Sydney 40 tiller
#1
Posted 28 November 2012 - 02:27 PM
I believe they were an option and I am thinking about switching.
Does anyone know if there is a tiller about?
What are the boats like with a tiller?
Thanks.
#2
Posted 29 November 2012 - 12:45 AM
That said, I would only consider a tiller on a 40 footer if all I was doing was racing inshore around the cans. Any offshore, long distance, or deliveries stick with the wheel.
#3
Posted 29 November 2012 - 02:07 PM
The issue is the significant wheel well that I assume the standard tiller has a solution for.
Yep only inshore.
Offshore or deliveries could be autopilot. Consensus of people who are much better sailors than I is an autopilot is more accurate anyhow.
#4
Posted 29 November 2012 - 08:42 PM
Robin
#5
Posted 29 November 2012 - 10:22 PM
I recall a Davidson 55 called Great fun at one of the earlier Clipper cups in Hawaii - might have been '80 or 82'- but it had a tiller about 12 feet long. Needed a helo landing pad to swing it in!
#6
Posted 30 November 2012 - 02:10 PM
I own one of the 38s with a tiller. The hulls of the 38 and 40 are very similar as are the deck layouts. From there they are quite different in rig and in weight. Unlike AVID I have owned much bigger and heavier boats with a tiller and much prefer that to a wheel. Even for offshore racing. At some point there is a switch over but not, in my opinion, at 40 ft. That said I do not believe that there is any 40 that had a "factory" supplied tiller conversion and it would be a pure custom job. I am not sure the expense would be worth the either the trouble or the marginal performance improvement that comes from the tiller.
Robin
Thanks.
Do you know if it's a lift out and drop in job?
To me it doesn't look to be a big job... The biggest bit looks to be the wheel well - which appears to be a single piece connected to the deck, which has as part of it the setup for runners, checks and back stay.
Wanna swap for my wheel?
#7
Posted 30 November 2012 - 10:32 PM
- after removing wheel and well is there sufficient distance between rudder head and any part of traveller/maintrim/hydrolics that a tiller of sufficient length can be inserted
- Remeber, depending on how you like to tack or jibe (do you go over the tiller or in front of) you need to have that space as well.
- You need to devise a proper seating station for the helmsman. Chocks or other non skid devices are not sufficient upwind. Needs a proper foot brace from each side of the cockpit.
- Remember that you need to leave enough room between the Helmsman with his extended tiller (therefor further in forward than wheel) and the Main Winch for the Main Trimmer.
- Sawzall will get rid of the wheel well but I would not begin with out being sure of need tiller length.
- One of the things that was done for the 38 to substantially improve its performance (less quirkey) over the 40 was (I believe I am correct in the following) to make the rudder itself slightly deeper and more balanced. So a rudder rebuild might be in order.
#8
Posted 01 December 2012 - 09:15 AM
All good advice.
Rudder is the new bigger job. And she has a new keel this year too.
#9
Posted 01 December 2012 - 11:26 AM
Robin
By very similar you mean the same with 2 feet on the back right??? Someone might be able to elaborate more, But wasn't the mold extended to make the 40?
Contact these guys http://www.innovatio...posites.com.au/ They are basically Sydney Yachts.. They have all the Molds and files for the Sydney boats. I'm sure they have it all on file. Probably even do a kit for you.
#10
Posted 01 December 2012 - 06:22 PM
Robin
#11
Posted 01 December 2012 - 09:29 PM
Actually it was the other way around. And as the 40 was less than 40 and 38 longer than 38 the first 38 mold was a modified 40 mold. The the first deck mold for the 38 is also a modified 40 deck mold. Exact proportions I can not give you.
Robin
You're right on it being the other way around but wrong on the length. The 40 is 12.5m.
Thanks for the website. I'll chase them.
