Kuka Light - Less is More
offshore imoca
53 replies to this topic
#1 STYACHT
STYACHT
  • 1,368 posts
Posted 07 November 2012 - 11:32 PM
Hi all,
Decided to start a thread to share some info and find out what kind of response the boat is finding in the Forums. One of the is that we are going to be presenting the boat in a few venues in the off season. First off is a short presentation at METS 2012 where Mitch Booth, multihull champion and helmsman of the boat, will discuss the cross overs between his multi experiences and Kuka Light.
http://www.kuka-light.com
http://www.marstrom.com/index.php?option=com_content&view=article&id=297:kuka-light-review-on-blurse&catid=84:news-spars-monohull&Itemid=72
In preparing data for the presentations, the similarity to the lightest of the IMOCA fleet (PRB) became pretty apparent. If you are able to join us in Amsterdam, we are going to be probing a bit deeper into the project.
The results of the boat in the two main regattas this season (both of which were exceedingly light air) don't do it justice. Really looking forward to pushing the concept even further.
#2 STYACHT
STYACHT
  • 1,368 posts
Posted 07 November 2012 - 11:33 PM
I forgot, please use FB to sign up for the free presentation: https://www.facebook...98460326956458/
#3 STYACHT
STYACHT
  • 1,368 posts
Posted 08 November 2012 - 10:11 PM
Getting of few of the simplified graphic comparisons together for this presentation. I thought it might be noteworthy to show how Kuka Light stacks up against some other boats. How light is light, how wide is wide, etc? For the following charts, a few bookends were normalized to the same LWL as Kuka. The notation is therefore: VOR42 for a 42' version of the VOR70, VO42OD for a 42' version of the new VO65OD, AC42 for a 42' version of the AC45, etc. For the IMOCA data, three current boats were averaged (one VPLP/Verdier, one OCDG, one JuanK). I make no claims about the accuracy of the data of the IMOCA's.
Attached File  Light.png   21.46K   261 downloads
Attached File  Wide.png   14.56K   307 downloads
Attached File  SADdw.png   15.29K   215 downloads
At the presentation there will be more such comparisons available, this is a sample.
#4 pogen
pogen
  • 4,061 posts
Posted 08 November 2012 - 11:34 PM
This is such a cool boat. Can you say what the cost comparison might be if it were in production? Way out of my league, but nice to think about.
I have seen some nice pieces about it on BLUR I think.
#5 Blur
Blur
  • 785 posts
Posted 09 November 2012 - 06:35 AM
http://www.blur.se/2...eet-kuka-light/
Definitely sweet. But tough work to get the full potential out
of for a "normal" crew. Kudos for doing it.
#6 STYACHT
STYACHT
  • 1,368 posts
Posted 09 November 2012 - 03:21 PM
Thanks Pogen,
The thing about Kuka Light is there were very few discussions about the costs. Crazy, right? The owner was definitely focused on what he wanted, and we prioritized the weight over most everything. We used fibre that you normally would not, Kevlar Nomex which you might, but not if you were concerned about getting the bottom line under control. We built a carbon fin for the keel. Everything done in the autoclave, which has its price as well.
That is not to say we favored weight to strength without a thought. Aside, I chatted with Mitch yesterday, who just delivered the boat back from Malta to northern Italy. He quoted 40+ knots and 6m seas. Crazy! But he seemed pretty nonchalant hosing the boat down and putting her to bed. That said, she has yet to race in that wind. The structural arrangement has adequate frames from the standpoint of number and size. She's tough. Now that the mast is sorted, it is tough too.
The upside is that we have really solid female moulds for everything on board. That is the way you must work in the autoclave. I think that if we were to build the boat again, in the moulds, with conventional nomex, standard high strength carbon prepregs and a steel fin, we could probably produce the boat for 550k-600k Euro. It is a guess, and pretty much the cost of the competition in HPR. There would be a weight change, but it is manageable.
#7 bladerunnerSWE
bladerunnerSWE
  • 30 posts
  • Interests:sailing
Posted 09 November 2012 - 05:45 PM
to what extent are you trimming the mast under way? are you only rotating it or are you tilting it up to wind aswell? what does the running rigging look like?
best regards
Dag
#8 STYACHT
STYACHT
  • 1,368 posts
Posted 09 November 2012 - 08:35 PM
best regards
Dag
Hi Dag,
so, I have to assume you mean mast cant and not rake. We have all lashed standing rigging (top and bottom) and we do not move the rake or cant while underway. Not yet anyway. We have done some studies with the effectiveness of cant, combined in fact with higher angle keel cants (like ... wait for it ... Speeddream) but opted against this, not because the gains were not there, but because of complexity. It can still be revisited. Rotation of the mast is achieved through three sets of small tackle. It is both limited as with any cat rig (pulled toward CL), but also induced, due to the relatively low boom compression compared to mast compression.
The running rigging is pretty straightforward. Perhaps more than I would like, personally. The owner was very set against running anything below decks in tubes. He simply wants to see everything that is going on. For the solent we have a floating ring type lead (common on Class 40). All headsail sheets are cross sheeted always. Halyards all locked except Solent, due to reef. Tack lines all jammed on deck. Lots of lashed rings and few blocks. The main is trimmed like an X40 cat - full beam trav to winch and a hydraulic sheet, no vang. If you sail cats, no need to explain. If you sail most monos, think of the sheet on this boat like a vang - in charge of leach tension. Think of the trav like a sheet - in charge of angle of boom. We have a set of runners (now at topmast) and are experimenting with deflectors in the off season.
#9 Left Hook
Left Hook
  • 6,103 posts
Posted 09 November 2012 - 08:41 PM
Just want to chime in and commend you in making the coolest, sexiest, fastest looking oats out there. It's truly so complex and awesome that I am in awe of the skills required to sail it to it's full potential, which, when realized, should be a force to be reckoned with.
#10 STYACHT
STYACHT
  • 1,368 posts
Posted 09 November 2012 - 08:57 PM
Your endorsement noted, but I want to qualify your statement just a bit. The boat is not that complicated, it is easy to make go fast. How could it not be? Helming is not a big effort, not that I have helmed for hours and days. The loads are not great, because the boat is so light, and not that big overall. It is powerful, but remember there are guys going alone around the world on 60' that are probably more powerful (in raw area terms) and nearly as light for their (2.5x larger) size.
Kuka sails with 6 crew - half that of boats her length. Yes, to get the maximum performance, it is very good to have experienced IMOCA, F20, X40, and/or VOR sailors on board, but I don't think that is due to complexity. They don't have to learn apparent wind sailing, and know immediately how to move weight and change sails. Most of the variables are set when the boat leaves the dock. If the keel system goes out, oh my, that is a problem, but otherwise, it is sailing.
Hard not to smile when you are chewing up the miles.
#11 bladerunnerSWE
bladerunnerSWE
  • 30 posts
  • Interests:sailing
Posted 09 November 2012 - 10:01 PM
Thanks for the reply! It's hard to workout all the details from the few pictures that are available. It's interesting because I haven't seen a wingmast on a monohull in the class (30-40'). We currently own and run a hydrofoil,wingmast tri ( http://sphotos-e.ak....7_3439862_n.jpg ) and are looking to implement as much as possible of what we've learnt into a monohull project in a couple of years (around 10m).
While we're on the topic of hightec stuff, what's your thoughts on different variations of DSS and intercept systems? Owen &clarke claim 10-20% less hull drag from their work on the open60 f.x
It wasn't my intention to hijack the thread to this degree, if you want to we can carry this over to pm's and I'll remove this post instead.
Best regards
Dag
#12 STYACHT
STYACHT
  • 1,368 posts
Posted 09 November 2012 - 10:19 PM
Hi Dag,
leave your post, because the link is worth it alone. Obviously with all that is going on in Auckland and San Francisco, it is awfully interesting to know what lurks beneath in that photo.
As for DSS, we spoke within the team early on whether this patented system was of interest for Kuka Light. The net outcome was no, it did not fit this project. We have raced against the Infiinti 30 in P2MC race, and the boat certainly seemed quick for her size. I understand the concept fully, but have not tried to crack into the details (after all, it is patented). Seems like an idea that continues to improve.
And as for the interceptor, or trim tabs in general, we did really see the point. We did some CFD work in a seaway early in the hull design, to settle the rocker question. We were not prepared to invest the amount of time it would take to get the gains that more variation in after section effects might provide. I don't know if I buy 10-20% less hull drag, at first glance. Maybe I have not paid precise enough attention, but have interceptors become standard in the latest IMOCA generation?
#13 bladerunnerSWE
bladerunnerSWE
  • 30 posts
  • Interests:sailing
Posted 09 November 2012 - 11:54 PM
It's indeed interesting times for foil tech. On the subject of infiniti's dss, we have a few ideas and from a glance I -think- we can make a better foil.
To be honest I haven't paid interceptors any attention until I heard about it in http://www.youtube.c...ycAvVYc0#t=242s the other day. According to Mike Golding he's the only one still using it. With the extraordinary claims and real boat testing it should get more attention.
You've designed a beautiful boat and I'm looking forward to the presentation, assuming that it'll be streamed/youtubed ofc.
#14 Blur
Blur
  • 785 posts
Posted 10 November 2012 - 11:11 AM
The word is that they had a hard time upwind in Middle Sea race, even compared to some of the Class 40. I guess it's not an easy boat upwind in a blow and choppy sea.
#15 STYACHT
STYACHT
  • 1,368 posts
Posted 10 November 2012 - 11:49 AM
It is not planned to be streamed. I can ask the organizers or Mr. Clean if he can do anything to change that.
I am also hoping to present something similar in Sweden for the WYRF and the YRDTS. That will depend on the organization if we can be added to the program.
Doug
#16 STYACHT
STYACHT
  • 1,368 posts
Posted 10 November 2012 - 11:54 AM
Upwind is not the ideal angle for Kuka Light. In the light light upwind, we cannot sail our "rating" which is faster than a boat twice as long. They do not have any trouble with a Class 40 if there are in anything like the same wind. We have the same sail area, same waterline more or less, a lot less weight, less wetted surface and far more efficient foils. If in the MSR they saw a Class 40 catch up to them, it was due to lack of wind and current. Maybe just sailing to the wrong side of the course. Stopped is stopped, whether 40' or 100'. In the MSR there was definitely no "blow" and only leftover chop very early on.
#17 hughw
hughw
  • 177 posts
Posted 10 November 2012 - 05:39 PM
Can add a bit to this - I put trim tabs onto the Bols 93' back in 2002 having run the idea in the tank, and in practice then there were certainly times we saw 10% speed gain - and that was extremely quantifiable as we were in dead flat water on the lee side of Sjaelland, boat speed 20-24 knots steady, and the tabs would put on a full couple of knots as we flattened out the running angle.
I would guess the 10-20% figure of total hull drag though is a bit optimistic! Interceptors do work well but have a min speed before they become effective in the total drag tradeoffs, tabs are a bit more flexible in that respect.
#18 Blur
Blur
  • 785 posts
Posted 11 November 2012 - 09:28 AM
Some shots from another competitor. Both Akilaria 40 och Pogo 40 were "notably faster" in those conditions. Same wind + track.
Naturally this is not what the boat is buit for, but it affects the time around the course. On elapsed time Kuka Light was equal with Marten 49, Welbourne 46 and Ker 51 - boats that should be beaten by a fair margin. I put this down to crew experience, but naturally every design have som s´weak spots that need to be managed and minimized.
#19 Team_EvoLv
Team_EvoLv
  • 1,011 posts
Posted 11 November 2012 - 11:59 PM
Good to see the arm chair admiralty has arrived! Children should never see things half done. Move along Blur, you're out of your depth
#20 Blur
Blur
  • 785 posts
Posted 12 November 2012 - 09:45 AM
Sorry for relaying photos and feedback from reality. Shouldn't happen again.
What's the point of looking at actual results, photos and observations on the race course when we have all the experts available in this thread. Naturally you know better than the people who were there.
#21 Team_EvoLv
Team_EvoLv
  • 1,011 posts
Posted 12 November 2012 - 01:16 PM
Take a look in the mirror Admiral! Are those office chairs getting uncomfortable yet?
Any 42fter that can finish within 4hrs of a group of 50-80ft boats over a 600nm race in light air is a rocket. More to the point, being corrected out by a boat of similar length that arrives in to port over a day later isn't much to brag about.
Stick to what you are good at, writing a nice story with pretty pictures. You'll go far!
#22 Blur
Blur
  • 785 posts
Posted 12 November 2012 - 04:35 PM
Case closed. No need for any other input. Many thanks for your great in-depth analysis. Really impressive.
I'll go back to racing my 36fter, beating 45-55ft boats on the water. I guess we're a light wind rocket. Oh, btw, we win races on handicap as well. Then we don't have to whine on SA after each race.
So yeah, I really like the look from my office :D
#23 Team_EvoLv
Team_EvoLv
  • 1,011 posts
Posted 12 November 2012 - 06:48 PM
So yeah, I really like the look from my office :D/>
Admiral, I'm surprised you don't have breathing difficulties with your head being so far up your arse. You've got nothing to brag about, don't ever forget it.
The facts remain, kuka is a brand new boat that is pushing new boundaries, boats like this take time to dial in. They sailed into the finish within 4hrs of a Cookson 50 and only 5hrs behind an old VO70, not bad for a 42fter!!! I'd say that was an awesome performance of the boat. Want to argue that too?
Making judgements about a boats supposed performance from an offshore race that had more restarts than a deals in a poker game is just dumb.
There are a lot of very knowledgable people on this website, if people like you didn't always take shots at their designs/products they would be more willing to contribute.
Oh yeah, just to be clear...they still corrected out well infront of the class 40s.
Next!
#24 Blur
Blur
  • 785 posts
Posted 12 November 2012 - 09:41 PM
What's your problem?
If you bothered to read my post (instead of just trying to be smart) you would have noticed that I only commented on Kuka Lights upwind performance after the start, since I had proper intel on that. You know. People in the real world. Actually observing. Taking photos. Anyhow. The info was interesting feedback for some of the people involved.
To bad you had to be exposed to fact. Next time we'll take it offline to spare you...
I've been in contact with the designer, owner and builder on several occasions over the last year and I just wrote an article on Kuka Light giving proper credit to everyone involved. And when the mast broke, I decided not to post just to give the team a break.
So I don't need your "advise" on how to work with people in the business and what makes them willing to contribute.
But thanks for reminding me why I spend less and less time on SA.
#25 Team_EvoLv
Team_EvoLv
  • 1,011 posts
Posted 12 November 2012 - 10:57 PM
Sorry blur, you just proved my point. Ignorance is bliss huh?
Oh don't let the door hit you on your way out
#26 bladerunnerSWE
bladerunnerSWE
  • 30 posts
  • Interests:sailing
Posted 17 November 2012 - 08:06 PM
So how did the presentation go? any clips?
#27 STYACHT
STYACHT
  • 1,368 posts
Posted 17 November 2012 - 09:22 PM
Hi blade, the presentation went well. As expected we had 25-30 in the audience. As I was on the stage I did not record the presentation. Mr. Clean came in the middle and was not set up for a youtube vid.
It occurred to me that there was a regrettable omission in the presentation itself. A round of credits ought to be shared for Marstrom Composites (autoclaved everything), Soleri Composites (assembly and boat building), Angelo Glisoni (coordination), Trimarine (in the person of Sebastiano Rech-Mourasutti, build oversight) at the primary level. Also Piero Brussolo (moulds), the team at Cariboni (deck hydraulics), Greg Waters (keel hydraulics), Kevin/Hans/Patrick (NS, sailmaking), Peter Kohlhoff (custom deck), Lombardini (engine), Boatspeed (prop box) and Compotech (carbon/Ti shafting). If I missed anything, feel free to post...
I will ask around among the attendees to find out if clips or the whole thing was recorded. By next week, I hope to have at the very least some stills plus I will post the presentation itself is there is an appetite. FYI it was not death by Powerpoint. Quick and dirty. But a few images not otherwise publicized.
#28 STYACHT
STYACHT
  • 1,368 posts
Posted 17 November 2012 - 09:40 PM
I am not going to be drawn into the duel above. I have zero problem with either Peter (Blur) or with criticism, the two not being lumped together. In the photographs I have seen from the beginning of the RMSR, the boat probably should either foot more, preferably reef, or perhaps both. The polars are pretty clear, pointing high is not a great idea, one needs speed in the boat to get the best VMG. But there are other factors in the real world, like waves. Kuka's low mass does mean they will accelerate and decelerate quicker than most boats. I will add that a rigging change shortly before the race limited our headstay tension more than usual or desired, hurting pointing.
I stand by my statement that we do not have a problem with Class 40's. Not even upwind if racing at near full potential, and certainly not over the course. Remember we do not care about rated results on this project - even if you all do. Of course it could easily be that we have more to learn about the boat. Upwind, I would be more worried about GP42's or the HPR40's than C40, as both Kuka Light and the C40 are ocean course concepts. The water ballast of the C40 comes in mighty handy.
#29 FastButNotFurious
FastButNotFurious
  • 24 posts
Posted 20 November 2012 - 07:19 AM
Congratulations for building this exceptional sailboat!
It is really important that we see such boats around that are focusing purely on performance and marine qualities, ignoring all these anachronistic rating systems that are putting competent designers to waste their time in making notoriously slow boats.
You had the luck and the privilege to have no budget restrictions. Ok this is how prototypes should ideally be. It would be interesting though to study a (limited) production version at a competitive price, maybe not a Kuka Light but a "Kuka Semi Skimmed" with some minimal amenities.
Making boats like this available to the broader sailing world can boost the entire sport which is lacking "fun" and speed at the moment although the potential is right here! Most sailors do not even know it is possible to get to these speed levels. I think there is a market for such a boat.
Keep on racing and sailing around this fantastic boat!
#30 STYACHT
STYACHT
  • 1,368 posts
Posted 20 November 2012 - 10:21 AM
I am going to begin to link to the presentation (below), the still images made at the time of the presentation, and a few short videos. Still have not located a full end to end video of the talk.
To give you a bit of an overview, we introduced Mitch and our company, spoke for about 10 minutes on the development of Kuka Light.
  • the concept from the standpoint of the owner and Mitch
  • the areas of development chosen - 3 of 4 primarily catamaran topics: weight, rig, foils
  • the design phase including those developments, adding canting keel
  • pictures of build and sailing
  • further development initiatives
We then handed the talk back to Mitch to draw parallels to and comment on the ongoing developments in mulithulls, dominated right now by AC72 wings and foils. The audience was encouraged to participate, but we had limited questions.
Please feel free to take the conversation further here.
Attached File  Less is More.pdf   910.66K   47 downloads
#31 STYACHT
STYACHT
  • 1,368 posts
Posted 20 November 2012 - 12:15 PM
Pictures from the presentation, and the Q&A after:
Attached File  2012-11-14 15.50.09 (Large).jpg   102.21K   10 downloads
Introduction of Mitch Booth
Attached File  2012-11-14 15.51.04 (Large).jpg   110.47K   16 downloads
Introduction of ST
Attached File  2012-11-14 15.51.53 (Large).jpg   118.48K   16 downloads
A few facts about Kuka Light
#32 STYACHT
STYACHT
  • 1,368 posts
Posted 20 November 2012 - 12:19 PM
Mitch explains the inception of the project
#33 STYACHT
STYACHT
  • 1,368 posts
Posted 20 November 2012 - 12:29 PM
More media further into the presentation:
Attached File  2012-11-14 15.59.07 (Large).jpg   97.52K   10 downloads
Doug explains the division of the boat into the autoclave
Doug begins the discussion of the design phase
Attached File  2012-11-14 16.09.00 (Large).jpg   98.89K   10 downloads
Mitch discussing AC72's state of the art
#34 STYACHT
STYACHT
  • 1,368 posts
Posted 22 November 2012 - 12:32 PM
See the notes earlier in the thread about my quick estimate of budgets for "Kuka - still pretty damned light"
Early days, but based on discussions at the METS, we have begun talks to produce a few more. We will try to get the word out when the time comes.
#35 Spoonie
Spoonie
  • 80 posts
  • Interests:Stuff
Posted 25 November 2012 - 11:05 PM
Your S bend dagger boards are interesting... a better concept than perhaps what the DSS boys are playing with? less likely to pop out of the water in waves at least...
Would be keen to see the full video if it ever comes available
#36 Autograph
Autograph
  • 117 posts
Posted 25 November 2012 - 11:53 PM
Loving the look of the boat, the owner seems to have a very focused vision. All we have for AV so far on this thread is a pic of her dragging her nose about, upwind, and some pics of a guy in a vee neck sweater. Just saying. Any chance youse could send the boat properly, in a mistral, and get the footage out? A 2 min clip is worth 10000 words...
Anyway, best of luck with the programme. Fastnet? or just a med/lake fair weather toy?
#37 Left Hook
Left Hook
  • 6,103 posts
Posted 26 November 2012 - 12:29 AM
https://www.google.com/search?q=Kukalight&hl=en&safe=off&tbo=u&tbm=isch&source=univ&sa=X&ei=cbeyUKiWGKfV0QHIyoCADA&ved=0CEYQsAQ&biw=1920&bih=912
#38 STYACHT
STYACHT
  • 1,368 posts
Posted 26 November 2012 - 09:23 AM
Please also link through to the boat's site for the race program. This boat is meant for the Rolex MSR and the Rolex Fastnet primarily. There are no plans to race in the lakes, though when I dream, I would like to fit an AC45 wing and do something in Geneva with it.
A note about that video, that is very very early in the trials period.
#39 STYACHT
STYACHT
  • 1,368 posts
Posted 26 November 2012 - 09:27 AM
This is the appropriately named "Drifter", at the end of the Palermo to Monte Carlo race. Mid sprit, not quite to the masthead. Note that the mailsail is not looking so flash here, in part due to issues with battens, and in part due to repairs from when the mast was dropped when a lashing gave way, breaking the boom. (Different to when the masthead was broken as seen on SA front page)
#40 STYACHT
STYACHT
  • 1,368 posts
Posted 26 November 2012 - 09:29 AM
This is one of the few shots I have of the masthead A3 up, during sea trials in May. Boat did not take this sail on RMSR, taking a new fuller masthead Genneker instead.
Note that in this shot, there are two guys on the bow as they are already sailing low to go for the furl. I have a video of this too, but haven't posted because it is not at full tilt.
#41 STYACHT
STYACHT
  • 1,368 posts
Posted 26 November 2012 - 10:22 AM
I talked with Hugh for some time at METS. We have mutual respect for each others work.
The preliminary S and C foil configurations that we developed (in 2009/2010) for Kuka were done to show the possibility to foil assist for shedding some wetted surface and to trim bow up, primarily. They would offer little or nothing in way of additional RM in the configurations the we have looked at, reacting a lot like the hull's displacement with heel. They presume the boat has a canting keel (maybe mast) to shift CG to windward. Yes, being farther from the free surface, they could for example be pitched harder.
DSS works to leeward to do both lifting and righting. I have yet to see a compelling reason to introduce it into a canting keel (though there is a mini about, so we ought to see this soon). I will let HughW speak to the combination.
Does this answer your question?
#42 STYACHT
STYACHT
  • 1,368 posts
Posted 26 November 2012 - 10:26 AM
Film made by www.saily.it from Palermo to Monte Carlo 2012 (see their site for original)
#43 STYACHT
STYACHT
  • 1,368 posts
Posted 26 November 2012 - 10:34 AM
... I have a video of this too, but haven't posted because it is not at full tilt.
#44 Autograph
Autograph
  • 117 posts
Posted 26 November 2012 - 06:00 PM
Sold, you have made a thing of beauty. Love the clean exit off the stern. Makes class 40's seem tubby.
#45 STYACHT
STYACHT
  • 1,368 posts
Posted 18 January 2013 - 03:55 PM
Sorry I have not checked into this topic of late. Thanks for your thumbs up there, Autograph, Left Hook etc.
News from the boat front, we are going ahead with some performance mods and optimization studies. Speaking to Mitch the other day "there is so much performance to be found, we have hardly scratched the surface..." I don't know yet if the boat was signed up under the big rush to race in this year's Fastnet. I will try to find out for y'all.
First numbers being put together for a bigger version of the same concept. Not sure which will offend the Swede's most, but I am going with Kuka XL.
Also wanted to note that I will be in Dusseldorf on Sunday if anybody missed out on the METS event and would like to sit down and have a chat about the boat, or anything else.
#46 STYACHT
STYACHT
  • 1,368 posts
Posted 28 March 2013 - 09:03 AM
Hi SA'ers,
So, the winter break and work session is nearly done. Kuka Light is back in the water, having had some nip-tuck work in the stern overhang, general updates and maintenance to rig / deck hardware, and most notably a new suite of instruments. Still in process is some adjustments to the dagger angles, but that is nearly complete.
The hull was laser scanned for measurement purposes last season, and this data, when carefully reverse engineered, proved that there were some shape differences that needed study. First a large physical template was made to confirm the shape. Then, a RANS CFD study was started to understand the impact of this, the effectiveness of corrective measures, and what performance improvements might be found with the use of interceptors. It is a fascinating result. @Blur may remind us that some people noted a bow down trim. This tendency has its roots in the beam of the boat, especially when pointing, but the shape of the stern was very strongly adding to it, particularly at reaching speeds. The good news is that the owner immediately felt the improvement when the corrected stern was sea trialed. We have yet to try the interceptors, but one step at a time.
Follow the link to FB below for images of the work.
She will now be running NKE instruments and using some customized hardware and software for data processing. Routing will from now on be done with Adrena, Optima and routage Pro. Thanks to http://www.boattech.it/ and http://www.pochon.com/ for all of their efforts in this area.
The first feedback came in the form of a leeway study. Conditions were a bit less than ideal, but the results are also very interesting. The work continues, with changes being evaluated and the results being fed back into our VPP for further development and understanding of the boat's potential. Next update I hope to include the regatta schedule for 2013.
#47 Tanton Y_M
Tanton Y_M
  • 285 posts
  • Interests:To never stop.
Posted 28 March 2013 - 01:46 PM
I like the boat. But I really like the mast and rigging best.
#48 STYACHT
STYACHT
  • 1,368 posts
Posted 08 April 2013 - 09:29 PM
Yves-Marie, care to elaborate?  The only difference to say, an IMOCA, is the lack of deck spreaders.  The difference to an Extreme 40 is ... almost none.
The boat had a short race this past weekend.  The new 3di main and jib were both in fine form, in pretty light winds.  According to the crew, it was disappointing that the Cookson 50 was not out for competition.  The handful of Class 40 yachts kept close for the first (lighter) half, with the Akilaria Aki Sports Three being the quickest.  But in the end, when the breeze came up to max 15kn, Kuka Light, pretty easily took line honors by some hours.  I am struggling to find the rated results on the site: http://www.laregatad...lassifiche.aspx  Find the race called ACT 1 Balene and see overall ranking.
Well let's see for ourselves... K-L has 1.437 (using 2012 still despite some headsail changes) and Aki Sports Three had 1.257 (also 2012).  Racing 26.3 hours, K-L had to win by 3 hours and 46 minutes to win in IRC.  The actual difference was 3 hours, 24 minutes.  Don't know if it was scored that way, because there is no definitive answer on the regatta site.
Nontheless, congratulations to Franco Niggeler, Mitch Booth, and crew onboard for a good start to the 2013 racing season.
#49 STYACHT
STYACHT
  • 1,368 posts
Posted 09 April 2013 - 12:53 PM
Images from the race.  They did get the win, so the above estimate was obviously off.  Upwind, both ways...
Next race should be http://www.151miglia.it/race-2013.  I am told there will be some closer boat for boat racing, with TP52, Cookson 50, and larger boats in the fleet.
#50 JL92S
JL92S
  • 507 posts
Posted 09 April 2013 - 08:01 PM
I thought it was the plan for Kuka Light to do the fastnet? I can't see the boat on the entry list.
#51 STYACHT
STYACHT
  • 1,368 posts
Posted 09 April 2013 - 10:55 PM
In fact the decision was made not to enter this year's Fastnet.  I don't really know why, and wish it was not the case.  The boat is perhaps not up to full potential, but it'd still be a great race.
#52 JL92S
JL92S
  • 507 posts
Posted 12 April 2013 - 07:17 AM
That's a shame I was looking forward to seeing it before the race and possibly in Cowes week as well. How about a transpac?
#53 GybeSetŪ
GybeSetŪ
  • 19,970 posts
Posted 12 April 2013 - 01:30 PM
when will you Poms get it?
your dinghy blokes are on the cutting edge
when will a cutting edge sportsboat or keelboat get some traction?
you are still buying J/boats fer chrissake
Kuka needs to come over and smash the Fastnet
#54 Tanton Y_M
Tanton Y_M
  • 285 posts
Posted 20 April 2013 - 02:41 PM
]STYACHT. "care to elaborate".
To answer your private conversation. The Imoca's boat with rotating masts seem to favor deck spreaders. They have shown to be vulnerable in several situations documented in the last and previous Vendee's type of races. I have been in favor of a rig, such as this one designed in the 90's  of a rotating spar with diamond rigging. I thing the deck spreaders came later and I never liked the system. I tried to explain in my blog and I understand that a few Imoca's in 2004 and 08 had rotating masts without deck spreaders, to be disgarded later for weight consideration. This is why I see with Kuka light a step in the right direction.
Attached File  OP60MSAIL-AL19-13.jpg   134.54K   41 downloads
Also tagged with one or more of these keywords: offshore, imoca
