Tapping into large diam electron source
#1
Posted 13 July 2012 - 06:11 AM
The macerator and pump draws around 18 amps, which is too much to utilise existing wiring in the area. However, the heavy cables for the anchor windlass run through the lockers just nearby, so I thought I'd tap into that source. The problem is that I would not be able to solder a 20A wire onto the heavy cables because I'd never get enough heat onto the job to get solder flowing on the heavy wires. So, I've been wondering if there's some sort of mechanical take-off I could use - mechanically clamp to the heavy cables and either clamp or solder to the lighter wiring. I can cut away the insulation from the heavy cables to attach the "takeoff" and seal the joint with self-amalgamating tape to avoid moisture ingress. Preferably no actual cutting of the heavy cables, just attaching.
Does anyone know of such a device? I've never come across one, but you never know what's out there ...
Thanks
#2
Posted 13 July 2012 - 06:22 AM
Instead, chop the cables and crimp on proper lugs. Then join all three with a single bolt, preferably on a post that is mounted to something substantial. Finally deal with insulating the posts so you don't get shorts.
Depending on the distance from your battery, it might be simpler and less expensive to just run a piece of duplex. Similarly, if you're not too far from the windless, you could run the duplex from the windlass back towards to the head.
Good luck!
#3
Posted 13 July 2012 - 06:30 AM
Good luck!
That's what I like about this place - someone usually comes up with something you didn't think of! This is a likely solution, thanks!
#4
Posted 13 July 2012 - 07:21 AM
#5
Posted 13 July 2012 - 03:35 PM
#6
Posted 13 July 2012 - 04:29 PM
Strongly recommend against soldering. First, it makes a brittle connection. Second, it will be very, very difficult to make a soldered splice into heavy cables without compromising the insulation for several hundred mm in each direction.
Good luck!
Third, any circuit protection for the windless (fuse/breaker) will be way to big to protect the smaller wiring.
That would create real fire hazard.
So the new wiring has to have protection of it's own.
#7
Posted 13 July 2012 - 07:37 PM
Good luck!
Fourth, I hope your windlass controls are pretty well secured so can't be accidentally operated, otherwise you might just want to run new wire and leave the windlass alone.
#8
Posted 13 July 2012 - 08:17 PM
that mud on the anchor looks awful sticky
Is that corn I see???
(I'm really sorry for this, it's been a long week)
#9
Posted 14 July 2012 - 12:37 AM
But I'd rather just run wires back to the breaker pannel and do it properly.
#10
Posted 14 July 2012 - 12:49 AM
Thanks for the feedback. Oh, and the sticky brown stuff on the anchor is mud.
#11
Posted 14 July 2012 - 02:08 AM
#12
Posted 14 July 2012 - 02:44 AM
Having spent several boat units on stuff I wanted to do, when the Minister for finance said she would like an electric toilet (no more leaks from the pump handle!) I agreed to install one.
Thanks
http://electrical.ha...connectors.aspx
Copper Split Bolt Connector...
#13
Posted 14 July 2012 - 03:55 AM
Thanks
In two years in salt water environment...Verdigris Split Bolt Connector. I'm with Moonduster and the bolt/lugs.
#14
Posted 14 July 2012 - 06:49 AM
And of course the hot wire will need to go straight to a fuse unless you size it based on your windlass breaker.
#15
Posted 14 July 2012 - 05:57 PM
#16
Posted 15 July 2012 - 09:14 PM
that fuse protects the circuit and also the wires in the circuits. If you put the fuse near the head then a wiring short can still take the full amperage of the windlass power and melt the lines.
scale the wires down is where you put the lower amperage fuse in.
#17
Posted 16 July 2012 - 04:33 PM
#18
Posted 17 July 2012 - 01:55 AM
#19
Posted 17 July 2012 - 08:22 AM
That's just a half-assed way of doing a half-assed job.On rethinking this some, I'd recommend running a positive feed from a dedicated breaker at the panel. However, your return could run forward to the windlass return. A pretty good compromise in terms of safety and cost.
#20
Posted 17 July 2012 - 11:37 AM
