Removable Mast Steps
#1
Posted 14 November 2012 - 01:41 AM
I ran across these while searching the internet. I like the ability to remove them when under sail so no added windage and easy to install, not sure about holes in the mast, but I guess you could put some rubber plugs in.
Anyone ever used them.
http://sailing.about...Mast_Steps1.htm
#2
Posted 16 November 2012 - 11:17 AM
We use the fold up type (2 steps) which gets me to the top of the stack on a 40 footer. These are pretty narrow steps -- handy to install among the halyards coming to the deck on either side of the mast.
http://www.defender....2069&id=1280218
#3
Posted 16 November 2012 - 11:20 AM
#4
Posted 16 November 2012 - 02:37 PM
Never used 'em.
Saw those and that is what the first two are that are already on the boat. They also make that model in fiberglass which is suppose to be lighter, quieter, and when installing them you tape sandpaper to the mast over the holes and shape the step to the mast shape to eliminate spaces or the need for shims. Also eliminate any worries about metals not working or playing well with others.
Since I will only be installing two steps and not very high up I will probably go with this type. They seem to be sturdy, easy to get, easy to install, and at maybe four feet above the deck there should not be an issue with fouling lines.
http://www.westmarine.com/webapp/wcs/stores/servlet/Product_11151_10001_100545_-1?cid=chanintel_google&ci_src=14110944&ci_sku=100545
#5
Posted 16 November 2012 - 07:09 PM
Never used 'em.
http://www.westmarin...4&ci_sku=100545
Just one thing to think about - are they going to be in the way when you(or your bowman) is jumping halyards? I know I'd kill my owner for putting a step like that anywhere below the halyard exits on the mast. Just something to think about.
#6
Posted 16 November 2012 - 08:15 PM
I've also seen mast mounted carbon instrument pods which have reinforced foot steps cut out of the side. Those are pretty gucci as well. Will see if I can find a pic.
