Trailer Bunk Pad
6 replies to this topic
#1 Anemkne Tickler
Anemkne Tickler
  • 10 posts
  • Interests:Antrim 27
    Solo offshore
Posted 26 November 2012 - 05:33 AM
I own an Antrim 27 weighing around 3000 lbs. I have a white VC Offshore Performance paint on the bottom, and I strictly dry sail. The bunk board carpeting is a mess, leaves stains on the bottom, and is at the end of its lifespan.
What is a good plastic/Teflon padding I can use on my 12' x 4" bunk boards instead of carpet?
#2 pin head
pin head
  • 622 posts
Posted 26 November 2012 - 01:45 PM
three strips of vinyl (i think) stips of rub rail/bumper materal with stiff plastic cordage inside. this will offer ventilation. I'd do it, but too lazy!
#3 Tucky
Tucky
  • 2,121 posts
Posted 26 November 2012 - 02:42 PM
I've had decent luck with astroturf type material, the plastic stuff they use on door mats. It is stiff enough to let the hull dry but not so stiff as to cause scratching.
#4 jaybird1111
jaybird1111
  • 61 posts
Posted 26 November 2012 - 03:27 PM
BoatBlanket has been treating me well.
http://www.sailrite....-Fabric-Gray-72
#5 Mojo Risin
Mojo Risin
  • 4,135 posts
Posted 26 November 2012 - 10:13 PM
This stuff: http://solutions.3m....Zbe0LP73J3X1Tgl
Used it on the bunks of my hydrohoist when I had the Rocket. Doesn't hold water and the loops allow it to air out.
Easy on the gelcoat also.
#6 Chinook
Chinook
  • 86 posts
  • Interests:g
Posted 26 November 2012 - 10:19 PM
Where do you get white VC Offshore? Sure it is not Trilux?
#7 Anemkne Tickler
Anemkne Tickler
  • 10 posts
    Solo offshore
Posted 26 November 2012 - 10:42 PM
VC Performance Epoxy
