Thanks for all your input so far. I appreciate it, although I hoped to get different advice.
I am pretty sure now that these are (better say were) Frederiksen sheaves, but I think they are not available anymore.
So now I need new custom sheaves with plain bearing made (probably during the season). I already know someone who can make them.
Obviously getting the pin and hole diameters is important. Anything else I have to look for?
What materials should/could be used? Stainless stell for the pin, bronze for the bearing surface and delrin for the sheave? what about aluminium?
On a 8m long boat, and unless you are using wire for halyards, delrin throughout is perfectly fine; you really dont need a bronze bushing.
I would suggest that you try and use UV stabilized Delrin, as opposed to acetyl, which is very similar, but not quite as good a material for mast sheaves. Black, I think, is the most UV stable. I would also suggest that you get the sheaves sizes as perfectly as possible; we turn our sheaves to a .005 precision - the better the fit, the better the performance. Also make sure that the axle pin is smooth and polished and round; a bolt wont really cut it and will chew up the new sheave in no time. Made sure the outer edges are radiused nicely, or it will beat the hell out of your halyards in no time, if the pull is slightly off axis. Try to mimic the scoring from a current Harken black magic block; the shape is parabolic (called Universal Scoring) and ensures that the line is evenly supported, regardless of size.
Finally, if your machinist is a clever guy, he can sculpt the extra material from the sides, making the sheave lighter and with less area for contact in the sheave box, which will reduce friction as well.
Oh, one last thing, we get $45.00 a sheave, up to 3", so you don't wind up paying too much.
Bam Miller
