We use the old style C-size Battcars and Battslides. The main has 6 full length battens with intermediate luff cars in between. All cars are ball bearing using 3/8" Derlin balls, no sliders. The Battcars use the "hat" bearing; shorter battens ride on a Battcar with 1/2" (10mm) hats, longer battens use a 5/8" (12mm) hats. The Schaefer elbows diameters are 3/8" for the shorter battens and 1/2" for the langer battens.
My questions are:
1) What plastic does Harken use for the "hat sections"?
2) Schaefer no longer makes the "elbows". Harken makes an elbow but it is only 10mm, which is fine for the shorter battens but not large enough for the longer battens that use a 12 mm elbow. Anyone know where to get these?
3) The new design elbow is screwed into the Battslide, whereas the old design is pinned. Will there be interference with the luffrope changing to the new elbow?
4) Any reason to move up to Torlon balls for the cars?
Sorry to post a dull and techinical request but I'll add tits if required.
if
