Symmetric kite on a U20, can the alloy mast handle it?
#1
Posted 05 September 2012 - 01:24 AM
#2
Posted 05 September 2012 - 09:35 AM
Are you sure the periscope is sufficiently high for an assymetrical ?
#3
Posted 05 September 2012 - 12:09 PM
Only to be used in one 42 nm downwind event. Winds typically 15 to 30 against a 3 knot current.
I'd think that an A2 in those conditions would be as good as a sym chute and easier to recover from when things get pear shaped.
#4
Posted 05 September 2012 - 12:45 PM
#5
Posted 05 September 2012 - 03:57 PM
Need to play the shore for current relief. With the A2 we did over 150 jibes this year, losing ground whenever we strayed too far from shore. Symmetrics pointed DDW, fewer maneuvers, less distance sailed, less adverse current.
#6
Posted 05 September 2012 - 04:02 PM
#7
Posted 06 September 2012 - 03:14 PM
#8
Posted 06 September 2012 - 06:27 PM
By the way the Moore 24 kite looks like a little mini kite compared to the current class Assymetric kites.
#9
Posted 06 September 2012 - 06:29 PM
Will it change your rating?
YES! IT WILL and it would be proper to be protested if you did not get your rating changed.
#10
Posted 12 September 2012 - 06:50 PM
#11
Posted 13 September 2012 - 05:04 AM
Noted, thank you.It's not the kite that is hazardous to your mast, it is the boom being out past the corner of the boat with the vang being on hard. If you have rigged the check stays that were approved by the class then you should be fine with any kite arrangement. If you don't and you want to run at deeper angles which means the boom will be right out and the vang will be on to keep the top of the sail closed, then I think that is risky...
#12
Posted 13 September 2012 - 03:24 PM
...from the sounds of it,I'm guessing this year's dam-to-dam??
....I wasn't there,,but it sounded like an off-year.
......believe me,you'll be happy with an asymmetric in an 'on' year,and glad yer don't have a pole to gybe!
....perhaps a chicken-chute would be on the wishlist then
...a rotating bow-pole would help in lighter stuff
#13
Posted 13 September 2012 - 03:40 PM
Would the load patterns really be that different?
#14
Posted 13 September 2012 - 08:41 PM
#15
Posted 13 September 2012 - 08:42 PM
Why wouldn't the mast be able to handle an S sail if it could already handle an A sail of similar size?
ACtually the guys doing this run smaller kites the Moore 24 kite at least when its up looks tiny compared to the stock Class Asym
