We're in the Southern Chesapeake, now anchored in Deltaville, not in the tight harbor but in Fishing Cove, where the X is. We're planning to move up the river to roughly where the arrow is pointing. We like that spot because it's deep enough so we won't get pile-drivered into the mud if it gets bouncy, and there are bluffs to the West and somewhat to the North that will give even better protection than the regular land. We'll be anchoring in ~18 feet of water give or take.
It goes without saying that we will strip all the windage we can, we dropped the genoa already tonight since the wind was light. I've some concern about the dinghy fleet.
anchor.jpg 340.02K
120 downloadsGround Tackle on Board:
300' of 7/16th proof coil anchor rode
Backup rode - 350' of 1" Megabraid with about 20' or so of chain on it.
Two more lengths of 1" Megabraid, about 100' & 150' with metal eyes
100# Manson Supreme
150# Luke Storm Anchor
105# CQR
Two snubbing lines - I think 7/8" dock lines with chain hooks on the end, light chafe gear.
About 6' of fire hose
One article I read suggested that while "throwing out every anchor" had it's merits, it could quickly become an unholy bugger-up if you swung too much. You wrap up a couple of rodes and you might drag and turn into that boat that took out the whole anchorage.
So rather put out two rodes or a star of anchors around the boat put out your primary all chain rode with two anchors on it. You put the biggest gnarliest anchor on the bitter end, and the second largest anchor some 15-20 feet up the chain. Then you really cut your chances of dragging more without the risk of tangling your rodes or those around you.
I'm leaning towards putting the massive Luke on the end of the chain, with the Manson about 20' up from it. Leave the CQR in the anchor locker, or at leased rigged up to the spare rode as a last minute stopper. Put the snubber lines on the chain rode and chafe gear the crap out of them; rubber braided hoses and the fire hose. Stick out about 150-175' of chain. I've some concern about the hooks on the snubber lines staying put though since they rely on the tension in the chain. Not that there won't be that, but all you need is a few seconds of slack in the wrong way, no? Some idea to lock those in place would be good - maybe seizing wire, but I couldn't get them off quickly then which would be awkward if I needed to use the Windlass.
Also the dinghy fleet. Currently we have the Portland Pudgy strapped on the deck in front of the mast. The RIB is in davits with the engine. I'm thinking I might want to pull the engine off and mount it on it's rail bracket, put the RIB on the foredeck lashed down and put the Pudgy in the davits. I could probably also tie one of the dinks down to the deck under the mast and leave the davits empty.
Thoughts?
