- It is very convenient for ramp launching (necessary in Boston since there are only two launch hoists in the harbor).
- It is very convenient if you happen to run aground
- It is very forgiving at most speeds and recovers quickly from stalls.
However what is not convenient:
- the 25 lb glass/foam blade
- the 15 lb stainless weldment rudder cassette which leads to:
- the need to repair the stainless almost seasonally, especially after particularly rough passages which may break the welds.
- the inability without modification to keep the rudder from bouncing down into the cassette in choppy conditions.
In addition, the stock rudder has the following performance-robbing "features"
- Cassette drags in the water as you approach planing speeds
- The thickness of the blade is nearly 3" which provides the stall characteristics but also provide a great amount of drag
- Because of the cassette design, the leading edge of the rudder describes an arc behind the pivot on the transom
- This leads to a LOT of weather helm, especially on point to point reaches.
