no way
64 replies to this topic
#1 Editor
Editor
  • Moderators
  • 5,905 posts
Posted 02 May 2013 - 07:51 PM
There is no way these sheeting angles are right. Look at the return on that jib leech and look how far to weather the boom is cranked. No way! Tell us what you think from this telltale shot by Jesus Renedo at Palmavela.
#2 Trent
Trent
  • 40 posts
Posted 02 May 2013 - 08:01 PM
"I knew there was a sandbar somewhere around here!"
"Come on boys, let's roll tack this mother."
#3 lartaunt
lartaunt
  • 909 posts
Posted 02 May 2013 - 08:07 PM
Unless they are in hyper-point mode to pinch somebody off, I would have to agree, this looks slow and is inducing the excessive heal that the hard hiking crew is failing to flatten out.
#4 MisterMoon
MisterMoon
  • 1,845 posts
Posted 02 May 2013 - 08:14 PM
"This is how you sail directly to windward. Tacking is for pussies!"
#5 NoStrings
NoStrings
  • 10,673 posts
Posted 02 May 2013 - 08:15 PM
"I don't know guys, she feels kind of sluggish"...I love seeing shit like this...especially when some self satisfied "rockstar" has done it.
#6 notallthere
notallthere
  • 2,881 posts
All lift is drag, but not all drag is lift...
#7 JMOD
JMOD
  • 879 posts
Posted 02 May 2013 - 08:25 PM
hyperpointing.... they probably have the wrong polars programmed
#8 Delta Blues
Delta Blues
  • 6,809 posts
Posted 02 May 2013 - 08:26 PM
Editor, you simply can't afford, or understand a Wally.
#9 longy
longy
  • 3,199 posts
Posted 02 May 2013 - 08:29 PM
  Looks like jib is too full, esp down low, with hooked leach. Hence main has to be over-trimmed down low (we can't see much) to fill it. I'd suspect there's a lot of twist in both sails.
#10 maxfunner
maxfunner
  • 144 posts
Posted 02 May 2013 - 08:35 PM
Light air sailing on modern racers.
Keel doesn't provide lift because you're not moving fast enough, so you need to increase the angle of attack on the keel to create some lift.
Baggy jib with a lot of twist, same on the main; boom way up and lots of twist.
Same trim style on a Farr 40 in light airs for example.
It's not pretty, but otherwise the keel won't give any lift and you'll get nowhere.
#11 mrming
mrming
  • 181 posts
Posted 02 May 2013 - 08:39 PM
It doesn't look like light air with that angle of heel and bodies on the rail...
#12 Great Red Shark
Great Red Shark
  • 7,476 posts
Posted 02 May 2013 - 08:42 PM
That jib-leech looks wicked hooked-closed to me,  but then what do I know.
But the boats I've sailed with continuous athwartships tracks sure wouldn't let you sail with that angle of attack for long.
#13 BronzeWing
BronzeWing
  • 322 posts
Posted 02 May 2013 - 08:47 PM
Having seen a Team NZ crew do something similar in an Ecthells in very light winds, it can work. Blade the jib, bring the traveller up over center and twist the main bigtime. As the boat starts to move, shape is slowly introduced to the jib and the twist is taken out at the same rate the traveller is eased. Awesome to watch. So ugly yes but it works in the right conditions.
#14 TimFordi550#87
TimFordi550#87
  • 2,344 posts
Jeebus criced, it's a 500th of a second in time! Maybe they were pinching up to a mark.
Nothing to see here, folks, move on.
#15 Lewdicrous Speed
Lewdicrous Speed
  • 154 posts
Posted 02 May 2013 - 08:50 PM
jib's just overtrimmed, or blown out,  lead position looks ok might be a touch forward
#16 Gorn FRANTIC!!
Gorn FRANTIC!!
  • 3,943 posts
Posted 02 May 2013 - 08:51 PM
You can forgive it for being ugly if it's going fast...blowing up the numbers on the mast instruments it looks like they're pulling 9.53 knots uphill at 41TWA in 10.3 knots TWS...not exactly shabby numbers in my book.
#17 mleitch
mleitch
  • 1 posts
Posted 02 May 2013 - 08:52 PM
I'd assume that rather than racing, they're posing for a cool picture..... Hopefully the sponsors aren't sailors ;)
#18 mcsailor0303
mcsailor0303
  • 917 posts
Posted 02 May 2013 - 08:56 PM
Ultra point mode???
#19 jrenedo
jrenedo
  • 31 posts
Posted 02 May 2013 - 09:04 PM
Hi , if that helps,  it has been taken right after the start , the made the pin end of the line, and where pretty clear from the other boats, wind speed was around 8 knots .
A big right swift minutes later cost them the race. And there is a lot of talent on board that boat, with plenty of guys from Telefónica Volvo and Adan Minoprio on the aft guard
#20 ؏ΩӁقڝӃڜ Җ
؏ΩӁقڝӃڜ Җ
  • 479 posts
Any one here raced on a boat that big?
I thought not.
We need to see the rest of the rig - not just the lower 5%.
#21 DiasDePlaya
DiasDePlaya
  • 50 posts
Posted 02 May 2013 - 09:14 PM
The pro's are doing that long time ago.
#22 Grinder
Grinder
  • 7,019 posts
Posted 02 May 2013 - 09:15 PM
What's it rate?
#23 Vee
Vee
  • 293 posts
Posted 02 May 2013 - 09:20 PM
I thought not.
+1000.
What does the twist look like.
#24 JRC808
JRC808
  • 213 posts
Posted 02 May 2013 - 09:26 PM
What can I say. Sometimes I have to sandbag too, when I get that far ahead of the competition. It helps me with my rating too.
Lol.
Maybe some crazy wind shear shit? the tops are really open? It's a bit excessive nonetheless.
#25 Editor
Editor
  • Moderators
  • 5,905 posts
Posted 02 May 2013 - 09:42 PM
yeah, they were awesome. look at what all that talent got them. i know, maybe they didn't have the boom pulled far enough to weather....
#26 full circle
full circle
  • 1,646 posts
Posted 02 May 2013 - 09:49 PM
oh...it's a baltic.
i'll get my coat.
#27 Geronimo
Geronimo
  • 285 posts
Posted 02 May 2013 - 10:11 PM
Definitely not in go mode here. I noticed this before I even clicked the link on Facebook. The lead needs to be dropped back and the traveler dropped down. Nuff said.
#28 RustySkiff
RustySkiff
  • 82 posts
Posted 02 May 2013 - 10:25 PM
Pull everything on until it's tighter than everything else.
#29 Terrafirma
Terrafirma
  • 3,569 posts
Posted 02 May 2013 - 10:54 PM
Certainly looks like they have way to much heel to justify that mode so perhaps a gust hit and they were all napping..?
#30 Pete M
Pete M
  • 10,009 posts
Posted 02 May 2013 - 10:55 PM
you guys are funny
#31 Grinder
Grinder
  • 7,019 posts
Posted 02 May 2013 - 11:14 PM
Funny how? Like a clown? Do we amuse you?
#32 Beachcomber
Beachcomber
  • 75 posts
Posted 02 May 2013 - 11:21 PM
Oh my gawd!  Those morans must be doing something wrong because I would never sheet the sails so hard on my 6 knot shitbox!
uhhhm...not so fast.
The more efficient the rig, the harder you can sheet the sails.
#33 PKGB
PKGB
  • 670 posts
Posted 02 May 2013 - 11:26 PM
...good comparison...
Just saying...
#34 sheeting yarns
sheeting yarns
  • 395 posts
Posted 02 May 2013 - 11:46 PM
PKGB's trim image comparing lower jib leech return looks like a safer VMG trim. One problem with the numbers off the instruments is that the leeway is a calculation rather than a precise measurement. So the numbers always look better for some time with super tight trim but the result of this trim over time is a much higher leeway. So the boat will look right and feel pretty good but will have plenty of sideways slip with the associated high drag that comes along with it. That being said, some boats (like TP52's) are designed with a keel performance bucket that works best with rather high (5-6 degree) leeway angles so if you are pretty confident in your actual leeway numbers, the optimum trim in flat water can be pretty firm.
It is not unusual in many high-performance yachts to have the mainsail boom quite a bit to windward but you need to be spot-on with the twist and lower mainsail depth to avoid excessive leeway and high rudder angles.
#35 Maxx Baqustae
Maxx Baqustae
  • 4,353 posts
Posted 02 May 2013 - 11:48 PM
I dunno. I think needs another wheel in the middle.
#36 V_One
V_One
  • 15 posts
Posted 02 May 2013 - 11:58 PM
The foot looks really tight. If the car was too far forward the foot would be much deeper. Between the tack and clew it's virtually straight.
Tight foot line maybe.... take it off the winch!
Just sayin.
#37 B.Wilkinson
B.Wilkinson
  • 278 posts
Posted 03 May 2013 - 12:12 AM
Just thinking out loud..... If you have better ideas, buy your own boat that big and do as you wish.... Just sayin'
#38 nuttyrave
nuttyrave
  • 24 posts
Posted 03 May 2013 - 12:45 AM
whoever mentioned Italian boats doesn't know their Finnish yards.
Has to do with the relative low pressure leeward of that forward 3di airfoil. It is not giving habitual lift to the main -> Little venturi effect benefit. that's my call.
I bet the captain knows...
#39 Gunny
Gunny
  • 66 posts
Posted 03 May 2013 - 01:14 AM
Hey, that's what's where the sailmaker put the stickers on the jib track and the traveler before he had to jump off and go to the bar.
#40 onedesignj80
onedesignj80
  • 288 posts
Posted 03 May 2013 - 02:06 AM
This is the Retro look from North Sails. Does anyone remember the " Frisbee Main " If I remember correctly that was back in the very late 70's or very early 80's......
#41 Flatbag
Flatbag
  • 4,301 posts
Posted 03 May 2013 - 02:26 AM
To quote the late Eric Strain, a well known and very succesful Sydney Dragon sailor:
"One day there will be an owner with lots of money... and ability!"
That guy aint it!
#42 Mudz
Mudz
  • 419 posts
Posted 03 May 2013 - 02:41 AM
That's normal. The direction they are travelling through the water is probably about 8-10 degrees to the centreline of the boat.
#43 skew
skew
  • 811 posts
Posted 03 May 2013 - 02:50 AM
They have VSPARS.  No matter how wrong it looks, it must be right!
#44 ipexnet
ipexnet
  • 160 posts
Posted 03 May 2013 - 03:00 AM
Spot on MAX, I was going to say the same thing.
but the jib does look a little tight the lower main pocket must be impacted. Gotta be a big rig
the loose luff on the main is the telling sign in all this, you need to be high on traveller to stop a stall.
Would be hard pressed to see  a farr40 so high
#45 ABC
ABC
  • 86 posts
Posted 03 May 2013 - 03:36 AM
Basic rule of thumb when trimming sails upwind: "pull it in till the boat stops - then let it out a little".  Maybe they have not gotten to the let it out a little part yet.
Who's the pro on the boat?  Maybe they can give us insight on trimming these new fangled sails that have battens and don't have to wrap around the spreaders.
#46 Drocca
Drocca
  • 9 posts
Posted 03 May 2013 - 03:44 AM
Painful to look at on such a beautiful boat. It would be nice to see a full view of the sails. I'm sure that broader lense wouldn't look any prettier.
#47 kiwichas
kiwichas
  • 66 posts
Posted 03 May 2013 - 04:29 AM
Could be a bit of wind sheer
#48 Jaja
Jaja
  • 78 posts
Posted 03 May 2013 - 05:51 AM
I have no problem with high traveler and loads of twist as suggested by other posters but it's clearly too tight. In eight knot i may go with an even higher traveler but far less sheet.
#49 Lorrie Clarkeson
Lorrie Clarkeson
  • 11 posts
Posted 03 May 2013 - 07:10 AM
Nice vid and the winners sails http://blog.gaastrap...ir-peter-ogden/ have a pause on the numbers in the middle of the vid. Just because you paid lots for something doesn't mean it's any good.
#50 polarbear
polarbear
  • 673 posts
Posted 03 May 2013 - 01:25 PM
  I'm thinking Farr 40 trim in some conditions.  Maybe the picture exaggerates the effect somewhat.  The other thing we don't know are the numbers they are seeing.  If you are high and fast, who cares if the sails look like shit ;)
#51 ChristianSch
ChristianSch
  • 347 posts
Posted 03 May 2013 - 02:10 PM
#52 Remodel
Remodel
  • 7,715 posts
Posted 03 May 2013 - 03:56 PM
Way.
#53 Chad Covert
Chad Covert
  • 3 posts
Posted 03 May 2013 - 05:41 PM
Not seeing anyone in font of them, so that's a good sign.
J24 light to mid air, same thing... opens the slot up. It is something you can't understand until you do it and realize it's fast.
#54 Oxygen Mask
Oxygen Mask
  • 6,672 posts
Posted 03 May 2013 - 10:53 PM
Couple years ago someone posted a video of boat on a windy ass day in SFO Bay sailing for miles with the main that far, or even farther, to weather. They were outpointing and overtaking and passing everything around.  In some conditions that can work quite well.  (Never could make it pay on my boat...)
Agree that you need to see the rest of the rig. Looks like only the bottom few feet of that main are above centerline. There is a hell of a lot of sail area farther up...
#55 Dawg Gonit
Dawg Gonit
  • 9,727 posts
Posted 03 May 2013 - 11:06 PM
Light Air, Flat water
Jib in tight
Traveller to weather with sheet off.
Point high
Main has power.
There are times it works.
I've done in the 2.4mR in light air, in Chicago and it works in the right condition.
If you get out of your comfort zone, travel and do regattas in different geographical areas, you will learn many many new techniques.
It is your job to choose which technique works at the time.
#56 robmo01
robmo01
  • 34 posts
Posted 03 May 2013 - 11:33 PM
Everthing is too freekin' flat for the conditions, the boat is heeling way too much, if they would put more curvature in both the main and jib, they'd take heel off the boat and increase speed, but what the hell, have a beah and enjoy the sunshine.
#57 bruno
bruno
  • 3,017 posts
Posted 04 May 2013 - 02:14 AM
upper leech in 2 worlds? some sag there, why no conniption fit?
#58 titop
titop
  • 302 posts
Posted 04 May 2013 - 09:58 AM
Stop theorizing ! Think of the two sails as one, if you look on the photos the n°1 is very full in front so plenty of drive forward. And only testing and speed could tell...
#59 titop
titop
  • 302 posts
Posted 04 May 2013 - 10:07 AM
On mini maxi when a n°1 is 4° off and mainsail 11° upwind . If you get n°1 not coming back it would be to flat lack of power. if the picture was taken in line off the boom the sails would probably look alright.
So you can go about 10 degrees higher as if the sails were in line as long as the keel cope with an add of drag. So it is between going high and slow and only practice can tell how much is too much.
#60 crusingsailor
crusingsailor
  • 24 posts
Posted 04 May 2013 - 01:20 PM
#61 blackjenner
blackjenner
  • 3,261 posts
Posted 06 May 2013 - 04:20 PM
Look closely at that picture again.
Here are your clues.
1) look at the distance between the deck winches and the pushpit railing.  It's almost twice on port as on starboard.
2) you can see more of the inside of the hull on the starboard side than the port side.
3) the pushpit is off center from the mast by a significant amount; one third on port side and two thirds on starboard.
We are not looking directly down the center line of that boat.  We are slightly port of the center line. I'm guessing around 10 degrees.
#62 Widget-CYC
Widget-CYC
  • 56 posts
Posted 07 May 2013 - 02:53 AM
And they thought the tiller was the only e-brake on a boat....
#63 RobG
RobG
  • 1,026 posts
Posted 07 May 2013 - 01:26 PM
 Yes, the photo is taken from slightly to port, but not much. The boom is well to starboard of the centre of the pushpit, the traveller is further across.
But I'm not going to say they have it wrong, we can't see the rest if the rig.
#64 Trickypig Хитрый свиньи
  • 4,001 posts
Posted 07 May 2013 - 05:46 PM
Possibly they've gone into jamming mode off the start. Maybe they've got a faster boat on their hip they want to force off.
Photo of boat in better trim... or perhaps they are too low in the groove! ;)
#65 Dawg Gonit
Dawg Gonit
  • 9,727 posts
Posted 08 May 2013 - 06:34 PM
And much winder / rougher conditions.
