#1
Posted 15 October 2012 - 11:44 PM
i sail on a formula 28 modified half tonner.
our current irc is 0.914 we have got the hull remeasured she came in lighter but with a sorter water line and on the trial cert she has dropped 2 points already. the owners are considering getting a non overlapping battened jib as aposed to an overlapping and putting a 50 square meter kite on i think the curent kite is only 42 square meters. our sail maker reckons this new configuration will give us a further 5 point drop witch is 7 points off for next season happy days.
but im just wondering has anybody had any experience converting to a non overlapping headsail for irc racing?
what are the pro's and cons ??
thanks, Johnny from Ireland.
#2
Posted 16 October 2012 - 03:33 AM
Does the boat suffer in light airs already?
What is the Area drop?
Does your Spreader angle and chainplate position allow the correct Aspect ratio headsail with the correct sheeting angles?
Will the foils tolerate this CE change?
Will this position you in bad air against your competition?
It is a given less area will give you a lower rating. But whether or not the boat is bettering it's Speed/Rating ratio is another thing.
#3
Posted 16 October 2012 - 06:58 AM
While you may have been advised by MSA....he is from Western Australia and not to be trusted.
Hope this helps
#4
Posted 16 October 2012 - 08:28 AM
Dear Johnny from Ireland....it's advice you seek and much will be forthcoming once you have posted pics of Dick Dastardly's "girlfriends" tits and been told to Fuck Off!
Hope this helps
Thanks for the kind note Evo...... Not sure what my geographical location at this point in time has to do with trust.. Does it change when I am in Sydney??
#5
Posted 16 October 2012 - 10:46 AM
Can't help with the specifics but thought a bit of background might help others chime in.
IMHO the reason for dropping the points by the owner is to make the class cut off for the ICRAs - avoid the tricked out half tonners and Corby 25's.
For what its worth it seems a sensible plan to me.
#6
Posted 16 October 2012 - 11:15 AM
The kevlar hulled Formula 28 in its original config was probably overpowered upwind and a little under juiced downwind for the company it would be in at the weather mark.(I have heard bar stories of one beating Moonduster to the weather mark on a light day.)
thanks for this info yeh thats the plan anyway to get her down a class for icra's and some other regattas.
she is a weapon upwind in the light stuff a little slugish downwind tho. we sail with 4 onboard and spent most of the season full hike on the rial so i think given the boats performance in the light stuff we can afford to take a hit on headsial power and could really do with 5-7 points off the rating with more downwind speed.
#7
Posted 16 October 2012 - 11:29 AM
#8
Posted 16 October 2012 - 11:32 AM
- should give you a little more bite upwind
...thats my 2 cents - best of luck !
#9
Posted 16 October 2012 - 12:30 PM
#10
Posted 16 October 2012 - 04:07 PM
Theres a formula 28 with non overlapping jib in howth rating .907. Not sure what work was done exactly to modify the boat but would be worth getting in touch with them or the previous owners who are from howth aswell. They go well in medium to heavy airs but arent to bad in the light stuff either. Your probably a bit undercrewed at 4 aswell
yeh we went up to see her yesterday took measurements of where her jib cars were moved to and were getting the same sails made up off mcwilliams. she seems to be doing well enough. our formula is lighter and doesn't have an inboard engine witch i think will prove an advantage when we race her. im not sure if formula 28s have ever been a class winning boat not much info on them.
i think 4 crew works great when everybody knows what there at.
thanks for the feedback everybody keep it coming. l
ooking to hear success or failure stories with regards changing your sail plan.
#11
Posted 16 October 2012 - 04:12 PM
How will Non-Overlapping headsails sheet? I presume the Chainplates are inboard?
were going put a new jib track in board of the chainplates and also a barbourhauler on the jib sheets for getting the right slot angel.
#12
Posted 16 October 2012 - 04:48 PM
#13
Posted 16 October 2012 - 08:33 PM
As far as I know the rating band break at ICRA is usually 0.920 so you wont have to worry about the Corbys etc. A Sigma 33 or J24 might cause you much bigger problems depending on the weather.
#14
Posted 25 October 2012 - 05:08 PM
Have a look at Harmony and Checkmate to see how it's done on an older half tonner -.New Keel, Rudder, Rig and sail plan to get the best out of this type of conversion. Spending that amount of money on an old boat makes a modern competitive boat an attractive proposition!
Pot hunting can be very expensive.
Good Luck.
#15
Posted 16 November 2012 - 11:27 PM
I can still remember racing against the Formula 28 "Flash" at Cork week in the late 90 when on Demolition and they were very quick and well stacked up on the rail. (we did beat them though, remember ugly is fast with IOR)
#16
Posted 23 November 2012 - 05:35 PM
A pupose built non-overlapper will have mast (and keel) furter aft to increase HSA relative to main. But 'retro' changes to nonoverlapping has worked in eg J109 very sucessfully for IRC racing where it is worth 10 to 12 points on handicap.
So can we compare ratio of J to E to predict if it will be sucessful on a Formula 28? Or maybe ratio of foretriangle area (or foretriangle plus main sail area) to displacement?
J109 J=4.05 E=4.72
F28 J=2.83 E=3.81
... Your J looks relatively small ! Plus you are about 3/4 fractional compared to the J109 10/11ths.
#17
Posted 26 November 2012 - 06:09 PM
I have no stories of a Formula 28 beating Moonduster to the windward mark, however, as a nipper, I was sailing on a very similar boat to Moonduster, a boat from Bangor called Born Free (Holland design, instead of a Frers design, but a masthead, cold moulded IOR 50 none the less) that was beaten to the windward mark on a light day by Skboo, a locally built half tonner, built for the 1984 worlds in Troon, and fabulously well sailed. She did it to Born Free (aka Born to Bark, she was never anywhere near as competitive as Moonduster) once that weekend, and always lead all of the scottish 3/4 tonners round the course...
#18
Posted 26 November 2012 - 08:19 PM
Also tagged with one or more of these keywords: irc
Sailing →
Sailing Anarchy →
PY and IRC Race Calculator App for AndroidStarted by JohnWin, 30 Apr 2013 |
Sailing →
Dinghy Anarchy →
Sailing →
Sailing Anarchy →
Make my mind up time.....Started by GBR562, 19 Feb 2013 |
Sailing →
Sailing Anarchy →
King 40 - Electric BackstayStarted by Racing Rigo, 10 Jan 2013 |
Sailing →
Sailing Anarchy →
Why did NoOne Buy Soozal?Started by Kenetic, 09 Dec 2012 |
