Does anyone know how to change the top display on a Raymarine (nee Tacktick) Race Master unit. I didn't think it could be done, but I have just noticed this article:
http://www.thedailys...ing-instruments
and at the weekend I saw a French J/80 racing with the same configuration.
2 replies to this topic
#1
Posted 18 October 2012 - 08:03 AM
#2
Posted 18 October 2012 - 09:16 PM
The top display can't be toggled easily, but you can change the mode the unit is running in through setup. Hold the dot button to enter setup, then use the down arrow to go to the options chapter. Use the right arrow to get to the MOdE section. Press the dot button to make it editable (it'll flash) then use left and right to change it and dot again to set it. You can switch it from Heading mode (HDG) to Speed (SPD) or Wind Direction (DIR). Once in one of those modes the top pane will be locked to that until you change the mode again.
#3
Posted 19 October 2012 - 08:52 AM
Thanks LakeHopper
Also tagged with one or more of these keywords: Tacktick, Raymarine
Sailing →
Sailing Anarchy →
Wireless Remote Control for ST1000/ST2000 AutopilotStarted by Tymadman, 21 Feb 2013 |
Sailing →
Cruising Anarchy →
Optimal tiller pilot mounting pointStarted by Ajax, 16 Jan 2013 |
Sailing →
Cruising Anarchy →
A Tale of Tiller PilotsStarted by Ajax, 24 Oct 2012 |
