Stainless Ferrules
19 replies to this topic
#1 egon
egon
  • 514 posts
Posted 21 May 2013 - 04:45 PM
Does anyone make stainless steel ferrules (low friction rings) like the Antals?  Looking for something with a 12-14mm ID.
--Matt
#2 Overbored
Overbored
  • 486 posts
Posted 21 May 2013 - 05:04 PM
I use a couple of deck fairleads and cut off the plastic part much cheaper then the Antals
http://www.iboats.co...CFWXZQgod1REAuA
#3 egon
egon
  • 514 posts
Posted 21 May 2013 - 06:44 PM
I need more metal then that.  This will be welded to another piece.
--Matt
#4 allen
allen
  • 3,234 posts
Posted 21 May 2013 - 06:58 PM
Have you considered a stainless steel rings?  I used them at one time but found them too heavy.  I bought them at the local ACE hardware.
#5 egon
egon
  • 514 posts
Posted 21 May 2013 - 07:21 PM
Allen,
I need surface area for the weld so there is little or no deflection.  A regular ring won't cut it.
--Matt
#6 allen
allen
  • 3,234 posts
Posted 21 May 2013 - 07:55 PM
Can you post a sketch of what you are trying to come up with?  I know a really good welder if that would help.  He has welded two things for me that nobody else would touch.
#7 egon
egon
  • 514 posts
Posted 05 September 2013 - 02:53 PM
Bump.  Still searching for a stainless steel ferrule with dimensions similar to the R14.10.
--Matt
#8 NonSequitur
NonSequitur
  • 443 posts
Posted 07 September 2013 - 07:38 AM
I cant make the search here work tonight (not that that it ever has) but I seem to remember a thread in which Bammiller machined up some of those for somebody.  Can always try him at Oyster Bay Boat Shop....
#9 Scarecrow
Scarecrow
  • 4,459 posts
Posted 07 September 2013 - 08:11 AM
Buy an ali one, take it to a local machine shop and say can you please turn me up some of these out if stainless.
#10 Alex W
Alex W
  • 1,832 posts
Posted 07 September 2013 - 02:23 PM
Silver brazing the ring instead of welding it would prevent heat distortion.
#11 bammiller
bammiller
  • 1,072 posts
Posted 08 September 2013 - 09:48 AM
What's the application and how many do you need?
Cutting them in aluminum is pretty easy, but the stainless stuff takes so much longer and is much tougher on the tooling. To set up to do a couple in stainless would be an expensive solution.
Bam Miller
#12 egon
egon
  • 514 posts
Posted 09 September 2013 - 05:50 PM
Frac spin halyard fairlead on a 26 footer.  To be welded to the headstay tang/halyard box.  Only need one.
--Matt
Bam Miller
#13 P_Wop
P_Wop
  • 2,867 posts
Posted 10 September 2013 - 02:05 AM
Aha.... Loads of IOR mastmakers back in the day used to make these. Known as spectacles as they were done as a pair. Go to your local boatyard who gave been managing raceboats for some time and ask for the scrap rigging bits bin. Bound to find some. Then cut and weld.
#14 rantifarian
rantifarian
  • 2,864 posts
Posted 10 September 2013 - 03:14 AM
We replaced our binoculars a while back, I think we got them through sydney rigging specialists, http://www.rigging.com.au/ .
Any machine shop is going to charge you a shitload, noone likes to machine stainless.
#15 bammiller
bammiller
  • 1,072 posts
Posted 10 September 2013 - 06:06 PM
Would something like this work?
Attached File  DSCN1394.jpg   121.37KB   8 downloads
Attached File  DSCN1395.jpg   119.81KB   5 downloads
Bam Miller
#16 rushsails
rushsails
  • 16 posts
Posted 29 September 2013 - 12:01 AM
You can go to any sailmaker that uses pressed rings and have them press just the liner. They come in various sizes and are cheap.
#17 Jim Conlin
Jim Conlin
  • 578 posts
Posted 04 October 2013 - 02:22 AM
Sailmaker thimbles are widely available.  Maybe $5.
#18 Mr. Fixit's brother,, Mr. Fixit
  • 1,130 posts
Posted 05 October 2013 - 02:23 PM
This was my first thought.
#19 pidry
pidry
  • 31 posts
Posted 08 October 2013 - 08:20 AM
I spent some time searching for the round stainless thimbles some time ago and now use the deck clips from Viadana ( a cheap brand from ITA). They cost about 3 € a piece.
The ferrules are  a separate part, so you don't have to cut anything ... I sell the remaining deck clip without the ferrule on eBay, so in the end the ferrules cost me close to nothing :-D
BUT ... don't use them for turns > approx. 90° or you will need a new rope quickly!
#20 jc172528
jc172528
  • 2,742 posts
Posted 10 October 2013 - 02:48 AM
http://www.sailforce...cts/view/31/130
