10:37 PM
Yeh been looking the objects and tools that are for sale on the aus a-cat site as they are in my price range. After a year or so I'd be looking to upgrade to a competitive design but for the first year it will be a learning curve getting used to the boat and how to set it up. I'm in cairns so the local a-cat scene in very new and small, but have no problem driving around the country to regattas as I do with the F18, so you see me at every nationals/states. Can't help but think I'm going to miss that spinnaker tho lol.
I sail an A and a Nacra 20. I held off a couple of years because of the spinnaker mindset also, but I'm happy to inform you that you probably won't miss it at all. The A will keep you plenty busy downwind and the feel (at least for me) is alot like a spin boat. The acceleration on bearaways, because of the light weight, will feel very familiar. Just do it and you won't look back.
#9
Posted 09 March 2012 - 12:14 AM
Steve Brewin and Glen Ashby.
Steve's ex tool sails out of our club, Im still sailing the capricorn F18. The tool is amazing in light weather, but so are all the a-cats.
In the big breeze and waves, the tables certainly turn, the F18 is a lot more stable and user friendly. horses for courses I guess.
Have fun
Lars
#10
Posted 09 March 2012 - 07:04 AM
#11
Posted 09 March 2012 - 08:51 AM
#12
Posted 09 March 2012 - 06:16 PM
I've pretty much decided to go the a-cat just got to sell the F18.... I will miss the 20knt runs out in the ocean but think I will get over it when I don't have to spend 2 hrs rigging. What I want to know I guess is weather the tool is going to be worth the extra 4-5k over the object given I plan to upgrade once I get the feel for an a-cat?
Your size may have some bearing on that decision also. The Tool carries weight decently don't know anything about the object. All things being equal Scarecrow has the right idea.
#13
Posted 09 March 2012 - 09:10 PM
#14
Posted 11 March 2012 - 02:20 PM
#15
Posted 13 March 2012 - 08:08 PM
thanks!
#16
Posted 17 March 2012 - 10:35 AM
what is the weight range for a newbie A-cat person? have been told 80-85kg, am currently 111kg - maybe I should take on Robnacra's infusion!Your size may have some bearing on that decision also. The Tool carries weight decently don't know anything about the object. All things being equal Scarecrow has the right idea.
SD
#17
Posted 17 March 2012 - 12:33 PM
#18
Posted 17 March 2012 - 01:11 PM
There is no standard size. Different builders and designs use different sized tube beams and some now have "square" beams. IIRC, my Flyer 1 has 90mm rear beam. C-Tech in NZ do a rear beam at 86mm. I believe that some have been as big as 100mm. And it's not just a matter of size. For isnatnce, stiffness can change a lot depending on whether you use high mudulus carbon.Does anyone know the diameter and wall thickness of a carbon, rear, A Class beam? Thanks....
#19
Posted 17 March 2012 - 04:22 PM
------------------There is no standard size. Different builders and designs use different sized tube beams and some now have "square" beams. IIRC, my Flyer 1 has 90mm rear beam. C-Tech in NZ do a rear beam at 86mm. I believe that some have been as big as 100mm. And it's not just a matter of size. For isnatnce, stiffness can change a lot depending on whether you use high mudulus carbon.
Thanks, Simon: do you know the wall thickness of your 90mm rear beam?
#20
Posted 17 March 2012 - 08:28 PM
Sorry, I don't. It's got sealed ends and no way of measuring.------------------
#21
Posted 17 March 2012 - 09:11 PM
#22
Posted 17 March 2012 - 10:01 PM
The object is quite wide in the stern so carries wt very well. Infant is perfectly suited to having a set of curved foils installed. If you are around 90kg that's what I would get to learn on. High volume makes it very easy to sail.
#23
Posted 17 March 2012 - 11:07 PM
#24
Posted 18 March 2012 - 10:34 AM
#25
Posted 18 March 2012 - 10:41 AM
#26
Posted 18 March 2012 - 01:40 PM
I cannot really comment on this save to say that when I got a quote from C-Tech recently they were specifying a 86mm ID and 2230mm long with a choice of high modulus carbon or regular.I found an A Class C-tech rear beam with these specs: 76mm(3") X 2.4 mm( .094") X 2200mm( 7.2')......
#27
Posted 18 March 2012 - 01:54 PM
#28
Posted 19 March 2012 - 01:18 PM
I think Bimare V1 crossbeam (2008/2009) were about 94mm OD with probably 3mm thickness and 3kg for the front-beam
The rear beam of the NIKITA is around 100mm OD but with hight modulus
Cheers
W
#29
Posted 19 March 2012 - 01:20 PM
=========Dough,
Cheers
W
Thanks-any idea about an F16 carbon rear beam?
#30
Posted 20 March 2012 - 09:15 PM
1332021671[/url]' post='3631324']
The object is quite wide in the stern so carries wt very well. Infant is perfectly suited to having a set of curved foils installed. If you are around 90kg that's what I would get to learn on. High volume makes it very easy to sail.1331316974[/url]' post='3619304']
1331276680[/url]' post='3618724']
Thx, this is the sort of info was chasing when I started the topic.
