Winch handle selection?
32 replies to this topic
#1 jim lee
jim lee
  • 746 posts
Posted 15 July 2012 - 07:14 PM
We've been using plastic red winch handles on the Darts. The loads are light so we don't need fancy massive ones, but the ones we use get stuck in the winches and are just a pain to use. I'm done with them.
Here's the question : If you bought a new boat and it came with winch handles, what type of handle would you like to see it come with?
Thanks!
-jim lee
#2 Olsonist
Olsonist
  • 4,754 posts
Posted 15 July 2012 - 07:38 PM
I have the DAX OneTouch and they're pretty good but we did break one; the handle is plastic. The newish Holmatro Extremes have aluminum handles and and are one touch. Otherwise, I've learned that there is no perfect winch size. I bring my own when I crew.
#3 micha571
micha571
  • 160 posts
Posted 15 July 2012 - 07:54 PM
Lewmar One Touch. Been using them since last year, and never going back, they're great.
www.teamswashbuckler.com
#4 Timo42
Timo42
  • 4,765 posts
Posted 15 July 2012 - 08:13 PM
Only Lewmar will give the right impression... :P
#5 micha571
micha571
  • 160 posts
Posted 15 July 2012 - 08:25 PM
RAMWEL?
#6 Gouvernail
Gouvernail
  • 18,638 posts
Posted 15 July 2012 - 08:29 PM
Generally we use whatever winch handle is on our boat, unless we cannot find one in which case we use whatever winch handle is on the closest unlocked boat.
#7 mustang__1
mustang__1
  • 14,166 posts
  • Location:Sarasota Florida, but currently in Newport, RI
Posted 15 July 2012 - 08:34 PM
No idea on price or availability but I really like the holmatro winch handles, more than the Lewmar one touch which is a close second.
#8 coyotepup
coyotepup
  • 231 posts
Posted 15 July 2012 - 09:50 PM
+1. With the power grip. (Yellow knob on top.) The squeezy button is a hundred times better than ones with thumb-operated levers at the end. Much faster. Your pit guy will appreciate it.
#9 Bad_Moose
Bad_Moose
  • 53 posts
  • Interests:Sailing!
Posted 15 July 2012 - 09:51 PM
The harken ones with the big bobble thing on top. They seem to work pretty well, I like using them.
We managed to snap (I shit you not, clean in half) one of those holmatro ones last year so I wouldn't recommend them.
#10 mezaire
mezaire
  • 821 posts
Posted 15 July 2012 - 10:57 PM
+2 Used and sold these for two years and never had a failure. In that time I think I had probably 30% failure rate in the Harken handles especially in the locking mechanism.
#11 End4end
End4end
  • 18 posts
  • Interests:sailing, getting pissed and getting laid in no particular order.
Posted 15 July 2012 - 11:41 PM
Depends on what you want to use them for.
Racing, I would only use Lewmar One Touch but for apres sail I am told some ladies favour the ones without the knob or T top on the handle for reasons of.... comfort.
#12 SEMIJim
SEMIJim
  • 374 posts
Posted 15 July 2012 - 11:49 PM
+3 Got a pair of 'em on Abracadabra. You just grab and squeeze the winch handle anywhere on its shank to insert or remove. Terrific.
Jim
#13 Irish River
Irish River
  • 151 posts
  • Interests:sailing, skiing
Posted 16 July 2012 - 12:12 AM
Money no object, DAX one-touch are great.
#14 Left Hook
Left Hook
  • 6,109 posts
Posted 16 July 2012 - 12:47 AM
in the pit on boats under 50 feet the Lewmar onetouch handles with the knob are my preference as well as for non-overlapping jibs below 50. For trimming overlappers and grinding kites the double handle ones are superior and also on anything over 50 that isn't pedestal driven.
#15 Bucket
Bucket
  • 130 posts
Posted 16 July 2012 - 04:03 AM
We have the Holmatro handles, preferred over the Lewmars because the knob rotates independently of the handle. I've never seen one of the Dax handles.
#16 akasideshow
akasideshow
  • 609 posts
Posted 16 July 2012 - 05:20 AM
Thanks!
-jim lee
you might need to dress the cam with a file, try not to take too much off as this part wears down over time
also make sure the part of the winch that the handle goes in is clean, they get gunked up over time causing more problems
#17 coyotepup
coyotepup
  • 231 posts
Posted 16 July 2012 - 10:31 AM
That is also the case with the yellow-knob Lewmar.
#18 Blownout
Blownout
  • 283 posts
  • Interests:beating you
Posted 16 July 2012 - 02:19 PM
i switched to the new sheafer carbon fiber handles this year. they are nearly weightless. we use the 8 inch handle and i removed the lock so i do not have to futz with it.
#19 fidd
fidd
  • 13 posts
Posted 16 July 2012 - 03:20 PM
#20 Vela Sailing Supply
Vela Sailing Supply
  • 444 posts
Posted 16 July 2012 - 03:50 PM
DAX One Touch are an excellent option. In fact, a good friend decided to use them on his boat over anything made of aluminum just in case they drop it on the cockpit there is a smaller chance to chip the gel coat out. Small detail, but important if you like to keep your boat looking good.
These guys used them and guess they were happy with them:
#21 Mojo Risin
Mojo Risin
  • 4,135 posts
Posted 16 July 2012 - 04:19 PM
I use them on my boat. Great handles. Very easy to get on and off the winch which was a big thing in my decision process.
#22 Pokey uh da LBC
Pokey uh da LBC
  • 514 posts
Posted 16 July 2012 - 09:09 PM
What size are the DAX handles? I like that they've done away with the square plate in favor of the retracting pins.
#23 Vela Sailing Supply
Vela Sailing Supply
  • 444 posts
Posted 17 July 2012 - 02:01 AM
All DAX handles are 9.5" between centers.
#24 Swanno (Ohf Shore)
Swanno (Ohf Shore)
  • 3,397 posts
Posted 17 July 2012 - 04:43 AM
Lewmar One Touch. Used to use the plastic Titan ones but they (double handled ones) bend a little too much. Lewmar are nice and strong and you can put everything into grinding.
#25 sumpin
sumpin
  • 4,492 posts
  • Interests:scallop mining and rudder fairing
    stair falling book cover mending
Posted 17 July 2012 - 05:00 AM
the Musto one spot XR5 has been a standard for us so far this season
#26 SemiSalt
SemiSalt
  • 3,745 posts
Posted 17 July 2012 - 06:22 PM
An older woman who crewed for me liked a long (for mechanical advantage) plastic (for light weight) winch handle. She wasn't strong enough to break it. Not sure I am either. Optimum choice depends on crew.
#27 Foolish
Foolish
  • 707 posts
Posted 17 July 2012 - 06:46 PM
Why is everyone talking about locking handles. I've used standard handles for years and have never lost one out of the winch. The greatest chance to lose one over the side is when moving putting it in or taking it out of the winch, especially if there is a lock involved.
#28 Left Hook
Left Hook
  • 6,109 posts
Posted 17 July 2012 - 07:04 PM
I can't tell you how many times I've seen an untended line fly through a cockpit and catch on a winch handle. The last thing you want happening when something is going wrong is a wayward line catching a winch handle, turning it into a flying missile going through the cockpit and taking someone out.
#29 Mauri Pro Sailing
Mauri Pro Sailing
  • 303 posts
Posted 17 July 2012 - 07:43 PM
We own a Farr 39 and we are switching all our winch handles for the Lewmar One Touch
8" vs 10": Go with 8" if you are trying to gain speed and 10" for more power.
Locking vs. Non-Locking: If possible go with locking ones. As long as you stay with Harken, Lewmar, Antal, Dax or Andersen aluminum or stainless handles you will be fine.
Power Grip vs. Handle: For racing we recommend the Power Grip (knob) handles. For cruising the standard handles work fine.
All Winch Handles (well not all but almost)
Best,
Juan
#30 capt araldite
capt araldite
  • 567 posts
Posted 17 July 2012 - 10:39 PM
I like the DAX handles as well, although we also broke one a while back. When we sent over a photo of the air bubbles in the moulding I have to say APS were excellent and replaced it under warrenty straight away. I will be buying a couple more when I am over in the US again in September.
#31 Rail Meat
Rail Meat
  • 6,968 posts
  • Interests:My ride: An OCD designed Class 40
Posted 18 July 2012 - 12:01 AM
I am told that the owner of Dax invited the one touch system and has licensed it to Lewmar. I have used the Lewmars and the Dax, and find the functionality to be the same, with the Dax slightly lighter. No issues with breakage, although the orance cap on top of the handle can pop off so you might want to preemptively seal in it with 5200.
I also have a couple of Antal handles. They are not one touch, but the grip material is great.
#32 The Owner
The Owner
  • 419 posts
Posted 18 July 2012 - 02:35 AM
We started with the Dax. Then used the Lewmar one touch 8 inch and now we have the Holmatros. Like the Holmatros the best. The Lewmar points on the locking mechanism seemed to be fickle and we have Lewmar winches, only a few years old and regularly serviced. Not sure the Holmatros are still available?
#33 Merit 25
Merit 25
  • 1,453 posts
Posted 18 July 2012 - 03:00 PM
I have to agree with this. Only time a handle has ended up in the drink is from human error. That's been on my boat and any other boats I've been on. However, the Holmatro handle I was molesting at the boat show were easier to release than the lewmar one touch I've used. That being said, my boat is 25 feet, and I can replace the plastic red ones that we're using now, for $45 ea. Hard to beat that, and you won't break them on my boat. They also float, so if you lose one in the pre-start, no biggie, just pick it up.
