Speed Dream 27
sailing video
14 replies to this topic
#1 Doug Lord
Doug Lord
  • 11,452 posts
Posted 06 May 2013 - 12:23 AM
First, turn the sound down-very bad sound quality but the boat looks real good(have questions about the keel popping in and out) :
http://www.speeddream27.com/main.html
#2 GybeSetŪ
GybeSetŪ
  • 22,166 posts
Posted 09 May 2013 - 11:47 AM
no a 49er, or 79er(B8.0) for that matter is proven and fast
no experimental nature to them at all, or claims that haven't already been proven
#3 facthunt
facthunt
  • 894 posts
Posted 17 May 2013 - 10:20 PM
what would you like to know about the keel pooping out.
#4 Jethrow
Jethrow
  • 694 posts
Posted 17 May 2013 - 11:11 PM
Looks like it needs racks out the back as they're already cramped in the back corner in not that much breeze.
The keel also seems to do a good job of making sure everyone gets soaked through.
#5 RustySkiff
RustySkiff
  • 82 posts
Posted 22 May 2013 - 01:27 AM
Needs more freeboard and wings
#6 Munter
Munter
  • 464 posts
Posted 22 May 2013 - 03:22 AM
It shows a nose down attitude while heeled. The windward side of the bow seems to end up with water sitting on top of it and presumably pushing the boat down. I know these are just early sails of a prototype but it looks a long way from exceeding 30kts like was claimed before launch.
#7 facthunt
facthunt
  • 894 posts
Posted 22 May 2013 - 08:15 AM
the rig looks good, wait for the capsize to windward
#8 fireball
fireball
  • 739 posts
Posted 23 May 2013 - 08:43 AM
We had a hilarious boat in Sydney called Q and owned by Bob Oatley's son. The canting keel actually rotated around the boat with a complex mechanism built into the hull.
It came unstuck when the thing jammed and they realised that instead of the keel canting you could have the keel vertical and the boat canting instead. There's some great pictures of it capsized in Sydney Harbour with the crew standing on the upside down hull.
Other possibile problems include: a boat to windard takes your breeze, your boat capsizes to windward and your rig hits theirs.
The thing was a total waste of time and never worked.
I wonder if there's a reason we only see video of Speed Dream 27 reaching along with no other boats around?
#9 Doug Lord
Doug Lord
  • 11,452 posts
Posted 23 May 2013 - 12:45 PM
Besides Q there is a Jo Richards/Guy Whitehouse design" Stravaganza with a 180 degree canting keel. Lake racer-don't know how they're doing. pictures from Whitehouse site. Nicole Scott pix of Q:
Pictures-1 & 2 Stravaganza, 3-Q
#10 Raz'r
Raz'r
  • 32,221 posts
Posted 23 May 2013 - 01:54 PM
Sure seems like a lot of bother to get almost multihull performance.
#11 RustySkiff
RustySkiff
  • 82 posts
Posted 26 May 2013 - 10:39 PM
Mulithulls are too unsafe compared to a monohull...oh wait a minute, is swinging the bulb safer?
#12 Rawhide
Rawhide
  • 1,575 posts
Posted 27 May 2013 - 02:39 AM
I really don't see the point of these rotating keels. Surely it would be a hell of a lot simpler to have the equivalent of the old sliding plank. You could have a lump of lead or water filled container that slides along a curved plank, which itself can be extended either side of the boat. This would have higher righting moment, less mechanism and because it is out of the water all the time there is less drag, and it can have an air volume equal to or greater than the mass of lead, so the boat is less likely to capsize if it ends up on wrong side. You will then just need the minimum standard keel to make the boat self-righting and the buoyancy in the ballast enclosure would help with this as well when immersed.
#13 Doug Lord
Doug Lord
  • 11,452 posts
Posted 27 May 2013 - 03:01 AM
I think you're 100% right as did Julian Bethwaite Paul Cayard and Russel Coutts. And one of the Herreshoffs in the 1850's(?) built several succesfull race boats with on-deck movable ballast. But when a design for a dinghy using this kind of system was suggested in DA the majority "shouted it down".
You might want to check the thread out. I believe either I or someone else will prove the viability of such a system in a modern boat(already proven in the old days! ) Anyway, either I'm very wrong(I'm not) or quite a few others are: http://forums.sailin...pic=146245&st=0
On-deck Movable Ballast designs-1) 18 footer,2) 14 footer,3) Bethwaite/Coutts/Cayard Pterodactyl-Coutts wanted sliding lead, Bethwaite wanted water. No pictures of Herreshoffs on-deck movable ballast boats-iron on rails(!)-and very fast:
#14 facthunt
facthunt
  • 894 posts
Posted 27 May 2013 - 11:54 AM
#15 ShowponyStuart
ShowponyStuart
  • 1 posts
Posted 17 August 2013 - 11:52 PM
I'd feel better about these projects if there was some discrete data being offered up as opposed to a bunch of videos showing undisclosed speeds and comments from otherwise intelligent people saying "wow, sailing the <insert version of the boat here> was really cool!" none of this helps define if Vlad is actually making progress on attaining multihull speeds in a monohull, or if it's just another 49er with more parts to break.
Im with you on this one. For some reason they seem to think they have some massive secret that everyone is out to steal, and providing any data like tacking or gybing or even any actual numbers on speed will suddenly result in 100 other people producing copies of their design.....that or its shit and isnt working as well as they hoped.
