Hot water...this seems do-able.
#1
Posted 09 December 2012 - 08:54 PM
http://www.precision...s-water-heater/
Built in the USA. Price is reasonable. The unit employs a power vent system and can can be mated with up to 20' of 2" exhaust flue, so mounting it in one of my very deep cockpit lockers becomes an option.
Anyone have any experience with these units??
#2
Posted 09 December 2012 - 09:00 PM
#3
Posted 09 December 2012 - 09:09 PM
I think so...with enough volume of air I assume the exhaust temp could be reduced to a safe level...and it can go on a vertical surface so there are more options.
This from the manual. In my case the outside of a coaming would work very well.
The duct can be up to 20’ long to the outlet and
must be secured in place. Use an outside metallic vent terminus that can not be closed and
has at least 7 square inches of open area. The vent pipe must be above the water line and
should be sloped toward the outside to prevent water from entering heater.
#4
Posted 09 December 2012 - 09:24 PM
#5
Posted 09 December 2012 - 09:38 PM
I have a CO detector aboard GK because of the range not being vented outside...it has never gone off except when I test it.
#6
Posted 09 December 2012 - 10:09 PM
I will say this. I thought about putting one on my boat. Felt they were up to par and that Wolter had solved any potential issues with the forced air flue. The reason I was thinking about it was unlimited showers, particularly when hooked up to city water. The reason I decided not to was because I have a teenage daughter.
#7
Posted 09 December 2012 - 10:26 PM
Our 30 yr old Polarmo on GK can empty both water tanks (80 gal total) under pump pressure that is no less than I have at home...right down to the last drop of water it'll be so hot you can't touch it, and that's set on med-low.
#8
Posted 09 December 2012 - 11:36 PM
#9
Posted 09 December 2012 - 11:38 PM
#10
Posted 10 December 2012 - 12:18 AM
If it's not broke , why fix it ?
I'm not replacing it until I can't fix it anymore...the heat exchanger had a water leak last year but an automotive rad shop took care of that repair. If I have any issues with the propane controls then I'm toast.
I had given up any chance of having this type of water heating again...I only posted it as a plausible replacement or upgrade for some here.
#11
Posted 10 December 2012 - 12:32 AM
Basically yes. I seem to recall the final straw was a large powerboat that had installed the Wolter in a hanging gear locker adjacent to the shower stall. Girl died from taking a prolonged shower much as you describe with your 80 gallon story. For several years folks were hawking parts from discarded units to get some more years out of their own.
I heard exactly the same story. There was only one more addition. The girl was cold and closed the port hole and hatch in the head. The owner of the boat had specifically told her not to, but she was cold and had no idea WHY she was to leave them open. The painfully obvious solution is to always mount these sorts of heaters in a space that is separately vented to the outside, a fan to exhaust the air around the heater might be a good idea too - it wouldn't take much.
Gate, one thing to consider. I have a couple of friends who have put the exhaust for this sort of heater on the side of the hull and it's unusable when the boat is heeled over. Also, when the weather gets really snotty, you don't really want to give away a hot shower or warm water for dishes. So, my friends are all slowly moving their exhaust to the transom, up high near the centerline. It works well for water heaters and also for the forced air diesel heaters. The only difficulty is if you like to anchor from the stern, as I do, you'll smell the darn thing a lot.
BV
#12
Posted 13 December 2012 - 05:44 PM
BV
I don't think you're going to smell a propane heater at all. our Newport Dickinson going full blast doesn't have any smell on deck or anywhere else, and this seems a lot more efficient than that. The diesel heaters are another story.
