I am using a galvanic isolator. I get that the green ground from my shorepower should go to the isolater right after the shorepower inlet. But then where does it go from the isolator? I've read that then it goes to the 'grounding bus'. Ok, I get that, sorta. The grounding bus is wired to the grounding lug on the engine. Got it. The galvanic isolation circuit (all the green wires attached to metal stuff on board like shafts, thru hulls, etc) is also attached to the grounding bus.
But, isn't the DC 'ground' (Neg) also attached to that bus? If there's a fault in the AC, won't it feed back through the green wire and into the battery? Do all my DC Neg leads go to the grounding bus or is there a different bus this will go to?
I have 2 battery banks of 2x T-105s. One house and one starter. These are wired through a m6011 Dual Circuit plus switch with an Automatic Charging Relay:
I've done a lot of electrical stuff in cars but for some reason I have the dumb when it comes to what I'm supposed to do on the boat. I think the combination of AC and DC on the boat is causing me more confusion than it should.
I guess what it boils down to is if the green wire is basically the same as the DC black (NEG) and do I just wire it up to the negative DC bus (on the left side in the diagram above which also serves as neg bus for DC fixtures)?
