VX One hits 24 knots at Macintosh Cup this past weekend!!
Savannah Yacht Club
49 replies to this topic
#1 Vela Sailing Supply
Vela Sailing Supply
  • 772 posts
Posted 06 May 2013 - 03:48 AM
Here is the clip, courtesy of Andrew Brennan
Tons of fun, with a broach, quick recovery and back to speed.
Good job boys.
#2 V. Green
V. Green
  • 4,296 posts
Posted 06 May 2013 - 05:15 AM
I am so ready to be back at the helm of a VX!
#3 MR.CLEAN
  • Reporters
  • 37,307 posts
Posted 06 May 2013 - 05:43 AM
#4 Christian
Christian
  • 9,265 posts
Posted 06 May 2013 - 12:56 PM
Just correcting you here - I know you are seldom wrong............................ahem........................but the vid starts out with kite run for the first 2/3, a broach, douse, and then ends with a 2 sail reach/run
#5 schoonerman
schoonerman
  • 3,281 posts
Posted 06 May 2013 - 02:24 PM
Great Video! Is that Brian's Son?
#6 PATSYQPATSY
PATSYQPATSY
  • 566 posts
Posted 06 May 2013 - 03:27 PM
Tired?  I am.  Very cool.
#7 Vox
Vox
  • 55 posts
Posted 06 May 2013 - 04:43 PM
Awesome. Now show us what the "SS" version does on the speedo.
#8 Icebear
Icebear
  • 189 posts
Posted 06 May 2013 - 07:26 PM
What true wind angles?
Estimated TWS!
All two sail reaching?
Impressive!
#9 kiwikz7
kiwikz7
  • 53 posts
Posted 06 May 2013 - 07:47 PM
The first part is spinnaker till the broach,then main and jib as the river turns 90 degrees, wind 20-25 knots with gusts to 30kts.
#10 tamaozy
tamaozy
  • 223 posts
Posted 06 May 2013 - 07:53 PM
Love it.  Would love to have seen some from a head cam as well, looks like plenty of water about and waves.  Too bad the chase boat didnt have a camera as well.  Good recovery from the broach.  I like it all.
#11 us7070
us7070
  • 9,194 posts
Posted 06 May 2013 - 08:14 PM
I asked  about this once before, but i'm not sure I ever got a good answer...
what are the main advantages of sheeting from the boom?
last time i asked, i was told it was really common in skiffs, but that doesn't really answer my question.
why would you prefer it over sheeting from a block on the cockpit floor?
In this video, it looks really awkward, and the few times i have done it, i didn't like it.
#12 chicken eater
chicken eater
  • 181 posts
Posted 06 May 2013 - 09:09 PM
I've wondered the same thing about sheeting from the boom. Without really knowing, the only thing I can think of is that it helps clear the cockpit for heavy air gybes. The crew doesn't need to worry about crossing infront of or behind of the mainsheet while trimming the spin. I agree that it would be a more natural motion to have a block on the deck floor.
Anyone else have any thoughts?
#13 Vela Sailing Supply
Vela Sailing Supply
  • 772 posts
Posted 06 May 2013 - 11:14 PM
Sheeting from the boom basically gives you two advantages: absolute clearance for crossing allowing for better tacks and gybes; also trimming from the boom gives you a lot more feel due to the less travel of the mainsheet and the leech tension is achieved by the vang, so it is vang sheeting all the time. This set up helps you to properly trim at all times doing small changes that are hard to achieve when you have a cam cleat.. You just need to get use to it and make keep it with you at all time, no different than any dinghy. It is not hard work at all because the vang carries the load.
#14 Vela Sailing Supply
Vela Sailing Supply
  • 772 posts
Posted 06 May 2013 - 11:15 PM
Right on Christian. They start with the spinnaker up, broach, doused it and then kept going under main and jib only.
#15 D Brennan
D Brennan
  • 19 posts
When sheeting the main down to a deck cam; the sheet stays loaded making it hard to play. The G-nav bang is very powerful and takes all the leech loads. Sheeting off the boom is easy with this setup because the sheet only controls the in-out position of the boom. Once you get used to it; you'll never go back.
VX One 131 Budgie Smuggler
#16 us7070
us7070
  • 9,194 posts
Posted 07 May 2013 - 01:55 AM
well, i vang sheet all the time with my "normal" mainsheet setup.
i guess i can see that when you trim the main from the boom,you pull the boom more to weather, rather than down, even when the boom is close to the centerline.
in a normal setup, when the vang is on hard, and the boom is out to leeward, the sheet pulls the boom to weather too, but as the boom gets close to the centerline, the sheet starts pulling the boom down, affecting the leech tension as well as the boom position.
so, i agree that there might be more independent control of leech tension and sheeting angle with the boom sheeting arrangement.
nevertheless, the guy in the video doesn't look completely comfortable with it - he is fiddling around a bit as he transfers the sheet through his tiller hand in a way that wouldn't happen in a normal setup.
#17 Hugh knows
Hugh knows
  • 1 posts
Posted 07 May 2013 - 03:34 AM
What is your definition of fiddling when going 24 kts..? Floor cams are optional though if that's what you desire!
#18 teener
teener
  • 838 posts
Posted 07 May 2013 - 04:26 AM
Started sheeting from the boom a few years back and haven't looked back.
Clears up the cockpit.
Keeps your hands up by your face when hand over handing with the tiller in your hand. This also makes it easier to free a hand if your are steering.
Less sheet load; direction of pull is more natural for loading your lats; less fatigue.
When hiking out, sheet load takes some of your weight which makes hiking easier and if you need to scramble back in the boat in a big lull you can pull yourself back in by the sheet.
The only drawback is you can't quickly close up the leech if you are trying to pinch somebody off.
#19 tedrules
tedrules
  • 43 posts
Posted 07 May 2013 - 12:57 PM
One other point has not been mentioned about the off the boom sheeting. it allows you to carry a longer tiller extension and still clear it through tacks. I have never sailed any other boat with off the boom sheeting and have not had any problem with it.
#20 Vox
Vox
  • 55 posts
Posted 07 May 2013 - 02:50 PM
Not to derail the topic, but how would a VX do in light air on flat water compared to a Viper or a Melges 24?
#21 us7070
us7070
  • 9,194 posts
Posted 07 May 2013 - 02:54 PM
What is your definition of fiddling when going 24 kts?
i guess that's a fair point.
#22 ultraracer613um
ultraracer613um
  • 1,360 posts
Posted 07 May 2013 - 04:34 PM
When I took delivery of my VX i had Vela send me the hardware so that i could sheet of the cockpit floor.   I never put it in.   It was a little strange at first but now i love it.
The VX rig is designed so that  don't need to tug on the mainsheet like you do on other non-backstay sportboats.  The mast has checks that attach at the GNAV point...  with the GNAV on hard those engage forestay tension.   you can ease main a bit and drive down into the jib with out the forestay sagging.    Makes it really easy to sail in a breeze.
Also agree on the feel and open cockpit points.
#23 CorrosionX
CorrosionX
  • 199 posts
Posted 07 May 2013 - 08:30 PM
I haven't sailed on the same circle with Melges 24s yet, but having started behind the Vipers twice this year in very light conditions (both at Mardi Gras Race Week and at Fort Worth Boat Club Audi Annual Regatta Leukemia Cup -- or whatever they're calling it nowadays), I can confidently say the VX is a better light air boat (at least sailing 2-up). We were routinely finishing intermixed with the back 1/3rd of the Viper fleet even though we were starting 10 minutes and 5 minutes behind them (respectively).
So while the Vipers have the better upwind speed potential (and thus perhaps the reason for the lower rating -- at least here locally), in most conditions a VX will pass them pretty easily. In light air the VX is faster all-around. And I think the XV is probably faster in 10+ as well since it planes much earlier, easier and faster. The Viper may be a half a tick quicker upwind in med to heavy breeze, but as soon as the windward mark is rounded, game over. My 2 cents anyways.
#24 GLAZE
GLAZE
  • 464 posts
Posted 08 May 2013 - 12:00 AM
A well sailed VX will not be close to a well sailed Melges. That doesn't mean they wouldn't pass a back of the pack boat.
#25 ultraracer613um
ultraracer613um
  • 1,360 posts
Posted 08 May 2013 - 02:26 AM
Oh I don't know about that glaze. A lot would depend on the conditions an how you define "close".
5 foot of waterline and 5k in additional sail cloth can't hurt though ;-)
I also don't think that has really been tested yet.
But... Who really cares. I raced my Vx two weekends ago in almost 20 with my kid an we finished in the top half. I have two great buddies and when we want to sail together it's the viper. There is another wild man who wants to be part of the monkey-pack so word is we-be adding a m24 to the arsenal for that purpose.
Damn, maybe a flying tiger is in the cards..
My point is... Uh, I forgot
#26 MR.CLEAN
  • Reporters
  • 37,307 posts
Posted 08 May 2013 - 03:38 AM
VX should crush M24 downwind in the crossover range.
#27 Rohanoz
Rohanoz
  • 1,651 posts
Posted 08 May 2013 - 06:29 AM
How do the takedown patches look on the kite now...
#28 BalticBandit
BalticBandit
  • 12,728 posts
Posted 08 May 2013 - 12:24 PM
boom sheeting also reduces boom bend.  with the stern bridle, your sheeting vertical loads go straight into the leech.  You can choose to vang sheet or you can have a "2 speed" mode where the vang is set looser so the leech opens up when you ease in the puffs, but then closes for point when you really sheet on.  Unlike a cockpit floor or traveller ratchet only about 1/2 your sheeting load is vertical on the boom.  the other half is lateral.  so for a given sheet tension, (think catenary tension of say power lines) you will get more movement of the boom to weather from boom sheeting than cockpit floor sheeting so not only do the bending loads on your boom reduce but your total sheet loads come down somewhat as well
#29 GLAZE
GLAZE
  • 464 posts
Posted 08 May 2013 - 02:51 PM
From what I've seen of the VX, It seems they don't make great VMG downwind.  They do go really fast, but not down the course.  Now that could be sailing style by the skipper, but I think most would agree that Rod (Vela Sailing) is an accomplished skipper.  When we race against them in the crossover conditions (Melges in Disp., VX planing) I always freak out watching them haul the mail.  But they always seem to have to jibe a lot more and never quite make up all the distance.  Now in a straight line, the melges wouldnt stand a chance in the crossover.  Here are results from a PHRF regatta with 2 melges and 2 VX's, J29 and Olson 29.  The conditions were light to crossover.
http://www.dcyc.org/.../LC12_PHRF2.pdf
scroll down to see elapsed and corrected times
#30 ultraracer613um
ultraracer613um
  • 1,360 posts
Posted 08 May 2013 - 03:11 PM
Back when lake Travis had water we had a mixed fleet of vipers, j29's and j80's. In the early days we had trouble figuring out how to pace with the soak and poke heavies - not so after a few years of learning where the vipers sweet spot is. Reckon you'll see the same evolution with the Vx. (You've seen rods shirts right - evolution) ;-)
Consider the Vx is pretty new. That was probably rods second or third regatta on the boat (ever?) And the melges is about as optimized as a od boat can be. You guy have been sailing them almost very weekend for how many years?
#31 Mauri Pro Sailing
Mauri Pro Sailing
  • 428 posts
Posted 08 May 2013 - 04:16 PM
I still think that all 3 boat are pretty cool boats and each owner have a reason to go with one over the other. JD is right that the VX started 5 minutes behind the Vipers (at least the one that I was racing on) but the top Vipers were finishing 8 to 10 minutes ahead of the first VX even though they finished in front of the last couple of Vipers. For what I have seen I think it is not what boat is a 0.1th of a knot faster but is going to come down to (without taking into consideration fleet size): If you want to sail with just one of your buddies, go with the VX, if you want to sail with two of your friends, go with the Viper , and if you like to sail with 3 other guys then go with the Melges 24 (or J70 if you are looking for even larger fleets). Bottom line all 3 boats are great boats and will provide with the enjoyment you are looking for. Either way do not stay on land, Go Sailing!
Juan Mauri
#32 bibs
bibs
  • 125 posts
Posted 08 May 2013 - 07:33 PM
I'm sold...just have to sell my J22 first.  THese can be sailed with the board un-pinned though right ?  Varying depth is the new black I'm afraid.
#33 Streetwise
Streetwise
  • 1,415 posts
Posted 08 May 2013 - 07:52 PM
I'm looking forward to seeing (and sailing) a VX in person at our club this summer. I ended up picking up a used Viper, but the VX is sweet too. I'm jealous of Jeff, with one of each! Our fleet will be 2 x Viper 640, 1 x VX One, 1 x Melges 20, 2 x J/70, and 1 x Open 5.00. This is going to be a fun summer!
Whatever boat you get, put a GoPro on it! :)
#34 us7070
us7070
  • 9,194 posts
Posted 08 May 2013 - 07:59 PM
are there many boats in the new england area?
#35 Streetwise
Streetwise
  • 1,415 posts
Posted 08 May 2013 - 08:50 PM
There are a few in Newport, and soon the one in Vermont, but I think that's it.
#36 SW Dropout
SW Dropout
  • 1,250 posts
Posted 09 May 2013 - 12:56 PM
Is a "few" one (i.e. Jim Myers's dealer boat), or do we actually know of others?  I haven't seen or heard of any others in LIS, RI, or Massachusetts.
#37 ZachF
ZachF
  • 111 posts
Posted 09 May 2013 - 02:12 PM
Chuck Brown and Phip Hallowell have one too.
#38 EYESAILOR
EYESAILOR
  • 494 posts
Posted 09 May 2013 - 02:22 PM
AFAIK, its two.
I was told  "a  few" by the builder. I was interested so I asked for names. I was given three names of Newport owners. It turns out I knew one of them, so called him. He didnt own a VX and had no intention of buying a VX but he had been out on a demo ride. I guess that counts for "one". I assume the other two are real. One was Jim.
Maybe Jim has sold another one or two. He is a really good person and goes above and beyond  to support junior sailing around here so I wish him well.
We are in the North East so if I want to race a sport boat one design it doesnt really matter how many people I want to sail with, the choice is J70 or Viper.
I might wish the options included the Ultimate 20, Melges 20, VX, SB20, Open 5.70 , Shaw, etc  but realistically they dont. I'm looking at the Cedar Point One Design entry registrations and it tells the story.
#39 Streetwise
Streetwise
  • 1,415 posts
Posted 09 May 2013 - 07:32 PM
Yeah, I really admire the VX One and seriously considered one after I sold my half share of my previous Viper. I do love sailing two-up, and I hope the VX dominates that segment. However, the Viper is so strong in the northeast that I couldn't resist coming back, and so I found a great used Viper in excellent condition and I'm very happy. Hopefully the VX One will find success too.
#40 VI-Newport-TP
VI-Newport-TP
  • 4 posts
Posted 10 May 2013 - 02:32 AM
AFAIK, its two.
Hi I am Tim Pitts the VX -one Fleet Captain in Newport - to set the record correct We now have 7 vx-one's  in New England - 6 based at Sail Newport- Since April 13th we have at least 3 boats out every weekend and as many as 5 Ripping around the harbor(I have not seen the boats mentioned above out sailing).   This is just the beginning of where the VX is  going. in new England   We have been invited to sail in the Atlantic Cup on memorial day   where current entries stand at  11 boats.   In the last 5 weeks 7 more boats been sold and the factory is constantly plugging out boats.. -- This summer we will be sailing a Monday sport boat series and the Friday Alhoa series - an all  that local regatta's that will support us (see VX one class web site)
Looking forward to next year we are wrapping up the planning of the  inguinal  VX -one Gold CUP a series that will consist 5 major regattas 2 in Newport ( 1 being the North Americans)  - each event will be promoted to be 20 + boats
The VX class members are committed to growing this great fleet,   to support all our regional regattas a 6 boat trailer program is in the works so that our boats can be moved in an inexpensive team manner we will be headed south for the winter - to have more warm weather fun
If you have questions or  want a test drive email me at fleet5vxone@gmail.com -
#41 VI-Newport-TP
VI-Newport-TP
  • 4 posts
Posted 10 May 2013 - 01:30 PM
Hey I will drive another  VX up to Vermont and join you guys for a weekend so 2 boats can be out there
#42 Streetwise
Streetwise
  • 1,415 posts
Posted 10 May 2013 - 01:51 PM
Right on! I think I need to schedule a multi-race WL sportboat race day, since most of our weekend races are around islands and government marks. Actually, those can be quite nice for some long blasting reaches and runs under spinnaker.
#43 intensitysails
intensitysails
  • 15 posts
Posted 10 May 2013 - 02:35 PM
Newport fleet at this moment is as follows;
Chuck Brown/Phip Hallowell
Tom Chiginski/Michael Brown
Michael, Christine & Anthony Norris
Tim Pitts Using 101
Bill Shaw/Sam Sylvester Using 111 (Also used for demos)
Jim Myers 007
6 boats right now.
#44 ols
ols
  • 26 posts
Posted 10 May 2013 - 05:52 PM
Incoming Vermont VX owner here... and apparently also VX #7 in New England.  Really looking forward to racing in both the upcoming Atlantic Cup in Newport and then the mixed sportboat fleet on Lake Champlain.
#45 Streetwise
Streetwise
  • 1,415 posts
Posted 17 May 2013 - 03:44 AM
Hey Oliver!
We are looking forward to having you at LCYC and in the sportboat fleet this summer! I can't wait to see your VX parked next to our Vipers and J/70s, and more importantly, on the water!
jason
#46 duncan (the other one)
  • 3,728 posts
Posted 17 May 2013 - 08:30 AM
nice shit-eating grins at 3:06 !
#47 port tack
port tack
  • 369 posts
Posted 17 May 2013 - 06:31 PM
Gonna have to call bullshit on this.  I too sailed in Mardi Gras and FT Worth Boat Club Audi thing and there was not a VX anywhere close to us when we finished.  You might have got close to the Viper in the back of the pack sailing 4 up his first time on the boat in those lighter conditions but I wouldn't call that a very good bases for comparison.  Not trying to get into a pissing match Viper vs. VX thing here, I think the VX is a very cool boat.  I think in any breeze the Viper is faster than the VX upwind, light air downwind close (W/L course) Viper will make better VMG to the mark, Moderate breeze VX will get up quicker, Heavy air I think the VX will go faster.  Just my .02 cents.
Just saw Juan's response which is spot on.
#48 Desert Jeff
Desert Jeff
  • 48,774 posts
Posted 27 May 2013 - 09:10 AM
First of all, great video!  I especially like the skill of the trimmer catching the beers rifled at him by the chase boat at the end of the vid.
Back to the sheeting off the boom question....  If you have a standard deck cleat setup, I assume you can still sheet off the boom by grabbing the mainsheet above the block.  I've seen videos where some guys do this on sportboats to pump the main for surfing/planning.  Is this a good technique for DW Aso sailing?  Or just for when you're pumping the main to get on a wave?  And if I understood it correctly, the key is to have the vang on hard to control the leech tension and then you're just pulling the boom in and out from the mainsheet line above the deck cleat.  Is this correct?
#49 Vela Sailing Supply
Vela Sailing Supply
  • 772 posts
Posted 27 May 2013 - 03:29 PM
J,
yes, you are right: having the floor mounted swivel base does not prevent you from trimming from the boom as you would do on a Laser or Finn when sailing off the wind and even on some sportboats as you mentioned. At this point you are only "fanning the main" in and out with he same leech tension due to vang set. Most of the VX's do the same but also upwind, vang-sheeting it is, and is not hard at all as the actual tension is held by the vang.
#50 Desert Jeff
Desert Jeff
  • 48,774 posts
Posted 27 May 2013 - 04:34 PM
J,
Thanks.  I've watched some Laser SB3 training videos (before it became the SB20) and it looks like some of the top boats do it that way.
