#1
Posted 22 October 2012 - 01:49 PM
Some must have an idea on how to retrieve the bloody thing......
#2
Posted 22 October 2012 - 01:53 PM
so yesterday the shackle at the top of our roller furler broke, why I have no idea, it was the factory supplied shackle and last I looked it was in decent shape, anyway, the jib came down, no problem, but the furler top is still at the masthead. The obvious solution is to climb the mast, but would not be possible for me and so would require a trip to a boat yard, hiring a rigger etc etc. shaking the forestay hasn't moved the thing at all......
No Bosun's chair? Stick it on the main halyard, and winch up a willing monkey...
#3
Posted 22 October 2012 - 01:55 PM
How big is the boat? <30' and you should be able to winch the mast head down along side a pier.
#4
Posted 22 October 2012 - 02:08 PM
Just don't use the shackle.
#5
Posted 22 October 2012 - 02:16 PM
#6
Posted 22 October 2012 - 02:23 PM
#7
Posted 22 October 2012 - 02:50 PM
#8
Posted 22 October 2012 - 03:12 PM
I'm always amazed at people who own boats and do not have the technology (i.e., a bosun's chair or a climbing harness) to get either themselves or a crew-member up the mast. Seems like owning a car and not knowing how to check the oil. If you do go the Royal Navy route be sure to TIE the chair or climbing harness to the halyard used to haul to poor waif up the stick rather than using the shackle. Lawyers and modern liability have made the expendability of small boys a much more expensive prospect that it once was.
By the way I have the technology, but I am disabled so I can neither climb the mast or hoist someone else so I would rather explore all possibilities before I risk someone else's wellbeing. If I need to pay a professional to help I will....
#9
Posted 22 October 2012 - 03:15 PM
#10
Posted 22 October 2012 - 03:25 PM
Bow and arrow: he's disabled archery requires a lot of physical control, also missing can have tragic consequences.Bow and arrow with a string? Lassoo? Long long specially made 50 foot long carbon fiber grabber? miniature RPA (quad copter)? Trained Squirrel?
Lasso: again requires very high level of skill, plus 50' is a long way to throw vertically with accuracy.
50' retrieval pole: potential but becomes difficult to control, also storage? Would need to be telescopic, adding complexity and weight. Getting closer, has potential
Trained Squirrel? Squirrels are notoriously unreliable and in general dicks. Good luck trying to get them to do anything for you without payment up front, then chances are they just bugger off before you can catch them again. Stay away from these pricks.
Mini copter: Looks like the best choice. Low physical expenditure, only hang up is a grabbing mechanism. Someone with more engineering expertise can probably figure that out pretty easily. This one has the most potential, what else you got?
#11
Posted 22 October 2012 - 03:30 PM
#12
Posted 22 October 2012 - 03:33 PM
#13
Posted 22 October 2012 - 03:39 PM
at that size boat you must have 2 jib halyards & a foil with grooves of some kind...ditch the furler and use real sails w/o those foam battens
I took the furling sails off 2 years ago & never looked back; last weeknd in 29 I was glad i had the 105% up; weekend before that in 7 I was glad I had the 155% up.
the amount of extra time you spend sailing to where you want to go with the wrong sails up is longer than the same trip + folding the headsails when you get there.
try it, you'll like it.
#14
Posted 22 October 2012 - 03:44 PM
#15
Posted 22 October 2012 - 03:47 PM
Despite any type of handicap (be it racial, mental or physical), I would not rule out the Archery option... I mean, that blind archer put the smack down at the Olympics earlier this year.
I'm with Miscon, scrap the squirrel idea. Raccoon's are very intelligent creatures and may be a viable option, however the majority lack basic social skills. Expect one to drink all your beer, hit on your wife and shit in your cockpit only to pass out in the head before retrieving the halyard.
Best of luck.
#16
Posted 22 October 2012 - 03:48 PM
If you cannot round up a child, small friend or bosun's chair, make a grapnel out of stiff wire (old clothes hangar wire always works, mount it " upside down" so the hooks are the highest part of it when you hoist the contraption. Work it up and down and twist it until one of the hooks connects with the old shackle or the line above it. Works for me.
Brilliant! That will work!
So you use the other halyard next to it to do this--jib or spin or even main if nothing else.
And just make sure you tie the downhaul on well enough not to lose it!
#17
Posted 22 October 2012 - 03:52 PM
#18
Posted 22 October 2012 - 03:53 PM
Bow and arrow with a string? Lassoo? Long long specially made 50 foot long carbon fiber grabber? miniature RPA (quad copter)? Trained Squirrel?Raccoon'sBowmen are very intelligent creatures and may be a viable option, however the majority lack basic social skills. Expect one to drink all your beer, hit on your wife and shit in your cockpit only to pass out in the head before retrieving the halyard.
Best of luck.
Fixed it for you.
#19
Posted 22 October 2012 - 04:08 PM
If you do send someone up the mast, in addition to tying the chair to the main halyard rather than using the shackle I'd consider using a spare jib or spin halyard as a safety line if you've got one. Have somebody tend it on the winch just to keep the slack out of it.
#20
Posted 22 October 2012 - 04:43 PM
#21
Posted 22 October 2012 - 04:59 PM
#22
Posted 22 October 2012 - 05:01 PM
If you had any children left for bait, you could troll for Great Whites with that gizmo.
#23
Posted 22 October 2012 - 05:29 PM
1. Arm yourself with a case of good beer.
2. Tie alongside a bigger boat, with a thirsty crew and a bosun's chair.
3. Have them send someone up their rig, with a line loosely attached round your headstay.
4. He pulls himself across the gap.
5. He snags your halyard, and brings it down.
6. Both crews drink all the beer.
#24
Posted 22 October 2012 - 05:38 PM
Six steps:
Best solution.
Best fun potential.
Best use of beer.
#25
Posted 22 October 2012 - 05:47 PM
Best of luck.
You make raccoons sound like your average bowman (and before people get out of shape, when I last raced I was a bowman).
There's nothing like the view from teh top of a mast on a 40 footer doing 12 knots up the Australian east coast... you get a great view of the rest of the fleet.
#26
Posted 22 October 2012 - 05:48 PM
Six steps:
Best solution.
Best fun potential.
Best use of beer.
+2
This method should keep the racoon/bowman from shitting in the cockpit.
#27
Posted 22 October 2012 - 08:13 PM
#28
Posted 23 October 2012 - 12:31 AM
Where is your boat kept? Surely there's an anarchist or two near by who could be persuaded to play fetch for a tasty malt beverage or six...
That would work, The boat is at my apartment on Miami Beach.....happy to provide the beer or even a sundowner rum, I have a pretty good selection from when I worked in the Caribbean.
#29
Posted 23 October 2012 - 12:36 AM
#30
Posted 23 October 2012 - 06:31 AM
Best of luck.
<snip>
What? you think bowmen arn't worthy of such a complement?
#31
Posted 23 October 2012 - 06:47 AM
although a case of beer is probably cheaper...
cheers,
#32
Posted 23 October 2012 - 08:11 AM
Polar Bear Series 2011, Vancouver, BC, "It's Magic", 1982 Bennetteau First 38
(note she was the foredeck, so when the spin haly let go, it was her responsibility)
Sorry just had to brag.
172824_10150149260634973_3174779_o.jpg 103.54K
56 downloads
#33
Posted 23 October 2012 - 08:31 AM
#34
Posted 23 October 2012 - 09:40 AM
seriously, how can someone who owns a keel boat, ask a question like "how do I get a halyard down ?" Scary shyt that. Has the gin palace ever left its mooring ??? The shackle pin came undone because you didnt tighten it with a shackle spanner. You only did it up finger tight. And if you hadve wrapped electrical tape around it (so it didnt tear the spinnaker), you wouldnt have lost the loose pin.
Reading the thread and comprehending wouldn't go astray before a rant.
#35
Posted 23 October 2012 - 09:51 AM
#36
Posted 23 October 2012 - 11:37 AM
#37
Posted 23 October 2012 - 01:01 PM
Unless of course, you sail singlehanded all the time. In that case, I'd go the dock waif route.
#38
Posted 23 October 2012 - 02:07 PM
Well I wasn't going to get into a shit fight with an idiot, but here goes:
1) I know EXACTLY how to get a halyard down, but I'm not capable of doing it anymore. In my youth, I would be up the mast in an instant, no problem, now I need more inventive ways.....
2) Does the "gin palace" leave the dock......yes actually EVERY week at least once or twice, including crossing to the islands, trips to the keys, wednesday night racing and a other races (conch cup, miami to key largo etc....) I have sailed for nearly 35 years including an atlantic crossing and a leg in the BT Global Challenge. Before my stroke I also owned and sailed an Open 5.70....so sometimes a "rum runner" but never a "gin palace"
3) The shackle BROKE, both pieces are on my desk. This is the first time I have ever broken a shackle. I think it was the one supplied with the furler, it had a pin that was tightened with an Allen key and it was tight. All other shackles on the boat that don't move much are moused with wire !
If you are in Miami I would be happy to take you sailing.......2 disabled sailors together...but I forgot, being an idiot isn't a disability, it's a lifestyle choice......
#39
Posted 23 October 2012 - 02:47 PM
Now to answer the question. Grab a second line of sufficient length to act as a down haul. Tie a slip Knot to form a loop around the forestay with some slack so when you hoist the loop it slips over the head roller. pull both spare halyard and downhaul to close the loop above the offending hardware. Pull down the hardware coat thoroughly with Mc Lube.
Loosen the backstay and wiggle the spare line and the forestay as the loop approaches the roller, whole deal shouldn't take 3 minutes.
I'll let you know when I have time for that beer.
Cheers
Rex II
#40
Posted 23 October 2012 - 02:48 PM
#41
Posted 23 October 2012 - 02:51 PM
Six steps:
Best solution.
Best fun potential.
Best use of beer.
+2
This method should keep the raccoon/bowman from shitting in the cockpit.
+3. I like it!
#42
Posted 23 October 2012 - 03:06 PM
[deleted] the usual [/end deleted]
never under any circumstance respond to TTT
if possible add him to your ignore list
if responding don't leave the quote in place so that people who have him on ignore don't have to read it.
#43
Posted 23 October 2012 - 05:54 PM
#44
Posted 23 October 2012 - 07:47 PM
I've kept boats in quite a few different locations, and finding someone to go up the mast and someone else to handle the winch (evidently necessary in this case) has never been a problem at all. For someone who can't do it themselves, I'd think people would be more than happy to help you. I'm a little surprised at the question too...Seriously, if you can't find a crew and a chair to go up the mast, seems like you could find a rigger who would make a boat call, you shouldn't have to take the boat to a yard.
#45
Posted 23 October 2012 - 08:28 PM
Nice response! If I lived over that way, I'd happily volunteer to be winched up to get it down for you
#46
Posted 23 October 2012 - 09:28 PM
The Main Man - Props
#47
Posted 24 October 2012 - 12:22 AM
TTT - Owned
Nice slap down.
#48
Posted 24 October 2012 - 02:26 AM
Sorry balder, but all that pic proves is Someone went up the mast. Let's see you prove it with a pic of her up the mast.
Yes. You can see my helmsman Joseph, the professional photog, taking a pic. He was supposed to get it to us, lets see if I can nail him down!
#49
Posted 24 October 2012 - 02:41 AM
Hahaha... Welcome to Sailing anarchy.
Cheers
Rex II
That's sweet, have to add that to the bag of tricks.
I could see that coming in handy when shorthanded offshore!
#50
Posted 24 October 2012 - 09:58 AM
I can understand why your situation has left you confused and angry, but seriously, if you are having this much trouble with your disability and your memory, safe boating requires you to finally hand in your ticket.
No way does someone with a background like you CLAIM to have, not know a few alternative ways of retrieving a halyard...
Give it up cbm. You came on here, asked a stupid noob question, and got the caning you deserved. Dont like it ? Tough.
Sometimes the person suffering the stroke is the last one to realise that he's got a problem. You've got a problem CBM.
#51
Posted 24 October 2012 - 10:36 AM
Seems like a dosage issue.
I'm very surprised that the SA community has just shown up and taken care of this for you.
#52
Posted 24 October 2012 - 11:27 AM
#53
Posted 24 October 2012 - 07:44 PM
#54
Posted 24 October 2012 - 10:54 PM
There should be no need to pay a professional... Have you checked with your crew? Most often the bowman will be more than happy to go up and get it. And if you are not able to grind him or her up yourself, there should be others on the crew to help do this. And if not your crew, maybe a few buddies in the marina?
If people are new at it, go slowly and talk them through it. Its good practice, and they need (and will probably want) to learn the skill. At some level, there should be trips up the mast for visual inspections every now and again and it should not be feared if done properly. And it could prove beneficial if a situation were to arise out on the water.....
Just an aside - lol - my "bow-woman" chewed me out the other day that I don't send her up the mast enough. Apparently she has been talking to all the other bowpeople at the YC and they have been making fun of her!
#55
Posted 26 October 2012 - 12:45 AM
I used an old stiff rope and tied a slip knot with a loop, then taped it to the main halyard. I tied another line to the stiff rope to make it long enough. Don't forget the messenger line for the jib halyard.
The stiff rope held an open loop. I pulled the main halyard up and, after a lot of foredeck dancings and swearing, I managed to get the end of the jib halyard into the loop. I closed the loop and hauled that bitch down.
#56
Posted 26 October 2012 - 01:26 AM
I had a similar problem and got it down without assistance.
Thanks, I'll try this when the wind lets up.....55knts at the moment !
#57
Posted 26 October 2012 - 05:35 PM
aa
#58
Posted 26 October 2012 - 07:09 PM
#59
Posted 13 November 2012 - 12:25 PM
aa
MastClimb.jpg 16.18K
69 downloads
#60
Posted 13 November 2012 - 04:00 PM
How did you fare during Sandy and related adventures?
I'm hoping that the halyard was your biggest problem......
#61
Posted 13 November 2012 - 04:51 PM
Ring up Shake A Leg in Miami. They are a great disabled sailing center and I'm sure they'll help you out. While on the phone, figure out how to get involved and pay it forward
www.shakealegmiami.org 305-858-5550
#62
Posted 15 November 2012 - 03:27 AM
I am both a voluntary skipper and instructor at SALM....their cherry picker is dead, and the hoist isn't high enough to climb up and swing across, thought of that already...
Anyway, I had Christian Dam, of Dam Rigging come by and he got it down, tuned the rig and replaced most of the lines while he was at it....did a great job, call him if you need rigging work in Miami.
#63
Posted 15 November 2012 - 03:44 AM
I was thinkin' same thing go out in a blow sheet in sail broadside to wind send someone scamper up mast?This idea was posted on SA quite sometime ago. The posting inspired considerable braggadaccio as I recall.
aaMastClimb.jpg 16.18K 69 downloads
#64
Posted 15 November 2012 - 09:41 PM
helping a friend, we lost the main halyard to the top of a 48ft wooden mast of questionable strength. After a 10 second red face, I thought and used what I had at hand - The second halyard, a bungee cord with metal hooks, a long line and duck tape. i used the second halyard line as my working line. I duck taped both ends of a bungee cord forming a two prong grappling hook to the top of a Alumium boat hook. Then I taped the boat hook on the second halyard line. I secured an additional long line so I had plenty of line to work with. The boat hook worked to counterbalance the bungee hooks and enabled a clearer, more percise shot of grabbing that floating fitting. Once readied I hauled up the bungee hook- boat hook. I walked the working line to the next dock over which reduced glair and neck strain. Once the bungee grapple was in position, I managed to snag the lost halyard fitting. I then walked back to the boat and dropped the second line under the weight of pole and line - bringing down the lost main halyard. Took all of 20 mins.
Come to think of it... No beer was provided.
#65
Posted 16 November 2012 - 04:05 PM
Six steps:
Now that sounds like a good solution...
Are you on a dock? No neighbors willing to help?
#66
Posted 17 November 2012 - 01:40 PM
Just got one the other day....
Jebus. No beer. BAD Juju.
#67
Posted 17 November 2012 - 05:07 PM
Best of luck.
Fixed it for you.
They have a bad habit of going rabid on you. Both the racoons and the bowmen.
#68
Posted 17 November 2012 - 05:11 PM
All good points. TTT is like the squirrel. Only less useful.
#69
Posted 06 December 2012 - 04:05 AM
Took 15 min of 'sky fishing' to grab the sucker but I snagged the end and brought her down to the deck. Bowman had to buy his own beer.
#70
Posted 06 December 2012 - 04:29 AM
Squirrels will only run half way up the mast, then they'll stop take one step forward, the dash back down...only to get smashed by a swinging boom.
