So for about $20 I built an alternative. The kitchen timer ($4 at Walmart) is attached with a magnet to it's housing. The prism shaped object is a cut up white board ($3 at Walmart) wrapped around a wooden frame. This allows everyone to see the bearings taken from all the wind shots. The bow guy is closest to compass and can get the best reading so will write them down on the whiteboard. There is enough room that multiple readings can be recorded to track trends in wind shifts. The backs are cut from a piece of plywood that I shaped using a mast block. Tomorrow I will use black webbing and buckles to attach to the mast and see what happens.
Please excuse the sloppy woodwork and varnish job, this is a ghetto Tacktick, I didn't want to spend too much time or money on it. Hope this helps someone.
