#1
Posted 07 December 2012 - 05:51 AM
See link below
http://www.ayachts.co.nz/a27.shtml
no connection, refreshing to see a boat on the water before a rendered image
#2
Posted 07 December 2012 - 08:21 AM
#3
Posted 07 December 2012 - 01:58 PM
While I take a broad-church definition of "sportsboat" I'd struggle to call it that.
#4
Posted 07 December 2012 - 03:17 PM
wholy s... that thing is overweight and underpowered - and it is clear from the pics that it digs quite the hole in the ocean. I am
not actually sure itactually sure it doesn't belong in the sportboat anarchy SA/D upwind @26 and downwind @63 - no dice)
we use SA/D upwind + SA/D downwind >= 105 as our definition of sportboat
#5
Posted 07 December 2012 - 03:26 PM
Like the idea of this boat though. MAke it 1500 lbs lighter and then we can talk - but keep the interior and the inboard - I like those!
#6
Posted 07 December 2012 - 03:36 PM
wholy s... that thing is overweight and underpowered - and it is clear from the pics that it digs quite the hole in the ocean. I amnot actually sure itactually sure it doesn't belong in the sportboat anarchy SA/D upwind @26 and downwind @63 - no dice)
My general cutoff is 35+ up and 100+ down as well as disp/length well under a hundred
This one is a total porker..........
#7
Posted 07 December 2012 - 11:36 PM
#8
Posted 08 December 2012 - 02:31 AM
I like the looks of the boat, the aft hull flare, windows, cockpit layout, wide side decks and cockpit line console, but you are right about the displacement. I would have expected a number closer to 3200 lbs
Actually - to be an exciting sportboat it should get down closer to 2000 lb and more than half in the bulb - and get a bigger kite
