Posted 09 August 2012 - 06:09 PM
Centerboard benefits:
BALANCE: Instantly balance the boat based on centerboard trim. The 62's and 66's all had minor balance issues when going up/down sail combos. Full main and solent, the balance was perfect. One reef and solent, starting to go neutral. After one reef, then you really need to go to staysail to keep upwind balance. Ditto with screecher. Once it is up, it is getting near lee helm when sheeted tight and pointing high. On the new 60, we have one solent with a reef point. No need to carry two jibs. Depending on whether full main and jib or any combination of reefs, you can dial in the right amount of helm with the push of a button. Ditto with the screecher. The centerboard can go 5 degrees forward of vertical. Normal position is vertical.
EASE OF ADJUSTMENT: The entire load of the CB is taken by the pin. There is much less friction than a daggerboard. You can adjust under load. And with the push of buttons, you can retract your windward board fully for less drag. You do not need to unload the boat to adjust as you do with a daggerboard.
LESS NOISE: Every daggerboard and trunk makes noise offshore when the boat is not powered up. Many groan when under full load. A centerboard makes no noise.
SAME OR LESS DRAG WHEN RACING: On the Gunboats with daggerboards, you'd have both boards about 2/3 down with the screecher, and about halfway up with Asym in VMG mode. The CB should offer the ability to sail around the race course with similar or less drag than the twin daggerboards.
SAFER IN IMPACT SITUATIONS: On passage, a CB is very attractive. If you run up on a container, the worst case scenario is your CB ram sheer pin breaks, and the board retracts. No damage to trunk or board.
CB POSITIONS WHILE SAILING:
Typically down on one side only, adjusted for helm balance. Other side is up. With nearly all sail combinations with main and jib or screecher, this will be ideal. You only need the area of one board. All Gunboats have been designed to sail on one board, but the daggerboard Gunboats never do. As soon as you go to VMG with Asym, one board is about 2/3 up, and the other is fully up.
INTERIOR: Step into the amidships cabins on our new Gunboat 55 or 60 and you will see just how nice a cat cabin can become. These new open cabins are a huge improvement over the earlier boats.
The Tornado is still at the top of the beach cat scene. The centerboards appear to work quite well.
