Cracked tiller - repair or replace?
#1
Posted 27 October 2012 - 03:52 PM
Is there a repair technique that would work, or is it time to replace it. If replacing it is the solution, anyone know of a good source? Getting it from the manufacturer is not applicable in this case.
#2
Posted 27 October 2012 - 04:42 PM
My tiller is 56 years old. It is laminated from 3 woods. At one point there were cracks showing at the joints and I took it completely apart, I glued it back together with West Systems and it has been fine since. That was probably 20 years ago.
Alternatively, you can take a saw or router and remove the crack and glue in a wood spline. I use a 3 inch battery saw and make splines on a table saw, cut them to the curve of the saw blade and glue them in. Most important that they fit at the outside as you end up jamming in epoxy on the inside.
#3
Posted 27 October 2012 - 08:42 PM
once done, spray with urethane and it will look like new
did mine and it is a strong as ever..
#4
Posted 27 October 2012 - 11:23 PM
Would still be interested in sources for a new tiller for future reference.
#5
Posted 27 October 2012 - 11:52 PM
I bought one a couple of years ago - it is the same as the OEM one for my boat. Working well.
#6
Posted 28 October 2012 - 12:54 AM
As a temp measure on mine when it kind of broke, i did 1 wrap in fiberglass mat, then coated in fiberglass resin. Held up nice and strong to the end of the year. Not the nicest looking, but it worked.
#7
Posted 29 October 2012 - 07:41 PM
I have a 30 year old wood tiller on my '81 Evelyn 26. What started a few seasons ago as a hairline crack near the hole for the tiller extension, is now longer and wider. I got through this season by installing two hose clamps and taping it up.
I split my tiller starting about 1/3 of the way down when the tiller extension got wedged in the wrong place... I took a good wood glue and about 4 clamps... it's held up in 30+ wind...
#9
Posted 07 November 2012 - 08:04 PM
Here's a link to a fiberglass sock listing.
http://www.boatbuild...ft#.UJq978XA838
#10
Posted 07 November 2012 - 08:19 PM
West Systems epoxy will fix it. You can open up the crack a little with a hardwood wedge and then apply the epoxy into the crack with a piece of paper and get some epoxy all the way to the end of the crack.
We did a similar fix only drilled it and epoxied hard wood dowel into it in a couple of spots around the bracket location. Never had an issue after that.
#11
Posted 08 November 2012 - 12:28 AM
http://www.catalinad...&product_ID=960
http://www.catalinad...&product_ID=939
They have a number of others on their website.
#12
Posted 10 November 2012 - 02:31 AM
