shortening shrouds.
#1
Posted 25 May 2012 - 06:15 PM
Thanks
#2
Posted 25 May 2012 - 06:19 PM
#3
Posted 25 May 2012 - 06:45 PM
Check out the local small plane airport and find a mechanic. I bet they will do it for you cheap. If you have plenty or room all they are out is a $5 part and the electricity it takes to fire up the industrial swager..... Don't put up with crap service......
Wow, I've never seen plane, mechanic and cheap in the same sentence before!
#4
Posted 25 May 2012 - 06:54 PM
#5
Posted 25 May 2012 - 07:14 PM
Were you at the shop or on the phone. Maybe swinging by with shroud and fittings in hand to talk with the rigger (assuming the lady you spoke to was not the rigger) may yield different results.
#6
Posted 25 May 2012 - 08:13 PM
#7
Posted 28 May 2012 - 12:25 AM
No one in southern central Connecticut will swedge new terminals on my wire probably because of the liability issue. The small airport idea sounds interesting, but can't imagine that they will have dies for 5/32 or 3/16". I don't want to use Norseman type fittings because of the expense for a single year and they're kinna clunky. Anybody know of other professions that need to swedge stuff?
Would it be the worst idea in the world to use wire rope clips (5 per splice) and cover them with shroud rollers? Is this stupid beyond belief?
Duncan
#8
Posted 28 May 2012 - 09:59 AM
Im not exactly understanding why you want to replace the shrouds in a year, anyway. Why not just get it done now, all at once and not have to think about it again. A rigger isnt going to charge you 5.00 to swage a piece of wire. To stay in business, they are likely billing $100/hour. Isnt that what you would charge, if that was the way you made a living?My problem is much the same, but with 5/32" and 3/16" wire for a 30 footer. I'm converting to a fractional rig and although I have carefully laid out everything I want to use the shortened shrouds for the first year to get precise measurements and then get new ones next year. The wire is 316 and in great shape with no problems of any kind at the terminals I want to keep. I've used dye and a magnifying glass and they look great.
Duncan
As yourself - s it that they don't want to do it or that the 100.00 is too expensive? What if that 100.00 was a quarter of the whole job? What is standing in the way with just getting it done?
If you don't have the time or money to do it right (especially on 5/32" and 3/16" wire) the first time, where are you going to find the time and money to do it all over again? Wire rope clips shouldn't even a consideration.
Rant over. Just surprises me that people insist on re-inventing the wheel.
Bam Miller
#9
Posted 28 May 2012 - 02:23 PM
#10
Posted 28 May 2012 - 03:11 PM
#11
Posted 28 May 2012 - 05:20 PM
Duncan
So I saw your other post re: shortening an old Stearns Twinstay by about 30". And you're creating a frac rig out of the existing MH for what kind of boat? Sounds like a lot of work on an obviously pretty old horse.
#12
Posted 29 May 2012 - 03:32 AM
What would you guys do?
Duncan
#13
Posted 29 May 2012 - 12:26 PM
Duncan
Bam Miller
As Bam says why re-invent the wheel.
Use Norseman fittings on the base of the existing shrouds and forestay (You can buy just the wire termination part/ threaded part that screws into the existing bottlesecrews.) When you replace the wire part in the future you just need to buy new cones to go inside the fittings.
You are supposed to replace the insert cones each time but I would be very tempted not to while you are in the adjustment phase if you rig hasn't seen big winds. I Shortened a rig on a 35' one off some years ago due to cracks in the base of the mast - essentially cut 3" of the bottom of the mast and rigging and re-terminated 10 shrouds (Yes a strange rig) and one forestay with new insert cones using the original Norseman Gibb terminals. I still have the removed inserts somewhere that look identical to the new ones we put in.
#14
Posted 29 May 2012 - 12:58 PM
First, the boat is a custom S & S Yawl 1961 that I have totally restored--decks, hull, rig you name it. As I mentioned in another site, although I carefully laid out the old and new locations of the mast tangs, I forgot one key ingredient. I failed to measure the amount of thread used in the turnbuckle body prior to removing the rig last fall. Therefore I can really only guess about length. The uppers and lowers had different turnbuckle engagements and they were even different from port to starboard, but I can't remember which was which. Any photos I have show the turnbuckles all taped up to protect the cotter pins, so that's no help at all. The idea was to come up with a solution for this year that would allow me to get precise measurements for next year. I could easily commission a new full set of shrouds only to find that some either did not have adequate thread engagement or were 'two blocked' with not enough take-up room. So the price issue is only based on temps. Since I already have essentially zero stretch wire, I don't see an advantage in switching to dyneema for an intermediate solution.
Duncan
I should have included this question with the last one. How and why are you converting this to a fractional rig?
#15
Posted 29 May 2012 - 03:18 PM
How--The boat had a straight extruded mast when I got her which I sawed down 12' from the truck in a curving wedge, taking out about 1 1/2" at the top to nothing at the bottom. Wow! At this point the 12 feet was so floppy that I figured I had ruined the spar and would have to start all over again. I built a 20' long truss strongback which I hose clamped to the sail track to make sure that it was straight. Intermediate hose clamps around just the mast were at three foot intervals keeping the two halves of the spaghetti perfectly aligned. Then built a tower of cross braced wood with a horizontal roller at the top in between a couple of cheek pieces slightly wider apart that the spar. Tower is pasted to trailer. A huge swivel pad with side cheek pieces is tossed up on the roof rack at the front of the VW bus and the whole 40' long train is driven 75 miles to the mast guy who perfectly welds said item and adds a beautiful shaped crane/truck to accept the tangs built exactly the way spruce spars were done 75 years ago. Also get sheave boxes for halyards and new pad eye for the fractional forestay. It looks fantastic. The backstay goes into the new masthead crane tang. I cut new upper tangs out of 316 and install them at the new forestay location with compression sleeves and bolts according to the instructions of the mast guy. This is 36" down from the top of the spar. I fill the old spreader base mounting holes and reinstall them 13" lower. Oh, and by the way faux spruce the mast while I'm at it. This is a classic Sparkman and Stephens design from the 60's when real boats were wood, yawls and had wood spars. Which is the why.
Why--Well, I'm and old fart and grew up admiring these graceful craft, many of whom had fractional rigs before the masthead big genny boats became the vogue in the 60's and later. So I just want it as the boat seems to look better to me that way in the scale drawings and models I have made. Jumper struts--I know I'm immediately going to get blasted for this issue. What are you going to do about them? First, I'll try without, but add them if needed. Bolero at 72 feet originally was built without them and so I'll see. She had a true 7/8th rig and I will have closer to a 10/11ths ratio. I'm adding dyneema or some such wizardly line as runners anyway as there is also a new inner jib stay 3' aft of the forestay to cary reachers plus a yankee and all that good 60's rag inventory. Oh yes, the sails are all miter cut.
Any other questions besides why I'm such an alpha hotel?
Duncan
p.s. Think I might have found a friendly boat yard that will squish some new terminals on my shrouds for me, but if that fails I will still need a plan B--Thoughts on that score?
#16
Posted 29 May 2012 - 04:11 PM
Tapering and welding masthead spars is a lot less critical than the same project in an unsupported section. Typically those welds undergo some preheat/postheat process to reintroduce the strength into the spar. It sounds like you're pretty 'retentive'
#17
Posted 29 May 2012 - 05:12 PM
This was supposed to be a 3 year fix-up-sell-and move up project, but that was18 years ago and I still find endless 'modifications' and projects to fry my skull. Here's a web site that explains it all.
http://retrogasm.tum...line-of-zombies
Last year's biggie was to put Dynel on the decks to simulate canvas. The reason that it took 17 years to do that was 100% of the decks needed to be recored and then there were the toe rails and...................... Looks fantastic and is a great nonskid material. New varnished teak winch bases for primaries and secondaries get slapped onto the coamings this year as well as the fractional rig. Two years ago I built my own electric head for $175. Ladies love it and NO odor as it's now fresh water since there is only a pint plus per flush. Do it! You will get big points with the gals (and guys).
Duncan
#18
Posted 29 May 2012 - 05:33 PM
#19
Posted 30 May 2012 - 03:39 PM
You can usually find a rigger that will - if the wire looks OK - swage on new terminals on a cash-only, under-the-table, I-don't-know-you, and you-were-never-here basis.How and why? Well let's start with the how as there is less subjectivity there.
Duncan
That said, if the wire is over 10 years old, you really shouldn't consider re-using it. Now then, even though the rig is down, it shouldn't be any real problem to take a series of measurements and create a scale drawing that will give you the actual measurements to within 1/2 inch plus or minus. I used to do that for customers all the time back in the day when they had lost a rig or were building a boat from scratch.
#20
Posted 09 June 2012 - 01:52 PM
An aircraft mechanic can do this for you, but I'd set an appointment and have it done while you wait. I've dealt with these chaps for decades and I've known several that need a ton of coaching to get things done.
#21
Posted 09 June 2012 - 02:17 PM
I'm very surprised at idea that steel shrouds have to be under ten years old. Aircraft that are 50+ years old are flying with original control cables. Putting on new ones is a hassle as they stretch to a more or less final length. Since this is a component that will kill everyone if it goes wrong, folks tend to take a hard look at them. The inspection criteria is mechanical condition - no frayed or cut strands, consistent smoothness, etc.
Nothing personal but "Fuck off Newb!" Now that that's out of the way.
Typically marine terminals collect seawater down amongst the strands inside the swage at deck level. It's an ideal spot for corrosion to occur and not be noticeable. 10 years is certainly a rule of thumb gauge for replacement. If you're very thorough in your maintenance, or sail in primarily fresh water that number can be extended considerably. 1X19 Stainless wire is very different than the 7X19 Galvanized or IPS cable that would be used on aircraft control cables. It's much more brittle but also stretches less.
#22
Posted 18 June 2012 - 11:53 AM
Duncan
#23
Posted 18 June 2012 - 10:36 PM
Duncan
#24
Posted 20 June 2012 - 01:37 PM
1339251423[/url]' post='3744456']
1339249942[/url]' post='3744431']
Hey Fixit - try rethinking your fucked up response. But wait, that may require THINKING which may be especially difficult for you. Nothing personal tho.
If you re-read the thread the topic , itis about shortening shrouds. Your comment about hidden corrosion doesn't play since shortening shrouds involves cutting them. When they are cut, the integrity of the material will be fully exposed at which time the assessment of its seaworthiness can be made.
As you were.
#25
Posted 20 June 2012 - 02:09 PM
As you were.
Nothing fucked up here, someone commented (not me) that 10 years is the 'rule of thumb' recommended limit for shroud life. You questioned why and I told you what the basic reason is. You might also want to look at the wire at the upper terminals and any bends over spreader tip etc. All these places can experience lateral movement which can work harden the stainless steel. Here's Brian Toss's view that if you can't proof-test your wire every 10 years (3-5 in southern climes) you should replace it. But what do I know
#26
Posted 25 June 2012 - 02:34 PM
Your quote of Homer Simpson is the one extremely accurate self assessment that is spot on. And that's an extremely witty use of a
#27
Posted 25 June 2012 - 06:04 PM
To put and end to all of this in relating to my initial inquiry--Here's the summary.
Yes, you can find a guy who will swage new fittings on old wire. However, he won't be very happy about it and will be even unhappier if you bring the new terminals to him. They could be non spec rejects that an employee lifted from the scrap bin or whatever. In addition he makes no money on that part of the transaction. So by the time that you buy new terminals through him at much higher prices than you will see on line, plus pay for the swaging to say nothing of driving to East Overshoe to his place of business, it's now big bucks. So I bought some Norseman fittings on line with free shipping, no traveling, no waiting time. NEXT YEAR, HOWEVER THERE WILL BE ALL NEW STANDING RIGGING.
Thanks for all your thoughts guys.
Duncan
Ps. Brian Toss is THE guy. On a challenge, he invented an 'icicle hitch' where the pull of the line in parallel to the icicle and toward the point. If you are building a full scale replica of THERMOPYLAE he is the only guy to consider.
#28
Posted 25 June 2012 - 06:11 PM
Duncan
#29
Posted 26 June 2012 - 01:36 PM
Newbi--The wire itself may last for much longer than the ten years that Brian Toss recommends, although as Mr. Fixit and or his brother (not sure exactly here who is who) says and is correct, there could very easily be issues where the wire is stressed at the spreader. You state that the integrity of the wire can be ascertained at the cut, but that doesn't tell you what is going on fro the other 30 or 40 feet. If you look back at one of my earlier posts, you'll see the comment about hidden crevice corrosion that can happen deep within the fitting where it can't be seen and simply cutting it off doesn't mean that there won't be similar stuff going on at the other end. You are right that this thread is about shortening shrouds, which typically means cutting off one end only. If you're going to cut off both ends and put all the money and effort into old wire, it just doesn't make any sense. Why spend $200 and not know if your $1800 mast might come down when for $300 you will be sure.
Duncan
Sounds like you got it licked with a sound solution. I hope you get to enjoy some of the sailing season up there. Will you now reuse the Norseman's on the new rigging or just keep em in your backup box?
#30
Posted 26 June 2012 - 07:11 PM
No, they'll go into the box of crap that 's too good to throw away, but will hang around forever 'cause who want's to risk their rig on a used norseman? Might drop them off at Sam's in Wickford to see it there's a sucker. I really want the full swaged new stuff to be 100% from the rigger. Maybe Newbie wants them to throw at someone.
Duncan
