Code Zeros
#1
Posted 08 May 2012 - 09:19 PM
Our local PHRF rates Zeros with no penalty, so I'm trying to figure out how to slot one in between the OEM/A2, a A3 and the jib.
Kmag's comments about the J125 downwind inventory in another thread are making me think my 2 kite/2 jib program needs some augmentation...
#2
Posted 09 May 2012 - 02:46 AM
#3
Posted 09 May 2012 - 10:17 AM
#4
Posted 09 May 2012 - 02:13 PM
#5
Posted 09 May 2012 - 03:03 PM
I know what a Zero is, and I really don't want to get into a debate about ratings and one design rules (too many people have pushed us down the rabbit hole before).
What I don't know is how the Zero fits into a sail inventory on a FT10 - what TWS/TWA does it work in? A Zero on a FT10 is not going to be remotely like a Zero on a J109 where the Zero can fly into much more wind because the 109 is comparatively heavy and stiff.
Obviously the Zero will work in TWS under 7 knots, and at higher wind speeds but at bigger angles.
I'm just trying to figure out if the sweet spot is big enough to plug the gap between my A3 and jib and justify the money for the 3 races/year when I need to reach.
#6
Posted 09 May 2012 - 03:40 PM
The Code Zero on the red boat was 100% the best sail to have for whenever it got light and we were doing any sort of sailing with the wind at or forward of the beam. Such a huge benefit compared to the small non overlapping jibs. We won Vineyard 09 and Block 10 because of that sail.
#7
Posted 09 May 2012 - 04:37 PM
Ok, maybe I should go back to posting and drinking - I'm probably more clear...
The sweet spot is big enough and it is worth it. By 8-10 knts the wind needs to be closer to the beam. I use it in really light air and waves out here because we only run with the class kite for PHRF and it is a little heavy and unstable in under 5 kts of breeze when the seas are confused. A 1A would be nice here but the boats are not rated for it and I have no intentions of getting one on. Only other sail I want on the Tiger for SB-KH this year is the class reacher we make. The class runner just gets sucked behind the main when trying to reach and it is not efficient at all. Essentially this could be used as a "1A" in the lighter air too.
You will have the Code 0 for as long as you have the boat and will get your money worth out of it.
#8
Posted 09 May 2012 - 08:48 PM
There that good we have 2, one that rates IRC and one that doesn't. They are exceptionally versatile.
#9
Posted 10 May 2012 - 05:06 AM
An A0 or C0 should be designed for an AWA of 30-100 degrees. Large angle I know but as the AWS increases the angle gets greater. At 100AWA in pressure you know when its too much for the sail. Ie 4 knots of breeze 35 AWA, 14 knots of breeze 85-100 AWA.
To answer your question, Most of the people here probably just have one because their Sailmaker told them so, they use it until they cant. Or in some cases don't use it because they don't know when or how.
Ask you sail maker to draw you up a crossover chart and define your current sail characteristics to him/her. Then you can have the sail to fit your exact inventory.. Or don't, up to you!
That is unless you want a pure upwind Zero/MHG, then it should be designed around bettering your Upwind targets, any reaching benefits are just a bonus!
