Ok, so have the mast out of a mumm 30 and wanting to make sure everything was right before it goes back in. Check cable for MHU and a number of spots have chafe down to bare copper, basically the cable is fucked. Easy I thought, buy new cable re solder into plug and presto, seems in pulling things apart I may have fucked them even more. I pulled the rubber grommet off the back of the plug assembly and it came with some pins and some pins stayed in the plug.
So, question is, is this completely fucked, can the wire be replaced. How does one re-feed the individual wire through the grommet at the back of the plug? Or, do I need to buy a new plug and cable assembly.
Cheers
213 masthead unit plug and cable
Started by bowman81, Dec 09 2012 08:56 AM
5 replies to this topic
#1
Posted 09 December 2012 - 08:56 AM
#2
Posted 09 December 2012 - 12:26 PM
Hi Bowman81,
If you need some new plugs or pins, you can order them at farnell/element14.
For instance the pins:
http://au.element14....242?Ntt=593-242
The hole unit is a standard AMP connector.
For the Vertical MHU I have the correct codes on my site:
http://www.oppedijk.com/bandg/mhu
For the horizontal I don't know the right order codes, so if you figure them out, please let us know.
Erik
Erik
#3
Posted 10 December 2012 - 06:18 AM
Hi Erik, thanks for the reply and links. I will try to attach picture when I can but the pins you linked above are not quite the same as the ones I removed, they have 2 rubber water seals on the shaft to prevent ingress into the plug.
It appears that the tapered rubber grommet at the back of the plug appears to be moulded around the wires once they are soldered in place. To get past this I have drilled this out to allow the wire to pass though and I will reseal with a silicon once everything is soldered in place. I think I have managed to save the pins which can be reused so hopefully everything will go back together and last another 10 years until it's someone else problem.
#4
Posted 11 December 2012 - 08:48 PM
The whole connector should be filled with something like SikaFlex. Can you post some pictures of the pins and assembly?
#5
Posted 11 December 2012 - 10:25 PM
Real PITA to fix with the rig in. I would be inclined to buy the whole thing together so it is legit. If you are going to DIY it at least think about a way to test it before the rig goes in.
#6
Posted 12 December 2012 - 10:33 AM
Sorry about the delay getting back to you. The pic below shows the pins, you can see the 2 black bands which are weather proofing to prevent water ingress from the front of the plug. Because the black grommet is moulded around the cable from factory I have hollowed the front out and have got my electronics guru to solder it all together before filling the grommet with silicon/sikaflex then reassembling. The correct pin out is available on the BG website and we can check continuity before re installing it. It all sounds easy when written down like that...
