protective sandable coating over plywood
#1
Posted 14 November 2012 - 06:53 PM
Thanks
#2
Posted 14 November 2012 - 07:07 PM
If sanding is hard, perhaps you are sanding too soon after application - the 206 is the slow hardener , and in temperatures below 60 it takes a couple of days to cure to a sandable state. If you can dent the surface of the material left in your mixing cup with your thumbnail, its not ready for sanding ...but it is still chemically active and you can bond right to it with no surface prep.
#3
Posted 14 November 2012 - 07:32 PM
#4
Posted 14 November 2012 - 07:49 PM
A common mistake is to try and put the epoxy first coat on too thick. Over plywood it is best to mix the resin and hardener thoroughly and then use a plastic spreader/squeegee to force it into the grain well. Don't let it puddle and squeegee almost dry and it goes a lot further. When it hardens then the raised grain and fuzz will sand quite evenly without loading up the paper if cured completely. Then the next coat you can float on thicker and build up the protective layer. Then reddish brown phenolic microballoons can be added to the 3rd coat to hide the grain especially on doug fir and I like using a softpad to level it all out. Squeegee another clear coat over the microballoons after sanding to fill pinholes and your ready to prime and paint.
Correction to "I would not use fairing compounds like 407 or 410 for this application." as a first coat if moisture exclusion is desired.
+1M to what Rasputin says
#5
Posted 14 November 2012 - 07:51 PM
#6
Posted 14 November 2012 - 10:44 PM
Vegas, there's been a heap of these posts/threads lately. Always the same, amine blush, sticky, brittle etc ...???
Does anybody read the instructions anymore?
#7
Posted 15 November 2012 - 12:53 AM
#8
Posted 15 November 2012 - 02:15 AM
"...read the instructions anymore"? Did anybody ever read the instructions??
Only to find out why it didn't work right.
#9
Posted 15 November 2012 - 02:19 AM
Don't waste time sanding undercured epoxy. Just cure it properly (dry heat) and it'll save you time and grief.
Just wait until next month - The "my epoxy didn't cure at 40F in the my New Jersey garage" posts will start up again ...
#10
Posted 15 November 2012 - 02:43 AM
The directions say over night as said above.
#11
Posted 15 November 2012 - 08:28 PM
#12
Posted 15 November 2012 - 08:47 PM
I learned this from a great boatbuilder and storyteller, Robb White. You can read excerpts from his wonderful book 'How to Build a Tin Canoe' here,
http://www.robbwhite.com/
He hated mixing his woodworking with epoxy work, (me too!) and would dry fit sometimes a whole boat in his basement workshop. He liked using tacks, brads, wire ties, hot melt, to tab parts together and then would turn the furnace on full blast and close the windows and doors and pre-heat the whole assembly. Let it get as hot as he could and then step outside and mix his epoxy and then turn off the heat and go in and brush, roll, spread whatever the whole thing and as it cooled it would soak all the epoxy into the wood, ply, joints and amalgamate the whole boat.
Buy his book, or better yet get the narrated set of CD's, his panhandle drawl and storytelling prowess is a treat!
http://www.amazon.co...s/dp/1401300278
How this south Georgia/Florida cracker got to be the darling of the New England Wooden Boat Magazine set is a wonder as well.
#13
Posted 15 November 2012 - 10:42 PM
A little trick that is opposite of what a lot of people try to do. I've coated wood panels with WEST and thought it would help to take them out in the sun to promote a faster cure. When the wood gets heatedup it starts gassing off and makes bubbles and pinholes in the epoxy coating, the last thing that you want. Best to heat the ply up ahead and then bring into a cooler environment to coat and as it cools it will suck epoxy into the wood for better penetration. After it kicks then you can put back out into the sun for post cure.
http://www.amazon.com/How-Build-Tin-Canoe-Confessions/dp/1401300278
I use this trick too, preheat then epoxy.
I never sand epoxy, I use sharp cabinet scrapers.
Sometimes I assemble and glue the whole shell using epoxy glues, then epoxy seal the rest of the ply.
#14
Posted 16 November 2012 - 01:54 AM
#15
Posted 16 November 2012 - 02:38 AM
#16
Posted 16 November 2012 - 04:47 AM
#17
Posted 16 November 2012 - 12:53 PM
