Winch Repair
#1
Posted 26 March 2012 - 05:29 PM
#2
Posted 26 March 2012 - 05:47 PM
You really do need to be VERY careful in the size and position of the new slots. It is likely that your old winch is not perfectly round, so it takes some work to get it right. Don't rush. Take a lot of time and measurements to make sure they are exactly where you want them. You need a precise milling machine to measure exactly.
#3
Posted 26 March 2012 - 08:17 PM
We tried doing a similar thing on a pair of 22's, and the voids in the casting were too bad to try and make an effective and reliable repair.
Bam Miller
#4
Posted 27 March 2012 - 02:13 AM
#5
Posted 27 March 2012 - 04:25 AM
Do you have anything less sullen with more tits?
#6
Posted 27 March 2012 - 04:51 AM
Two really is the customary number for breasts ... or tits as you like to call them.
#7
Posted 27 March 2012 - 01:53 PM
Ish,
I like two. I was speaking in terms of more visibility, not more quantity. Breasts sounds so formal.
#8
Posted 29 March 2012 - 10:14 PM
I am working with old barrent winches I have a pair of 32 s/t that have some significant ware on the slots the Paws drop into. I serviced the winches over the weekend. (One is so bad the paw is no longer retained in the slot, when the winch is apart. ) What is the best way to fix this problem? do we have a shop braze more brass on to the slot and re-cut it? can we cut new paw slots at 90 degrees to the old slots? (we have access to a machine shop to do the work, but really don't want to have to cut a new cog/with paw slots if we don't have to) Since the season starts in just over six weeks, i have some time to get this fixed, but I need some advice on the best way to get this done.
Get some tube (brass, stainless etc.) with an id that matches the final pawl pivot hole id. Then with a milling machine, center a bit (which measures a few thousandths under the od of the tube you've procured) over the old pawl slot hole. Bore to full depth. press in sections of tube. Personally to open up the slots for the pawl arm i then chuck and true the drum in a lathe and remove the sleeve where it protrudes into the drum. Not sure if this makes sense as ive written it but my boats got 16 barients of various flavors and ive rebuilt the majority of them. If you can afford it, from a safety standpoint best to replace the winch...
#9
Posted 30 March 2012 - 06:30 PM
Don't bother filling in the old slots. You are better to just cut new slots into the winches. They don't need to be at 90 degrees to the old slots, so long as they are directly opposite to each other. Give yourself lots of space in case you screw up the first and second time. (I speak from experience).
ok .i see .thanks.
#10
Posted 02 April 2012 - 11:19 PM
#11
Posted 03 April 2012 - 04:55 PM
Can you post a picture of your winch opened up?
#12
Posted 03 April 2012 - 07:25 PM
Ish,
Kind of depends of the species, doesn't it?
Four is interesting...
Posted 03 April 2012 - 09:32 PM
On the second winch I got it right the first time. Both of these winches have worked perfectly for 4 years since the repair.
Go for it!
Posted 04 April 2012 - 12:45 AM
Ish,
There's something about bilateral symmetry that just works.
Nice job, Foolish. I never would have thunk of that.
#15
Posted 04 April 2012 - 09:38 PM
Ish,
He did do a nice hob with this, didn't he!
Foolish, how did you do that?
This is Fix-It Anarchy - do tell!
#16
Posted 04 April 2012 - 10:00 PM
Here is a picture of the repair we made! It looks pretty good.
Posted 05 April 2012 - 02:43 AM
Nice job. The old slots did not look all that worn (at least compared to a couple of winches on my boat).
