Trailer Bunk Pad
2 replies to this topic
#1 Anemkne Tickler
Anemkne Tickler
  • 10 posts
  • Interests:Antrim 27
    Solo offshore
Posted 26 November 2012 - 05:33 AM
I own an Antrim 27 weighing around 3000 lbs. I have a white VC Offshore Performance paint on the bottom, and I strictly dry sail. The bunk board carpeting is a mess, leaves stains on the bottom, and is at the end of its lifespan.
What is a good plastic/Teflon padding I can use on my 12' x 4" bunk boards instead of carpet?
#2 allen
allen
  • 536 posts
Posted 26 November 2012 - 05:48 AM
If you strictly day sail how about paint?
#3 Christian
Christian
  • 7,725 posts
Posted 26 November 2012 - 06:45 AM
Hydro Turf in a diamond pattern is what I use with very good results - it conforms well to the hull - the boat doesn't slide - it is closed cell so it doesn't soak up water - the pattern lets some air through so it doesn't stay wet - you can get it as self-stick
