Secumar anti inversion masthead float question
#1
Posted 13 June 2012 - 03:33 AM
#2
Posted 13 June 2012 - 05:17 AM
That one has a lot of flotation. They are not hard to right even turtled with the board handing below it.
#1 tie the board to the boat securely when sailing. If it turtles it will go to bottom fast.
#2 Never let non sailors drive. Dont ask WHY.
#3 Get a good bailing bucket.
#4 Dont let it happen.
#5 wear a PDF
#6Now Just
#3
Posted 13 June 2012 - 09:20 AM
#5 wear a PDF
#6Now Just
Driftwood is right
secure the board
do not let non sailors drive
or hang on to main sheet
they will take you for a swim
( know this from personal experience )
#7 don't solo sail in cold water
in warm water with help near by
do a test capsize
can you get the boat back up
can you get in the boat
is the cb trunk above water
can you bail fast
i use a 5 gal pickle bucket
solo sail Thistle
capsize
for me hard part is getting back in the boat
mac
#4
Posted 14 June 2012 - 04:48 AM
#5
Posted 14 June 2012 - 04:50 AM
#5 wear a PDF
#6Now Just
#6
Posted 15 June 2012 - 03:56 PM
Thanks. Is it OK to tie off to the main ? This would be if I was using the masthead float and not in protected waters but still quick swim to land (1/4 mile.
NO one hand on de main one on de tiller. Stay with the boat its bigger than you head in the millions of gallons your floating on and u want to live right?
#7
Posted 18 June 2012 - 01:25 AM
#8
Posted 18 June 2012 - 01:43 AM
No. I would still have one hand on the main and the other on the tiller but I would have the main secured to my waist ethier by a knot or attached to a harness with a snap shackle. This would probably make it easier to right the boat but without the risk of it blowing away from me due to the masthead float . Any flawed thinking here ?
The biggest problem I can see is that the mainsheet is always going to be tangled, thus distracting you at best and causing a capsize more often than otherwise.
I would sail without attaching yourslf to the boat; just remember to hang on.
You might consider setting up "righting lines" under the gun'l. This will make it easier & quicker to right and also give you something to grab any time you're getting seperated.
Posted 18 June 2012 - 02:23 PM
Regards,
FM
#10
Posted 26 June 2012 - 06:09 AM
#11
Posted 28 June 2012 - 11:14 AM
Plus there is the obvious risk of getting tangled in it, either whilst sailing or while in the water.
If you do need to get rescued, you want to make it as easy as possible for your boat to be righted. Having the mainsheet cleated or secured to yourself or something else does not make it easy.
